The Perfect Partner for Apple Watch and iPhone Fast Charging
We’re all guilty of having multiple tech devices, from Apple Watches to smartphones and gaming consoles. With so many different charging methods and devices to choose from, finding the best option for your Apple Watch and iPhone can be overwhelming. Forget dodgy third-party chargers that’ll only wreak havoc on your battery life. We’re here to show you what fast charging is, and how you can find a fast charger you can trust that’ll keep you powered and protect your battery life.
Why Fast Charging Matters for Apple Users
If you’re an Apple user, you’ll likely know that Apple devices allow us to have the world at our fingertips. From using it as a means of communication to its GPS abilities, our tech devices can do it all. However, this comes with the need for regular charging; otherwise, a dead battery could leave you in a difficult situation, such as being unable to pay a restaurant bill or calling someone in an emergency.
Keeping our devices fully charged at all times can be inconvenient, especially if you choose a power bank or charger that isn’t cut out for the job. Some third-party charging devices can have slow charging times and even degrade your battery life. People often have concerns regarding the safety of fast charging and whether it can damage the battery or shorten its lifespan. Using reliable fast-charging devices is essential for Apple users—whether you’re on the go or working from home—and is key to protecting your device’s battery.
Man using EcoFlow RAPID Pro X in airport lounge
What Makes the EcoFlow RAPID Pro X Different?
EcoFlow RAPID Charging for iPhones: Power in Your Pocket
The EcoFlow RAPID Pro X Power Bank stands out among a saturated market of portable chargers. With a 27,650 mAh capacity and a 300W output, it supports fast charging for all your essential devices, from smartphones to headphones and even smartwatches. And you don’t have to sacrifice your power, meaning each device that’s charging gets the same fast speeds, charging devices in as little as 20 minutes.
If you travel frequently, a power bank will be your new best friend, and the EcoFlow RAPID Pro X Power Bank is air travel-friendly. Take it on board with you wherever you go and stay connected even in the skies.
Charge Your Apple Watch on the Go – No Wall Plug Required
No wall plug? No problem. With the EcoFlow RAPID Pro X Power Bank, you can charge your Apple Watch on the go, wherever life may take you. With its compact and lightweight design, you can carry it in your pocket, on a plane, or train, and still have the reliable power your essential devices need. Simply plug your Apple Watch Lightning charger into one of the three ports and let it work its magic to charge you to full power in no time.
What Devices Work With the EcoFlow RAPID Pro X?
The good news is that the EcoFlow RAPID Pro X is compatible with laptops, phones, tablets, headphones, smartwatches, game consoles, and any other devices with a USB-C charging port. This includes the MacBook Pro and Air, iPhone, iPad, Samsung Galaxy, and Dell XPS. With the ability to charge up to three devices at once, you can be sure all of your most important devices stay topped up when you need them most.
Perfect for Travel, Work, or Daily Life
There’s a common debate over fast vs. slow charging, and the answer depends solely on your individual needs. Power banks are a game-changer for anyone who leads a busy work life, loves to travel, or simply always has their gadgets on the go. With our electronic devices capable of doing so much for us in our everyday lives, it’s not unusual to sometimes get caught off guard and find ourselves with only 2% battery by lunchtime.
With the EcoFlow RAPID Pro X, you can give yourself the peace of mind that you’ll never find yourself low on battery or stuck in an emergency. Whether you work from home and have to keep multiple devices charged up at once, or you’re a busy mom who finds themselves only having a short time to get your tech charged up, the EcoFlow RAPID Pro X has you covered. With a 300W output, it can take you from 0% to 80% in just 45 minutes. It’s built to last and features X-VELO batteries to minimize energy loss and maintain optimal temperature control.
If you’re looking for even more power and flexibility, the EcoFlow RIVER 3 Plus + 160W Solar Panel is a great option. By pairing with the 160W solar panel, you can ensure you stay powered up no matter the location, whether you’re on a camping trip in the mountains or at a music festival by the sea.
For the ultimate next-level cover, explore EcoFlow’s range of whole-home backup solutions and keep your most important devices connected, always.
How Fast Do Apple Watch Chargers Charge?
This will vary depending on what type of charger you use. Newer models of the Apple Watch chargers feature fast charging, which means you can charge from 0% to 80% in approximately 30-45 minutes. Older models, including the Series 6 and earlier, can take up to an hour or more to charge to 80%.
Is There a Fast Charger for an Apple Watch?
Yes. The newer models of the Apple Watch come with a USB-C Magnetic Fast Charging Cable. You’ll also need a suitable Apple power adapter to use with the charging cable. Other third-party adapters like the EcoFlow RAPID Pro-X Power Bank are a great option for safe and effective charging, allowing you to charge up to three devices at once.
How Do I Turn on Fast Charging on My iPhone?
Fast charging is enabled by default and doesn’t need to be switched on. If you have an iPhone 8 or newer, your device will automatically have it. To make the most of the fast charging feature, you’ll need a power supply unit with at least 18-watt power output and a fast charging cable.
Under 10ms UPS keeps sensitive devices safe, with 600W output and 1200W X-Boost. Expandable, ultra-quiet, and lightweight—with fast 1-hour charging and up to 220W solar input for all-day, anywhere use.
Power Your Apple Essentials With the EcoFlow RAPID Pro X
Busy schedules, unexpected outages, and excessive use can cause us to lose power just when we need it the most. Whether you’re powering your Apple Watch, iPhone, headphones, or all three, the EcoFlow RAPID Pro X Power Bank will keep you up and running. With super-fast charging speeds and no need for a socket, you’ll never have to get stuck without power again.
Smart Devices
