Best Off Grid Solar System: How to Choose the Right Setup for Your Cabin, RV, or Homestead
- What "Best" Means Depends on Where You're Going Off Grid
- Best Off Grid Solar Systems by Use Case
- Best Off Grid Solar Systems for a Full Homestead: 5 Brands to Know
- The Four Core Parts of an Off-Grid Solar Power System
- How to Size the Best Off Grid Solar System for Your Needs
- Choosing the Best Off Grid Solar Batteries: LFP vs Lead-Acid
- Off Grid Solar Costs and the Federal Tax Credit in 2026
- Conclusion
- FAQs
There's no single best off grid solar system. A weekend hunting cabin in Michigan needs very different gear than a full-time homestead in New Mexico. Off grid, a bad match shows up fast. You wake up to a dead battery on the third cloudy day. And there's no power company to fall back on. This guide helps you match a system to how you live. Then you'll size it with a free federal tool. We'll also take an honest look at batteries and costs.
The right system covers your daily power use through your darkest month. Most people fall into one of four groups: a seasonal cabin, an RV or van, a tiny home, or a full homestead. On remote land, running a new utility line may cost more than going solar, so ask your utility for a quote first. Seasonal owners have one more job. A cabin may sit empty for months, so plan ahead for keeping batteries healthy through winter.
Local rules still apply off grid
Off grid, the rules still apply. Some towns limit what you can put up, often for looks or noise. Check county permits and any HOA rules before you buy, and RV owners should read campground rules, too. Once you know your group, you can match it to a system that fits.
Most lists of the best off grid solar systems are just kits sorted by size. That's because "best" really means "best for your setup." The table pairs each group with a system style and an example setup.
Use case | How it's used | What matters most | System style that fits | Example EcoFlow setup |
Weekend or seasonal cabin | Short stays, closed for winter | Easy setup and storage between visits | Portable power station plus panels | EcoFlow DELTA 3 Max (2048Wh) + 400W Solar Panel bundle |
RV or van | Moving often, limited roof or ground space | Weight and portability | Portable power station plus panels | EcoFlow DELTA 3 Max (2048Wh) + 2 × 220W Solar Panel bundle |
Tiny home | Full-time living, small footprint | More storage for evening loads | Larger all-in-one unit plus panels | EcoFlow DELTA 3 Ultra (3072Wh) + 2 × 220W or 400W Solar Panel bundle |
Full homestead | Well pump, freezers, shop tools | High daily use and a large fixed array | Component system (fixed array, battery bank, inverter), often put in by an electrician | Beyond a portable unit; size it with the steps below and a local installer |
EcoFlow DELTA 3 Max + 400W Solar Panel
Do you only visit your cabin on weekends? Then you want power that's ready the day you arrive, with nothing to rewire. An all-in-one unit keeps the charge controller, inverter, and LFP battery in one box, so you only add a panel.
This setup works best for weekend and seasonal cabins with light use. Since everything but the panel sits in one box, there's no wiring to redo each season. You can show up, set out the panel, and have the lights and fridge on that same day.
EcoFlow DELTA 3 Max + 2 × 220W Solar Panel
Life on the road means tight roof space and new campsites. Two smaller panels fit wherever you have room. The same 2,048Wh unit rides along, with 4 ways to charge and a 10ms auto-switch.
EcoFlow DELTA 3 Ultra + 2 × 220W or 400W Solar Panel
In a tiny home, a full-size fridge, cooking, and lights all pull from the battery after dark. That's where extra storage helps, since the EcoFlow DELTA 3 Ultra holds 1,024Wh more than the EcoFlow DELTA 3 Max. EcoFlow lists a transfer switch or inlet box, put in by an electrician, to connect it to your home. Compare tiny house off-grid power options before you buy.
A homestead with a well pump, freezers, and shop tools often outgrows a portable unit. Most owners move to a system built around a large inverter and a 48V battery bank. These five brands show up often in top lists. Specs come from each maker's site.
EG4 Electronics (EG4 18kPV-12LV)
This hybrid inverter works on or off the grid and pairs with 48V lead-acid or lithium batteries. It puts out 12,000W at 240V and has a 10-year warranty. It suits DIY owners planning large builds.
SunGold Power (SGR-8K10E complete off-grid kit)
This one ships as a full kit with an 8,000W inverter, two LiFePO4 batteries (10.24kWh), and panels. SunGold lists US support in Irvine, California. It's a simpler path to a mid-size system.
Sol-Ark (Sol-Ark 15K-2P)
This model is built for heavy loads. Off-grid, it delivers up to 12,000W of continuous output at 120/240V; the 15,000W in its name is the grid-connected AC rating. It can use up to 19,500W of solar power across its MPPT inputs. Sol-Ark says its products are made in Allen, Texas. Most units are put in by a pro.
Victron Energy (MultiPlus-II 48/5000 120V)
This 4,000W inverter and charger works with separate Victron solar charge controllers. Two units can link up for 240V split phase. It's best for piece-by-piece builders. Victron is based in the Netherlands, so check US support with your dealer.
Rich Solar (NOVA 12K)
This 10,000W split-phase hybrid inverter has grid-tie, off-grid, and hybrid modes. Rich Solar lists US support in Norco, California. It's a flexible pick if you may hook up to the grid later.
Every off-grid system has to make, control, store, and change power. Solar panels make DC power when the sun is up, and a charge controller keeps the battery charging safely. MPPT models track the panel's best output point, while PWM models are simpler and pass along less. A battery stores power for nights and cloudy days, and an inverter turns it into 120V AC for your outlets.
Component system vs all-in-one unit.
Should you buy separate parts or one box? It comes down to how much power you need and how much work you want to do. Many owners also add a backup generator for long cloudy spells, which makes it a hybrid system.
Component build | All-in-one power station | |
Setup effort | Higher, often with an electrician | Lower |
Room to grow | Very flexible | Limited to the maker's add-ons |
Portability | Fixed in place | Moves with you |
Who it fits | Full homesteads | Cabins, RVs, and tiny homes |
Sizing starts with how much power you use, not panel watts. First, multiply each device's watts by its daily hours and add them up, using labels or the ENERGY STAR Product Finder. Next, get your worst-month peak sun hours from the free PVWatts Calculator, or check NREL solar resource maps for your region.
Then divide daily watt-hours by those sun hours, and divide again by 1 minus system losses. PVWatts uses 14% losses in its example. For storage, multiply daily watt-hours by the cloudy days you want to ride out. The sample below shows the math.
Step | Example value |
Daily use | 3,000Wh |
Worst-month sun hours | 4.5 |
System losses | 14% |
Array size | 3,000 ÷ 4.5 ÷ 0.86 ≈ 775W |
Two days of storage | About 6,000Wh usable |
A Seattle cabin needs more panels than a Phoenix cabin for the same fridge. It helps to learn how peak sun hours work. Cutting waste first also lets you buy a smaller, cheaper system.
Off grid, the battery is often the first part to fail. Its type sets how much of it you can use, how much care it needs, and how long it lasts. Most buyers weigh LFP against lead-acid.
Factor | LFP | Lead-acid |
Upkeep | No watering | Flooded types need water |
Usable capacity | Most of the rated capacity is usable | Deep discharges shorten life, so less is used in practice |
Cycle life | Often rated for several thousand cycles; check the product's rating and conditions | Sealed: 150 to 200 cycles at 100% depth vs 1,000+ at 30% |
Heat | Keep in rated range | Every 15°F rise halves sealed battery life |
Upfront cost | Higher | Lower, but often oversized |
Those lead-acid numbers come from Sandia's sealed lead-acid battery study. The EcoFlow DELTA 3 Max and EcoFlow DELTA 3 Ultra use LFP cells, so there's no watering. Lead-acid also loses a lot of power below freezing, so compare battery types for off-grid living before you commit.
A portable kit can cost a few hundred dollars. A homestead array can run tens of thousands, based on panels, battery, inverter, wiring, labor, and permits. Many guides still promise a 30% federal tax credit that no longer applies.
What happened to the 30% federal solar credit
The IRS Residential Clean Energy Credit covered 30% of costs for systems put in from 2022 through 2025. The IRS says it "is not available for any property placed in service after December 31, 2025." So a 2026 system won't qualify. Your state or utility may still have programs.
The best off grid solar power system fits how you live and your worst month of sun. Before you shop, add up your daily watt-hours, check PVWatts, and plan for two cloudy days. For cabins, RVs, and tiny homes, the EcoFlow DELTA 3 Max and EcoFlow DELTA 3 Ultra are simple picks. Pair either one with EcoFlow solar panels. A full homestead will likely need a system built from parts and a local installer.
What is the best off grid solar system for a cabin?
It depends on how often you're there and what you run. Weekend cabins often do well with a power station and portable panels. Full-time cabins should follow the sizing steps above.
How much solar do I need to go off grid?
There's no single number for everyone. Divide your daily watt-hours by your worst-month sun hours, then by 1 minus losses. A cabin in Maine will need more panels than one in Arizona.
What are the best off grid solar batteries, lithium or lead-acid?
LFP needs little care and gives you more usable power. Lead-acid costs less up front, but you'll need a bigger bank. For most buyers who want less upkeep, LFP is the easier pick.
Can I still get the federal solar tax credit for an off grid system in 2026?
Not for new systems. The IRS says the credit ended for property placed in service after December 31, 2025. Many older guides still list it, so check the date on any source.
Can a portable power station be an off grid solar power system?
Yes, for smaller loads. Paired with panels, it combines the charge controller, inverter, and battery. For many cabins and RVs, it's the best off-grid solar system to start with, but it won't replace a homestead array.
