4 Best Battery Backup Options for Modems & Routers in 2026
A sudden power outage cuts off your Wi-Fi, remote work, security cameras, and smart home devices, even if it's just a momentary grid failure.
Standard routers and modems draw a modest wattage, so most battery backups can handle them, but making the right choice depends on how long you need coverage, how many devices you're running, and what your living situation is.
Explore EcoFlow’s top four options that cover the range from apartment-size portability to whole-home network resilience.
An EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
EcoFlow’s Top Backup Options for Modems & Routers
  1. Best for Basic Home Office Backup: EcoFlow DELTA 3 Classic
  2. Best for Whole-Home Network Resilience: EcoFlow DELTA Pro Ultra X + Smart Home Panel 3
  3. Best for Off-Grid Connectivity: EcoFlow DELTA Pro Ultra + 2×400W Solar Panels
  4. Best for Extended Backup in Apartments or Small Homes: EcoFlow DELTA 2 Max
When you work from home, Wi-Fi and power access are critical. The EcoFlow DELTA 3 Classic is a good fit for home office setups where one or two essential devices need reliable short to medium-term coverage.
The <10ms automatic switchover is fast enough to keep a router, modem, NAS, or desktop running without interruption during a grid power drop. When the battery is drained, it charges from 0 to 80% in 45 minutes via AC, getting your protection back up quickly.
When you have Storm Guard Mode activated, it’ll also auto-charge if severe weather alerts are detected through the EcoFlow app, keeping tabs on the weather even when you're busy with other tasks.
Its quiet LFP battery is rated for 10+ years, and it's safe and non-distracting when you use it indoors.
If your home has a more complex network, the EcoFlow DELTA Pro Ultra X + Smart Home Panel 3 provides an integrated whole-home backup system that pairs with your electrical panel, keeping all of your circuits live, including your routers, mesh nodes, security systems, and more. You don't have to choose which devices to protect; your entire network stack will stay on automatically.
Once professionally installed, it's a hands-off system that you can monitor through the app, so you can always check if you need to, but without the responsibility of extensive upkeep.
Rural homes, properties without reliable access to the grid, or anyone who wants solar-first connectivity without grid dependence should turn to the EcoFlow DELTA Pro Ultra + 2x400W Solar Panels.
It has a 6 kWh base capacity, but is expandable up to 90 kWh with additional batteries and three inverters. It comes with two 400W rigid solar panels, but has capacity for up to 5.6 kW total solar input per inverter.
When thinking about the cost of whole-house battery backup, this bundle is one of the most competitively priced options for households that rely on solar as their primary recharge method, rather than grid power.
Short on space? No worries. The EcoFlow DELTA 2 Max is compact enough to fit in closets or under a desk and portable enough to relocate between spaces if needed.
With its 2048Wh capacity and 2400W AC output, it's an excellent choice for renters or anyone without the space or budget to build a whole-home battery.
A PPS in this capacity can cover your router, modem, mesh nodes, and other essentials for an extended outage without requiring installation.
An EcoFlow DELTA Pro Ultra + 2×400W Solar Panel bundle
What to Consider When Choosing Modem & Router Backup Solutions
  • Runtime: Most routers use 10–20W of power. A 1024Wh station at that draw can run your router for 40+ hours. But if you add a modem, mesh nodes, and a security camera, that runtime will drop significantly.
  • Power Draw: Check the wattage label on all the devices you plan to back up. Combine the total draw to determine the minimum capacity.
  • Number of Devices: If you're backing up a whole stack, including router, modem, cameras, and more, you'll need more capacity in output ports.
  • Recharge Speed: A unit that takes 8–12 hours to recharge becomes a liability during back-to-back blackouts. Look for a fast AC recharge of under two hours.
  • Solar Compatibility: Solar input can turn a one-time backup into an ongoing power source during extended outages, which is especially useful if you live in rural areas or have severe weather seasons.
  • AC vs. DC Output: Routers run on DC power internally. AC output stations can power them using a wall adapter, which introduces a small efficiency loss. While this isn't a dealbreaker, it should be noted for runtime calculations.
  • Automatic Switchover: Your switchover time is the gap between the moment of grid failure and battery takeover. Anything >20ms risks a momentary dropout. Look for <10ms ideally.
  • Space: If you're renting or have a smaller household, you may not be able to accommodate a full home battery installation. In these cases, a portable power station is a more practical alternative to building a dedicated home battery system.
  • Expandability: Entry-level stations with battery expansion options allow you to add capacity as your needs grow.
Do I Need Battery Backup for My Modem?
If connectivity matters during outages, you'll need battery backup for your modem because it will lose power the same moment your router does. Modems and routers typically draw 15–25 watts combined. Note that, without motor backup, router backup alone will accomplish nothing.
How Long Will Battery Backup Run a Router?
The runtime depends on battery capacity and total device wattage. A modem and router alone, powered by a 1024Wh station, can give you roughly 32 hours of power. But if you add mesh nodes, security cameras, or more, that runtime will drop. Use larger capacity stations or solar recharge options to extend runtime.
Modems and routers draw low wattage, making them one of the more practical uses of a PPS. But choosing the right fit comes down to scale.
Compact solutions like the EcoFlow DELTA 3 Classic are ideal for short outages, while higher-capacity options like the EcoFlow DELTA 2 Max provide extended runtime without installation.
For full-home coverage, the EcoFlow DELTA Pro Ultra X system delivers seamless backup, while solar-enabled setups like the EcoFlow DELTA Pro Ultra + 2×400W Solar Panels support long-duration, off-grid connectivity.
Home Backup
