Alternative Heat Sources Without Electricity: What Works and What's Safe Indoors
A winter power outage can get uncomfortable fast. Two hours after the heat shuts off, the thermostat may be blank, the house may already feel colder, and everyone starts looking for another way to stay warm. That's when bad ideas can seem reasonable. A gas oven, grill, or camp stove may produce heat, but that doesn't make it safe to use inside. The better approach is to know which alternative heat sources without electricity can actually work, which ones still need a little power, and how to keep your family safe while the grid is down.
Alternative Heat Sources Without Electricity at a Glance
There aren't as many options as you might think. Most fall into three groups: heaters that vent combustion outdoors, fuel-burning heaters designed for indoor use, and appliances people should never use as emergency heaters. The table below gives you the quick version.
Heat source
Fuel
Works with no electricity?
Vented outdoors?
Key rule (source)
Wood stove
Seasoned firewood
Yes
Yes, through a chimney
Burn dry, split wood at under 20% moisture and keep the stove door closed except when loading (EPA Burn Wise). Have the chimney or flue inspected each year (CDC).
Wood-burning fireplace
Seasoned firewood
Yes
Open the damper before lighting and leave it open until the ashes are cool; keep a screen or glass enclosure in front (CPSC).
Gas fireplace or gas stove with a standing pilot
Natural gas or propane
Yes for flame, no for the blower
Depends on the model
Heat & Glo says a standing-pilot unit lights in an outage. EPA says to make sure the flue is open whenever a gas fireplace is in use.
Gas fireplace with electronic (IPI) ignition
Only with backup batteries installed
Heat & Glo lists two D-cell batteries for IntelliFire systems and four AA for IntelliFire Plus. Check your own manual.
Portable propane heater rated for indoor use (example: Mr. Heater Portable Buddy MH9BX)
1 lb propane cylinder
Yes
No
Maker lists 4,000 to 9,000 BTU per hour, up to 225 square feet, an oxygen depletion sensor, and tip-over shutoff. CPSC: keep a door open to the rest of the house, open a window at least one inch, and never run it while you sleep.
Portable kerosene heater
Kerosene
Yes
No
DOE says most states have banned unvented kerosene heaters for use in the home, so check your state rule before buying one. Same CPSC ventilation rules apply.
Pellet stove
Wood pellets
No
Yes
DOE: without a backup power supply, losing power means no heat and possibly some smoke in the house.
Gas oven or range, charcoal grill, camp stove
Various
N/A
No
Never. CDC and CPSC both say not to heat a home with a gas range or oven or to burn charcoal indoors. CDC adds portable gas camp stoves.
Wood stoves and fireplaces can still provide heat when the power is out, while a standing-pilot gas fireplace may also work depending on the model. Portable propane and kerosene heaters need more care, since only certain models are rated for indoor use and ventilation still matters. The Department of Energy does not recommend unvented combustion heaters indoors because of the carbon monoxide risk, so always follow the heater's instructions and use a working CO alarm. A traditional fireplace can also pull as much as 300 cubic feet per minute of heated air up the chimney, making a wood stove or insert more efficient. Avoid makeshift options such as candles or improvised burners, and winterize your home before winter to reduce heat loss during an outage.
Heat Sources That Still Need a Little Electricity
Having fuel doesn't always mean a heater can run without power. A pellet stove still needs electricity for its auger, controls, igniter, and fan. A gas furnace also needs power for its blower and controls. That makes these systems good candidates for backup power, since the battery only needs to run the electrical components rather than produce the heat itself.
Heat Sources That Still Need a Little ElectricityHeat Sources That Still Need a Little Electricity
Pellet stoves
Pellet stoves are a good example of a heater that sits somewhere between a traditional fuel heater and an electric appliance. The Department of Energy says pellet stoves use about 100 kWh of electricity per month under normal conditions. Without backup power, a power outage can stop the stove and may even allow some smoke into the house. The heat output can be substantial. DOE lists pellet stove heating capacity from about 8,000 to 90,000 BTU per hour. The electricity isn't making that heat. It is running the parts that feed pellets into the fire and keep the stove operating. That makes a pellet stove an interesting match for battery backup.
Gas furnaces and boilers
A gas furnace can have plenty of fuel available and still leave you with a cold house. The blower, ignition system, and electronic controls all need electricity. During an outage, the furnace stays off unless those components have a suitable backup power source. Don't guess at the power requirement. Check the equipment nameplate or have an electrician measure the actual load. If your furnace is hardwired, don't try to make your own extension-cord connection. A transfer switch or properly installed smart panel should be handled by a licensed electrician.
Gas fireplace blowers and electronic ignition
Some gas fireplaces can light during an outage if they use a standing pilot or have the right battery backup for their electronic ignition system. That doesn't necessarily mean every part of the fireplace will work. A blower that moves warm air into the room still needs electricity. Check the rating label on the blower and the fireplace manual before deciding how much backup power you'll need.
Low-watt electric comfort (electric blankets, heated throws)
Low-watt options such as electric blankets and heated throws warm your body rather than the whole room, which can make them useful during a long outage. Check the wattage on the product tag or controller to see how much power yours needs. These smaller electrical loads are a better match for a battery than a high-wattage space heater.
Keeping Blowers, Pellet Stoves, and Electric Blankets Running on Battery Power
A battery won't replace the heat from a furnace. Running a space heater directly from one can drain the battery quickly. A better approach is to power the electrical parts of a fuel-burning heater, so the fuel provides the heat while the battery runs the controls, auger, or fan.
How long can a battery run a pellet stove?
Estimated runtime: Pellet stove electricity consumption varies by model and operating conditions. Because the DOE's cited estimate of 100 kWh per month could not be verified, use the manufacturer's specifications for your stove's actual electrical consumption to estimate runtime. Assuming 85% usable energy after conversion losses, the EcoFlow DELTA 3 Max provides approximately 1,741Wh from its 2,048Wh capacity, while the standard EcoFlow DELTA Pro Ultra X bundle provides approximately 8,670Wh from its 10,200Wh capacity. At a continuous electrical draw of 145W, these capacities would support approximately 12 hours and 60 hours (2.5 days) of operation, respectively. These are illustrative estimates, not guaranteed runtimes. Startup demand, operating cycles, and other connected loads can affect actual performance. For any device, divide usable battery energy in watt-hours by its power consumption in watts to estimate runtime. For guidance on assessing your stove's electricity needs and battery backup options, read our powering a pellet stove during outages guide.
•Whole-Home Backup (with the right setup): 12kW output and 12kWh capacity in the standard bundle (1 inverter + 2 Smart Extra Batteries), expandable up to 36kW and 180kWh with added inverters and batteries. Whole-home backup requires Smart Home Panel 3 installed by a licensed electrician, and coverage depends on your home's loads. • Fast Switchover: Automatic switchover in about 20ms with Smart Home Panel 3, so selected circuits stay on when the grid drops. • Installation: Plug-and-play design that EcoFlow says can be installed in 7 days. Permitting, your electrical panel, and installer schedules can change that timeline. • Comprehensive Safety: End-to-end system protection built to high safety standards.
For smaller, cord-connected heating loads, a portable option may be all you need. The EcoFlow DELTA 3 Max is designed for loads such as pellet stoves, fireplace blowers, and electric blankets.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The two EcoFlow systems serve different needs. The EcoFlow DELTA 3 Max handles cord-connected loads such as a pellet stove, plug-in blower, or electric blanket, while the EcoFlow DELTA Pro Ultra X with Smart Home Panel 3 can back up selected hardwired circuits, including a furnace blower, when professionally installed. The battery itself adds no fumes to the room, but the heater it powers may still burn wood, gas, propane, or kerosene. That means carbon monoxide and fire safety still come first.
Carbon Monoxide and Fire Rules for Any Fuel-Burning Heater
Almost every fuel-burning heater produces carbon monoxide as it burns. The CDC reports that more than 400 Americans die each year from unintentional CO poisoning unrelated to fires, while more than 100,000 visit emergency departments. The risk can be higher during an outage when homes are closed up and people turn to equipment that isn't meant for indoor heating.
CO alarms come first
The CPSC recommends battery-operated CO alarms, or alarms with battery backup, on every level of your home and outside sleeping areas. The CDC also recommends a smoke detector and battery-operated CO detector near areas heated by a fireplace, wood stove, or kerosene heater. Test your alarms regularly and replace the batteries as recommended.
Symptoms and what to do
CO poisoning can cause headache, dizziness, weakness, upset stomach, vomiting, chest pain, and confusion. If anyone develops these symptoms or a CO alarm sounds, get everyone to fresh air and call 911 or Poison Control at 1-800-222-1222.
The never list
Some heating-related mistakes are simply not worth the risk:
  • Never use a gas range or oven to heat your home. Burning gas can produce dangerous levels of carbon monoxide, especially when the appliance is used for an extended period indoors.
  • Never burn charcoal indoors or bring a charcoal grill inside. Charcoal produces carbon monoxide even when there is no visible smoke, so a garage, basement, or enclosed room is not a safe place for it.
  • Never use a portable gas camp stove indoors. These stoves are designed for outdoor use and can produce carbon monoxide when operated in an enclosed space.
  • Never run a generator inside a home, basement, or garage. Keep it outdoors and at least 20 feet from windows, doors, and vents so exhaust cannot enter the house.
Rules for portable fuel heaters
Use a portable fuel heater only as directed by the manufacturer. CPSC recommends placing it on a level, hard, nonflammable surface with at least three feet of clearance from bedding, curtains, furniture, and other combustibles. Follow the required ventilation guidance, keep the heater away from sleeping areas, and turn it off before leaving the room or going to sleep.
Rules for wood stoves and fireplaces
Burn dry, split, seasoned wood, and avoid trash, cardboard, painted, or pressure-treated wood. EPA recommends wood seasoned for at least six months with moisture below 20%. Keep ashes in a covered metal container outdoors and have the chimney and flue inspected before heating season. The carbon monoxide dangers in winter emergencies guide covers other risks to check before using a fuel-burning heater. Once the heater is running safely and your CO alarms are working, the next step is keeping that heat from escaping the room.
How to hold on to the heat you have
How to hold on to the heat you haveHow to hold on to the heat you have
A small heater can keep one room warm when it could never heat the whole house. Focusing the heat in one space and slowing down heat loss can help you stay comfortable longer during an outage.
  • Close off unused rooms. Shut the doors to rooms nobody is using, so you're not wasting heat.
  • Block drafts. Place towels or rags along gaps under doors to reduce cold air coming in.
  • Close blinds and curtains. Keep them closed to help hold heat inside. On clear, sunny days, open curtains on sun-facing windows and close them again at dusk.
  • Dress for the cold. Wear loose layers of warm clothing, along with a hat, mittens, and blankets. Sleeping bags can also help if everyone stays in the same room overnight.
  • Choose one warm room. Use the room with the heat source or the smallest practical room as your main living space during the outage.
Room size matters, too. DOE notes that a 42,000 BTU stove can heat about 1,300 square feet, while the Mr. Heater Portable Buddy is rated for up to 9,000 BTU per hour and up to 225 square feet. A portable heater is best treated as a one-room solution, not a way to heat the entire house. These low-cost ways to stay warm can also help reduce heat loss during a normal winter. Once your household is safe, check on neighbors who may need extra help, especially older adults. Sealing one room and layering up can buy you time, but a house that keeps getting colder or signs of dangerous cold mean it's time to change plans.
When to Stop Heating at Home and Leave
Staying home isn't always the safest choice during a winter outage. If your heat source can't keep up, or someone in the household is especially vulnerable to the cold, moving to a warmer place may be safer than trying another heater. The CDC recommends seeking shelter with friends or at a community shelter when conditions become too cold.
Know when the cold is becoming dangerous
A body temperature below 95°F is a medical emergency and needs immediate attention. If someone is showing signs of hypothermia, move them to a warm place and seek medical help right away. If a CO alarm sounds or anyone develops symptoms of carbon monoxide poisoning, leave the house and call 911 or Poison Control.
Prepare before the next outage
A few simple preparations can make the decision easier when the next storm hits:
  • Keep fuel ready. Store dry firewood in a dry, covered area, and keep spare propane stored according to the heater manufacturer's instructions.
  • Check your equipment. Keep fresh batteries on hand for gas fireplace ignition systems and make sure the fireplace is ready before the first cold snap.
  • Test your alarms. Check smoke and CO alarms before winter and replace batteries if they're weak or expired.
  • Know where to go. Check your county's emergency management resources ahead of time so you know the nearest warming center or shelter if your home becomes too cold.
Having fuel, batteries, working alarms, and somewhere warm to go is the foundation of preparing for a winter power outage before the first ice storm.
The best alternative heat sources without electricity are usually the ones that can make heat without relying on the grid, such as a properly installed wood stove or a suitable standing-pilot gas fireplace. But plenty of heating equipment still needs electricity for blowers, controls, igniters, or augers. That's where battery backup can help. Before winter, test your CO alarms, inspect your chimney, and check the wattage of the equipment you may need to power. For cord-connected heat helpers, the EcoFlow DELTA 3 Max is a practical option. For selected hardwired circuits, the EcoFlow DELTA Pro Ultra X with Smart Home Panel 3 offers a larger whole-home backup setup when professionally installed.
What is the best way to heat a house without electricity?
A properly installed vented wood stove or a standing-pilot gas fireplace can provide heat without grid power. Neither should be treated as a way to heat every part of a large home. During an outage, focus on keeping a safe, smaller area warm.
Are indoor propane heaters safe when the power goes out?
Only use a propane heater that the manufacturer specifically rates for indoor use. Follow the heater's ventilation requirements, keep at least three feet of clearance from combustible materials, use a working CO alarm, and never leave the heater running while you sleep. DOE does not recommend unvented combustion heaters inside homes.
Can I use my gas oven or stove to heat the house?
No. The CDC, CPSC, and EPA advise against using a gas oven or range for heat because it can produce dangerous levels of carbon monoxide. It can also increase the risk of fire or burns, especially when left running for long periods. Use a heating appliance designed for indoor use instead.
Will a pellet stove work during a power outage?
Not without backup electricity. A pellet stove uses power for components such as the auger, controls, igniter, and fan. A battery backup can keep those components operating, provided the battery has enough capacity and output for the stove.
Can a battery power station run a heater when the power goes out?
Yes, but how long it runs depends on the heater's wattage and the power station's usable capacity. High-wattage space heaters can drain a portable battery quickly, so a pellet stove, fireplace blower, or electric blanket may be a more practical use of backup power. To estimate runtime, divide the battery's usable watt-hours by the device's wattage.
Power Outages
