How Many Watts Does a Refrigerator Use? Running, Starting, and Amps
Your refrigerator runs every hour of every day. That makes it one of the few appliances that never really takes a break. Knowing its wattage helps you understand your power bill. It also matters when you shop for a generator or battery backup. So how many watts does a refrigerator use? The honest answer is that it depends on the size, age, and type. This guide breaks down typical fridge wattage, running and starting watts, and amp draw. It also shows how to keep a fridge running during an outage.
Most full-size home refrigerators use a few hundred watts while the compressor runs. Smaller models use much less. But the compressor doesn't run all the time, so daily energy use is lower than you might expect.
Here are typical ranges by fridge type. These are general estimates, so always check your own model.
Fridge Type
Typical Running Watts
Rough Daily Use
Mini fridge
50 to 100W
0.5 to 1 kWh
Top-freezer fridge
100 to 400W
1 to 1.5 kWh
Bottom-freezer fridge
150 to 500W
1 to 2 kWh
Side-by-side or French door
200 to 800W
1.5 to 2.5 kWh
Older fridge (15+ years)
Often at the high end
Often 2 kWh or more
A small refrigerator in a dorm or office sits at the low end of this chart. If that's what you're running, it helps to know how much electricity a mini fridge uses over a full month.
Running Watts vs. Starting Watts
A fridge has two power numbers that matter. Running watts are what it uses once the compressor is going. Starting watts are the short burst it needs to get the compressor moving.
That startup surge often runs two to three times higher than running watts. It only lasts a second or two. But your generator or battery must handle it, or the fridge won't start. This is the number people most often miss when they size backup power.
Your fridge also cycles on and off through the day. The compressor might run for about a third of the time, depending on the model. Opening the door often, a warm kitchen, or a full load of warm groceries will make it run longer.
Features change the math too. Ice makers and through-the-door water dispensers add to your energy use. Most frost-free fridges also run a small defrost heater a few times a day. Those short bursts are part of why larger, feature-packed models sit at the high end of the chart.
How to Find Your Fridge's Wattage and Amps
The most accurate numbers come from your own fridge. You don't need special tools to find a good estimate. A quick look at the label gets you most of the way there.
Reading the Label
Look for a sticker inside the fridge, on the back, or near the bottom grille. It usually lists volts and amps. Multiply the two, and you get the rated wattage. The Department of Energy's Energy Saver guide explains this method in detail.
The yellow EnergyGuide label is another great tool. It shows estimated yearly energy use in kilowatt-hours. Divide that number by 365 to get your average daily use. For example, a fridge rated at 500 kWh a year uses about 1.4 kWh a day.
For the most exact answer, use a plug-in energy meter. Plug the meter into the wall and the fridge into the meter. Leave it for a full day or two, and it will show your real usage. These meters are cheap and easy to find at hardware stores. They're also handy for checking other appliances around your home.
How Many Amps Does a Refrigerator Use?
Most home refrigerators are rated somewhere around 3 to 7 amps on a 120-volt circuit. The label number is a maximum, though. Actual draw while running is often lower. During startup, the amp draw spikes for a moment.
Here's a quick way to convert between amps and watts:
  • Watts = Volts × Amps. A fridge rated at 5 amps on 120 volts is about 600 watts.
  • Amps = Watts ÷ Volts. A 180-watt fridge on 120 volts draws about 1.5 amps.
  • kWh = Watts × Hours ÷ 1,000. A 150-watt average over 24 hours is 3.6 kWh.
Many kitchens put the fridge on its own circuit. That helps prevent tripped breakers when the compressor starts. Knowing how many amps your fridge draws at startup also helps you pick the right extension cord or backup unit.
Keeping a Refrigerator Running During an Outage
Keeping a Refrigerator Running During an OutageKeeping a Refrigerator Running During an Outage
A power outage puts your food at risk fast. Knowing your fridge wattage makes backup planning much easier. The right setup can keep food cold for a day or more.
According to FoodSafety.gov's power outage chart, a closed fridge keeps food safe for about 4 hours. After that, perishable food can become unsafe. That window is shorter than most people think. A full freezer does better and holds its temperature for about 48 hours if you keep it closed. It's worth knowing how long food stays good without power before the next storm. Keep a fridge thermometer inside so you can check the temperature without guessing.
Sizing Battery Backup for a Fridge
A battery backup needs two things to run a fridge. It needs enough output to handle the startup surge. It also needs enough capacity to cover the hours you want. A portable power station is a simple way to do both, with no fuel or fumes. It plugs right into your fridge and runs quietly indoors. Start by checking your fridge's running watts and your likely outage length. Then pick a unit with a little extra capacity for peace of mind.
•1kWh–5kWh Scalable Capacity: Expandable capacity using DELTA 3, DELTA 2, DELTA 2 Max, or DELTA Pro 3 Extra Batteries (via an Alternator Charger XT150 Output Cable). • 1,800W Output with 3,600W Surge: Delivers a continuous 1,800W AC output (3,600W surge) and reaches up to 2,200W with X-Boost™ technology. • 5 Fast Recharging Methods: Supports versatile charging via AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), and Multicharging. • 5-Year Warranty Protection: Backed by a comprehensive 5-year warranty for long-term reliability and peace of mind.
The EcoFlow DELTA 3 Plus is a good fit for one standard fridge during a short outage. You can also add extra batteries later for longer coverage. But some homes want to run more than a fridge. A chest freezer, a microwave, or a coffee maker can add up quickly. For bigger loads and longer outages, a 2 kWh unit gives you more room.
EcoFlow DELTA 3 Max (2,048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Here's a rough idea of runtime for an average full-size fridge. Real results depend on your fridge, the room temperature, and how often you open the door. The estimates allow for some energy loss during conversion from battery to AC power.
Battery Capacity
Estimated Fridge Runtime
About 1 kWh
Roughly 8 to 14 hours
About 2 kWh
Roughly 16 to 28 hours
About 3 kWh
Roughly 24 to 42 hours
How to Lower Your Fridge's Energy Use
A few easy habits can cut your fridge's power use. They also make your backup battery last longer. Most of them take just a few minutes.
Try these simple tips:
  • Set the fridge between 35°F and 38°F and the freezer to 0°F.
  • Keep the door closed as much as possible.
  • Clean the condenser coils once or twice a year.
  • Leave a few inches of space behind the fridge for airflow.
  • Check the door seals for gaps or cracks.
  • Let hot leftovers cool a bit before you put them away.
Placement matters too. Keep your fridge away from the oven, the dishwasher, and sunny windows. Extra heat around the fridge makes the compressor work harder.
If you camp or travel, a 12V fridge is another efficient option. Many portable refrigerator freezers sip power compared with a full-size model.
When to Replace an Old Fridge
Older refrigerators often use far more energy than new ones. If yours is 15 years old or more, it may be time to compare. ENERGY STAR certified refrigerators are more efficient than the federal minimum standard. Over the life of the fridge, those savings add up.
A second fridge in the garage is another common energy drain. Garages get hot in summer, so the compressor works harder. If you don't really need that extra fridge, unplugging it can save money every month.
Most full-size refrigerators use a few hundred watts while running and about 1 to 2 kWh a day. Starting watts can be two to three times higher, so plan for that surge. Check the label or use an energy meter for exact numbers. During outages, a closed fridge stays safe for about 4 hours. For longer backup, the EcoFlow DELTA 3 Plus and EcoFlow DELTA 3 Max keep your fridge running.
Q1: How many watts does a fridge use per day?
Most full-size fridges use about 1 to 2 kWh per day. Older or larger models can use more.
Q2: How many watts does a small refrigerator use?
A mini fridge usually uses 50 to 100 watts while running. That works out to roughly 0.5 to 1 kWh per day.
Q3: How many amps does a refrigerator use?
Most home fridges are rated at about 3 to 7 amps on a 120-volt circuit. Actual running draw is often lower than the label.
Q4: Can a portable power station run a refrigerator?
Yes. A unit like the EcoFlow DELTA 3 Plus can handle the startup surge and run a standard fridge for many hours.
Q5: What size generator do I need for a refrigerator?
Plan for the starting watts, not just the running watts. Many standard fridges start fine on a 2,000-watt generator, but check your model.
Q6: Is it cheaper to run a new fridge than an old one?
Usually, yes. Newer models use better insulation and compressors. An ENERGY STAR certified fridge can cut your yearly energy use compared with a 15-year-old model.
Q7: Does an empty fridge use more electricity?
It can. A full fridge holds cold better, so the compressor runs less after you open the door.
Smart Devices
