How Many Watts Does a Gas Furnace Use? Separating Gas Heat From Electric Parts
How many watts does a gas furnace use? Probably fewer than you'd expect, because the gas makes the heat. Electricity only runs the support parts. These are the blower that pushes warm air through your ducts, the inducer fan, the igniter, and the control board. The blower usually draws the most. Its draw varies a lot between an older single-speed motor and a newer variable-speed one. This guide shows you how to read your furnace's rating plate and estimate daily use. It also explains why the blower motor matters and how to plan backup power with an electrician.
The answer depends mostly on the blower motor and the size of the furnace. The burner supplies the heat, while electricity runs the parts that move air and keep the burner safe. So gas furnace wattage is a handful of small electric loads added together. One of them is much bigger than the rest.
What Each Part Does
Each electrical part has its own job and timing. The startup and shutdown sequence varies by furnace model.
Part
Job
Draw pattern
Blower motor
Moves air through the ducts
Often the largest running load. Usually starts after ignition and can run after the burner shuts off.
Inducer fan
Vents combustion gases
Establishes draft before ignition and can run through a post-purge
Hot surface igniter
Lights the burner
Short burst at startup
Control board and gas valve
Safety checks and the start-up sequence
The board can draw standby power. The gas valve is energized when called for by the controls.
The blower often accounts for much of a furnace's running electrical load. It starts after ignition in many units and may continue to run after the burner shuts off. See the Carrier 59SC5B installation manual's Sequence of Operation for a model-specific example. Other controls may still use power in standby.
How to Read the Rating Plate
The rating plate identifies the model and lists its electrical ratings. Rated volts multiplied by rated amps gives an apparent-power figure in volt-amperes (VA). Have an electrician use the specific furnace's rating plate and installation manual, including its minimum circuit ampacity and maximum breaker or fuse rating where listed, and follow local requirements. The Carrier 59SC5B electrical data table lists those values separately.
Check the model's manual or spec sheet for a listed input power. For measured running watts, have an electrician use a power clamp meter or power analyzer that measures voltage, current, and true power. A basic current clamp measures amps and does not directly give real watts.
Electric models are a different story. Compare all this with electric furnace wattage and cost. There, electricity makes the heat itself, and the numbers run far higher.
Those small numbers matter most when the power goes out. That's when a modest electric load decides whether your house has heat at all.
Backing Up a Gas Furnace in an Outage
Picture an ice storm that knocks out power at 2 a.m. in January. Your gas line still works, but the furnace sits silent. A gas furnace won't run without power, even with gas flowing. The igniter, inducer, controls, and blower all need electricity. You can read why running a gas furnace without electricity doesn't work if you want the details on each part.
Backing up the furnace means powering the furnace circuit, not just the thermostat. A thermostat with its own batteries keeps its screen lit, but it can't start the blower. A licensed electrician sizes that circuit and accounts for the blower's startup draw. They also connect it to the backup source with the right transfer equipment.
Generator or Home Battery?
An electrician can evaluate a fuel generator with suitable transfer equipment or a compatible home battery. Check the combined running load for each setup and the total startup demand when the blower starts with other loads already running.
Whichever route you pick, the electrician's checks come first. They'll usually look at a few things before connecting anything:
  • The furnace circuit's voltage and breaker size
  • The blower's startup draw and its running draw
  • Other loads you want on backup, such as the refrigerator or lights
  • The transfer equipment that keeps backup power separate from the utility lines
  • Local permit and inspection rules
A Home Battery Option for the Furnace Circuit
For a home battery, the real question is power draw. More solar input doesn't answer it. One battery with enough output and enough storage covers a gas furnace. EcoFlow TITAN 5000 is a 5kWh home battery with 7,200W of 120V/240V split-phase output. A qualified, licensed electrician installs its Smart Home Panel 10. With that panel, it can back up a gas furnace circuit, which covers the blower, inducer, igniter, and controls.
A technician checks the furnace nameplate before sizing backup power.A technician checks the furnace nameplate before sizing backup power.
Next to 7,200W, a gas furnace's electric load is small, so storage sets the runtime. The base 5kWh can cover many hours of furnace cycling. You can add battery packs later if your outages tend to run long.
EcoFlow TITAN 5000
How Long Backup Could Last
So how long could it keep your furnace going? The table below shows two example loads, and every figure in it is an estimate. The 500W load is an assumed example, not a number taken from a rating plate. The 40% line assumes the blower runs about four minutes out of every ten on a cold day. Runtime equals usable capacity (5,017.6Wh × 0.85, or about 4,265Wh) divided by the load.
Load (example)
Watts used
EcoFlow TITAN 5000 (about 4,265Wh usable, est.)
Furnace running nonstop (assumed 500W)
About 500W
About 8.5 hours
Furnace averaged over its cycles (40% run time)
About 200W
About 21 hours
Swap in your furnace's measured watts for a closer estimate. Backup lasts for a limited time that depends on the battery's charge and the actual load. Any lights, refrigerator, or router on the same backup panel draw from the same stored energy.
Next comes the part that moves this math the most. That's the blower motor.
Why the Blower Motor Matters
The blower motor is a useful place to start when comparing two furnace models. Its speed and design can shape much of the running draw. The control board can still use electricity between heating calls.
PSC vs ECM Motors
Older furnaces often have single-speed PSC (permanent split capacitor) motors. These run at a fixed speed set by their wiring. Many newer furnaces use variable-speed ECM motors that can slow down when your home doesn't need full airflow. That's the core of the ECM vs PSC blower question. The motor type changes both the running watts and the startup draw.
PSC vs ECM Furnace MotorsPSC vs ECM Furnace Motors
The federal government regulates this part of the furnace too. In 2014, the U.S. Department of Energy set energy conservation standards for residential furnace fans. Each fan gets a fan energy rating (FER) in watts per 1,000 cubic feet per minute of airflow. Under DOE's furnace fan final rule, covered furnace fans have had to meet those limits since July 3, 2019.
How do you know which motor you have? Check the furnace manual or the label on the blower motor itself, or ask your HVAC technician at the next tune-up. Whatever the motor type, it pulls extra power for a moment as it starts. Backup sizing depends on starting versus running watts for the blower, not on the running number alone.
Once you know the motor and its running watts, you can turn those watts into daily energy. That's the figure that shows up on your electric bill.
How to Estimate Your Furnace's Daily Electricity Use
For a blower that runs at a steady power level, multiply its measured running watts by its actual operating hours to estimate blower energy. For the whole furnace, include the other components and standby draw or measure the total energy over representative cycles.
The U.S. Energy Information Administration explains the two units. Watts measure power at a single moment, and watt-hours measure energy used over time. Divide watt-hours by 1,000 and you get kilowatt-hours (kWh), the unit on your bill. EIA's guide to measuring electricity uses a 40W bulb as its example: five hours of use comes to 200Wh, or 0.2kWh.
A Worked Example
Here is an example using assumed blower power and run time. Use your own measured values for a household estimate.
Step
Math
Result
Daily energy (example)
500W while running × 10 hours of run time
5,000Wh, or 5kWh
Daily cost (example)
5kWh × 18.16 cents per kWh
About $0.91
30-day cost (example)
$0.91 × 30 days
About $27
The 18.16-cent rate is EIA's preliminary U.S. average residential price for August 2026, from EIA's Electric Power Monthly. Your utility's rate may be higher or lower, so use the price per kWh on your own bill.
Ways to Get Better Numbers
Have an electrician measure true watts and energy over representative cycles with a power clamp or power analyzer. A thermostat's heat-call time can differ from actual blower run time. In Auto, the blower can start after ignition and run on after the burner turns off. Exact timing depends on the model. A continuous fan setting can raise the daily total.
Fuel cost is the other half of the picture, too. Comparing heat pump vs furnace costs means counting both the energy that makes the heat and the electricity that moves the air.
A gas furnace burns gas for heat and uses electricity for the blower, inducer, igniter, and controls. The watts depend on which parts are operating and at what speed. Run time affects daily energy consumption in Wh or kWh. For outage use, have a licensed electrician check continuous and startup loads and determine whether an EcoFlow TITAN 5000 setup can support the furnace circuit.
Running watts depend on the blower, its speed, and which other parts are drawing power. For actual watts, look for a model-specific input power figure or have an electrician measure true power. For circuit sizing, use the furnace's electrical ratings and installation instructions and applicable local requirements.
What uses the most electricity in a gas furnace?
The blower often draws the most during normal operation. It can start after ignition and continue after the burner shuts off. The igniter works briefly at startup, and controls can draw power in standby. The Carrier 59SC5B sequence is one example.
Does a gas furnace work without electricity?
No, it doesn't, even with gas flowing to it. Without power, the igniter can't light the burner, and the inducer can't vent combustion gases. The controls can't run their safety sequence, and the blower can't move warm air. Keeping it running in an outage takes backup power on the furnace circuit.
How much does it cost to run a gas furnace blower?
Multiply the blower's running watts by its hours of use, convert to kWh, and multiply by your electric rate. In the labeled example above, 5kWh a day at the August 2026 U.S. average of 18.16 cents per kWh comes to about $0.91 a day. Your own cost depends on your furnace, your weather, and your utility's rate.
What size backup do I need for a gas furnace?
Check total running watts first. For the startup check, add the blower’s total starting demand to the other loads running at that moment. Add an incremental startup figure to the running total only if the manufacturer specifies it as additional watts. Have a licensed electrician verify the furnace circuit and your backup equipment.
Home Backup
