How Many Amps Does a Dishwasher Use? Peak Draw, Cycle Energy, and Circuit Size
Maybe a breaker tripped halfway through a wash, or you're swapping out an old unit and want to know if the wiring can handle the new one. So how many amps does a dishwasher use? The number isn't steady. It stays low while the pump sprays water, then climbs when the heater warms the water or dries the dishes. That's why makers ask for a 120-volt circuit rated 15 or 20 amps. This guide covers the rating label, peak current versus full-cycle energy, the circuit rules makers list, and what to plan for with home backup.
You don't have to guess at this one, because the answer is printed on the machine. Open the door and look along the edge of the door or the tub for the rating label. It lists amps, watts, or both.
If the label only shows watts, divide by 120 volts to get amps. The highest draw comes while the heater is on, so that's the number that matters for the circuit.
Why the Draw Changes During a Cycle
Has a breaker ever tripped late in a wash and not at the start? That timing is a clue. A dishwasher runs in stages. First it fills, and the pump pushes water through the spray arms, which takes little power.
Then the heating element comes on to warm the water, and it may come on again if you use heated dry. The element is the big load, so the amps climb each time it turns on. If trips happen at that point, look at what else is running on the same circuit.
What the Maker's Instructions Say
The installation guide tells you what the circuit has to supply. One set of Whirlpool dishwasher installation instructions puts it this way: "A 15-20 amp, grounded, 120 volt AC only, electrical supply is required."
The same guide asks for a fuse or breaker rated at least 15 amps, or 20 amps if a disposer is connected with the dishwasher. Those are circuit sizes, though. They set the ceiling, and the machine itself draws less than that for most of the cycle.
Dishwasher Amps by Cycle Phase
So how many amps does a dishwasher pull at each stage? The table below uses example watts to show how the draw moves through a cycle. These are sample figures, so swap in the numbers from your own label.
Phase (example figures) | Watts | Amps at 120V |
Wash and pump phase | 200W | About 1.7A |
Heating phase | 1,200W | 10A |
Heating + disposer on the same circuit | 1,200W + 500W | About 14A |
If a friend asks how many amps is a dishwasher, the fair answer is "it depends on the minute." Dishwasher amps sit near the bottom of the range for most of the wash and jump once the heating element kicks in.
One caution on the math helps here. Dividing watts by volts gives a close estimate for a heater, but motors and pumps behave a little differently, so a meter may not match the table exactly. It also pays to compare the watts a dishwasher uses across phases before you settle on a planning number.
Peak amps decide the circuit. If a home battery will cover the kitchen, though, the peak and the energy for a full cycle both matter.
Including a Dishwasher on Home Backup
Picture day two of an outage, with the sink full and everyone tired of washing by hand. Can the dishwasher go on a backup system? It can, but it takes some planning first.
alt: Electrician reviewing a household breaker panel while planning a dishwasher circuit for selected-circuit backup.
An electrician looks at the dishwasher's peak draw next to the other circuits that could run at the same time. The battery also needs enough stored energy for a full cycle. And water and drainage have to be working, or the machine can't do its job.
Three Numbers to Separate
A dishwasher has three different numbers. Each one answers a different question.
Rated current: The amps on the label, which tell you what circuit the maker expects.
Heating peak: The highest draw, which has to fit with everything else running at that moment.
Full-cycle energy: The kilowatt-hours one load uses, which comes out of the battery's stored energy.
The usual wiring rules still apply on backup power. The dishwasher keeps its dedicated circuit, its breaker, and wiring that follows the manual and local code.
Water and Drainage Come First
What good is a powered dishwasher with no water? A backup supply alone doesn't mean the dishwasher can run. If the water is off or the drain is backed up, power won't help.
Homes on a private well have one more thing to check. The well pump needs power before the dishwasher can fill, so it has to be part of the same plan. On city water, make sure the supply is still running before you start a load.
Treating the Dishwasher as an Optional Circuit
In most backup plans, the fridge, the lights, and the internet come first. The dishwasher is an optional circuit, something you add once the basics are covered.
If you're planning backup for selected circuits, EcoFlow TITAN 5000 is one system built for that kind of setup. It connects through a Smart Home Panel 10, which must be installed by a qualified, licensed electrician.
A dishwasher's heating peak is well under EcoFlow TITAN 5000's 7,200W output, so it can fit alongside other loads. What matters is that the electrician plans which circuits run together.
With the Smart Home Panel 10, the system works with the grid in a No Export setup, per EcoFlow. Backup lasts for a limited period that depends on battery capacity and your actual load.
A Sample Energy Budget
How much stored energy would a dishwasher load take? The table below is an estimate built on example figures, and your numbers will differ.
Example load (estimates) | Energy |
One dishwasher cycle (assumed machine-only energy) | About 1.3 kWh |
Fridge, router, and lights for 12 hours (assumed 150W average) | About 1.8 kWh |
Total | About 3.1 kWh |
EcoFlow TITAN 5000 usable energy (about 4,265Wh, est.) | About 1.2 kWh left in this example; other loads are not included |
These are illustrative assumptions, not measured equipment figures: 1.3 kWh for the dishwasher alone and a 150W average for the other loads. The usable-energy estimate assumes a full 5,017.6Wh battery and an 85% allowance, giving about 4,265Wh; actual losses and standby use vary. Size a real system using measured or manufacturer-specified cycle energy. Budget the water heater, well pump, and any other required equipment separately.
The method takes two steps. First, add up each circuit's kilowatt-hours for the hours you expect to be without power. Then check the peak watts of everything that could run together against 7,200W. A bigger plan changes the math, so it helps to weigh whole-home versus essential circuits before you pick which breakers to back up.
Backup planning starts with good wiring, though. That brings up a question a lot of homeowners ask during a kitchen remodel.
Should a Dishwasher Be on Its Own Circuit?
Say you're redoing the kitchen and the electrician asks where the dishwasher circuit should go. Should a dishwasher be on its own circuit? Many makers say yes, and your model's instructions have the final word.
What GE and Whirlpool Require
GE's built-in dishwasher installation guide calls for a 120V supply on an individual, properly grounded branch circuit. That circuit is protected by a 15 or 20 amp breaker or a time-delay fuse. The Whirlpool guide mentioned earlier asks for a separate circuit as well.
GE's guide also says the wiring must be two-wire with ground. If your supply doesn't meet those requirements, it tells you to call a licensed electrician before going further.
Why does it matter so much? A circuit shared with a toaster or microwave can trip when the heating phase starts. A few points come up in both makers' guides and are worth checking in yours:
Circuit size: 15 or 20 amps at 120V, and no larger.
Disposer sharing: The Whirlpool guide lists 20 amps when a disposer is connected.
No extension cords: Both guides say not to use one.
Grounding: The circuit has to be properly grounded.
Local Code, GFCI, and AFCI
Local code applies on top of the manual. GFCI or AFCI protection rules vary by area, so ask a licensed electrician what your town requires. Breaker sizes aren't interchangeable either, and it's worth knowing how 15 amp versus 20 amp circuits differ before you change anything.
Older homes sometimes have the dishwasher on a shared kitchen circuit. If yours does, bring it up during any remodel or panel work so the electrician can plan a new run.
Wiring covers the peak. Your power bill depends on a different number, which is energy per cycle.
How Much Energy Does a Dishwasher Cycle Use?
If you're watching your bill, peak amps won't tell you much. Energy per cycle is the number that adds up, because the heater only runs for part of each load.
Whether you search "how many amps does dishwasher draw" or "how many amps for dishwasher," amps only describe one moment. Kilowatt-hours describe the whole wash.
Finding kWh Per Load on the Label
The yellow EnergyGuide label gives estimated yearly electricity use under standardized test assumptions. Dividing that figure by the stated annual number of loads gives an approximate allocation per load, not a measurement of one wash on the dishwasher circuit. The federal dishwasher calculation includes water-heating energy and low-power-mode energy as well as machine energy. For a backup budget, use the dishwasher's measured or manufacturer-specified cycle energy and account for its hot-water supply separately.
For example, a hypothetical 270 kWh yearly label based on four loads a week averages about 1.3 kWh per load. That allocation retains the label's test assumptions; it is not a machine-only measurement and should not be copied into a dishwasher-circuit backup budget. Drying settings affect consumption, so check which settings the label or measurement covers. The ENERGY STAR dishwasher guide suggests looking for an option to turn heated dry off.
What One Load Costs
The U.S. residential average was 18.16 cents per kWh in August 2026, a preliminary figure, according to EIA's monthly price table. At that rate, 1.3 kWh of electricity costs about 24 cents. This is an arithmetic example, not a measured cost for every dishwasher load. Your cycle settings, hot-water source, and electricity rate affect the actual cost.
Simple Ways to Use Less
Full loads help the most. ENERGY STAR notes that dishwashers use about the same energy and water no matter how many dishes are inside. The same guide says a standard certified dishwasher costs about $50 a year to run.
Turning off heated dry and letting the dishes air dry trims each load a little more. And if you've wondered about the sink, it's worth seeing whether a dishwasher or hand washing costs less in your home.
How many amps does a dishwasher use? It depends on the phase. Draw is low during washing and peaks during heating, which is why makers like Whirlpool and GE call for a 120V, 15 or 20 amp circuit, often a separate one. Read your rating label, check local code, and count full-cycle energy if backup is part of the plan. A licensed electrician can tell you whether the dishwasher belongs on an EcoFlow TITAN 5000 selected-circuit plan.
How many amps does a dishwasher draw?
It changes during the cycle. Dishwasher amp draw is low while the pump runs and highest while the heater is on, so makers size the circuit at 15 or 20 amps on 120V. Your rating label has the figure for your model.
Does a dishwasher need a 20 amp circuit?
Not always. One Whirlpool guide allows a 15 amp circuit for the dishwasher alone and lists 20 amps when a disposer is connected. Check your own manual, since models differ.
In many cases, yes. GE calls for an individual branch circuit and Whirlpool asks for a separate one. Your model's instructions and local code decide what's required in your kitchen.
Can a dishwasher and disposer share a circuit?
Some makers allow it on a 20 amp circuit. Follow the installation instructions for both appliances, and have an electrician confirm that the setup meets local code.
Can a home battery run a dishwasher?
Yes, with planning. The system has to cover the heating peak along with other loads, and the battery needs enough energy for the full cycle. Water and drainage also have to be working.
