How Many Watts Can a 30 Amp Breaker Handle? The Math at 120V and 240V
How many watts a 30 amp breaker can handle depends on voltage and power factor. On single-phase AC, 30A corresponds to 3,600 volt-amperes (VA) at 120V or 7,200 VA at 240V. Those numbers equal watts for a load with a power factor of 1. Continuous loads, wire and receptacle ratings, and appliance requirements also affect what a circuit can supply.
How Many Watts Is 30 Amps?
If you've typed "30 amp how many watts" into a search bar, you probably got two different numbers. Amps alone don't tell you watts. You also need the voltage and the load’s power factor, and a 30 amp breaker in a US home can be 120V or 240V.
So how many watts are in 30 amps? Start by multiplying the amps by the volts. That gives you apparent power, which is measured in volt-amps (VA). At 120V, 30 amps works out to 3,600VA. And how many watts is 30 amps at 240 volts? The same math gives 7,200VA.
Watts measure real power, which is the apparent power times the power factor. Fluke's power factor guide walks through the formula. Only when the power factor is 1 does 3,600VA equal 3,600 watts and 7,200VA equal 7,200 watts. At a power factor of 0.8, a full 30 amps at 120V delivers just 2,880 watts.
Circuit | Math | Apparent power at 30A | At 24A continuous, ordinary breaker |
30A at 120V | 30 × 120 | 3,600 VA (3,600 W at PF = 1) | 2,880 VA (2,880 W at PF = 1) |
30A at 240V | 30 × 240 | 7,200 VA (7,200 W at PF = 1) | 5,760 VA (5,760 W at PF = 1) |
Why the 80% Column Matters
Those maximums fit a load that runs for a short time. A heater that stays on all evening is a different case. The National Electrical Code calls a load continuous when its maximum current is expected to go on for three hours or more.
For a circuit with continuous loads, or a mix of both kinds, the 2014 NEC text of Section 210.20(A) says the breaker rating can't be less than the noncontinuous load "plus 125 percent of the continuous load." IAEI Magazine's breaker sizing article quotes that text, along with the exception for assemblies listed to run at 100% of their rating. The code itself is on the NFPA 70 official code page, and your area may enforce a newer edition.
Here's a mixed example. A 16 amp continuous load plus a 10 amp noncontinuous load checks as 16 × 1.25 + 10 = 30 amps, which is the most a standard 30 amp breaker allows. With only a continuous load on the circuit, the same math works out to about 80% of the breaker rating. On a 30 amp breaker, that is 24 amps: 2,880 VA at 120V or 5,760 VA at 240V, with the same numerical values in watts only at a power factor of 1.
The Breaker Is Only One Part of the Circuit
So how many watts in 30 amps can you count on? Only as many as the weakest part of the circuit allows. The wire, the receptacle, and the appliance nameplate each carry their own rating, and a 30 amp breaker doesn't replace checking any of them.
Before you add up loads, look up the 30 amp breaker wire size your circuit needs, because wire that's too thin can overheat before the breaker trips. Any change to fixed wiring belongs with a licensed electrician. A 240V circuit also gets its own math, separate from the 120V side.
The numbers are easier to picture with a real 120V, 30A outlet in front of you. Some portable power stations have one, and they make a handy example.
A 120V, 30A Example: Portable Power Station Outlets
Say you're looking at a power station and notice one outlet that's bigger than the rest. Some models carry a single 30A, 120V outlet next to their standard 20A outlets. That 30A label tells you what one port can deliver. The station also has a total output limit that covers every outlet at once, which is the same idea as a breaker's limit across its whole circuit.
One Outlet, One Total Limit
If you want to see that idea on real equipment, EcoFlow DELTA 3000 Gen4 is a clear example. It has four 20A outlets and one 30A outlet at 120V, with 3,600W of total output. At 120V and 30A the outlet corresponds to 3,600 VA. That equals the separately specified 3,600 W station rating only for a unity-power-factor load.
So the 30A outlet lines up with the 120V row in the table above. Anything you plug into the other four outlets counts against the same 3,600W.
What the Estimates Look Like
How long would a load near that limit run? The table below applies two formulas to this one station. For single-phase AC, real watts equal RMS volts × RMS amps × power factor. Runtime equals usable watt-hours divided by real watts. Every figure is an estimate that assumes about 85% of the stored energy is usable.
Example | Math | Estimated result |
30A outlet ceiling | 30A × 120V | 3,600 VA; 3,600 W at PF = 1 |
Illustrative continuous current, all load continuous | 30 A × 0.8 × 120 V | 2,880 VA; 2,880 W at PF = 1 |
Runtime at 2,880W | (3,072Wh × 0.85) ÷ 2,880W | About 0.9 hour |
Runtime at 1,000W | (3,072Wh × 0.85) ÷ 1,000W | About 2.6 hours |
The 80% line borrows the NEC continuous-load idea as an example, and EcoFlow doesn't publish it as a rating. A few checks keep the math honest for your setup:
Add up the running watts of every device you'll plug in at the same time.
Check the per-outlet limit, since four of the five outlets are 20A.
Read each device's nameplate before you count on it.
Limits and Delivery Timing
This example has limits you should know about. It covers a 120V circuit only, so it can't show you how a 240V dryer or water heater circuit behaves. A power station also doesn't take the place of a 30 amp circuit wired into your home.
Timing matters too. The EcoFlow US page lists EcoFlow DELTA 3000 Gen4 as shipping in early January 2027 (checked November 16, 2026). Confirm delivery for your address before you plan around it, and don't count on it for an outage or storm that's happening this week.
The Same Math for 30 Amp RVs
Campers will recognize this outlet rating. Death Valley's Furnace Creek Campground, for example, has full-hookup sites with both 30 and 50 amp service, according to the National Park Service campground page. The same math applies when you compare 30 amp RV generator sizes for a trip.
That covers the portable side. Back at home, a 30 amp breaker usually has a much simpler job.
What Can You Run on a 30 Amp Breaker?
How much can you run on a 30 amp breaker? Start with what's already on it. Most 30 amp home circuits feed one large appliance and nothing else. The nameplate and the installation manual tell you what that appliance needs.
Common 30 Amp Appliances
The list below gives general examples. Your own equipment may differ, so treat it as a starting point.
Electric clothes dryer (240V): GE Appliances calls for a 208/240V individual circuit with a 30 amp breaker for its electric dryers, per the GE Appliances dryer requirements.
Some electric water heaters (240V): The rating plate lists the voltage and wattage for your model.
Small central AC condensers: The unit's nameplate gives the breaker size the maker allows.
RV hookup (120V): A 30 amp campground pedestal feeds the whole rig through one cord.
The Breaker Protects the Wire
What if a smaller circuit keeps tripping and a 30 amp breaker looks like an easy fix? It isn't one. A breaker's job is to protect the wire behind the wall, and a larger breaker lets more current through wire that was never sized for it.
The Consumer Product Safety Commission makes the same point about fuses. An oversized fuse can let too much current flow and overheat the wiring, according to the CPSC electrical safety checklist. The breaker, wire, and receptacle have to match, and matching them is an electrician's job. To see how the rule scales down, compare 15 versus 20 amp circuits.
Even a correctly sized circuit can be pushed too hard. When that happens, it usually gives you some warning.
Signs a 30 Amp Circuit Is Overloaded
Has your dryer breaker tripped twice in one week? Frequent trips mean the circuit is carrying too much load or there's a fault somewhere. A warm outlet or a burning smell means stop using the circuit and call an electrician.
Warning Signs to Watch For
These are general warning signs. Any one of them deserves a closer look.
The breaker trips often, especially in the middle of a cycle.
Cover plates or plugs feel warm to the touch.
You hear buzzing from the outlet or the panel.
You see scorch marks or discoloration around the receptacle.
Lights dim when the appliance starts.
What to Do Next
The same CPSC checklist says unusually warm outlets or switches can point to an unsafe wiring condition. Its advice is to stop using them until an electrician checks the wiring.
Don't keep resetting a breaker that won't stay on. An overload is one possible cause, and a wiring fault is another. It helps to understand the dangers of short circuits before you assume the load is the problem.
At 30A, a single-phase circuit supplies up to 3,600 VA at 120V or 7,200 VA at 240V. Multiply VA by the load’s power factor for watts. If maximum current is expected to continue for at least three hours, include 125% of that current plus all noncontinuous current when sizing an ordinary breaker. Check the wire, receptacle, and appliance nameplate with an electrician. The EcoFlow DELTA 3000 Gen4 has a separately rated 3,600W total AC output.
How many watts is 30 amps at 120 volts?
At 120V, 30A is 3,600 VA, or 3,600 real watts at unity power factor. With only a continuous load on an ordinary 30A branch circuit, 24A corresponds to 2,880 VA.
How many watts is 30 amps at 240 volts?
At 240V, 30A is 7,200 VA. At a power factor of 1 that is 7,200 W. An all-continuous load of 24A is 5,760 VA, with watts depending on the load’s power factor.
What is the 80% rule for breakers?
For an ordinary breaker, include all noncontinuous current plus 125% of any current expected to remain at its maximum for at least three hours. If all the load is continuous, a 30A breaker ordinarily serves up to 24A. An appliance that cycles for three hours does not necessarily draw maximum current for that whole time.
Can I put a 30 amp breaker on 12-gauge wire?
On an ordinary general-purpose branch circuit, no. There, 12-gauge copper wire is generally limited to a 20 amp breaker, and a 30 amp breaker can let it overheat. Dedicated air conditioning circuits follow NEC Article 440 instead. An electrician sizes those from the minimum circuit ampacity and maximum overcurrent protection on the unit's nameplate.
Can a power station handle 30 amps?
Some can at 120V. EcoFlow DELTA 3000 Gen4, for example, has one 30A outlet. The station's total output limit still applies to everything plugged in at once, so add up your loads first.
