Colorado Winter Storm Warning: What It Means, Expected Conditions and How to Prepare
Colorado winter weather can change sharply over a short distance. Snow may be falling steadily on the west side of Denver while roads remain merely wet farther east. Along I-70, a drive that begins under clear skies can encounter blowing snow, poor visibility, and chain restrictions before the next pass.
A Winter Storm Warning signals that you should stop treating the forecast as a routine chance of snow. Significant winter weather is occurring or expected soon enough to threaten travel and disrupt normal activity. The warning itself provides the most useful details: the affected locations, the expected timing, likely snow or ice amounts, and the hazards forecasters consider most serious.
This guide explains what a Colorado Winter Storm Warning means, why conditions differ so much across the state, and how to prepare your home, vehicle, and backup power before the storm reaches its peak.
What Does a Winter Storm Warning Mean in Colorado?
The National Weather Service (NWS) issues winter weather alerts according to the likelihood, timing, and expected effects of a storm. The terms are not interchangeable. A watch gives people time to prepare for a storm that remains uncertain, while a warning means hazardous conditions are underway or likely enough that plans should change.
A search for “winter storm warning Colorado” is only a starting point; read the full alert for your location. Open the full warning and confirm whether it covers your location. Colorado counties often span major changes in elevation, and an alert may apply only above a stated altitude or to one side of the Continental Divide.
Winter Storm Warning vs. Watch vs. Advisory
The three alerts describe different levels of certainty and expected disruption. An advisory still deserves attention; it generally indicates that winter weather may make travel difficult even though the event is not expected to meet warning criteria.
Alert Level | Timing & Confidence | Expected Impact | Recommended Action |
Winter Weather Advisory | Hazardous conditions are expected or occurring | Slick roads, reduced visibility, snow, or mixed precipitation may disrupt travel | Slow down, allow more time, and continue checking updates |
Winter Storm Watch | Significant winter weather is possible within the next few days, but important details remain uncertain | Heavy snow, blowing snow, sleet, or ice could create dangerous conditions | Gather supplies and reconsider travel before the forecast becomes more certain |
Winter Storm Warning | Significant winter weather is imminent or already occurring | Travel may become dangerous or impossible, with substantial snow, blowing snow, or mixed precipitation | Avoid unnecessary travel and complete preparations before conditions deteriorate |
National Weather Service Criteria for Issuing a Winter Storm Warning
Colorado does not have one snowfall number that automatically triggers a warning everywhere. Each NWS forecast office uses criteria suited to the terrain and normal winter climate of the zones it serves. Forecasters also consider blowing snow, ice, storm timing, and the likely effect on travel.
For areas along and east of the Continental Divide served by the Boulder and Pueblo offices, representative heavy-snow criteria are generally 6 inches in 12 hours or 8 inches in 24 hours at lower elevations. In the mountain forecast zones, the corresponding figures are generally 8 inches in 12 hours or 12 inches in 24 hours. Criteria in western Colorado vary by zone. Some valleys use lower thresholds than high mountain areas because a smaller accumulation can create an unusual and disruptive event there.
Those numbers are forecast guidelines, not promises about what will land in every driveway. A warning covers an area, while Colorado snowfall often concentrates in narrow elevation bands. Read the elevation language and location-specific totals included with the alert.
Warning Valid Period and Expiration Times
Every warning includes a start time and an expiration time. A Winter Storm Warning may be posted while snow is already falling or before the main impacts begin, depending on forecast confidence and local guidance. The NWS can extend, shorten, upgrade, or cancel it as the storm develops.
An expiration time does not certify that roads are clear. Snow may have ended while crews are still working through drifts, crashes, avalanche-control closures, or packed ice. Wind can also pick up loose snow after the last flakes fall and reduce visibility on open highways. Check the latest alert and road report rather than assuming that the end of the warning restores normal travel immediately.
What Weather Conditions Can Colorado Expect During a Winter Storm?
Terrain controls much of Colorado's winter weather. Elevation changes the temperature, while the direction of the wind determines which slopes receive the most moisture. A storm favorable for the Front Range foothills may leave parts of the Western Slope comparatively quiet, and the reverse can happen with the next system.
A point forecast for your address or destination is more useful than a statewide total, particularly when a trip crosses a pass or climbs several thousand feet.
Expected Snowfall Amounts, Accumulation, and Duration
Some Colorado storms move through quickly, producing several hours of snow followed by clearing and strong wind. Others slow near the mountains and draw moisture toward the foothills, allowing snow to continue for a day or more. A prolonged upslope event can produce feet of snow in favored foothill locations even when accumulations decline rapidly across the adjacent plains.
The final total is only one part of the forecast. Snowfall rate affects how quickly crews can clear a road, and temperature influences whether the snow is light and windblown or wet and difficult to move. Several inches during a busy commute may cause more disruption than a larger overnight total.
Look for three details in the warning: the expected range, the period of heaviest snow, and the altitude where rain is forecast to change to snow. If the forecast gives a wide range, that often reflects uncertainty about the storm track or the location of a narrow heavy-snow band.
Regional Differences in Snowfall Across Colorado
A winter storm Colorado residents encounter can affect the state's major regions very differently:
The Front Range & Foothills: Easterly upslope flow can push moist air against the terrain, favoring communities such as Evergreen, Nederland, and western Boulder. Snowfall in the foothills may be substantially greater than totals at Denver International Airport, even though the locations are not far apart on a map.
The Central & Northern Mountains: Mountain communities and passes near Vail, Breckenridge, Steamboat Springs, and the I-70 corridor often receive prolonged snow when moist air rises over the terrain. Wind and repeated snowfall can lead to poor visibility, difficult pass conditions, and traction or chain restrictions.
The Eastern Plains: Totals may be lower than in the foothills, but the open landscape gives wind little resistance. Blowing and drifting snow can close a road after the falling snow has weakened, especially where a crosswind repeatedly fills the same stretch of pavement.
The Western Slope & San Juan Mountains: Grand Junction may remain relatively sheltered during a storm that produces heavy mountain snow farther south or east. Silverton, Wolf Creek Pass, and other high-elevation locations can face much deeper accumulation, but the exact result depends on wind direction and storm track.
Elevation can also create a sharp rain-snow boundary. A valley floor may see wet roads while a nearby pass is snow-covered, and temperatures can fall quickly after sunset. Conditions at the starting point therefore say little about the highest part of the route.
Freezing Temperatures, Strong Winds, and Blowing Snow
Snow is not the only concern. Behind a cold front, temperatures may fall into the single digits or below zero, and strong wind can push the wind chill far lower. At a wind chill near -25°F, frostbite on exposed skin may become possible in about 15 minutes. The risk is especially serious for anyone stranded without adequate clothing or shelter.
Wind can change road conditions long after plows pass. Dry snow can blow back across cleared lanes, hide pavement markings, and build firm drifts around a stopped vehicle. Open sections of I-25 and I-70 are particularly exposed. In the mountains, blowing snow can remove the visual contrast drivers use to distinguish the shoulder from the travel lane.
Treat changing visibility as a reason to slow down early, not after the vehicle ahead disappears. Use low-beam headlights, increase following distance, and leave the highway at a safe location if lane markings become difficult to follow.
How Can a Colorado Winter Storm Affect Daily Life?
A major storm can interrupt work, school, travel, deliveries, and medical appointments at the same time. Mountain closures may separate communities that seem close together, while heavy, wet snow at lower elevations can damage trees and overhead lines. If those damaged lines cause an outage, a portable power station can provide temporary power for essentials such as lights and phone charging, within its output and runtime limits. Even after the storm moves out, cleanup and cold temperatures may prolong the disruption.
Road Closures, Icy Roads, and Travel Disruptions
Colorado Department of Transportation (CDOT) crews may be working continuously while snowfall and wind cover lanes again. Crashes, disabled trucks, avalanche mitigation, and unsafe visibility can still close part of a highway. Floyd Hill, the Eisenhower-Johnson Memorial Tunnels, Vail Pass, and Monument Hill are common pressure points because of grade, elevation, traffic, or exposure.
Denver International Airport can also experience deicing delays, gate changes, and cancellations. If a flight is scheduled during a warning, check the airline before leaving home and allow for slower ground transportation.
Avoid treating a four-wheel-drive vehicle as permission to ignore a closure or restriction. Four-wheel drive may help the vehicle move, but it does not shorten the distance needed to stop on packed snow or ice.
Power Outages Caused by Heavy Snow and Strong Winds
Wet snow can cling to branches and overhead lines, and wind adds stress to both. Neighborhood outages are more likely when trees still hold leaves early in the season or when repeated storms have already weakened branches. Restoration may also take longer when crews must wait for safe road access.
When electricity fails, the immediate problems are usually simple ones: lights, refrigeration, and communications. Heating may also stop even if the home uses natural gas, because many furnaces and boilers rely on electric controls, igniters, blowers, or pumps.
A portable power station such as the EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh) can keep essential appliances, including refrigerators, LED lights, and communication devices, running during an outage, as long as their combined running and starting power demands stay within the unit's output limits. Before storm season, identify the devices you would connect first and test the intended setup so cords and accessories are easy to find in the dark.
Health and Safety Risks From Extreme Cold and Poor Visibility
Several hazards become more likely when snow, wind, cold, and an outage occur together:
Hypothermia and Frostbite: A person can lose body heat quickly in an unheated vehicle or while working outside in wet clothing. Numbness, pale or waxy skin, confusion, slurred speech, and uncontrollable shivering require prompt attention.
Carbon Monoxide Poisoning: A fuel-powered generator, charcoal grill, camp stove, or other combustion device can produce deadly carbon monoxide. Never operate it inside a home, garage, or other enclosed space.
Cardiovascular Strain: Wet, compacted snow is heavy. Shoveling combines cold exposure with sudden exertion and can place substantial stress on the heart, particularly for older adults or anyone who is not accustomed to strenuous exercise.
Whiteout Collisions: A rapid loss of visibility can cause drivers to brake abruptly or lose track of the lane. Chain-reaction crashes become more likely when traffic is moving too fast or following too closely for the available sight distance.
Children, older adults, people with medical conditions, and pets may need extra protection during an extended outage.
How Should You Prepare for a Winter Storm Warning in Colorado?
Use the time before the warning begins to finish work that requires dry pavement, daylight, or a trip to the store. Start with the needs that cannot wait: medication, heat, water, vehicle readiness, and a safe way to receive updates. Then prepare for the possibility that roads will remain difficult after the snowfall ends.
For longer outages, a home battery can support selected household loads when its output, stored energy, and installation match the home's needs.
Home Protection and Essential Emergency Supplies
Disconnect garden hoses and protect plumbing in garages, crawl spaces, and exterior walls. Know where the main water shutoff is located, and move stored items out of the way so it can be reached quickly. If a sink sits against an exterior wall, opening the cabinet doors during severe cold can allow warmer room air to circulate around the pipes. Knowing how to keep pipes from freezing without heat also helps when an outage interrupts normal heating.
Set aside at least three days of familiar, shelf-stable food and at least one gallon of water per person per day for drinking and sanitation, for at least three days. Homes with a private well should store additional water because the pump may not operate during an outage. Include pet food, a manual can opener, flashlights, batteries, a battery-powered NOAA weather radio, basic first-aid supplies, and enough prescription medication to avoid an unnecessary trip during the storm. Keep these supplies together as a winter storm emergency kit that everyone in the household can locate.
Charge phones, lanterns, power banks, and other rechargeable equipment before snow begins. Test smoke and carbon monoxide alarms, and keep exterior furnace and dryer vents visible so they can be cleared if drifting snow blocks them.
Backup Power and Heating During Winter Outages
List the electrical loads that matter most before choosing a backup plan. Refrigeration, a furnace blower, communications, and a few lights generally deserve priority over convenience appliances. An appliance’s starting demand can be higher than its normal running wattage, so the total load must remain within the backup system’s limits.
An EcoFlow TITAN 5000 Plus paired with a Smart Home Panel 10 and professional installation can provide automatic backup for up to 10 selected household circuits when grid power fails. The SHP10 configuration supports both 120V and 240V circuits, allowing homeowners to back up essential loads such as a furnace blower, refrigerator, sump pump, and other compatible household appliances. Its expandable battery capacity also allows homeowners to adjust backup runtime based on their electricity needs and expected outage duration.
Keep blankets and winter clothing accessible even when the heating system is working. If indoor temperature begins to fall, close off unused areas only when doing so will not expose plumbing to freezing. Never use an oven, charcoal grill, or outdoor heater to warm the house.
Vehicle Preparation and Winter Driving Safety
Colorado's Traction Law applies to the I-70 Mountain Corridor between Dotsero and Morrison from September 1 through May 31 each year. CDOT may also activate traction requirements on other state highways when weather or road conditions warrant. Under the updated law, AWD and 4WD vehicles must have winter, all-weather, or mud-and-snow (M+S) tires with at least 3/16-inch tread depth. Vehicles that do not meet these requirements must use tire chains or an approved alternative traction device (ATD) on two or more drive tires. When the Passenger Vehicle Chain Law takes effect during severe winter storms, every vehicle must have chains or an approved alternative traction device.
Check tire condition and pressure before the storm, not at the base of the pass. Fill the fuel tank or charge the EV, top off winter-rated windshield-washer fluid, and confirm that the battery, heater, defroster, and wipers work properly. Keep the following items in the vehicle:
Folding snow shovel and sand or non-clumping kitty litter for traction
Warm blankets, insulated gloves, winter boots, and an extra dry layer
Jumper cables or a portable jump starter
Snacks, drinking water, an ice scraper, and a flashlight
A phone charging cable and any medication that may be needed during a long delay
Before traveling, check COtrip for current road conditions, closures, cameras, and restrictions. Review the complete route, including the return trip. A pass that is open in the morning may close later as snowfall or wind intensifies.
Snow Removal Tools and Post-Storm Safety Precautions
Place shovels, a roof rake, traction material, and ice melt where they can be reached without crossing a drifted yard. During a long storm, removing manageable amounts may be easier than waiting for heavy snow to settle, but do not work outside when visibility, wind, or physical strain makes the job unsafe.
Push snow when possible rather than repeatedly lifting it. Take breaks, drink water, and stop if you have chest pain, unusual shortness of breath, dizziness, or nausea.
Before starting a vehicle, clear the tailpipe as well as the windows, lights, cameras, and roof. After an outage or heavy drift, check furnace and appliance vents from the ground. Use a roof rake only from a safe position; do not climb onto an icy roof. Sagging, new cracking sounds, or visible structural changes call for professional evaluation.
A Colorado Winter Storm Warning means that significant winter weather is close enough—or already underway—that travel and household plans should change. The most important details are local: elevation, storm timing, snowfall rate, wind, and the exact roads between you and your destination. Read the full warning, check current road conditions, and finish preparations while travel remains manageable. A winter-ready vehicle, several days of basic supplies, warm clothing, and a backup plan for essential electrical loads can turn a disruptive storm into one the household can safely wait out.
How to Check the Road Conditions in Colorado?
You can check live Colorado road conditions, chain laws, and highway closures through the official COtrip.org website, the COtrip Planner mobile app, or by dialing 511 from any phone inside the state. Both the website and app display real-time CDOT traffic cameras, snowplow locations, and active traction alerts along I-70, I-25, and mountain passes.
What Should You Do if You Get Stuck in Your Car During a Snowstorm?
Stay inside your vehicle, turn on your hazard lights, and call 911 or *277 (Colorado State Patrol) to report your location. Walking away from your car in a blizzard dramatically increases your risk of hypothermia and getting lost in poor visibility. Run your engine and heater for about 10 minutes each hour to stay warm, and always step out beforehand to ensure your exhaust pipe is completely clear of snow.
Where Do Most Avalanches Occur in Colorado?
Most avalanches in Colorado occur on steep, snow-covered slopes angled between 30 and 50 degrees in the backcountry of the San Juan, Sawatch, Elk, and Front Range mountains. Areas near Red Mountain Pass, Loveland Pass, Berthoud Pass, and Vail Pass see frequent slide activity, especially right after heavy snowfall combined with strong ridge-top winds. Always check the Colorado Avalanche Information Center (CAIC) forecast before heading into backcountry terrain.
What Are the 4 P's in Freezing Weather?
The 4 P’s of freezing weather preparedness stand for People, Pets, Pipes, and Plants. Checking on elderly neighbors, bringing dogs and cats indoors, insulating exposed plumbing or dripping faucets, and covering sensitive outdoor vegetation cover the four most vulnerable areas around your home when an Arctic cold front hits.
