Power Your Entire House Reliably with a Battery Backup
The power is out, the food in your fridge is going off, your battery is on 10%, and the house is starting to get chilly. This is a common occurrence when the grid goes down or a storm decides to wreak havoc. But, it doesn’t have to be! We’ll talk you through a whole-house battery backup system, the pros and cons, and how to find the best solution for you and your home.
How Does a Whole House Battery Backup Solution Work?
A whole-house battery backup is a powerful energy backup solution that can keep your home connected, even after a storm or power outage. When the power cuts out, your backup is automatically switched on, so you can stay connected without a hitch.
With all of the modern advancements in technology, you can now manage your energy via connected apps so you stay in complete control. Whole-house battery backups are designed to stand the test of time and work at maximum efficiency, storing excess energy and using it when you need it most.
What Are the Pros and Cons of Home Battery Backup?
Pros
  • Lower energy bills: One of the best things about home battery backup is the savings you can make on your energy bills. You can store excess energy when rates are low—like at night—and use it during peak times.
  • Better for the environment: It has fewer fumes, and it’s a much quieter option than a generator that needs fuel to run. Instead, you get access to clean energy you don’t have to feel guilty about using.
  • Long-term energy independence: No more relying on the grid. Go independent and power your own supply so you never have to worry about being cut off during an emergency.
  • Smart control features: Many home battery backup systems have smart features like the EcoFlow App. Here you can get detailed insights into how you use your energy and have full control at your fingertips.
Cons
  • Maintenance: Battery backups have a finite lifespan and will eventually need replacing. How long your battery lasts will also depend on regular maintenance to keep it working efficiently.
  • Cost: Whilst there’s a high upfront cost, some rebates and initiatives can help cover the expense.
  • Limited capacity: Some have a limited storage capacity that might not be suitable for prolonged power outages.
  • Spatial requirements: If you have a tight space, you might struggle to find a suitable, clean, dry, well-ventilated place to keep your home battery backup system.
EcoFlow DELTA Pro 3
Benefits of a Home Battery Storage System
Energy Independence
Whether it’s issues with the grid or a freak storm, a whole-home battery storage system like the EcoFlow DELTA Pro 3 means you don’t have to worry about being stuck without power. Keep all your appliances—fridges, Wi-Fi, and even AC—running smoothly, no matter the situation.
Subsidies Available
Some initiatives and rebates are available to help with the costs of installing a home battery storage system. The Residential Clean Energy Credit (formerly known as the Federal Tax Credit) covers 30% of the purchase and installation costs. Adding solar panels to your system also qualifies for the tax rebate. Other local government initiatives may be available to help reduce the financial burden.
Pair With Solar and Join a Virtual Power Plant
You can get even more rewards when you pair your battery storage with solar panels. With some systems, you can join a virtual power plant where you sell your extra energy back to the grid. Why waste stored power when you can make some cash?
Get 1–5kWh expandable capacity with multiple battery options. Deliver up to 2200W output (3600W surge) with X-Boost. Recharge fast with 5 versatile methods, and enjoy peace of mind with a 5-year warranty.
Compare Standalone Versus Solar-Plus-Battery Setups
To find the best home battery backup solution for you, we’ll compare standalone and solar-plus-battery setups:
Standalone Battery Backup: This is an excellent option for homes that might not have a roof for solar panels, but still want that power reliability. Charge your battery through the grid, through an outlet, or your car, and if there’s an outage, you still have power that kicks in to keep things ticking along. Some setups may allow you the option to add on solar panels down the line.
Solar-Plus-Battery Setup: By adding solar panels, you can effortlessly create power every day and charge up your battery so it’s ready in case of an emergency or outage. A bonus is being able to use your stored power at peak times to help lower your electricity costs. It also allows you to go entirely off-grid and power your entire energy system without relying on the grid. The EcoFlow DELTA 3 Plus 220W Portable Solar Panel is a great solar-plus-battery option and comes with a 5-year warranty.
When building a home battery backup system, consider your household’s needs, whether they’re financial or environmental concerns, or the guarantee of power in the wake of a natural disaster.
EcoFlow DELTA 3 Plus outside home
Are Whole Home Battery Backups Worth It?
Absolutely! Whole-home battery backups keep your appliances running when disaster strikes. If energy independence wasn’t enough, other benefits include lower electricity bills and less environmental impact.
Can I Power My Whole House With a Backup?
Yes, but it depends on your system’s capacity and energy needs. Smaller batteries cover essentials like lights and Wi-Fi, while larger or scalable systems can run heavy appliances, HVAC, and refrigerators. Choosing the right size ensures reliable whole-home backup during outages.
How Long Will a Whole House Battery Backup Last?
It depends on battery size and how much power your home uses. A smaller system may last several hours, while larger or expandable batteries can keep essentials running for days. Pairing with solar panels helps recharge continuously, extending backup power through longer outages.
What Is Better, a Generator or Battery Backup?
Generators are great as a power backup, but they need fuel top-ups, regular maintenance, and are worse for the environment. With a battery backup, you can enjoy reliable power without having to feel guilty about your environmental impact, save money, and have the option to scale up.
Ready to Power Your Entire House With EcoFlow’s Delta Pro Ultra Battery Backup System?
Don’t get stuck in the dark ever again with a whole-house battery backup system you can count on. From bigger energy savings to less impact on the environment, and more energy independence, it’s no wonder battery backups are becoming so popular. Shop EcoFlow’s power solutions and begin your journey to energy independence today.
Home Backup
