Fall Home Maintenance Checklist for Homeowners
Fall is a good time to deal with the small home repairs that are easy to ignore during summer. A loose shingle, clogged gutter, drafty window, or overdue furnace tune-up can become a bigger headache once temperatures drop. This fall home maintenance checklist covers the roof, heating system, yard, outdoor equipment, safety devices, and backup power, so you're ready for winter.
Check the Roof and Clean the Gutters
Your roof and gutters take a beating from summer heat, storms, falling leaves, and heavy rain. Give them a close look before winter weather makes repairs harder.
Look for roof damage
Start with a ground-level inspection if possible. Look for missing or cracked shingles, damaged flashing, uneven areas, and signs of trouble around chimneys, skylights, and vents. If you're not comfortable with heights, inspect the roof without climbing or hire a professional.
Clear the gutters
Leaves and debris can clog gutters, allowing water to back up, freeze, and form destructive ice dams. Clean out gutters and make sure downspouts direct water at least 3 to 5 feet away from your home's foundation. This fall yard cleanup guide can help you cover other outdoor maintenance tasks before winter. Check your gutters again late in the season after the remaining leaves have fallen.
Check flashing and roof edges
Check the flashing around chimneys, skylights, and walls for gaps, rust, or lifted sections. Fixing these problems before winter can help prevent leaks. If you spot damage or signs of water intrusion, have a roofing professional take a closer look. Once the roof and gutters are ready, move inside and check the heating system and drafty areas.
Seal Drafts and Service the Heating System
A house can lose a surprising amount of heat through small gaps around doors and windows. Fall is also the right time to make sure your furnace or other heating equipment is ready for the colder months.
Seal Drafts and Service the Heating SystemSeal Drafts and Service the Heating System
Find and seal air leaks
Check around exterior doors, windows, baseboards, and other openings where outdoor air can get inside. You may notice a cold draft on a windy day, or you can look for visible gaps around the frames. Weatherstripping works well around moving parts of doors and windows. Caulk will fill smaller gaps around stationary frames. The U.S. Department of Energy notes that sealing air leaks around doors and windows can reduce heating costs by up to 20%.
Replace the furnace filter
A dirty furnace filter restricts airflow and forces your system to work harder. Check the filter before heating season starts and replace if it is dirty or according to the manufacturer’s recommended schedule. A clean filter also reduces dust circulation around the house. If you have pets or someone in the home has allergies, you may need to check the filter more often.
Schedule a furnace tune-up
An HVAC professional inspection can catch small problems before you rely on the furnace every day. Before the weather gets colder, a technician can inspect the system, check important parts, and make sure it's working properly. If you’re thinking about switching to a different heating system, comparing heat pump and furnace costs can help you understand the differences before you make an upgrade. With the heating system ready, it's also a good time to check your backup power before the first major storm or outage.
Having Backup Power Ready Before the First Storm
Fall weather can bring strong storms, heavy rain, high winds, and the first cold snaps of the year. A power outage is a lot easier to handle when your backup battery is already charged and your cables and accessories are where you expect them to be. Don't wait until the power goes out to figure out how everything works. Test the system while you still have grid power, charge the batteries, and check the cables for damage.
EcoFlow DELTA Pro Ultra
•Certified Safety: The only portable power station certified to both UL1973 and UL9540 for extreme home reliability. • High-Power Output: Delivers 7.2–21.6kW, powerful enough to run your whole home, including a central AC. • Massive Capacity: Offers 6–90kWh capacity for comfortable whole-house backup lasting weeks. • Smart Integration: Provides auto-switchover, prolonged backup, and energy bill savings via the EcoFlow Smart Home Panel 2. •Flexible Charging: Features 5 charging options so backup plans always have a backup. • Self-Heating Battery: Automatically starts self-heating below 32°F to ensure normal operation in cold weather.
For homeowners who need strong backup capacity without going as large as the DELTA Pro Ultra, the DELTA Pro offers 3.6kWh of capacity out of the box. It can also expand up to 25kWh with an extra battery, giving you more room to cover essential appliances during a longer outage.
EcoFlow DELTA Pro
•Expandable Capacity: 3.6kWh to 25kWh expandable capacity with DELTA Pro Smart Extra Battery. •Powerful AC Output: 3,600W continuous AC output (expandable to 7,200W with two DELTA Pro units and Double Voltage Hub) capable of powering 99% of appliances. • Home Backup: Plug & Play home backup solution. • Fast Charging: Incredible 6500W MultiCharge delivering 2.7 hours of AC charging. • EV Charging: Industry first feature allowing recharge at thousands of EV stations worldwide. •Durability: Long-lasting LFP battery supporting up to 10 years of use.
With the house ready for colder weather, it's time to turn your attention to the yard and outdoor equipment. A little cleanup now can help protect your property, hoses, and tools from freezing temperatures and winter storms.
Take Care of the Yard and Outdoor Equipment
Fall cleanup isn't only about making the yard look neat. Leaves, dead branches, standing water, and unprepared equipment can cause problems once freezing weather arrives.
Take Care of the Yard and Outdoor EquipmentTake Care of the Yard and Outdoor Equipment
Clear leaves and debris
Rake leaves from the lawn or mulch them if your mower allows it. Wet leaves can block sunlight and trap moisture, so clear them from the yard and areas around vents, drains, and outdoor equipment. This fall yard cleanup guide covers more seasonal tasks.
Trim branches near the house
Check for branches hanging over the roof, driveway, power lines, or other structures. Trim weak branches before winter storms can knock them down. Leave branches near power lines to a qualified professional or your utility company.
Winterize hoses and sprinklers
Disconnect and drain garden hoses before freezing temperatures arrive. Water left inside can freeze and damage hoses or connected pipes. If you have an in-ground sprinkler system, follow the manufacturer's winterization instructions and drain the lines before a hard freeze.
Prepare the mower for storage
Clean the mower, remove grass from the deck, and check the oil if needed. For gas-powered equipment, follow the manufacturer's instructions for draining or stabilizing fuel before storing it. With the yard ready, finish your checklist with a few indoor safety checks.
Safety Checks Before Winter
Heating equipment gets more use as temperatures fall, so fall is a good time to test your smoke and carbon monoxide detectors. The U.S. Fire Administration recommends testing these alarms regularly and replacing batteries or units according to the manufacturer's instructions. A few other checks can help you start the heating season with fewer surprises.
Task
Why It Matters
Test smoke and CO detectors
Cold weather heating increases fire and CO risk
Inspect and clean the chimney
Removes flammable creosote buildup before first use
Check fire extinguisher expiration
An expired extinguisher may not work when needed
Review the family fire escape plan
Keeps everyone prepared before heating season begins
Check your chimney and fireplace
If you use a wood-burning fireplace or stove, have the chimney inspected and cleaned as recommended. Creosote can build up inside the flue and create a fire hazard. Also check the area around the fireplace for anything that could catch fire. Keep furniture, decorations, and other combustible items away from the heat source.
Check your fire extinguisher
Make sure your fire extinguisher is easy to reach and hasn't passed its expiration or service date. Check the pressure indicator if your model has one, and look for visible damage or corrosion. Everyone in the household should know where it is. You don't want to start looking for it after a fire has already started.
Review the escape plan
Go over your home's fire escape plan with everyone who lives there. Make sure bedrooms have clear exits and that everyone knows where to meet outside. If your home has multiple floors, make sure everyone knows how they'll get out if the usual route is blocked. A seasonal home maintenance checklist can also help you keep track of safety and maintenance tasks throughout the year.
A fall home maintenance checklist covers more than raking leaves. Check the roof and gutters, seal drafts, service the furnace, prepare outdoor equipment, test safety devices, and make sure your backup power is ready before winter weather arrives. Start with the jobs that could cause expensive damage if they're ignored, such as roof leaks, clogged gutters, heating problems, and exposed outdoor pipes. Then work through the smaller tasks. Having everything checked before the first major storm can make the transition into winter a lot easier.
When should fall home maintenance start?
Start in early fall, before the temperatures drop and winter weather arrives. This gives you time to schedule HVAC or roofing work, clean the gutters, prepare outdoor equipment, and charge your backup power before you need it.
What is the most important fall home maintenance task?
There isn't one task that applies to every home. Roof and gutter problems, heating issues, air leaks, frozen pipes, and safety equipment can all cause problems during winter. A complete checklist helps you catch several of these issues before cold weather sets in.
How often should a furnace be serviced?
Follow your furnace manufacturer's maintenance recommendations. Many homeowners schedule a professional inspection once a year, often before the heating season begins. Replace or clean the filter according to the manufacturer's instructions as well.
Do gutters really need cleaning every fall?
Most homes should have their gutters checked and cleaned as needed during fall, especially when nearby trees drop a lot of leaves. You may need to check them more than once if leaves continue falling after the first cleaning.
What should be on a fall safety checklist?
Test smoke and carbon monoxide detectors, inspect the chimney if you use a fireplace, check your fire extinguisher, and review the household fire escape plan. It's also a good time to make sure everyone knows what to do during a winter power outage.
Home Solutions
