Duquesne Light Outages: How to Check and Report
Duquesne Light serves more than 620,000 customers across Pittsburgh and Allegheny County. When the power goes out, knowing where to check the outage status and how to report the problem can save you a lot of time. This guide covers the Duquesne Light outage map, ways to report an outage, what usually causes outages in the area, and what you can do while crews work on restoration. It also covers backup power and a few basic safety steps to keep in mind during an outage.
How to Check the Duquesne Light Outage Map
The Duquesne Light outage map gives you a quick look at reported outages across its service area. The map updates about every 15 minutes, so you can check back for changes as crews respond to problems. The map also breaks outages down by county, telling whether the problem is limited to your neighborhood or part of a larger outage affecting the Pittsburgh area.
You can check the same outage information through the Duquesne Light mobile app. The app also gives you access to reporting tools, which can be useful if you're already away from a computer. If you're trying to understand how utilities share outage information, this guide to SCE outage management offers another example of how outage updates and restoration information can work.
What to look for on the map
When you open the outage map, check the area around your home first. Then look at the number of affected customers and any available restoration information. If your address isn't showing an outage, that doesn't always mean your home is the only one without power. Your outage may not have been reported yet, which is why reporting it directly still matters.
How to Report a Duquesne Light Outage
If your power is out and you don't see your address on the outage map, report the outage to Duquesne Light. You can report it by phone, online, or through the utility's mobile app. Reporting the outage gives Duquesne Light another way to confirm the problem and identify affected customers. It can also help you get updates as crews work on restoration.
How to Report a Duquesne Light OutageHow to Report a Duquesne Light Outage
Report by phone
Duquesne Light's outage number is 1-888-393-7000. The line is available 24 hours a day, seven days a week. Have your service address or account number nearby before you call. You may also want to note when the power went out and whether nearby homes are affected. That information can make the reporting process quicker and give the utility a clearer picture of the outage.
Report online or through the app
You can also report an outage through the Duquesne Light website or mobile app. This can be a convenient option if you don't want to wait on the phone during a widespread outage. Make sure the outage is reported for the correct service address. If several homes in your area have lost power, your report can also help the utility confirm the extent of the problem.
What to do about a downed power line
A downed power line is an emergency. Stay away from the line and anything it may be touching. Call 911 first if you see a downed power line. You should also report the problem to Duquesne Light, so the utility knows about the damaged equipment. Once the outage is reported, you'll still need to keep essential devices running while crews work on repairs. That's where backup power can help.
Backup Power While Waiting on Duquesne Light
Many outages are resolved within a few hours after crews are dispatched, but major storms can change that quickly. Widespread damage can leave some households without power for a day or longer. A portable power station can keep a few important devices running while you wait. That may include a refrigerator, phone chargers, Wi-Fi equipment, lights, or medical equipment. For longer outages, a whole-home battery can cover more of your electrical needs. The right option depends on how much power your household needs and how long you expect to be without utility service.
EcoFlow DELTA Pro Ultra X
•100% Whole-Home Power: Delivers 12–36kW output and 12–180kWh capacity. • Fast Installation: Plug-and-play design installs in 7 days, saving up to 80% on time and cost. • Smart & Reliable: Auto switchover in under 10ms standalone, under 20ms with Smart Home Panel. • High Savings: Saves up to $6,000 per year with a 3-year ROI. • Comprehensive Safety: Provides end-to-end system protection meeting the highest safety standards.
If you don't need whole-home backup, a smaller portable power station can cover the essentials during a Duquesne Light outage. The EcoFlow DELTA 3 Max is a more portable option for keeping a refrigerator, chargers, and other important devices running.
EcoFlow DELTA 3 Max (2048Wh)
• 2400W Powerful Output: 4800W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3400W such as refrigerators, coffee makers, washers, and circular saws. • 4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. • Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2kWh product. • OASIS 3.0 Smart App Control: Dashboard to monitor real-time battery status, electricity prices, and savings. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
Storms can affect the power system in different ways, and the damage may not be clear right away. Knowing the common causes can help you understand why an outage happens and why restoration times may vary.
What Typically Causes Outages in Duquesne Light's Territory
Duquesne Light serves Allegheny County and much of southern Beaver County, including Pittsburgh and nearby communities. Weather is a major factor in power outages across this part of western Pennsylvania, with summer storms and winter ice creating some of the biggest problems.
Summer storms
Summer thunderstorms may bring strong winds, lightning, and falling trees or branches. These conditions can cause damage to power lines and other electrical equipment, sometimes knocking out power to thousands of customers. Strong winds can also carry branches into lines or knock trees onto electrical equipment. Lightning can damage equipment directly, while heavy rain can make storm response and repairs more difficult.
Winter ice
Winter weather brings another set of problems. Ice can build up on trees and power lines, adding weight that can cause branches or equipment to fail. Dense tree cover can also contribute to outages during strong winds, even when conditions aren't severe. For more background, power outage causes explains some of the common problems that can leave homes without electricity.
Staying Safe During a Duquesne Light Outage
 Staying Safe During a Duquesne Light Outage Staying Safe During a Duquesne Light Outage
A power outage can create a few hazards around the house. Take extra care with electrical equipment, food storage, generators, and anything that may have been damaged during a storm.
  • Stay away from downed lines: Treat every fallen power line as live. Keep people and pets away and call 911 if you see one.
  • Keep the refrigerator closed: Opening the fridge and freezer less often helps keep food cold for longer.
  • Don't run a generator indoors: Never use a portable generator inside your home, basement, or attached garage. Carbon monoxide can build up quickly in enclosed spaces.
  • Use flashlights instead of candles when possible: Battery-powered lights reduce the risk of starting a fire during an outage.
  • Check your home before restoring equipment: If you notice damaged wiring, outlets, or electrical equipment after a storm, contact a qualified electrician before using it.
For another look at outage preparation, this SDG&E outage guide covers safety and planning steps that can also apply during other utility outages.
Checking the Duquesne Light outage map can help you see whether an outage has already been reported and track updates as crews respond. If your address isn't listed, report the outage directly so the utility has the latest information. Save 1-888-393-7000 in your phone before the next storm. Many outages are restored within a few hours, but widespread storm damage can keep some customers without power longer. For longer outages, the EcoFlow DELTA Pro Ultra X can provide whole-home backup, while the EcoFlow DELTA 3 Max can keep essential devices running when you don't need to power the entire house.
How do I report a Duquesne Light outage?
You can report an outage online, through the Duquesne Light mobile app, or by calling 1-888-393-7000. Have your service address or account number ready when you report it. This can help Duquesne Light identify the affected location more quickly.
What's the phone number for Duquesne Light outages?
The Duquesne Light outage number is 1-888-393-7000. The line is available 24 hours a day, seven days a week. You can use it to report an outage, a downed power line, or another problem with your electric service.
How often does the Duquesne Light outage map update?
The Duquesne Light outage map updates about every 15 minutes. Check it during an outage to see reported problems and the number of affected customers. The map may also show available restoration information as crews work.
What areas does Duquesne Light serve?
Duquesne Light serves Pittsburgh, Allegheny County, and much of southern Beaver County. Its service area covers homes and businesses throughout the Pittsburgh region. The utility's outage map can help you check problems in your area.
How long do Duquesne Light outages usually last?
Many outages are restored within a few hours after crews are dispatched. Storms that are severe can do more widespread damage and take longer to repair. Some customers may remain without power for a day or longer, especially when crews need to repair several damaged lines or pieces of equipment.
What should I do if I see a downed power line?
Keep clear of the line and all that it may touch. First, call 911 and keep people and pets away. Then report the downed line to Duquesne Light so the utility can send a crew and address the hazard.
Power Outages
