Alabama Power Outage Map Guide: How to Report and Stay Safe
- How to Check the Alabama Power Outage Map
- How to Report an Alabama Power Outage
- Backup Power While Waiting on Alabama Power
- Alabama Power's service area and common outage causes
- Thunderstorms and tornadoes
- Staying Safe During an Alabama Power Outage
- Conclusion
- FAQs
- How long do Alabama Power outages typically last during a hurricane?
Alabama Power serves more than 1.4 million customers across the state, so a major storm can affect a lot of households at once. During hurricane season or a severe thunderstorm, the fastest way to get useful information is to check the outage map and report your outage if it isn't already listed. This guide explains how to use the Alabama Power outage map, report an outage by phone or online, prepare for longer outages, and stay safe while crews work to restore service.
The Alabama Power outage map at outagemap.alabamapower.com shows reported outages across the utility's service area. Depending on the outage, you can see the affected area, number of customers without power, current status, and the cause when available. The map covers communities across the state, including Birmingham, Montgomery, Mobile, and Tuscaloosa. You can use it to see whether an outage is limited to your neighborhood or affecting a wider area.
The map reflects outages Alabama Power already knows about, so your address may not appear right away. If your power is out and you don't see your home listed, report the outage directly to the utility. For a regional comparison, this guide to Georgia Power outages shows how a neighboring utility handles outage information.
If your power is out, report it even if you see a nearby outage on the map. Your report gives Alabama Power another way to confirm the problem and identify the affected area. You have a few ways to report an outage, depending on what works best during the situation.
Report by phone
Call 1-800-888-2726 to report an Alabama Power outage or downed power line. The line is available 24 hours a day, seven days a week. Have your service address ready before you call. If you know when the power went out and whether nearby homes are also without electricity, have that information handy too. It can help the utility get a clearer picture of what is happening in your area.
Report online or through the app
You can also report an outage through the Alabama Power Outage Center or the company's mobile app. This can save you a wait on the phone when a storm has caused widespread outages. Before submitting the report, make sure you've selected the correct service address. If several homes nearby have lost power, reporting your outage can help Alabama Power confirm how far the problem extends.
If you see a downed power line
Treat every downed power line as live. Stay away from the line and anything it may be touching, including fences, trees, vehicles, and standing water. Call 911 immediately if you see a downed power line, then report it to Alabama Power at 1-800-888-2726 so crews can locate the damaged equipment.
Once the danger is reported, the main question becomes: How do you keep critical appliances and devices running until power is restored?
Alabama's Gulf Coast location makes the state vulnerable to hurricanes and tropical storm remnants. Severe thunderstorms and tornadoes can also cause outages elsewhere. A large storm can leave many households without power at once. Rural customers may have to wait longer for crews to reach their area. A charged portable power station can keep essentials such as a refrigerator, lights, phones, and Wi-Fi running while you wait. For longer outages, a whole-home battery can cover more circuits and appliances. The right option depends on how much power your household needs and how long the outage lasts.
If you only need backup for a few devices, a portable power station may be enough. The EcoFlow DELTA 3 Max can run a refrigerator, lights, phones, and other essential appliances during an outage.
Storms can damage Alabama's power system in several ways. Fallen trees, damaged lines, hurricanes, and tornadoes can all cause outages. Knowing the common causes can help you understand what to expect while crews restore power.
Alabama Power serves most of Alabama. Its customers include homes, businesses, and industrial facilities across cities, smaller communities, and rural areas. That wide service area means the cause of an outage can vary quite a bit from one region to another.
Hurricanes and tropical storms
Southern Alabama can see major outages when hurricanes or tropical storm remnants move inland from the Gulf. High winds can knock down trees, damage power lines, and affect electrical equipment across several communities at once. Storm surge and flooding can also cause dangerous conditions around damaged electrical equipment. Restoration may take longer when crews have to wait for roads to become accessible or work through widespread damage.
Severe thunderstorms can bring strong winds, lightning, and falling branches. A single storm cell may cause a local outage, while a larger line of storms can affect several counties. Tornadoes can bring down trees and power poles. They can also damage parts of the electrical system. If you're preparing for summer storms, this summer power outage guide covers practical steps to take before severe weather arrives.
Ice and winter weather
Ice storms can affect parts of Alabama during the colder months. Ice causes tree branches and power lines to sag, increasing the chance of damage from downed trees or branches. The type and location of storm damage can impact how quickly crews can restore service. A small outage caused by one damaged line may be repaired sooner than a widespread event involving multiple parts of the grid.
Power outages can create hazards beyond the loss of electricity. Downed lines, damaged wiring, spoiled food, generators, and candles all require extra care. Keep these steps in mind while your power is out:
Stay away from downed lines: Treat every fallen power line as live. Keep children and pets away, and call 911 if you see one.
Keep the refrigerator closed: Opening the fridge and freezer less often helps keep food cold for longer.
Don't run a generator indoors: Never use a portable generator inside your home, basement, or attached garage. Carbon monoxide can build up quickly in an enclosed space.
Use flashlights when possible: Battery-powered lights are a safer choice than candles during an outage.
Check damaged electrical equipment: If a storm damages wiring, outlets, or other electrical equipment, have it checked by a qualified electrician before using it.
Plan for well water: If your home depends on a well pump, having the right backup setup matters. This guide to well pump batteries explains how to think about the power requirements before an outage.
You may also want to consider the costs of a prolonged outage before choosing your backup setup. Understanding the financial impact of power outages can help you account for spoiled food, lost work time, and other unexpected expenses.
Check the Alabama Power outage map first to see whether your area has already been reported. If your home isn't listed, report the outage through the Outage Center, mobile app, or 1-800-888-2726. Save the number in your phone before the next storm hits. For Alabama households preparing for hurricane season or severe weather, backup power can keep essential appliances and communication devices running while crews work. The EcoFlow DELTA Pro Ultra X is built for whole-home backup, while the EcoFlow DELTA 3 Max is suited to essential loads and everyday outage needs.
How do I report an Alabama Power outage?
You can report an outage through the Alabama Power Outage Center, mobile app, or by calling 1-800-888-2726. Have your service address ready when you report the outage. If you see a downed power line, call 911 first and then report it to Alabama Power.
What's the phone number for Alabama Power outages?
The Alabama Power outage phone number is 1-800-888-2726. The line is available 24 hours a day, seven days a week for outage and downed-line reports. Save the number in your phone, so you don't have to search for it during a storm.
How many customers does Alabama Power serve?
Alabama Power serves more than 1.4 million customers across Alabama. Its service area includes urban, suburban, and rural communities throughout much of the state. That broad service area means outages can have very different causes depending on the location and weather conditions.
Restoration time can vary widely during a hurricane or major storm. Local damage may be repaired relatively quickly, while widespread damage to trees, poles, and power lines can take much longer. Rural areas may also face longer waits when crews are working across a large service area.
Does Alabama Power have a mobile app for outages?
Yes. You can use the Alabama Power mobile app to report an outage and access outage-related information. Reporting through the app can be useful when phone lines are busy during a widespread storm.
