Deep Cycle Battery for a Camper: What to Know
A deep cycle battery is what keeps a camper's lights, fridge, and water pump running between hookups. Unlike a starting battery, it's designed to provide steady power over longer periods and handle repeated discharge and recharge cycles. This guide covers common battery types and group sizes, how to match capacity to your appliances, and the maintenance habits that can help your battery last longer.
What Makes a Battery "Deep Cycle"
Deep cycle batteries are built for repeated discharge and recharge, making them a good fit for camper appliances that may run for hours at a time. They provide steady power for things like lights, refrigerators, and water pumps between hookups, rather than the quick burst needed to start an engine.
Built for repeated discharge
A starting battery delivers a strong burst of power to crank an engine. A deep cycle battery is designed to supply power over a longer period, then recharge and do it again. That difference matters in a camper. Your refrigerator, water pump, interior lights, and other equipment may draw power throughout the day. A battery designed for repeated cycling is built around that type of use. Deep cycle batteries can be discharged deeply and recharged repeatedly, with the exact usable capacity depending on the battery chemistry and setup. If you want a closer look at the construction and operating differences, what makes a deep cycle battery explains the basics in more detail.
Deep Cycle Battery Types and Group Sizes
Battery chemistry affects how much a battery weighs, how long it lasts, how it needs to be charged, and what it costs. Group size refers to the battery's physical dimensions and terminal layout, so both factors matter when choosing a battery for your camper.
Compare the common battery chemistries
You'll commonly see flooded lead-acid, AGM, and lithium batteries in RV and camper setups. Flooded lead-acid batteries are a familiar option and can work well in many campers, but they need more care than sealed options. AGM batteries are sealed and tend to be easier to maintain. Lithium batteries, including LiFePO4 models, have a much longer cycle life and are often chosen for frequent off-grid use. Typical cycle life is about 300 to 500 cycles for flooded lead-acid, 500 to 1,000 for AGM, and 2,000 to 5,000 or more for LiFePO4 lithium batteries. Charging also depends on battery chemistry. If you're comparing batteries for a camper, how to charge a deep cycle battery can help explain why the charging method needs to match the battery you're using.
Pick a group size that fits your setup
Group size gives you a starting point for comparing traditional camper batteries. The right size depends on your camper's available space and how much power you expect to use during your trips. A larger group size can provide more amp hours, but it also takes up more space and may add weight.
Group Size | Typical Amp Hours | Best For |
Group 24 | 70-85 Ah | Small RVs, pop-up campers, weekend trips |
Group 27 | 85-105 Ah | Medium-sized campers, moderate use |
Group 31 | 95-125 Ah | Larger RVs, extended trips |
These ranges are useful for comparison, but they don't tell you how long a battery will actually run your camper. Your appliances, daily usage, battery chemistry, and available charging all affect runtime. If you don't want to sort through battery sizes, chemistries, and separate charging components, an all-in-one power station offers another way to handle your camper's power needs.
Skipping the Battery Decision With a Power Station
Building a camper battery system means choosing the battery, charger, inverter, wiring, and other compatible components. A portable power station puts those pieces into one system, so you don't have to match each part yourself. That's useful for campers that need portable power for appliances, electronics, and other equipment without modifying the camper's existing electrical setup.
If you need less capacity or a lighter setup, the EcoFlow DELTA 3 Max offers a smaller 2,048Wh option while still providing enough output for many common camper appliances.
Whether you use a traditional battery or a portable power station, start with what your camper actually needs. Add up the power used by your main appliances and compare that with the capacity of the setup you're considering. This helps you avoid running short on power during the trip.
Sizing a Deep Cycle Battery to Camper Appliances
Battery size makes more sense once you know how much power your camper uses each day. Start with the appliances you actually run, then estimate how many hours each one operates. This gives you a clearer idea of how much battery capacity you'll need and helps prevent choosing a setup that's too small for your typical trips.
Add up daily watt-hours
Wattage tells you how much power an appliance draws while it's running. Watt-hours give you a better idea of how much energy it uses over time. For example, a 150W refrigerator running for eight hours would use about 1,200Wh. A 50W TV running for three hours would use about 150Wh. The same approach works for lights, fans, coffee makers, microwaves, and other equipment.
Appliance | Watts | Daily Energy (Wh) |
Refrigerator | 150W | ~1,200 (8 hrs/day) |
LED lighting | 10W/light | ~50 (5 hrs/day) |
Microwave | 1,000W | ~500 (30 min/day) |
TV | 50W | ~150 (3 hrs/day) |
Add the daily energy use together to get a rough starting point. Then account for the battery's usable capacity and the way you'll recharge it. For longer trips without hookups, RV battery options for dry camping can help you think through a setup for extended time off the grid.
Don't size the battery from wattage alone
A 1,000W microwave may have a higher power draw than a refrigerator, but you might run the microwave for only a few minutes at a time. The refrigerator may draw less power but operate for many hours. That's why looking at daily watt-hours gives you a more useful picture than comparing appliance wattages by themselves. You also need enough output capacity to handle appliances with higher starting or operating loads.
Maintenance Tips for Longer Battery Life
Regular battery checks can help catch small issues before they turn into a dead battery at camp. A few basic habits can also help extend battery life between replacements.
Store lead-acid and AGM batteries fully charged. This helps reduce sulfation when the battery sits unused for weeks or months.
Check the terminals before each trip. Look for corrosion, loose connections, or other visible issues that could affect the battery's performance.
Watch for unexpected battery drain. If the battery loses charge faster than usual, check why your battery drains to find a possible parasitic draw before your next trip.
Choosing a deep cycle battery for a camper starts with the power your appliances actually use. Group size and battery chemistry matter, but daily watt-hour consumption gives you a better starting point for deciding how much capacity you need. For occasional weekend trips, a smaller setup may cover the basics. If you spend more time boondocking, a higher-capacity lithium battery or portable power station can give you more energy between charging sessions. Check your appliances before buying and estimate their daily energy use. If you want to avoid matching a separate battery, charger, and inverter, the EcoFlow DELTA 3 Ultra Plus and EcoFlow DELTA 3 Max combine those functions in portable power systems.
What size deep cycle battery do I need for my camper?
Start by listing the appliances you use and estimating their daily watt-hour consumption. A small camper used for weekend trips may need less capacity than a larger RV running a refrigerator, microwave, lights, and other equipment for several days.
What is the difference between a deep cycle and starting battery?
A starting battery delivers a quick burst of power to crank an engine. A deep cycle battery supplies power for longer periods and handles repeated discharge and recharge cycles. That makes deep cycle batteries better suited to running camper appliances between hookups.
How long does a deep cycle RV battery last?
Battery life depends on the chemistry, how deeply you discharge it, how often you cycle it, and how well you maintain it. The supplied reference lists typical cycle ranges of 300 to 500 for flooded lead-acid, 500 to 1,000 for AGM, and 2,000 to 5,000 or more for LiFePO4 lithium batteries.
Can I use a marine battery in my camper?
Some marine batteries support both engine starting and deep cycle use, while others are mainly designed for starting. Check the battery's specifications, capacity, and charging requirements before using it in your camper. For a house battery, make sure its design matches the camper's everyday power needs.
Is lithium worth the extra cost for a deep cycle camper battery?
Lithium batteries generally offer a much longer cycle life than lead-acid and AGM batteries. Whether the higher upfront cost makes sense depends on how often you camp, how much power you use, and how long you expect to keep the battery.
