How to Keep Pipes From Freezing Without Heat: A Room-by-Room Plan for a Cold House
When your furnace stops working on a freezing night, keeping your home comfortable becomes difficult. But there is another problem to worry about: frozen water pipes. Pipes inside exterior walls, attics, crawl spaces, and garages can freeze when temperatures drop, potentially leading to costly leaks and water damage. Knowing how to keep pipes from freezing without heat can help you protect your plumbing during a winter power outage, furnace failure, or extended periods away from home. The right steps depend on how cold your house becomes, where your pipes are located, and how long the heating interruption lasts.
How Long Before Pipes Freeze Without Heat?
There is no exact countdown for when pipes will freeze in an unheated house. Outdoor temperature, insulation, drafts, pipe material, and the location of the plumbing all affect how quickly water freezes. Uninsulated pipes in exposed areas are particularly vulnerable. Research summarized in a Multnomah County fact sheet indicates that pipes in an unheated attic may begin freezing when outdoor temperatures reach 20°F or below. However, freezing can happen at higher temperatures when cold air reaches the pipes directly.
  • Attics and crawl spaces: These areas often have limited insulation, allowing cold temperatures to reach nearby water pipes and increase the risk of freezing.
  • Exterior walls: Pipes behind poorly insulated exterior walls are more exposed to cold outdoor air, especially during prolonged freezes.
  • Garages: Water lines running through unheated garages can freeze when temperatures drop significantly.
  • Air leaks: Gaps around pipe openings, foundations, windows, and doors allow cold drafts to reach plumbing.
  • Poor insulation: Homes that lose heat quickly may expose indoor pipes to freezing temperatures during extended cold spells.
Watch for frost on exposed pipes, reduced water flow, or a faucet that produces only a trickle, as these may indicate ice forming inside the line. During winter storms, understanding how long a power outage can last can help you prepare for extended periods without heating and take steps to protect vulnerable plumbing.
How to Keep Pipes From Freezing Without Heat: 7 Steps to Take Right Now
You do not need a working furnace or electricity to take several useful precautions. These measures do not create heat, but they can slow heat loss and reduce pressure inside vulnerable pipes.
Insulating exposed pipes beneath a kitchen sink to prevent freezingInsulating exposed pipes beneath a kitchen sink to prevent freezing
1. Let Vulnerable Faucets Drip
Open a faucet connected to an exposed or vulnerable water line and allow a slow drip. Moving water can make freezing less likely, while relieving pressure can reduce the risk of a pipe bursting. However, dripping water is not a guarantee against freezing. If the flow stops, leave the faucet open. This can help relieve pressure as the ice melts.
2. Open Cabinets Under Sinks
Open kitchen and bathroom cabinet doors, particularly those against exterior walls. This allows whatever warmth remains in the room to circulate around the plumbing. Move cleaning products, medications, and other potentially hazardous items out of reach of children and pets.
3. Keep Garage Doors Closed
If water lines run through your garage, keep the garage door shut as much as possible. This limits the amount of cold air reaching exposed pipes.
4. Concentrate the Remaining Indoor Warmth
Close off rooms that do not contain plumbing and keep doors open between the kitchen, bathrooms, laundry room, and other areas with water lines. This helps you concentrate the home's remaining warmth around vulnerable plumbing.
5. Wrap Exposed Pipes
Foam pipe sleeves are a good first choice because they slow heat loss without requiring electricity. If you do not have them, towels or blankets can provide temporary protection, although they are not a substitute for proper pipe insulation. Start with accessible pipes in attics, crawl spaces, garages, and utility areas.
6. Block Cold Drafts
Use towels or rags to temporarily block drafts around accessible pipe openings, gaps beneath doors, and other places where cold air enters. Avoid blocking required ventilation or combustion-air openings. Once the immediate emergency passes, seal these gaps properly to prevent the same problem next winter.
7. Locate Your Main Water Shutoff
Find your main shutoff valve before a pipe freezes or bursts. Knowing where it is can save valuable time if water starts leaking.
Losing heat during January can put both household members and plumbing at risk, which is why winter blackouts can be more dangerous than summer outages. The steps above can help slow heat loss when a furnace fails, but if a power outage shuts down your heating equipment, restoring electricity quickly becomes essential to keeping your home and pipes warm.
If the Heat Is Out Because the Power Is Out: Backup for Freeze-Related Loads With EcoFlow TITAN Classic and EcoFlow TITAN Plus
Sometimes the furnace itself is fine, but a power outage stops it from working. Gas furnaces still need electricity for components such as the blower, igniter, and controls. Heat pumps and electric furnaces may depend on 240V circuits. A properly configured home battery system may keep compatible equipment operating during an outage. However, the right solution depends on the heating equipment, its electrical requirements, and how long the outage lasts.
Check These Four Things First
  • Voltage: Check the equipment nameplate. A gas furnace commonly uses 115V or 120V, while many heat pumps and electric furnaces use 240V.
  • Running power: Use the nameplate's voltage and current ratings to estimate electrical demand.
  • Starting power: Motors can draw more power at startup. Ask an HVAC technician or electrician if the starting requirement is unclear.
  • Installation conditions: Use only manufacturer-approved heat cable, follow its installation instructions, and connect it to a GFCI-protected outlet where required. Keep the battery system in a suitable, dry location.
EcoFlow TITAN Classic: 120V Heat Cable and a Gas Furnace's Electrical Load
The EcoFlow TITAN Classic provides 4,000W of rated output for compatible 120V equipment, such as approved pipe heat cables or gas furnace electrical components. For example, an 18-foot, 126W heat cable could run for approximately 33.7 hours using 4,250Wh of usable energy, while a 955W furnace load could run for about 4.5 hours. Actual runtime varies with consumption, and the TITAN Classic cannot power 240V equipment.
EcoFlow TITAN 5000 Classic
• 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don't even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
EcoFlow TITAN Plus: Homes That Truly Depend on a 240V Heat Pump or Fixed Heating Circuit
Compatible plug-in appliances and heat cables can connect directly to the TITAN unit's appropriate output ports, provided they meet the unit's electrical specifications and are used according to the product instructions. The Smart Home Panel 10 (SHP10) is used to connect compatible equipment to selected household circuits; it is not required for every plug-in load. For fixed heating equipment connected to household wiring, use a compatible SHP10 configuration installed by a licensed electrician. Neither system guarantees freeze protection during prolonged outages, so check the expected runtime and consider additional precautions to protect vulnerable plumbing.
EcoFlow TITAN 5000 Plus
EcoFlow TITAN Classic supports compatible 120V freeze-protection loads, including plug-in heat cables, while TITAN Plus may suit homes with compatible 240V heating equipment. Compatible plug-in heat trace cables can connect directly to the appropriate TITAN output ports, provided their electrical requirements match the unit's specifications and the product instructions are followed. For fixed heaters or equipment connected to household circuits, use a compatible Smart Home Panel 10 (SHP10) configuration installed by a licensed electrician. Because a gas furnace still needs electricity to operate its blower and controls, confirm that your backup setup can support the furnace's electrical load. If an outage lasts longer than your battery can provide power, draining vulnerable plumbing may still be necessary to help prevent frozen pipes. For standalone-use and installation guidance, consult the official EcoFlow TITAN 5000 Classic product page.
Prevent Pipes From Freezing Without Heat Next Time: Insulation and Air Sealing
Temporary measures buy time, but insulation and air sealing offer longer-term protection. The goal is to slow heat loss around plumbing and prevent cold air from reaching exposed pipes. Start with the attic, basement, crawl space, and garage. Look for uninsulated water lines, gaps around pipe penetrations, and openings where outside air enters the building.
Prevent Pipes From Freezing Without Heat Next TimePrevent Pipes From Freezing Without Heat Next Time
Seal Gaps Near Pipes
Inspect your attic, basement, and crawl space for gaps around pipes, rim joists, and sill plates, then seal small cracks with suitable caulk and larger openings with appropriate spray foam, following product safety instructions. Before temperatures drop, preparing your house for freeze warnings can help you identify insulation weaknesses, protect vulnerable plumbing, and plan backup power while keeping sealing materials away from hot flues and other unsafe surfaces.
Pipe Insulation vs. Heat Cable
Pipe insulation slows heat loss without electricity, while heat cable uses power to help prevent pipes from freezing. Both can help protect plumbing, but heat cable requires extra safety precautions.
Feature
Foam Pipe Insulation
Heat Cable
Electricity
Not needed
Required
During outages
Still insulates pipes
Stops heating without backup power
Installation
Fit around pipes
Follow manufacturer instructions
Safety
Check for damage
Use a GFCI outlet; never overlap or cover unless permitted by the manufacturer
Maintenance
Check insulation condition
Inspect each season and replace damaged cable
Crawl Space and Garage Basics
Insulate exposed water supply lines in crawl spaces and garages, seal rim joists and pipe openings, and weatherstrip the garage door to keep cold air out. These steps also fit into preparing your home before a winter storm, along with checking emergency supplies and planning for power outages. If freezing conditions persist for days, insulation may not be enough, so know how to shut off your water and drain vulnerable pipes.
When to Shut Off the Main and Drain the Pipes
If the house will remain unheated during a prolonged hard freeze, shutting off the water and draining the plumbing may be the safest option. Empty pipes are less likely to burst because there is less water available to freeze and expand.
  1. Store water first: Fill clean containers with drinking water and set aside enough water for essential household needs before shutting off the supply.
  2. Shut off the main valve: Close the home's main water supply valve to stop incoming water.
  3. Open the faucets: Turn on hot and cold taps until the water stops flowing, and flush toilets to release water from the plumbing.
  4. Protect the water heater: Turn off its fuel or electrical supply according to the manufacturer's instructions before draining it. Never power an electric tank water heater while it is empty.
  5. Restore the system carefully: Close the faucets, reopen the main supply, and check for leaks as the pipes refill.
Well systems, hot-water boilers, and fire sprinkler systems may require special procedures, so consult a licensed plumber before draining unfamiliar equipment. Planning for water security during a power outage can also help you prepare for disruptions to your water supply. Draining a fire sprinkler system can disable fire protection, so never do so without qualified professional guidance.
If a Pipe Freezes Anyway: Safe Thawing and What to Do After a Burst
If a faucet produces only a trickle, ice may be blocking part of the pipe. Leave the faucet open and thaw the pipe slowly, beginning near the faucet and working toward the colder section. A hair dryer can be used on an accessible pipe if electricity is available and the area is dry. Never use an open flame, and never operate electrical appliances in standing water. If the frozen section is inaccessible or you cannot restore the flow safely, call a plumber.
What to Do if a Pipe Bursts
If a pipe bursts, shut off the main water supply, avoid wet electrical areas, contact a licensed plumber, and photograph the damage for insurance purposes. During winter emergencies, keep carbon monoxide alarms working and understand the hidden dangers of carbon monoxide before using backup equipment. Never use a gas range or unvented combustion appliance to heat your home, and always operate generators outdoors, away from doors and windows.
Pipes can freeze quickly in an unheated home, especially when outdoor temperatures fall to 20°F or below. Insulate exposed plumbing, seal drafts, open cabinets, and use dripping faucets to help reduce freezing risks. Before winter, locate your main water shutoff and learn when draining pipes may be necessary. If power outages interrupt your heating, consider EcoFlow TITAN Classic for compatible 120V loads or EcoFlow TITAN Plus for compatible 240V circuits, installed by a licensed electrician.
How long before pipes freeze without heat?
There is no fixed number of hours. Uninsulated attic pipes may begin freezing when outdoor temperatures reach 20°F or below, and drafts can increase the risk even when temperatures are higher.
Will dripping faucets keep pipes from freezing with no heat?
A slow drip can relieve pressure and reduce the risk of a burst, but it does not guarantee protection. Combine it with pipe insulation, open sink cabinets, and draft control.
At what indoor temperature should I set the thermostat when I'm away?
Michigan's MI Ready program recommends setting the thermostat no lower than 55°F to help prevent frozen pipes. If the heating system fails entirely, use other protective measures and consider shutting off and draining the plumbing when appropriate.
Should I drain my pipes if the power is out for days?
If the house will remain below freezing, shutting off the main and draining the plumbing can offer reliable protection. Store water first and follow the manufacturer's instructions for your water heater and any specialized systems.
Can a home battery keep my pipes from freezing during an outage?
A compatible battery system may power approved heat cables or suitable heating equipment, provided its voltage and output match the load. Runtime is limited by available energy, and no battery guarantees that pipes will not freeze.
Tips
