EcoFlow TITAN 5000 Classic vs. Jackery HomePower 3600 Plus: Which Is Better for Home Backup?
When the power goes out, the question is not simply whether you have a battery. It is whether that battery has enough capacity and output to keep your essential appliances running for as long as you need them. The EcoFlow TITAN 5000 Classic and Jackery HomePower 3600 Plus are both designed for home backup, but they approach that job differently. This comparison looks at capacity, output, charging, expandability, and home integration to help you decide which system makes more sense for your home.
Overview of the Two Home Backup Power Stations
Both models use LiFePO4 (LFP) batteries and accept additional battery storage. A home battery comparison should account for capacity, output, charging input, circuit integration, and how often the equipment needs to be moved. The TITAN 5000 Classic provides more base capacity and higher input limits, while the HomePower 3600 Plus has a lighter chassis with integrated wheels and a pull handle.
Built around a 5,017.6Wh (5kWh) LFP battery and a 4,000W continuous 120V AC inverter, the EcoFlow TITAN 5000 Classic is the 120V-only base model in EcoFlow’s TITAN lineup. Rather than prioritizing frequent road trips, this 102.5-pound stationary powerhouse focuses on reliable home backup, high-voltage solar intake (up to 3,200W), and automatic home circuit backup when paired with the compatible 120V Smart Home Panel 10. When paired with EcoFlow’s Smart Home Panel 10 (120V), it transitions from a plug-in emergency battery into an automated, AI-managed home energy hub.
1. 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, and lighting all at once. 2. 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. 3. <25 dB. Quiet enough for indoor use—quieter than a whisper.
The Jackery HomePower 3600 Plus combines a 3,584Wh LFP battery with a 3,600W continuous 120V inverter in a 77.16-pound chassis. Its built-in luggage-style wheels and telescoping handle make it easier to move from a hallway closet to the garage or the driveway where you park your RV. A single unit supplies 120V only.
EcoFlow TITAN 5000 Classic vs. Jackery HomePower 3600 Plus: Key Specifications Compared
Here’s how the two systems compare in capacity, output, charging, expandability, and other practical features.
Specification
Base Battery Capacity
3,584Wh (3.6kWh) LFP
Rated Continuous Output
4,000W (Single unit)
3,600W (Single unit) / 7,200W (Dual units)
Maximum Expandability
Up to 30kWh (Main unit + 5 × 5kWh batteries)
Up to 21kWh (1 unit + 5 batteries) / ~43kWh (Dual-unit max)
Output Voltage
120V AC single-phase only
120V AC (Single unit) / 120V & 240V (Dual units + Connector)
Max Solar Input
3,200W (1 MPPT, 30–250V, 16A)
1,000W (Dual DC8020 ports, 16–60V, 24A max)
Max AC Wall Charging
Up to 4,000W (high-amperage input)
~1,720W (15A standard wall outlet, ~2.5 hrs)
Backup Switchover Time
<10 ms standalone / ≤20 ms with Smart Home Panel 10
<10 ms standalone UPS / Manual toggle on Transfer Switch
Noise Level
<25 dB (rated) / <30 dB at 2,000W load
30dB in Quiet Mode / 50.3dB at full load
Unit Weight
102.5 lbs (46.5 kg)
77.16 lbs (35 kg) with built-in wheels & handle
5 Years
5 Years (3-year standard + 2-year extended registration)
EcoFlow TITAN 5000 ClassicEcoFlow TITAN 5000 Classic
Which System Provides Better Essential Home Backup Performance?
During an outage, battery capacity determines potential runtime, while output determines which loads can operate together. A backup power plan should also account for motor startup demand, expansion options, and whether 240V equipment must be supported.
Rated Output and Appliance Support
With 4,000W of continuous output, the TITAN 5000 Classic gives you an extra 400W of headroom over the Jackery HomePower 3600 Plus (3,600W). That margin matters during an outage on a busy morning when your refrigerator compressor kicks on while someone runs a 1,200W microwave and a 1,000W drip coffee maker. Both units can handle standard 120V household essentials—including gas furnace blowers, sump pumps, and routers—and each includes a 30A 120V NEMA TT-30R receptacle for RV or transfer-switch hookups.
Battery Capacity, Runtime, and Expandability
A home backup generator should be sized from the loads that must run and the required backup duration. Out of the box, EcoFlow gives you 40% more stored energy—5,017.6Wh compared with Jackery’s 3,584Wh. With an average 250W essential load (a full-size fridge, LED lights, and home internet), that means roughly 17 hours on a single TITAN 5000 Classic versus around 12 hours on a standalone HomePower 3600 Plus after accounting for inverter losses. Adding five extra batteries takes the TITAN to 30kWh, while five expansion packs bring the HomePower 3600 Plus to roughly 21.5kWh. During multi-day winter storms, when grid restoration may take 48 to 72 hours, EcoFlow’s 5kWh base unit can provide the same reserve with fewer extra batteries in your utility room.
120V and 240V Appliance Support
Neither power station produces 240V output by itself. For a backup plan centered on 120V circuits—standard wall outlets, lighting, a fridge, and a gas heating system—the TITAN 5000 Classic combines more output (4,000W) and more base storage (5kWh) in one unit.
Jackery’s route to 240V requires a second HomePower 3600 Plus and a Jackery Connector. Together, the two stations provide 7,200W at 120V/240V for equipment such as an electric well pump or dryer. That configuration also means purchasing two main power stations, finding twice the floor space, and managing the connecting cables. EcoFlow buyers who want native single-unit 240V can move up to the standard TITAN 5000 or TITAN 5000 Plus instead of the TITAN 5000 Classic reviewed here.
Which System Offers Better Charging and Solar Capability?
A solar battery used through a long outage must be evaluated for both stored capacity and realistic recharging. Both stations accept solar and AC charging, but their input ceilings, array compatibility, weather, and installed battery capacity affect recharge time.
Solar Input and Array Compatibility
The difference in solar input limits has a direct effect on how quickly each base battery can recharge:
  • EcoFlow TITAN 5000 Classic: The high-voltage MPPT input accepts up to 3,200W at 30–250V and 16A. Its wide voltage window supports rigid residential panels wired in series, allowing for thinner-gauge wire and minimal voltage drop. Under peak midday sun, the 5kWh base battery can recharge in roughly 1.8 hours.
  • Jackery HomePower 3600 Plus: Solar input tops out at 1,000W across two low-voltage DC ports. Each port is rated for 16–60V and 12A, which works well with portable solar panels on a patio or at a campsite. With two compatible 500W panels, Jackery lists a solar charging time of around six hours under its test conditions. Actual charging time varies with sunlight, panel position, temperature, and input power.
AC Charging Performance
Charging speed matters when a hurricane or blizzard is approaching and there is limited time to prepare. From a standard 120V/15A household outlet, the Jackery HomePower 3600 Plus draws up to 1,720W and takes about 2.5 hours to charge from zero to 100%. Meanwhile, the EcoFlow TITAN 5000 Classic accepts up to 4,000W through its Smart Home Panel 10 or a dedicated high-amperage feed. Despite its larger 5kWh battery, it can reach a full charge in under 1.5 hours with that higher-input setup.
Generator and Multi-Source Recharging
Both power stations can charge from a portable gas or dual-fuel inverter generator when extended winter cloud cover limits solar production. The Jackery’s 1,720W (15A) AC input ceiling works with most compact 2,000W–2,500W inverter generators. The TITAN 5000 Classic can also charge from a standard 120V generator outlet while adding pass-through power and simultaneous solar + AC charging. Those options can shorten generator runtime and reduce fuel use.
Which System Offers Better Home Integration and Energy Management?
Either station can power devices plugged directly into its outlets. A DIY home battery backup connected to hardwired household circuits requires approved transfer equipment and professional installation. The two brands then take different approaches to switchover, circuit control, and day-to-day energy management.
Home Circuit Integration and Backup Switching
  • EcoFlow TITAN 5000 Classic + Smart Home Panel 10 (120V): With EcoFlow’s Smart Home Panel 10, the TITAN 5000 Classic can support up to 10 individual 120V circuits connected to your home wiring. If grid power fails, the Smart Home Panel 10 transfers those circuits to battery power automatically within 20 milliseconds. A desktop PC can keep running without rebooting, Wi-Fi stays connected, and no trip to the garage is needed if the outage happens overnight or while you are away.
  • Jackery HomePower 3600 Plus + Manual Transfer Switch: Jackery’s optional 120V/30A Manual Transfer Switch (MTS) supports up to 6 essential circuits through a NEMA L5-30 inlet. It provides a code-compliant way to avoid back-feeding the grid, but it does not automate the transfer. During an outage, someone must go to the switch, connect the power station if it is not already plugged in, and move the rocker switches from “Line” to “Gen.”
Smart Energy Management and Outage Preparation
Beyond emergency outages, software determines whether your battery sits idle in a closet or helps lower your monthly utility bill.
The TITAN 5000 Classic uses OASIS 3.0 AI Mode to learn household consumption patterns and check three-day local solar forecasts. Through the EcoFlow App, users can also monitor the system in real time, adjust charging settings, schedule charging and discharging, and manage the use of available solar energy. In states with Time-of-Use (TOU) rates, including California, Texas, and parts of the Northeast, it can charge during lower-cost off-peak overnight hours and discharge during more expensive afternoon peak periods. Through SHP10, you can also prioritize essential circuits and automatically shed non-essential circuits as the battery level falls. Storm Mode monitors National Weather Service alerts and charges the battery to 100% ahead of severe weather, so your home is ready without you having to remember to plug in the system at the last minute.
Jackery’s mobile app also covers real-time monitoring, adjustable charging speeds, scheduled charge/discharge windows, and a Self-Powered Mode that prioritizes solar consumption. These are useful controls for a portable power station.
Which Should You Choose: EcoFlow TITAN 5000 Classic or Jackery HomePower 3600 Plus?
Start with how the system will be used. For home backup power, single-unit capacity, output, solar input, and circuit switching affect outage coverage. A lighter unit and built-in wheels become more relevant when the battery needs to move between locations. Compare each configuration with the actual loads, voltage requirements, and intended installation.
Choose EcoFlow TITAN 5000 Classic If You…
  • Need Higher Single-Unit 120V Backup Capacity and Output: One TITAN supplies 5,017.6Wh of storage and 4,000W continuously, giving overlapping kitchen and utility loads more room to run without adding a second main unit.
  • Want Greater Battery Expansion Potential: A single-controller system can grow to 30kWh, giving you more reserve for a multi-day outage without adding another main unit.
  • Need Higher Direct Solar Input Capacity: The TITAN accepts up to 3,200W at up to 250V, so a larger rigid array can restore more energy during a short window of usable daylight.
  • Want Smart 10-Circuit Home Integration: With the Smart Home Panel 10, as many as 10 circuits switch to battery power automatically in under 20ms with no transfer switch to flip by hand.
  • Prefer AI-Powered Energy Management and Automated Outage Preparation: Instead of pulling grid power at peak rates, OASIS 3.0 waits to charge during cheaper off-peak TOU windows to help lower your regular electric bill. You also get Storm Mode to top the battery up ahead of bad weather, plus automatic load shedding that cuts non-essential circuits as charge drops so your priority appliances keep running.
Choose Jackery HomePower 3600 Plus If You...
  • Prefer a Lighter Design with Built-In Wheels: The 77.16-lb Jackery has a telescoping handle and integrated wheels, which can make repositioning easier on suitable level surfaces. Stairs and uneven terrain may still require assistance.
  • Want Portable Backup for Both Home and RV Use: The compact unit has a built-in 30A outlet, so it can move from home backup to weekend camping, tailgating, or RV boondocking.
  • Prefer a Basic 30A Manual Home-Backup Setup: Jackery offers a compatible manual transfer switch for selected circuits. It requires the user to switch circuits between LINE and GEN during an outage rather than transferring them automatically.
The better choice depends on the required voltage, capacity, charging setup, circuit integration, and how often the unit needs to be moved. Jackery offers a lighter chassis with built-in wheels and an optional two-unit path to 240V. EcoFlow provides more base capacity, higher single-unit 120V output, greater listed solar input, expansion up to 30kWh, and optional automatic integration with Smart Home Panel 10. Compare both configurations against measured household loads and installation requirements before deciding.
Can You Use Either Power Station While It Is Charging?
Yes. Both models support pass-through charging, so solar panels or a wall outlet can recharge the battery while your connected appliances keep running. Keep in mind that when charging via a standard 120V wall outlet in UPS/bypass mode, maximum pass-through power is limited by the wall circuit’s amperage (for example, 1,440W on a standard 15A outlet for the Jackery).
Does Adding Extra Batteries Increase the EcoFlow TITAN 5000 Classic’s Output?
No. Adding TITAN 5kWh extra batteries only increases total energy storage capacity (runtime) up to 30kWh—the continuous AC output remains 4,000W. Think of extra batteries as adding a larger fuel tank rather than installing a bigger engine.
How Does the TITAN 5000 Classic's UPS Function Work?
When connected to grid power, the TITAN 5000 Classic provides uninterruptible power supply (UPS) functionality. If a power outage occurs, it automatically switches to battery power within 10 milliseconds, supplying compatible devices connected directly to its AC outlets. This fast switchover helps minimize power interruptions for essential electronics, such as computers, Wi-Fi routers, and other compatible 120V devices.
Are These Power Stations Suitable for Indoor Use?
Yes. Both units use non-toxic LiFePO4 battery chemistry, produce no carbon monoxide or exhaust fumes, and operate quietly indoors. Unlike gas generators, which must sit at least 20 feet away from windows and doors, either power station can be kept in a garage, basement, laundry room, or hallway closet as long as there is adequate airflow around the cooling vents.
Do You Need an Electrician to Connect These Systems to Your Home?
If you only plug appliances directly into the front outlets on either power station, no electrician is needed. However, if you want to connect the EcoFlow TITAN 5000 Classic to a Smart Home Panel 10 or wire the Jackery HomePower 3600 Plus into a 30A Manual Transfer Switch, hiring a licensed electrician is strongly recommended and is required by most local U.S. building codes to ensure a safe, code-compliant installation.
Home Backup
