What Is Solar Energy Storage and How Does It Work?
Solar panels have one obvious flaw: they only work while the sun's actually out. That's the whole problem solar energy storage exists to solve, and it's a direct answer to whether can you store solar energy is even possible in the first place.
It's what turns a system that generates power for a few hours a day into one that can actually run your home at night, during an outage, or whenever electricity costs the most.
A flexible portable power station like the EcoFlow DELTA Pro Ultra is one way to capture that excess and use it whenever you actually need it, no rooftop install required. This guide walks through the types of storage available, why it's worth having, what to weigh before choosing, and roughly what it costs.
Can Solar Energy be Stored?
Yes. Can solar energy be stored is one of those questions with a genuinely simple answer: your panels generate more electricity than you use during sunny hours, and that surplus gets captured in a battery instead of going to waste. Later, whether that's after sunset, during a blackout, or in the middle of an expensive rate window, you draw it back down.
How to Store Solar Energy
The short version of how to store solar energy: panels generate DC electricity, an inverter or charge controller routes the excess into a battery, and the battery holds onto it until you need it, at which point it gets converted back into power your outlets can actually use. Everything downstream of "capture the surplus" is really just a question of which storage technology does the holding.
What Are the Types of Solar Energy Storage?
Most homeowners only ever deal with one of these when it comes to solar energy storage. The rest exist, they're just not sitting in anyone's garage.
Battery storage
This is the one people actually mean when they say solar energy battery storage. It's also the default answer whenever someone asks about solar panel energy storage in general, since batteries are what actually make it to most rooftops.
A battery captures the excess electricity your panels generate and holds it for later, whether that's backup power during an outage, running an off-grid cabin, or simply making better use of the solar you're already producing instead of exporting it to the grid for a few cents.
Portable power stations are a genuinely flexible version of this. No electrician, no permits, no holes in your roof. They charge from solar panels or a wall outlet, plug straight into whatever needs power, and move with you if your needs change.
For higher-capacity, whole-home-oriented backup, the EcoFlow DELTA Pro Ultra is built to take on serious loads without blinking.
6,144Wh base capacity, expandable up to 90kWh, with 7,200W AC output for whole-home circuits and multi-day backup.
For a more mobile, mid-tier option, the EcoFlow DELTA Pro Portable Power Station covers a lot of ground without the size or price tag of a whole-home system.
3,600Wh capacity, expandable up to 25kWh, with 3,600W continuous output for a more mobile mid-tier setup.
Thermal energy storage
Thermal storage skips electricity entirely and stores solar energy as heat instead. Utility-scale concentrated solar plants do this with molten salt, heating it to several hundred degrees during the day and drawing on that stored heat to keep generating power well after sunset.
On a much smaller scale, solar water heaters do something similar, storing hot water for later use rather than storing electrons. It's a completely different category from what most people mean by home solar storage, and not something you'll find installed in a typical house.
Mechanical storage
Mechanical storage banks energy as physical motion or position rather than as a chemical charge. Pumped hydro pushes water uphill during surplus generation and lets it flow back down through turbines when power's needed.
Flywheels spin a rotor faster to store energy and slow it down to release it. Compressed air does the same trick with pressurized air in underground caverns.
These systems work at a grid scale, not a household one, and they're limited by geography, pumped hydro needs elevation and water access, more than by the technology itself.
Hydrogen storage
Hydrogen storage takes surplus solar power and uses it to split water into hydrogen and oxygen through electrolysis, then stores the hydrogen for later use, in a fuel cell, a turbine, or industrial processes. Its real advantage is duration: batteries are excellent for hours, but hydrogen can hold energy for weeks or months without the slow bleed-off batteries experience over time.
The tradeoff is efficiency. A meaningful chunk of the original energy is lost in the conversion process, which is part of why it's still mostly a research and utility-scale technology rather than something showing up in residential systems yet.
What Are the Benefits of Storing Solar Energy?
Good solar energy storage pays off in a few different ways, and not all of them show up on your electric bill right away:
  • Backup power during outages — your system keeps running when the grid doesn't
  • Energy independence — less reliance on the utility for your day-to-day electricity
  • Lower electric bills — using stored solar instead of buying grid power during expensive peak hours
  • A smaller carbon footprint — using more of the clean power you're already generating instead of sending it back to the grid
How Much Does Solar Energy Storage Cost?
Costs for solar energy storage vary a lot depending on capacity and setup, but as a general range, a full home battery system typically runs somewhere between $6,000 and $20,000 installed before any incentives, with cost scaling up alongside the amount of storage you add.
If you're still wondering whether can solar energy be stored without that kind of investment, a portable power station is a considerably smaller one and gets you flexible backup without an installation crew showing up at all.
One thing worth knowing if you've read older articles on this: the federal 30% Residential Clean Energy Credit that used to apply to home batteries expired for new systems at the end of 2025. It's genuinely gone for anyone installing in 2026 or later.
State and utility incentives haven't disappeared though, several states still offer meaningful battery rebates, so it's worth checking what's available locally before assuming you're paying full price. Either way, the ongoing savings from avoiding peak rates and outages tend to offset the upfront cost over time, just on a longer timeline than a couple of years ago.
Storage Type
Typical Installed Cost
Several hundred to a few thousand dollars, depending on capacity
Whole-home battery system
Roughly $6,000 to $20,000+, before any state or utility incentives
It's worth reading more about the pros and cons of solar panels if you're still deciding whether solar makes sense for your home, and this look at portable solar panels if you want a setup that doesn't involve your roof at all.
Can you store solar energy in a way that actually makes it useful around the clock? Yes, and that's really the whole point. Whether it's a full home battery system or a portable power station, solar energy battery storage is what turns solar panels from a daytime-only novelty into a genuine, round-the-clock power source. If you're leaning toward something flexible rather than a rooftop install, the EcoFlow DELTA Pro is worth a look.
What is the cheapest way to store solar energy?
A portable power station is generally the lowest-cost entry point into solar panel energy storage, since it skips professional installation entirely and scales with your budget far more easily than a whole-home battery system.
How long can solar energy be stored?
Battery storage typically holds a charge for days to weeks depending on the battery and how it's used, though most home systems are sized around daily cycles rather than long-term storage. Hydrogen storage, by contrast, can hold energy for months with far less loss over time.
How to store solar energy without batteries?
Thermal storage (storing heat rather than electricity) and mechanical storage (pumped hydro, flywheels, compressed air) are both non-battery answers to how to store solar energy, though they're mostly used at a utility or industrial scale rather than in a typical home.
What is the best type of storage for solar energy?
For most homeowners, battery storage, either a whole-home system or a portable power station, is the practical answer. Thermal, mechanical, and hydrogen storage all have real applications, but they're built for grid-scale or specialized use, not a house with solar panels on the roof.
Portable Power Stations
