What is a Small Photovoltaic Panel?
Small photovoltaic panels convert sunlight into electrical energy, giving you a convenient way to utilize the sun's energy in your life. Unlike the enormous panels on top of houses, though, these small devices—from a few watts to 200 watts—are not heavy and are easy to carry around. People use them for anything: charging mobile phones, powering camps, running back-up systems for sensitive devices in case of power failures, or messing around with hobby projects. As more individuals look for clean energy sources, these small panels offer a convenient way to tap into solar power wherever you are.
What Makes a Photovoltaic Panel "Small"?
You might wonder just what makes these solar panels 'small' compared to what you observe on rooftops.
The definition of "small" for PV panels is not so much a definition as an indication of their electricity output size as opposed to physical size. Small panels will generate 1 to 200 watts of power. The lower end (1-20 watts) is ideal for powering phones and tablets, whereas panels generating 50-200 watts can power small appliances or lights.
They exist in different sizes: pocket units may be only 6×9 inches when unfolded, medium portable panels are between 12×18 and 24×36 inches, and the largest "small" panels are approximately 3×5 feet. They also have varying designs—some fold book-style, others roll up, and most have rigid composition based on what they are used for.
Solar-powered camping setup with tentSolar-powered camping setup with tent
Key Characteristics of Small Photovoltaic Panels
Beyond their size and power output, these compact solar solutions have several features that set them apart.
1-20 Pound Weight for Easy Transport
Miniature PV panels typically weigh 1 to 20 pounds and are sufficiently lightweight to be relocated and set into position. They are most often made with foldable or roll-up structures that can be accommodated in a few percent of their spread area space. This mobility allows you to follow the sun throughout the day or stow the panels in seconds in inclement weather.
1-200 Watt Power Generation
They output just 1-200 watts, as opposed to the 250-400 watts of standard residential panels even in ideal conditions. This reduced output makes them adequate for charging devices, powering LED lamps, or topping up small battery banks—but not for energy-hungry appliances like refrigerators and air conditioners.
Multiple Mounting and Connection Options
Small solar panels come with a variety of mounting options including built-in stands, hanging loops, and magnetic bases for simple placement. Connection types range from direct USB to standard MC4 connectors so that they can be used individually or wired up in small groups together to increase power output when needed.
$30-300 Price Range with Higher Per-Watt Cost
You can purchase a decent small solar photovoltaic panel for less than a full system installation—typically $30-80 for a 10-watt panel or $100-300 for a 100-watt panel. This low-barrier entry cost makes solar technology affordable to consumers, though the cost per watt (about $3-5/watt) is still higher than big systems ($0.50-1.00/watt).
Common Applications of Small Photovoltaic Panels
So what can you actually do with these portable power generators? Quite a lot, as it turns out.
Charging Smartphones, Tablets, and USB Devices
Portable photovoltaic panels are ideal for charging personal gadgets in areas inaccessible to power sources. You can charge smartphones, GPS, headlamps, and Bluetooth speakers directly with a 5-20 watt panel using built-in USB ports. On cloudy days or nighttime use, pair your panel with a power bank—charge the power bank during the day, and it will charge your devices at any time. Various panels have multiple USB outputs like USB-C for fast charging supported devices.
Powering Camping and Outdoor Adventures
Small PV panels are relied upon by outdoor enthusiasts to bring length and convenience to outings. LED light strip lighting in campsites or in tents burns for hours on a 15-30 watt panel. Higher-powered 50-100 watt models power portable fans, mini coolers, and camping devices. Motor boaters and RV owners install semi-permanent panels (60-200 watts) to charge battery systems utilized for powering navigation aids, water pumps, and entertainment units without engine or generator operation.
Providing Emergency Backup Power
During power outages, miniature photovoltaic panels provide essential backup power. A basic 30-50 watt panel connected to a battery pack can power critical communications—powering enough to keep phones powered and operating emergency radios. Large setups (100-200 watts) will drive medical equipment, miniature medical refrigerators for meds, and essential lighting. Solar panels operate quietly, burn no fuel, and can operate safely indoors, unlike gas generators, so are also valuable additions to round out emergency kits.
Enabling Educational Projects and DIY Systems
Small panels are excellent teaching aids and components of art projects. 1-5 watt panels find their applications in school-level science classes to demonstrate energy conversion and circuit theories. Hobbyists incorporate 10-30 watt panels into automated gardening systems to power microcontrollers, water pumps, and sensors. Robotics enthusiasts use such panels to create self-sustaining machines that can power forever under right circumstances. Their affordability makes them suitable for experimenting without significant initial investment.
Supporting Minimal Off-Grid Structures
Small cabinas, garden sheds, and small houses benefit from modest solar setups. A 100-200 watt panel system will supply basic LED lighting, charging equipment, and occasionally small appliances in low-energy buildings. The panels will typically supply a charge controller and battery system for storing energy. Short of supplying traditional household use, they are an invaluable degree of independence for simple living quarters and workshops where the installation of utility lines would be too expensive or even impossible.
Benefits of Using Small Photovoltaic Panels
These everyday uses highlight why more people are turning to portable solar power for their energy needs.
Environmentally Friendly Power Source
Small photovoltaic panels harness clean solar energy without producing emissions, noise, or waste during operation. Unlike disposable batteries or fossil fuel generators, they create no pollution while providing usable electricity. This renewable approach reduces your environmental impact without requiring the substantial space and installation commitments of full-sized solar systems.
Power Independence When You Need It
When traditional power sources are unavailable or impractical, small PV panels provide valuable autonomy. They work anywhere with sunlight, whether you're miles from the nearest outlet or experiencing a local power outage. This independence is particularly valuable in emergency situations when maintaining communication devices and basic lighting becomes essential
Cost Savings for Specific Applications
For recurring power needs like garden lights, trail cameras, or outdoor sensors, small photovoltaic panels eliminate the ongoing expense of disposable batteries. While the initial investment is higher, most panels recover their cost within 1-2 years of regular use and continue functioning for 10+ years. This long-term value makes them economically sensible for specific, low-power applications.
Accessible Renewable Energy
Small photovoltaic panels offer perhaps the simplest entry point into renewable energy. Their plug-and-play operation requires minimal technical knowledge, making solar power accessible to anyone interested in cleaner energy alternatives. This simplicity lets you incorporate sustainable practices into your daily life with virtually no learning curve.
Portable solar panel and power stationPortable solar panel and power station
Factors to Consider When Using Small Photovoltaic Panels
With the right panel and setup for your needs, you'll be harnessing the sun's power wherever life takes you.
Match Power Output to Your Device Requirements
Before purchasing a small photovoltaic panel, calculate the power needs of the devices you plan to charge. Most smartphones require 5-10 watts for efficient charging, while tablets and laptops need 15-45 watts. Check your device's power specifications (typically listed as watts or volts and amps) and select a panel that meets or exceeds these requirements.
A panel's rated output represents ideal conditions. In real-world use, expect 50-70% of the rated capacity due to factors like cloud cover, panel angle, and time of day. For charging multiple devices or using a panel in less-than-ideal conditions, choose a model with 1.5-2 times your minimum power requirements.
Position Panels for Maximum Sun Exposure
Panel placement significantly affects performance. In the Northern Hemisphere, face panels south; in the Southern Hemisphere, face them north. The optimal tilt angle approximately equals your latitude in degrees. During winter months, add 15° to this angle; during summer, subtract 15°.
Avoid even partial shading whenever possible. A small shadow covering just 10% of a panel can reduce output by up to 50% due to how cells connect within the panel. Position panels away from trees, buildings, and other potential shade sources, especially during peak sun hours (typically 10 AM to 2 PM).
Consider Essential Accessories
Small photovoltaic setups often require additional components:
  • Charge Controllers: Required when connecting panels directly to batteries to prevent overcharging. Look for PWM (Pulse Width Modulation) controllers for basic setups or MPPT (Maximum Power Point Tracking) controllers for more efficient power conversion.
  • Batteries: For storing solar energy. Lithium-ion batteries offer better efficiency and longevity than lead-acid alternatives but cost more initially. Match battery capacity (measured in amp-hours or watt-hours) to your expected usage between charging opportunities.
  • Inverters: Necessary if you need AC power for devices with standard plugs. Small inverters (100-300 watts) convert the panel's DC output to household AC but introduce 10-20% power loss during conversion.
Select Appropriate Durability Features
Different environments demand different panel constructions:
For backpacking and frequent transport, flexible, foldable panels with reinforced connection points withstand repeated handling better than rigid alternatives.
For marine applications, look for panels with sealed junction boxes and corrosion-resistant materials that can withstand salt spray.
For permanent outdoor installation, rigid panels with tempered glass and aluminum frames offer better longevity and weather resistance.
For extreme temperatures, check the panel's operating temperature range—most perform optimally between 59-95°F (15-35°C) but continue functioning outside this range with reduced efficiency.
Proper maintenance extends panel life regardless of construction. Keep surfaces clean using soft cloths and mild soap, avoid storing panels in high-heat environments, and inspect connection points regularly for corrosion or damage.
Power Your Life with Small Solar Panels!
Small photovoltaic panels bring solar energy into everyday life without the complexity of full installations. Ranging from 1-200 watts, these compact devices offer handy power solutions whether charging a phone in the field, creating backup power during outages, or powering a small off-grid structure. Their portability, affordability, and simplicity of installation bring renewable energy to anyone.
