Electric Heater for Garage: Types, Sizes, and How to Choose
A garage can become difficult to use long before winter reaches its coldest point. Tools feel icy, stored materials may not tolerate the temperature, and a workout or repair becomes less appealing after the concrete and metal surfaces have been cold all night. An electric garage heater can make the space more workable without adding a fuel-burning appliance.
The best electric heater for garage use depends on what you need to warm. Warming one workbench is different from holding a two-car garage at a steady temperature. Floor area matters, but so do ceiling height, insulation, climate, and the available electrical service. This guide covers heater types, sizing, installation, operating costs, and safety.
What Types of Electric Garage Heaters Are Available?
Electric garage heaters range from small plug-in units to permanently mounted equipment on a dedicated circuit. The basic difference is not simply how much heat they produce. Some warm a person or work area directly, while others circulate heated air through the room. Choosing the format first can prevent paying for a whole-garage solution when spot heat would be enough.
Portable Electric Space Heaters
A portable electric space heater for garage use makes sense when most of your time is spent at one workbench, exercise station, or repair area. It can be placed near the occupied zone, plugged into a suitable wall outlet, and stored after winter. For occasional use, that flexibility may be more valuable than heating every cubic foot of the garage.
Its limits should be clear. A portable unit can take the edge off a cold corner, but it will not make an uninsulated two-car garage feel like a finished room during severe weather. Cold walls, vehicles, tools, and concrete continue absorbing warmth even after the nearby air feels comfortable.
Placement matters as much as output. Set the unit on a stable, level surface where a cord will not cross a walking path. Plug it directly into an appropriate wall outlet rather than an extension cord or power strip, and keep it away from gasoline, solvents, cardboard, sawdust, rags, and other materials commonly stored in garages.
Wall-Mounted Electric Garage Heaters
Wall-mounted heaters keep the floor clear in garages crowded with vehicles, cabinets, yard equipment, and storage. A fixed location also makes the heater less likely to be moved beside combustible materials.
Many models use a fan to send heated air toward the occupied part of the garage. An adjustable bracket can help direct that airflow toward a work area rather than the garage door or an empty corner. Before choosing the location, consider shelving, vehicle clearance, the swing of doors, and whether stored items might later block the intake or outlet.
Some wall-mounted units plug into a receptacle, while higher-output equipment may require permanent wiring. The mounting surface must support the heater and preserve the required clearance. An open patch of wall is not suitable if it leaves the unit exposed to water, impact, or flammable-liquid storage.
Ceiling-Mounted and Hardwired Garage Heaters
Ceiling-mounted fan-forced heaters are commonly used for larger garages. Installed near the joists, they preserve wall and floor space and direct warm air into the occupied zone instead of allowing it to remain near the ceiling.
Location still affects performance. A heater aimed across an open section has a clearer air path than one blowing into a cabinet, vehicle lift, or storage rack. It must also remain accessible for cleaning and service.
High-output ceiling units usually operate on 240V and are connected to a dedicated circuit. That work belongs in the installation budget from the beginning. An electrician should verify panel capacity, conductor size, breaker requirements, disconnect provisions, and the heater’s instructions rather than adapting the unit to whatever circuit happens to be nearby.
What Size Electric Heater Do You Need for Your Garage?
Heater size is expressed in watts or BTUs per hour. Floor area provides a useful first estimate, but a garage with an insulated door and finished walls loses heat very differently from a metal-sided structure with open studs.
Decide what temperature you need before sizing the equipment. Keeping a work area in the low 50s is a different assignment from maintaining living-room comfort on the coldest night.
Calculate Heating Needs by Garage Size
For the examples below, assume about 10 watts per square foot, or roughly 34 BTU/h per square foot, for a reasonably insulated garage with an ordinary ceiling height in moderate winter conditions. This is a starting estimate for comparing heater sizes.
Use this formula to convert watts to BTU per hour:
Watts × 3.412 = BTUs per hour
The table applies that assumption to the example garage dimensions below for a preliminary estimate:
Garage Size | Approximate Dimensions | Floor Area (Sq. Ft.) | Recommended Wattage | Required Heat Output (BTUs) | Typical Circuit Voltage |
1-Car | 12' × 20' to 14' × 22' | 240 – 300 sq. ft. | 2,500W – 3,000W | 8,500 – 10,200 BTU | 120V / 240V |
2-Car | 20' × 20' to 24' × 24' | 400 – 576 sq. ft. | 4,000W – 5,600W | 13,600 – 19,000 BTU | 240V (Dedicated) |
3-Car | 30' × 20' to 36' × 24' | 600 – 850 sq. ft. | 6,000W – 8,500W | 20,500 – 29,000 BTU | 240V (Dedicated) |
Workshop / 4-Car | 32' × 30' or larger | 900+ sq. ft. | 9,000W – 10,000W+ | 30,000+ BTU | Dual 240V or Multi-Unit |
These are planning ranges, not promises of a particular temperature. Air leakage, high ceilings, and open connections to other spaces can make square footage understate the load. Where dependable freeze protection or steady comfort matters, a professional heat-loss calculation is better than guesswork.
Adjust for Insulation, Ceiling Height, and Climate
Three conditions can move a garage well outside the basic sizing range:
Ceiling Height: The estimate assumes an 8-foot ceiling. A garage with a 10-foot or 12-foot ceiling contains more air and provides more overhead surface through which heat can be lost. Account for heat loss through the walls and ceiling and for drafts around tall doors before choosing the heater output.
Insulation Quality: Finished walls, insulated doors, and effective weatherstripping slow heat loss. Exposed framing, thin metal doors, single-pane windows, and gaps at the sill can have the opposite effect. A poorly insulated garage needs more heat to maintain the same indoor temperature under the same outdoor conditions.
Geographic Climate: A heater maintaining 55°F during a relatively mild Pacific Northwest winter faces a much lighter load than one operating through sustained sub-zero weather in Minnesota, Michigan, or Upstate New York.
Sun, wind, exterior-wall exposure, and door use also influence performance. A large door that opens frequently releases heated air quickly, making fast recovery or direct radiant heat more useful.
How Do You Choose the Right Electric Heater for Your Garage?
Once the output is reasonably clear, match it to the electrical system and the way the garage is used. Buying the heater before checking voltage, circuit capacity, controls, and installation cost can turn an apparent bargain into an expensive project.
Choose Between 120V and 240V Electric Garage Heaters
A portable 120V electric heater for garage use commonly tops out at 1,500 W (about 5,100 BTU/h). That output is useful for an occupied corner, a small enclosed shop, or short periods at a workbench. It is generally spot heat rather than a whole-garage solution.
Larger 240V heaters commonly fall between 3,000 W and 10,000 W or more. They are better suited to whole-garage heating and are generally fixed in place on a dedicated branch circuit.
Voltage is not a quality rating. The useful question is whether the heater can meet the load without running continuously or overheating one area while the rest remains cold.
Check Electrical Circuit Capacity and Installation Requirements
Read the heater’s nameplate and installation instructions before assuming that an existing circuit can support it. A 5,000W heater operating on 240V draws approximately 20.83 amps:
5,000W ÷ 240V = 20.83A
Fixed electric space heating is generally treated as a continuous load for branch-circuit sizing. This example uses the common 125% sizing factor:
20.83A × 1.25 = 26.04A
A dedicated 30 A circuit with 10 AWG copper conductors may be appropriate for this example. A licensed electrician should confirm the conductor, breaker, disconnect, and connection method using the heater’s listing and nameplate, terminal ratings, wiring method, and locally adopted code.
Panel capacity matters too. A garage may already serve an electric vehicle charger, air compressor, welder, freezer, or large power tools. A licensed electrician can determine whether the service and panel have room for the new continuous load and whether the intended heater location requires additional protection.
Compare Energy Efficiency and Operating Costs
Electric resistance heaters convert nearly all their electrical input into heat at the point of use. Two units drawing the same wattage consume the same electricity while running, but one may direct heat more effectively toward the occupied area.
Fan-forced heaters: These units warm the air and circulate it through the garage. They are generally better for bringing the overall room toward a more even temperature, provided shelves and vehicles do not block the airflow.
Infrared heaters: Radiant heat warms people, tools, vehicles, and other surfaces in its path. It can be effective for a work zone or a garage door that opens often because comfort does not depend entirely on heating all the room air first.
The heater’s wattage, actual runtime, and thermostat cycling determine how much electricity a space heater uses. To estimate operating cost, divide the heater’s wattage by 1,000, multiply by the hours it runs, and then multiply by the local electricity rate per kilowatt-hour. Thermostat cycling means actual consumption may be lower than continuous nameplate use, but poor insulation and frequent door openings can keep the heater running much longer than expected.
Look for Adjustable Thermostats and Essential Safety Features
An adjustable thermostat lets the heater cycle after the garage reaches the selected temperature. A remote thermostat may read the room more accurately than a sensor beside the heating element.
For a portable heater, look for tip-over protection, automatic overheat shutoff, and a safety certification mark from a nationally recognized testing laboratory. A sturdy base is another practical advantage in a working garage.
Permanent heaters should be listed for the intended installation and mounted according to their instructions. Dust, vehicle movement, water exposure, overhead storage, and flammable products all affect where a unit can be used safely. A safety feature does not make poor placement acceptable.
How Do You Use an Electric Garage Heater Safely and Efficiently?
Garages combine electrical equipment with fuel containers, solvents, sawdust, stored paper, wet floors, and moving vehicles. Heater safety therefore depends on housekeeping and placement as much as built-in controls.
Heat escaping around the door or through an unfinished ceiling must be replaced continuously. Correcting the largest leaks can improve comfort without increasing wattage.
If a permanently wired garage heater is part of your outage plan, have an electrician confirm whether a home battery can support that circuit alongside other essential loads.
Maintain Proper Clearance Around the Heater
Keep the front, back, and sides of a portable heater at least 3 feet from combustible materials such as cardboard boxes, paper, plastic bins, rags, clothing, lumber, and upholstered items. Do not use the grille to dry gloves or a damp shop towel, and do not place the heater where it can be struck by a door, vehicle, rolling cart, or falling tool.
Portable electric heaters should be plugged directly into a suitable wall outlet, not an extension cord or power strip. Stop using the heater if the plug, cord, or outlet becomes hot, fits loosely, shows discoloration, or gives off an electrical odor. Turn the heater off when the garage is unattended.
Ceiling and wall units need the clearance specified for that exact model. Overhead racks, vehicle antennas, lumber, and seasonal storage can end up closer to a heater than expected after the garage is reorganized. Check the area periodically rather than treating the original installation as permanent proof that the clearance remains adequate.
Seal Air Leaks and Improve Garage Insulation
Begin with the garage door because it combines a large surface area with several potential leak points. Replace a cracked bottom seal, adjust weatherstripping at the sides and top, and check whether daylight is visible when the door is closed. An insulation kit may help a thin door, but it should be compatible with the door and should not interfere with its balance or operation. Side doors, windows, wall penetrations, and the joint between framing and the concrete floor can admit cold air as well.
Seal appropriate gaps with materials intended for the location. If the garage shares a wall or ceiling with the house, preserve the required fire separation and avoid cutting or filling assemblies without understanding how they were constructed.
Insulation does more than reduce heater run time. Warmer interior surfaces make the garage feel more comfortable at a lower air temperature. Address water leaks and moisture problems before closing wall or ceiling cavities so damp material is not hidden behind a finished surface.
Set the Thermostat for Comfortable and Efficient Heating
A lower garage setpoint reduces the temperature difference between indoors and outdoors. While working in the garage, you might start at 50°F to 55°F and adjust for your activity level and comfort.
Use an unoccupied setback only with a fixed heater whose instructions allow that mode of operation. Turn off portable heaters whenever you leave the garage. Leave time for the space to warm up before starting a project. On a fixed-output heater, a higher setpoint extends the heating cycle without increasing its heat output. If an outage stops the heater, a portable power station can keep a work light on while you check exposed pipes for drafts.
A steady setpoint on a suitable fixed heater can help protect exposed plumbing. To help keep pipes from freezing without heat, wrap exposed water pipes with foam pipe insulation and seal cold drafts around them. One corner can fall below freezing even when the thermostat elsewhere reads above freezing.
Use Backup Power Safely During Outages
When a garage also functions as a workshop, gym, or utility area, a winter outage can interrupt more than a hobby. Falling temperatures may threaten exposed plumbing or temperature-sensitive materials. Electric heaters do not produce carbon monoxide at the point of use, and a compatible battery power station can provide temporary, quiet power without operating a fuel-burning engine in the garage. For smaller, compatible 120V electric space heaters, a system like the EcoFlow DELTA 3800 Gen4 Portable Power Station offers 3,763Wh of battery capacity and a 3,600W output, acting as a dependable temporary power reserve for critical spot warmth.
If you need to keep a high-draw, compatible 240V garage heater running, the EcoFlow TITAN 5000 supports dual 120V/240V output with 5kWh of base capacity and up to 7.2kW of battery output, handling demanding backup requirements with ease. Its storage capacity can also be expanded to 30kWh by adding up to five extra batteries. Prior to connecting any heating unit, always verify that the heater’s rated wattage and wiring specs match your power station’s thresholds, consult a certified electrician to ensure code-compliant setup, and keep exposed water pipes wrapped in foam insulation to minimize the risk of freezing.
An electric garage heater can make winter repairs, workouts, and routine storage tasks far more manageable. Start with the way the garage will be used: a portable unit may be enough for one occupied corner, while a larger space may justify a wall- or ceiling-mounted 240V heater. Then compare the output with the room’s size, ceiling height, insulation, climate, and door-opening pattern.
Do not separate heater selection from the electrical plan. Confirm circuit and panel capacity before purchasing high-output equipment, follow the listed clearance requirements, and keep combustible or flammable materials away from the heater. Weatherstripping and insulation can often improve comfort as much as additional wattage. With those details addressed, the heater can deliver useful warmth without creating avoidable installation costs or safety problems.
What Is the Most Efficient Electric Heater for a Garage?
Infrared radiant heaters are the most efficient option for spot-heating specific task areas, while fan-forced 240V convection heaters provide the best whole-room efficiency in well-insulated garages. Because all electric heaters convert close to 100% of their electricity into heat, overall operating efficiency depends heavily on keeping the room properly insulated and setting an accurate thermostat.
Is It Better to Oversize a Garage Heater?
No, a heater sized for the garage’s heat loss is usually the better choice. An oversized unit can reach the thermostat setpoint quickly and cycle more often. Consider the garage’s insulation, air leakage, ceiling height, and outdoor design temperature along with the heater’s controls.
Is It Cheaper to Run a Gas or Electric Garage Heater?
Natural gas heaters generally cost less per hour of continuous operation in regions with high residential electricity rates. However, electric heaters are far cheaper to purchase upfront, require no ventilation flues or gas line plumbing, eliminate the danger of indoor carbon monoxide leaks, and require virtually zero ongoing burner maintenance.
How Much Does It Cost to Run a 1500 Watt Heater 24 Hours a Day?
At full power, a 1,500 W heater running for 24 hours would use 36 kWh. At an example rate of $0.18 per kWh, that works out to $6.48. Since residential electricity rates vary by state, use your own rate and the hours the element actually runs to estimate cost. The 24-hour example is for calculation. Turn off portable heaters when you leave the garage.
What Is the Average Cost to Install a Garage Heater?
Installing a hardwired 240V electric garage heater may cost around $300 to $800 in electrical labor and materials for a straightforward installation, assuming the existing panel has sufficient capacity and an available breaker space. Costs can rise to $1,000 to $1,800 or more if the project requires additional electrical work, such as installing a subpanel or running a longer conduit route through the attic. Actual costs vary by location, wiring distance, panel condition, and permit requirements.
