Are Infrared Heaters Safe? Clearance, Outlets, and Supervision Explained
Are infrared heaters safe? Used the right way, they can be. An electric infrared heater doesn't burn fuel, so it doesn't make carbon monoxide, but it still gets hot enough to start a fire. The Consumer Product Safety Commission's 2026 winter tips say to keep portable heaters at least three feet from anything that can burn. They also say to plug electric space heaters directly into a wall outlet, never a power strip. Below, we cover how infrared heat works, CPSC and U.S. Fire Administration rules, heater failures, and how to keep lights and phones on.
Electric infrared heaters are safe when you follow the manual and basic fire rules. They warm people and objects directly, and the main risks are fire and burns, not fumes. That sets them apart from fuel-burning heaters, which need venting and can give off carbon monoxide.
How Infrared Heat Works
Think about standing in the sun on a cold winter day. The air is still chilly, but your face and hands feel warm. An infrared space heater works the same way. It sends out heat that warms the people, furniture, and floor in front of it, instead of heating all the air in the room first.
That's why an infrared heater can warm a small area fast. It's also why the space in front of it matters. Anything close to the hot element soaks up that heat, whether it's your legs or a couch cushion.
If the word "radiation" worries you, some context helps. The CDC lists infrared as non-ionizing radiation, the same broad group as visible light and radio waves. This kind of radiation doesn't have enough energy to remove electrons from atoms. The Health Physics Society's expert answer says these heaters are safe for people to use with normal care. It names burns, fires, and eye damage from staring at the heater for long periods as the real concerns.
Infrared vs. Fuel-Burning Heaters
Not every space heater carries the same risks. When people ask whether a heater is safe, the first thing to sort out is how it makes heat. An electric infrared model turns electricity into heat, while a kerosene or propane heater burns fuel to make it.
The fuel type alone doesn't tell you whether a heater can go indoors. Some fuel heaters are meant for outdoor use only, so read the label and manual first. For a kerosene heater, EPA's winter indoor air tips say to check with your local fire department that it's legal in your area. EPA also says to follow the maker's instructions and increase ventilation. And it warns never to run a gas-burning heater in a poorly vented or closed room, or where you're sleeping.
Question
Fuel-burning portable heater
Indoor use
Indoor-rated electric models only
Only if the model is labeled for indoor use, local rules allow it, and required ventilation is provided
Can make carbon monoxide?
No
Yes
Refueling?
None needed
Turn it off and let it cool first, per CPSC
Main hazards
Fire and burns from the hot element
Fire, burns, and carbon monoxide
That's a big reason electric models are a common pick for bedrooms and living rooms. They still need the same distance and attention rules as any other heater, though. And CPSC says CO alarms belong on every level of the home and outside sleeping areas, whatever kind of heat you use.
What CPSC and USFA Say About Space Heater Fire Safety
Most space heater fire safety comes down to distance and attention. CPSC's 2026 winter safety tips put it this way: "Keep portable heaters at least three feet away from drapes, furniture, bedding and other combustible materials." The same release says to turn heaters off when sleeping.
The numbers show why those rules exist. CPSC estimates that portable heaters, including electric space heaters, were involved in an average of 1,600 fires per year from 2020 to 2022. Those fires led to an average of 70 deaths and 150 injuries annually.
USFA's heating fire safety tips line up with CPSC. They say to keep anything that can burn at least 3 feet from all heat sources, and to turn space heaters off when you leave the room or go to bed. Good infrared heater safety looks like this:
  • Keep at least three feet of open space around the heater.
  • Plug it straight into a wall outlet.
  • Turn it off when you leave the room or go to sleep.
  • Follow the setup and cleaning steps in your manual.
Leaving a Heater Running
Is it safe to leave an infrared heater on while you sleep or step out? Both agencies say no. A heater that's off can't tip into a blanket at 2 a.m. or overheat while nobody's home to notice.
Even a few hours each evening, while you're awake and in the room, adds up on your bill. Check how much electricity space heaters use when you plan those hours.
Even a well-kept heater can fail in the middle of winter. If that happens, you'll need light and a phone while you sort it out.
If Your Heater Fails: Lights and Phones While You Wait
What you do next depends on what you see. Sparks, arcing, buzzing, or a burning smell are danger signs, so keep away from the heater and call the fire department right away. A heater that just stops working or keeps tripping the breaker can be switched off and unplugged once it's safe, then checked by a qualified technician.
Danger Signs vs. Ordinary Faults
The Massachusetts fire safety guide splits electrical warning signs into two groups. Arcs, sparks, a sizzling or buzzing sound, or a smell of something burning mean you should call the fire department immediately. Don't reach in to unplug a heater that's doing any of that. If you see smoke or flames, get everyone out and call 911.
Frequently tripped breakers and overheated plugs, cords, or outlets call for a licensed electrician soon. Switch the heater off and unplug it only if you can do so without touching anything hot or damaged. Don't patch it with tape or plug it back in to test it. Then find the maker's support line in the manual.
If you rent, tell your landlord the same day. And if the house turns cold, a friend's place, a relative's home, or a local warming center beats a freezing room.
Keeping Lights and Phones On
If the heater tripped a breaker, that room could go dark, and you'll want a lamp and a charged phone close by. Those are small loads, and a battery power station can cover them without burning anything indoors.
The EcoFlow DELTA 3 Classic is a 1,024Wh power station that runs on battery power, with no fuel and no fumes. In this article, it has one small job. It keeps a lamp and phones going after you shut off a faulty heater and wait for help.
EcoFlow DELTA 3 Classic powers a lamp through an AC outlet and charges a phone through one of its two USB-C ports.EcoFlow DELTA 3 Classic powers a lamp through an AC outlet and charges a phone through one of its two USB-C ports.
Use it for a lamp and phone charging while you contact your landlord or a repair service. Plug the lamp's own cord straight into one of the station's AC outlets, and charge phones from its USB ports. It isn't meant to run the heater.
EcoFlow DELTA 3 Classic (1024Wh) + Bag
• Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. •1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. •10ms Auto-Switch: In standby UPS mode, with AC input connected to a wall outlet and a compatible load connected directly to AC output, it switches to battery power within 10ms if grid power fails.
Runtime Estimates for Lights and Phones
How long will that small setup last? It depends on what you plug in, and the answer starts with each device's watts. You'll usually find that number on the bulb, the lamp's base, or the charger itself.
The runtimes below are estimates, not test results. We counted 85% of the 1,024Wh rated capacity as usable energy (about 870Wh) and divided by the load in watts. The watt figures are assumed examples, not label values, so check your own lamp and chargers.
Load (example)
Watts used (assumed)
EcoFlow DELTA 3 Classic (870Wh usable, est.)
LED lamp + two phones charging
About 25W
About 35 hours
LED lamp only
About 10W
About 87 hours
Phones draw less once they're full, so real runtime will vary. If you want an exact number, a plug-in watt meter shows what your lamp really pulls. Treat the station as backup for a limited period, based on its capacity and the actual load. Keep spare lights and chargers in a well-stocked emergency kit too, so they're ready for any outage.
Where you plug a heater in matters as much as where you put it. Next, the outlet rules.
Can You Plug an Infrared Heater Into a Power Strip?
No. CPSC says to plug electric space heaters directly into a wall outlet, never into an extension cord or power strip. Power strips and extension cords can overheat under heater loads.
Why Power Strips and Extension Cords Overheat
A heater pulls a heavy, steady current for hours. Power strips are usually built for lighter things like lamps, chargers, and TVs. An infrared heater power strip setup pushes that load through a part that wasn't designed for it. The same goes for a thin extension cord tucked behind a couch, where heat has nowhere to go.
Safe Space Heater WiringSafe Space Heater Wiring
The Health Physics Society's answer points to other cord problems as well. It warns about overloaded outlets and cords worn down by rugs.
Quick Outlet Checks
You don't need special tools to spot most cord and outlet problems. A quick look before each cold snap catches the common ones:
  • Plug the heater directly into a wall outlet, and don't overload that outlet.
  • Keep the cord out from under rugs and furniture.
  • If the plug or outlet feels hot, stop using it and call an electrician.
  • Follow your manual's cord rules, along with CPSC's no-extension-cord advice.
Winter puts more use on cords and outlets all over the house. Follow winter electrical fire prevention steps for them, not just the ones near the heater.
Good habits help most when the heater itself is built with safety in mind. Finally, here's how to choose a safer model.
Choosing a Safer Infrared Heater
Look for a listing mark and built-in protections. Tip-over and overheat shutoff are common features. Match the size to the room.
Safety Features to Look For
A mark from a nationally recognized testing lab, such as UL or ETL, means the model was tested to a safety standard. Check the label on the heater and the product listing to confirm the mark.
Feature
What it does
Why it matters
Testing lab mark (UL, ETL)
Shows the model was tested to a safety standard
Confirm it on the unit and in the listing
Tip-over shutoff
Turns the heater off if it falls over
Helps if a pet or child bumps it
Overheat shutoff
Cuts power if the heater gets too hot
Adds a backup if something blocks it
Guard or grill over the element
Keeps hands back from the hot surface
Useful in homes with kids and pets
Room size guidance
Shows what space the heater is meant for
Helps you pick the right size
Matching the Heater to the Room
Size matters more than many shoppers expect. Check the maker's room size guidance on the box or in the listing, and pick a heater meant for the space you're trying to warm. A small heater pushed close to a couch to make up for a big room breaks the three-foot rule.
Because infrared heat warms what it faces, placement counts too. Aim the heater toward where you sit, keep it on a flat, hard floor, and leave clear space on every side. If one heater can't keep up, the fix is a better-sized model, not a closer one.
Check for Recalls Before Using an Older Heater
Pulling an old heater out of storage or buying one secondhand? Search CPSC's recalls and safety warnings by brand and model before you plug it in. If it shows up there, follow the recall steps and don't use it.
Garages bring their own risks, like stored paint, gas cans, and sawdust. Different rules apply when choosing a garage space heater, so check that guide first.
Infrared heaters are safe when you use them the way CPSC and USFA advise, with three feet of clearance, a direct wall outlet, and no unattended use. Stop using any heater that sparks or overheats, and move somewhere warm if the room gets too cold. While you contact a landlord or repair service, an EcoFlow DELTA 3 Classic can keep lights and phones on for a limited period, depending on the load.
Are infrared heaters safe to leave on overnight?
No, not while you sleep. USFA says to turn space heaters off when you go to bed, and CPSC's 2026 tips say to turn heaters off when sleeping. If your bedroom runs cold, warm it before bed, then switch the heater off.
Do infrared heaters produce carbon monoxide?
Electric infrared heaters don't. Carbon monoxide comes from burning fuel, and an electric model doesn't burn anything. Fuel-burning heaters can produce carbon monoxide. Never use an outdoor-only heater indoors. Use an indoor-rated model only where local rules allow it, follow its ventilation instructions, and keep working CO alarms at home.
Can I plug an infrared heater into a power strip?
No. CPSC says to plug electric space heaters directly into a wall outlet, never into a power strip or extension cord. If the plug or outlet feels hot while the heater runs, stop using it and have an electrician check it.
How far should an infrared heater be from furniture?
At least three feet, per CPSC. That gap covers drapes, bedding, and anything else that can burn. USFA uses the same 3-foot distance for all heat sources, including fireplaces and radiators.
Are infrared heaters safe around kids and pets?
They can be, with the right setup and close supervision. Choose a model with a guard and tip-over shutoff, keep kids and pets back from the front of the heater, and don't leave them alone with it running. Follow any extra rules in your manual.
Tips
