Electricity Load Definition: What Load Means for Your Home and Backup Power
Here's a plain electricity load definition: load is the power your devices draw at any moment, measured in watts. A lamp can illustrate a small running load. A refrigerator's compressor can draw more power when it starts. The energy used over time is measured in watt-hours. EIA uses the same ideas at grid scale with terms like peak load and base load. This guide explains watts, peaks, and watt-hours with household examples, shows how utilities bill for them, and walks through checking loads against a power station's limits.
What Is Electricity Load?
An electricity load is the amount of power an electrical device or system draws while operating. Your lights, refrigerator, television, and air conditioner all contribute to your home's electrical load. The more appliances you run simultaneously, the higher your total load becomes.
Load is measured in watts (W) or kilowatts (kW). One kilowatt equals 1,000 watts. However, load and energy aren't the same thing. Load tells you how much power you're using at a particular moment. Energy measures how much electricity you consume over time.
The EIA uses two important terms to describe electricity demand:
  • Peak load: The maximum amount of electrical load during a specified period.
  • Base load: The minimum amount of electric power delivered or required over a given period at a steady rate.
These definitions also help explain how electricity works inside your home.
Watts vs. Kilowatts vs. Watt-Hours
Understanding the difference between these units makes electricity bills and backup power calculations easier.
Measurement
What It Means
Example
Watts (W)
Power an appliance draws
A 40W light bulb
Kilowatts (kW)
1,000 watts of power
A 2kW space heater
Watt-hours (Wh)
Energy used over time
200Wh over five hours
Kilowatt-hours (kWh)
1,000 watt-hours of energy
1kWh over an hour at 1kW
Here's a simple example. Suppose you use a 40W lamp for five hours.
40W × 5 hours = 200Wh = 0.2kWh
The lamp draws 40 watts while operating. After five hours, it consumes 200 watt-hours of energy.
This distinction matters when choosing a portable power station. Its output rating, measured in watts, determines which appliances it can run. Its battery capacity, measured in watt-hours, determines how much energy it can store. Knowing the difference between kW and kWh makes bills easier to read and keeps you from buying the wrong battery size.
A lamp and a fridge show how load works in practice.
Load in Practice: A Lamp, a Fridge, and a Power Station
Every device has a running load, and motors add a short starting peak. A power station has two limits: per-outlet and total output. Check both before you plug in.
Steady Loads vs. Motor Startup Peaks
An LED lamp drawing about 10W after it turns on is an example of a small, steady operating load. Its driver can still draw a brief inrush current at switch-on. Use the running wattage for energy calculations and check startup separately when sizing an inverter.
The ENERGY STAR listing for the 13.9-cubic-foot Frigidaire FFHT1425V series reports estimated use of 332 kWh per year. Dividing 332,000Wh by 8,760 hours gives about 38W of average power over the year.
That 38W is an average across the compressor's on and off cycles. At startup, the compressor can draw a brief surge. Compare the manufacturer's startup and running figures in the same units, such as watts with watts or amps with amps. The annual energy figure alone cannot tell you the startup demand.
If you are planning backup power, check how many watts a refrigerator uses at startup and while running. If the starting draw exceeds the inverter's limits, it can shut off even if the battery is fully charged.
Checking Per-Outlet and Total Output Limits
When you plug appliances into a portable power station, two numbers matter on the spec sheet:
  • Total continuous output: The maximum combined watts all outlets can deliver at the same time.
  • Per-outlet limit: The maximum watts a single 120V AC receptacle can handle safely on its own.
Check both the per-outlet and total output limits before connecting appliances. Use suitable outlets according to the power station and appliance manuals. Never daisy-chain power strips.
EcoFlow power stations make load easy to see, since each has a clear output limit and a battery size in watt-hours. Two examples show how running watts, startup peaks, and energy fit together.
When you're powering a lamp, phone, Wi-Fi router, or other small electronics, your combined load may be relatively low. The EcoFlow DELTA 3 Classic has a 1,800W continuous output and a 1,024Wh battery. That makes it a useful example for understanding steady household loads.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Adding a refrigerator introduces another consideration: startup power. You also need enough total output to handle other appliances running simultaneously.
The EcoFlow DELTA 3000 Gen4 provides 3,600W of continuous output and 7,200W of surge power. Its 3,072Wh battery offers more stored energy for longer backup needs.
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
How the products divide the job
Choosing between these two setups comes down to matching the hardware to your load profile:
  • EcoFlow DELTA 3 Classic: Ideal for steady, low-to-moderate loads like lighting, laptops, phones, and internet gear during brief grid hiccups.
  • EcoFlow DELTA 3000 Gen4: Built for heavier home backup needs, especially when a refrigerator compressor starts alongside multiple 120V household appliances, provided the combined load stays within the unit's per-outlet and total output limits.
How Long Can a Power Station Run Your Appliances?
Battery capacity and appliance load determine estimated runtime. A larger battery generally provides more operating time, while a higher connected load drains it faster.
For a simple estimate, use this formula:
Estimated runtime = (Battery capacity × 0.85) ÷ Appliance load
The 0.85 factor represents an estimated 85% usable battery capacity. Actual runtime varies with conversion losses, appliance cycling, temperature, and operating conditions.
The following examples use estimated usable capacities of 870Wh for the EcoFlow DELTA 3 Classic and 2,611Wh for the EcoFlow DELTA 3000 Gen4.
Load
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.)
LED lamp (10W) + phone (10W)
About 20W
About 44 hours
About 131 hours
Refrigerator (38W average) + lamp (10W) + router (15W)
About 63W
About 14 hours
About 41 hours
These are estimates using the 85% usable-capacity assumption. The 10W lamp, 10W phone, and 15W router are illustrative placeholders. Replace them with actual device ratings before making backup plans.
For refrigerator planning, remember that average consumption doesn't show the entire picture. The compressor's starting surge also matters when checking power station compatibility.
Next, the difference between peak and base load at home.
Peak Load vs Base Load at Home
Your home doesn't use the same amount of electricity throughout the day. Some appliances run continuously, while others switch on only when needed.
Your base load represents the minimum power your home needs over a period. Refrigerators, Wi-Fi routers, and standby electronics often contribute to it.
Peak load is the highest power demand during a particular period. It can happen when several high-power appliances operate together.
For example, running an electric oven, clothes dryer, and air conditioner simultaneously can increase your home's peak load considerably.
Four Terms Used to Describe Household Loads
Base and peak load describe demand over a period. Running and starting load describe how a device draws power at different stages. The same device can contribute to more than one of these measures.
Term
Home Example
Why It Matters for Backup
Base load
Wi-Fi router, security cameras, standby electronics
Multiply steady base-load watts by the hours you want to cover to estimate energy (Wh)
Running load
LED lamps, TV, desktop computer, box fan
Adds the device's operating watts to the total while it runs
Starting (surge) load
Refrigerator compressor, sump pump, well pump motor
Must fit safely under your inverter's surge rating
Peak load
Central AC, electric dryer, oven, and water heater at once
Helps estimate backup output. Circuit breakers must be sized for each circuit's conductors, loads, and applicable requirements
How to Calculate Your Home's Peak Load
You don't necessarily need to power every appliance during an outage. Start by identifying the devices you want to keep running.
Calculating home's peak loadCalculating home's peak load
Follow these steps:
  1. List household essentials such as the refrigerator, lights, and router. For medical equipment, make a separate outage plan with the equipment manufacturer and your care team. The EcoFlow DELTA 3000 Gen4 safety note says it is not intended to be the sole backup source for life-support medical equipment.
  2. Check running watts: Find each appliance's wattage on its label or in its owner's manual.
  3. Identify starting surges: Check whether refrigerators, pumps, or other motor-driven appliances need additional startup power.
  4. Add simultaneous loads: Calculate the combined running watts of appliances you expect to use together.
  5. Compare output limits: Make sure the power station can handle the continuous load and starting surge.
You should also consider whether you need whole-home backup or critical-load backup. Whole-home systems aim to support more household circuits, while critical-load setups prioritize essential appliances and selected circuits.
The right choice depends on your household's peak demand, budget, and backup priorities.
How Utilities Bill for Load and Energy
Most residential electricity bills are based on energy consumption, measured in kilowatt-hours (kWh). However, some utility plans also include demand charges based on peak power usage, measured in kilowatts (kW).
Understanding these charges helps you see why both energy consumption and peak load matter.
How utilities bill for load and energyHow utilities bill for load and energy
Energy Charges
An energy charge is based on the electricity you consume over a billing period.
For example, imagine your home uses 900kWh in one month. If your electricity rate is $0.15 per kWh, your energy charge would be:
900kWh × $0.15 = $135
This calculation excludes fixed fees, taxes, and other utility charges.
Running appliances for longer generally increases total energy consumption. Using efficient appliances and switching off unnecessary devices can help reduce your kWh usage.
Demand Charges
A demand charge is different. The EIA defines it as the portion of an electricity bill based on a consumer's maximum electric capacity usage.
For example, a utility might measure your highest electricity demand during a 15-minute interval. That peak could affect your bill under a demand-based rate schedule.
Demand charges aren't included in every residential electricity plan. Some utilities apply them to specific customer groups or rate structures.
Check your utility's rate schedule to understand whether your bill includes:
  • Energy charges based on monthly kWh consumption.
  • Demand charges based on maximum kW usage.
  • Fixed monthly service fees.
  • Time-of-use rates with different peak and off-peak prices.
If your plan includes demand charges, spreading out high-power appliance usage may help reduce simultaneous demand.
The electricity load definition is simple: load is the power your devices draw at a given moment, measured in watts. Energy measures that power over time, using watt-hours or kilowatt-hours. Peak load represents the highest demand during a specified period, while base load represents the minimum steady requirement.
These differences matter when planning household electricity use and backup power. Before choosing a power station, list your appliances, check their running watts, account for starting surges, and estimate how many hours you'll need backup.
The EcoFlow DELTA 3 Classic provides an example of handling smaller, steady loads. The EcoFlow DELTA 3000 Gen4 offers higher output and more battery capacity for larger backup needs. Compare their output ratings and battery capacities against your actual requirements before choosing a system.
What is electricity load?
Electricity load is the power an appliance or electrical system draws at a particular moment. It's measured in watts (W) or kilowatts (kW). Your refrigerator, lights, air conditioner, and other connected devices all contribute to your home's total electrical load.
What is the difference between load and energy?
Load measures how much power a device draws at a given moment, in watts. Energy measures how much electricity it consumes over time, in watt-hours or kilowatt-hours. For example, a 40W lamp running for five hours consumes 200Wh of energy.
What is peak load?
Peak load is the maximum electrical load during a specified period. At home, it can occur when several appliances operate simultaneously. For example, running an air conditioner, oven, and clothes dryer together can create a higher peak demand.
What is base load?
The EIA defines base load as the minimum steady power required or delivered over a given period. Devices that draw power continuously, such as routers and standby electronics, can contribute to it. A refrigerator's cycling compressor adds to the load when it runs.
How do I find my home's load?
Add the running wattage of appliances you expect to use simultaneously. Check each appliance's label or owner's manual for its power rating. Also account for motor startup surges. A home energy monitor can help track actual electricity usage and identify your household's peak demand.
Tips
