Full House Generator: How to Choose the Right Size for Your Home
A power outage feels very different when it lasts through a hot afternoon, a freezing night, or several days of storm cleanup. A full house generator can keep essential equipment operating, but only if the system matches the home’s electrical demands and the way the household plans to use backup power.
The largest generator is not automatically the best choice. Proper sizing accounts for running watts, appliance startup surges, 120- and 240-volt loads, fuel or battery capacity, and the circuits that truly need power. This guide explains how whole-home backup works, how to estimate generator size, and what to review before installation.
What Is a Full House Generator?
A full house generator, also called a whole home generator, supplies electricity when utility service fails. Some systems are designed to energize nearly every circuit in the home. Others serve a selected group of circuits that may power refrigeration, HVAC equipment, water pumps, lighting, and communication devices.
The term describes the job the system performs, not one specific technology. Backup power may come from a permanently installed engine generator, a whole-home battery, or a portable generator connected through approved equipment. Automatic operation is common with standby and battery systems, while portable units generally require manual setup.
How a Full House Generator Works
Most permanently installed standby generators use an Automatic Transfer Switch (ATS). The switch monitors utility service. When an outage occurs, it isolates the home from the grid, preventing power from feeding back onto utility lines, and signals the generator to start. Electricity then reaches the breaker panel and the circuits assigned to backup power.
When utility power returns and remains stable, the transfer switch reconnects the house to the grid and shuts down the generator after its normal cooldown sequence. A battery system follows a similar electrical principle, although an inverter supplies the backup power rather than an engine and alternator.
Portable generators require a different arrangement. Individual appliances may connect with properly rated cords, or the generator may supply approved household circuits through an inlet and transfer equipment installed by an electrician. A generator should never be connected to a wall receptacle to energize home wiring.
Key Components of a Whole-Home Generator System
A complete backup installation normally includes more than the power source itself:
Power unit: A fuel-powered engine and alternator, or a lithium iron phosphate (LFP) battery and inverter.
Transfer switch: Moves the electrical load safely between utility service and the backup source while preventing backfeeding.
Fuel or charging setup: A natural gas line, propane tank, or grid and solar charging connections that support the chosen system.
Load management modules: Temporarily limit or sequence high-draw equipment so several large appliances do not overload the backup source at once.
Types of Generators for Whole-Home Backup
The three main choices differ in cost, runtime, installation, and day-to-day operation. A home battery vs. generator comparison is most useful when it accounts for required output, outage duration, recharging or fuel access, and installation.
Generator Type | Power Source | Key Characteristics | Considerations |
Standby Generator | Natural gas, liquid propane, or diesel | Permanently installed; starts automatically, usually within 10–30 seconds. | Requires professional installation, permits, routine maintenance, and outdoor clearance. |
Whole-Home Battery System | Stores grid electricity and/or solar | Quiet, produces no exhaust, and can switch over in milliseconds. | Runtime depends on battery capacity and solar charging; multi-day backup can require more batteries. |
Portable Generator | Gasoline, propane, or dual fuel | Lower upfront cost; can be stored when not in use. | Requires manual setup, outdoor operation, and safe refueling. |
A standby generator is often chosen for automatic operation and longer outages. A home battery offers quiet backup without onsite combustion. A portable generator may cover essential circuits at a lower initial cost, but it requires manual placement, connection, fueling, and monitoring.
What Size Generator Do You Need for Your Home?
Square footage is a poor shortcut for generator sizing. Two 2,200-square-foot houses can have completely different loads. One may use natural gas for space heating, water heating, and cooking. The other may have an electric heat pump, electric range, well pump, and clothes dryer.
Start by identifying the equipment that must operate during an outage, then calculate how much of it may need to run simultaneously. This provides a more practical estimate than choosing a generator based solely on the home’s floor area or electrical-service rating. Consider each appliance’s running wattage, startup surge, and expected usage overlap when determining what size generator your home needs, then have an electrician complete the final load calculation.
Identify the Appliances and Systems You Need to Power
Make two lists: equipment that must remain available and equipment that would simply be convenient. Most household loads fall into three groups:
Heating, cooling, and water: Central air conditioning, heat pump, furnace blower, sump pump, and well pump.
Kitchen and laundry: Refrigerator, freezer, range, microwave, and clothes dryer.
Work and daily use: Wi-Fi router, computers, lights, and a garage door opener.
The list should reflect how the household will behave during an outage. Refrigeration, one HVAC system, water service, and several lights may be essential, while the electric dryer or second air conditioner can wait. Also record whether each appliance uses 120 or 240 volts. A backup source that supplies only 120 volts cannot operate 240-volt equipment even if its wattage appears sufficient.
Determine Running Watts and Starting Watts
Running watts describe the power an appliance needs after it is operating. Starting watts refer to the short surge required by equipment with compressors or motors. The surge may last only a few seconds, but the generator or inverter still has to support it.
A refrigerator may use 150 to 200 running watts and require 800 to 1,200 starting watts when the compressor turns on. Central air conditioning, heat pumps, sump pumps, and well pumps can have much larger surges. A soft starter may reduce the starting demand of a compatible air-conditioning compressor, but it does not reduce the unit’s normal running load.
Read the nameplate, manual, or manufacturer specifications for each appliance rather than relying only on online averages. Add the running watts of the loads likely to operate together, then add the highest single startup surge expected at that time. Avoid adding every appliance in the house unless the system genuinely needs to run them all simultaneously.
Match Generator Size to Your Home's Power Needs
Divide the estimated wattage by 1,000 to convert it to kilowatts. The ranges below are useful for early planning, but the final choice should reflect the actual equipment and the backup source’s continuous and surge ratings.
7 kW to 10 kW (Essential Circuits): Can cover lights, a refrigerator, Wi-Fi, a sump pump, and a gas furnace blower. It may not run central air conditioning alongside large kitchen appliances.
12 kW to 16 kW (Mid-Size Whole Home): Can handle most essentials and a 3- to 4-ton central AC unit or heat pump, especially with load management. Actual compatibility depends on the HVAC system’s running and startup requirements.
18 kW to 24+ kW (Full Whole-Home Coverage): Suits larger homes with multiple HVAC zones and high-demand appliances, such as electric water heaters, ranges, or EV chargers.
Load management can sometimes avoid the cost of sizing for every possible combination. For example, a controller might prevent an electric water heater from operating while the air conditioner starts, then restore the water-heating circuit after the surge passes.
Allow for Future Load Growth
A generator may remain in service through several home upgrades. An EV charger, finished basement, heat pump, hot tub, or new well equipment can change the load considerably. Discuss likely projects with the electrician before choosing capacity. A reasonable buffer may help, but buying far more output than the home is expected to use adds cost and does not replace proper planning.
How to Choose the Right Full House Generator for Your Home
Once the expected load is known, compare the practical differences among systems. Voltage, electrical-service design, outage duration, fuel access, noise, maintenance, and automatic operation can matter as much as the advertised kilowatt rating.
Check Electrical System Compatibility
Most U.S. single-family homes use 120/240-volt split-phase service, commonly rated at 150 or 200 amps. Appliances such as central HVAC equipment, well pumps, electric ranges, water heaters, and dryers may use 240 volts, so a system intended to operate them must provide compatible output.
An electrician should review the main panel, service rating, grounding and bonding arrangement, and the loads assigned to backup power. Some homes use a service-entrance transfer switch that can manage the main panel. Others use an essential-load subpanel with only the selected circuits.
Do not assume that a 200-amp utility service requires a generator capable of reproducing the full service capacity. Homes rarely use every circuit at maximum output at once. A load calculation and a realistic outage plan provide a better sizing basis.
Compare Fuel-Powered Generators and Battery Backup Systems
Fuel-powered generators continue producing electricity while their fuel supply and maintenance schedule allow. Natural gas offers convenient continuous delivery where service remains available. Propane can be stored on the property, while gasoline is more common with portable units and requires safe storage and refueling.
Battery systems store electricity in advance and supply it without engine exhaust, fuel handling, or the regular engine service required by a combustion generator. Their runtime is tied to stored energy, connected loads, and available recharging. Solar can add energy during daylight when the system and conditions allow.
For homeowners who want to avoid engine noise and carbon monoxide risks altogether, the EcoFlow DELTA Pro Ultra Whole-Home Backup Power supplies reliable backup power for essential household loads like a central heat pump, refrigerator, lighting, and Wi-Fi router, keeping the home warm and connected throughout a winter blackout.
For households that need to run heavy-duty appliances during an outage, the EcoFlow DELTA Pro Ultra X Whole-Home Backup Power delivers 12 kW of base output power. It can power demanding 240V loads such as an electric range, oven, electric water heater, and clothes dryer while reducing power-sharing bottlenecks.
Evaluate Runtime and Noise Levels
Runtime should be based on the likely load, not only the system’s maximum rating. A natural gas standby generator can operate while the gas supply remains available, but extended use still requires scheduled shutdowns for oil checks and changes. Propane runtime depends on tank size and generator load. Battery runtime depends on usable capacity, connected appliances, and recharging.
A specification sheet can make noise look like a minor detail, but where the equipment sits matters just as much as its decibel rating. Published sound levels depend on the model, operating load, test conditions, and measurement distance. Compare specifications on the same basis rather than assuming every standby generator or battery system has the same noise level.
Even a compliant unit can become irritating outside a bedroom window or beside a neighbor’s patio. Consider those everyday spaces when choosing the site, then check local noise limits before finalizing the location.
Consider Maintenance Needs and Warranty Coverage
Engine-driven generators require oil and filter changes, spark-plug inspections, starting-battery checks, and periodic exercise cycles. Dealer maintenance may cost about $200 to $400 per year, depending on the equipment and service plan. A generator that sits unused for months still needs attention so it will start when the grid fails. For full house generators or other standby models, follow the applicable maintenance schedule and obtain a local service quote rather than relying on a nationwide annual-cost estimate.
Battery backup avoids oil changes and spark-plug service, but it is not entirely hands-off. The equipment may need firmware updates, and it must remain within the manufacturer’s operating limits. Check the monitoring system periodically to make sure the batteries are charged and ready for an outage.
Read the warranty details as carefully as the output specifications. Find out whether coverage includes parts, labor, batteries, transfer equipment, and service travel. Compare the actual term and exclusions for each model rather than assuming a minimum coverage period. Note any registration deadlines or required maintenance that could affect a future claim.
What Should You Consider Before Installing a Full House Generator?
Installation questions are easier to resolve before the equipment is ordered. The site needs suitable drainage, safe exhaust clearance, practical routes for wiring and fuel, room for future service, and a clear path through local permitting.
Choose an Appropriate Installation Location
A fuel-burning standby generator cannot simply be set wherever open space is available. It needs a stable, well-drained outdoor base. A spot near the electrical panel and fuel source can reduce trenching, piping, and wiring costs, but it must still meet required clearances and local code. Rule out low areas that collect water, places beneath roof runoff, and locations where drifting snow could restrict airflow.
Technicians also need enough working space to inspect and service the unit. Think about where the exhaust travels and how the sound will carry toward bedrooms, patios, and neighboring homes. Depending on the manufacturer and local rules, a battery system may be installed in a garage, basement, utility room, or approved outdoor location. Temperature, moisture, ventilation, and emergency access should all be part of that decision.
Meet Ventilation and Exhaust Safety Requirements
Fuel-burning generators produce carbon monoxide. Permanently installed standby units must follow the manufacturer’s listed clearances and all local requirements for windows, doors, vents, property lines, and combustible construction.
Portable generators require much more separation from occupied buildings. The U.S. Consumer Product Safety Commission says to operate them outdoors only, at least 20 feet from homes and other buildings, with the exhaust directed away from windows, doors, vents, and neighboring structures. Never run one in a home, garage, basement, crawl space, shed, carport, or enclosed porch, even if doors are open.
Install and maintain working carbon monoxide alarms on every level and outside sleeping areas. Keep the generator dry according to its instructions, and never refuel an engine while it is running or hot.
Check Local Permits and Electrical Codes
Permanent installations usually require an electrical permit. Fuel-burning equipment may also require mechanical, plumbing, or fuel-gas permits. The installation must comply with applicable National Electrical Code (NEC) provisions, local building and fire rules, utility requirements, and noise restrictions.
The local authority may inspect the transfer switch, wiring, equipment pad, fuel system, grounding, and clearances. Natural gas work may also require utility coordination. Check homeowners association (HOA) rules before placing visible exterior equipment or pouring a pad.
Use a licensed electrician and qualified fuel contractor where required. Improvised connections can energize utility lines, damage appliances, create a fire hazard, or expose occupants and utility crews to serious risk.
Plan for Fuel Supply and Storage
Fuel availability determines how long an engine generator can operate. Estimate consumption at a realistic household load rather than assuming the generator will remain at full output throughout the outage.
Natural gas: Ask the utility or installer whether the meter and piping can supply the furnace, water heater, range, and generator at the same time. Some homes need a larger meter or gas line.
Liquid propane: Fuel use varies by generator model and load. For example, a 20 kW standby generator may consume approximately 2.36 gallons per hour at half load and 3.74 gallons per hour at full load. At those rates, 200 usable gallons would last roughly 2.2 to 3.5 days of continuous operation. Use the selected model’s fuel-consumption data and the tank’s usable capacity for planning.
Gasoline: Gasoline can degrade within 30 to 60 days without stabilizer and creates storage risks. Portable gasoline generators are generally better suited to shorter outages than extended whole-home backup.
Choosing a full house generator starts with the appliances and systems that matter during an outage. List those loads, record their running and starting watts, and decide which ones must operate together. Then compare the result with the backup system’s voltage, continuous output, surge capacity, fuel or stored energy, and transfer equipment.
A standby generator can support long outages when fuel remains available. A whole-home battery provides quiet backup without combustion exhaust, while a portable generator may cover essential needs at a lower initial cost. Before buying, confirm the installation location, electrical compatibility, permits, maintenance requirements, and realistic runtime. A carefully sized system is more useful than one chosen by square footage or headline wattage alone.
How Long Does It Take to Install a Whole-House Generator?
Most residential whole-house generator installations take 1 to 3 days of on-site labor, though permitting and utility upgrades can extend the total timeline to several weeks. Mounting the unit, wiring the Automatic Transfer Switch, and connecting fuel lines usually wrap up within a day or two, while waiting for city permits, HOA sign-offs, or gas meter upgrades accounts for most of the lead time.
How Long Does a Whole-House Generator Last?
A properly maintained whole-house standby generator can typically last 15 to 20 years, although its actual lifespan and operating hours vary depending on usage, maintenance, and operating conditions. Routine oil changes, air filter replacements, and regular exercise cycles help reduce wear and support long-term reliability. By comparison, modern LFP whole-home battery systems can offer approximately 3,500 to 6,000+ charge cycles, potentially providing 10 to 15 years of service depending on usage patterns, charging conditions, and battery specifications.
Is It Safe to Run a Whole-House Generator Overnight?
A properly installed standby generator can run overnight outdoors if it meets clearance and maintenance requirements. Keep working carbon monoxide alarms on every floor. Indoor battery systems produce no combustion exhaust, but follow the manufacturer’s placement instructions.
How Quickly Does a Whole-House Generator Restore Power?
A standby generator equipped with an Automatic Transfer Switch (ATS) typically restores power within about 10 to 30 seconds after an outage, depending on the system. By comparison, battery backup systems with automatic transfer capabilities can switch over in less than 20 milliseconds, helping keep computers, routers, and other sensitive electronics running with minimal interruption.
