How Many Amps Does a PC Use? How to Measure It at the Wall
A PC's current depends on its hardware and workload. To see how much your setup draws, use a properly rated plug-in power meter that displays AC amps. Measure at idle and during a typical heavy workload. Include monitors and other equipment powered separately from the PC. A power supply's rated wattage describes its output capacity, while a wall meter shows what the system draws.
For single-phase AC, current depends on real watts, RMS voltage, and power factor (PF). Schneider Electric's UPS guide explains that PF is the ratio of real power in watts to apparent power in volt-amperes. If your meter shows only watts, you also need voltage and PF to estimate current.
Current (A) = real power (W) ÷ [RMS voltage (V) × power factor]
For example, at 120 V and PF 0.90, a desktop drawing 300 W uses about 2.78 A. At PF 1.00 it would use 2.50 A. Measure AC amps directly when possible and repeat the reading across different workloads.
PC power consumption changes with workload and hardwarePC power consumption changes with workload and hardware
Typical PC Amps at Different Workloads
The table illustrates how power translates to current with an assumed 120 V supply and PF 0.90. The PF assumption is for comparison. Actual current depends on the device and operating mode.
Computer or workload
Power consumption
Illustrative current at 120 V and PF 0.90
Efficient desktop, short idle (ENERGY STAR record)
22.6W
About 0.21 A at the assumed PF
Example: office PC under load
150W
About 1.39 A
Example: gaming PC under load
500W
About 4.63 A
The 22.6 W figure comes from an ENERGY STAR record for the HP EliteDesk 8 Tower G1i, which also lists 3.7 W in sleep mode. Another certified desktop record lists 32 W at short idle. The resulting amp values in the table use the stated PF assumption. Measure your own equipment for actual current and compare readings at idle and under load.
What About Laptops?
Laptops generally consume less electricity than desktop computers because they use lower-power components and are designed to operate efficiently on battery power. Comparing laptop versus desktop power use shows why laptops can often operate longer on smaller batteries. A laptop used for browsing or office work typically needs less power than a desktop running demanding software or games. However, screen brightness, processor activity, charging, and connected accessories can all affect laptop consumption.
Backing Up a PC and Monitors
A power interruption can interrupt your work, close applications unexpectedly, and potentially cause unsaved data to disappear. For gamers and professionals working with large files, even a short outage can be frustrating. A battery backup can help keep your computer running or give you time to save your work and shut down safely. However, choosing the right system requires more than checking your PC's power supply rating. Start by measuring the actual wattage of everything you want to keep running.
For example, your backup load might include:
  • Desktop PC or laptop: The main computer is usually the largest power consumer in your setup. Its actual usage depends on the processor, graphics card, screen, and workload.
  • One or more monitors: Each monitor adds to your total electricity use. Larger screens, higher resolutions, and higher refresh rates may increase power consumption.
  • Wi-Fi router and modem: These devices use relatively little electricity but need continuous power to maintain your internet connection.
  • External storage drives: Add separately powered drives only when their power supply is outside the PC's measurement point. Bus-powered drives are included in the PC's wall reading.
  • Keyboard, mouse, and other accessories: Devices powered over the PC's USB connection are already included in a wall measurement of the whole PC. Add only equipment with a separate power supply outside that measurement.
Which EcoFlow Power Station Fits Your Setup?
EcoFlow portable power stations provide battery capacity and AC output for compatible electronics during power interruptions. The right model depends on your measured load, desired runtime, and equipment requirements. EcoFlow power stations can help support different computer setups, from everyday home offices to more demanding gaming workstations. Before choosing one, consider both continuous output and available battery capacity. Also, test power-transfer behavior with your own equipment rather than assuming every PC will remain on during a switchover.
EcoFlow DELTA 3 Classic (1024Wh)
For a laptop and monitor, or a light desktop, the EcoFlow DELTA 3 Classic provides a practical backup option. Its 1,024Wh capacity and 1,800W output give you room to support compatible electronics without choosing a much larger system than your setup requires.
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
EcoFlow DELTA 3000 Gen4
The EcoFlow DELTA 3000 Gen4 offers 3,072Wh of battery capacity and 3,600W of continuous output. This makes it worth considering for a gaming PC, workstation, and multiple monitors, provided the complete setup stays within its operating limits.
• Longest Runtime¹: Powers a refrigerator for up to 58 hours — 17 hours (41.5%) longer than the industry average for 3kWh portable power stations. • Powers Most Home Appliances: Delivers 3,600W of continuous output and 7,200W of surge power⁴. • Compact Yet Powerful: The smallest and lightest⁵ portable power station in its class with 3kWh capacity and 3,600W output. •UPS Backup with <10 ms Transfer Time: Switches to backup power within 10 ms when an outage occurs. • Up to 5-Year Warranty: Includes 3-year standard warranty and 2-year extended warranty available upon EcoFlow App registration.
How Much Runtime Can You Expect?
Battery capacity determines how much energy is available, while the connected devices determine how quickly that energy is consumed.
For planning, use this formula:
Estimated Runtime = Usable Battery Capacity (Wh) ÷ Total Load (W)
The following estimates use 85% of rated capacity as a planning allowance to account for conversion losses. Actual runtime varies with operating conditions.
Example Setup
Watts used
EcoFlow DELTA 3 Classic (870Wh usable est.)
EcoFlow DELTA 3000 Gen4 (2,611Wh usable est.)
Example: laptop and monitor
about 90W
about 9.7 hours
about 29 hours
Example: gaming PC and three monitors under load
about 600W
about 1.4 hours
about 4.4 hours
These figures illustrate runtime using assumed loads. Replace the example wattages with your own meter readings. If you are considering UPS backup for a gaming PC, check both available energy and supported power. Test switchover with the complete setup before relying on it.
How to Convert PC Watts to Amps
Read AC amps from a meter at the wall for a direct measure of current. A meter that shows apparent power in VA also lets you estimate amps by dividing VA by the measured RMS voltage. If you only have real watts, include the power factor for the same load and operating condition.
The basic formula is:
Use the power factor of the load you are measuring. It can differ across devices and change with workload.
A Practical Calculation Example
Suppose a desktop consumes 300 W and two separately powered monitors use 30 W each. For an example current calculation, assume the complete setup has a combined measured PF of 0.90 at 120 V.
First, add the real power of the devices:
300 W + 30 W + 30 W = 360 W
Use the combined power factor and the RMS voltage:
360 W ÷ (120 V × 0.90) ≈ 3.33 A
Why You Should Check the Household Circuit
A 15 A branch circuit may already supply other outlets or equipment. Measure real current for your setup and have a qualified electrician check the available circuit capacity and applicable load limits when you are unsure.
Watts, Amps, and Volts: Understanding the Difference
Watts, amps, and volts describe different aspects of electricity, but they work together when calculating a device's power requirements. Understanding each measurement helps you interpret power readings and estimate electrical demand. It is also useful to distinguish watts from watt-hours when planning energy consumption over time. These three electrical measurements describe different things:
Measurement
Meaning
Watts (W)
The rate at which electrical power is used
Amps (A)
The electrical current flowing through a circuit
Volts (V)
The electrical potential supplied to a device
Understanding amps, volts, and watts makes it easier to calculate the requirements of computers, monitors, and other household electronics. Also remember that watts and watt-hours are different. Watts describe power at a particular moment, while watt-hours describe the amount of energy consumed over time.
Why Your PSU Rating Isn't Your Actual Draw
Your computer's power supply unit (PSU) converts electricity from the wall into the power required by internal components. Its wattage rating indicates how much power it can deliver, not how much electricity your PC continuously consumes. Understanding how PC power supplies work helps clarify why a desktop with a 750W PSU does not necessarily draw 750W whenever it is switched on. Actual consumption changes depending on the processor, graphics card, storage devices, cooling system, and current workload.
What Determines Actual Power Consumption?
Several hardware and usage factors determine how much electricity your computer consumes at any given time. The processor, graphics card, workload, and power supply efficiency all affect its energy demand. Connected devices and operating modes also influence the total power consumption of your PC.
Desktop PC Internal Components and Cooling SystemDesktop PC Internal Components and Cooling System
1. Processor and Graphics Card
The CPU and GPU are major contributors to desktop power consumption. Basic office tasks generally require less processing power than gaming, video editing, or 3D rendering.
2. Workload
Browsing websites, writing documents, and checking emails usually place lighter demands on your hardware. Running demanding games or rendering software increases power consumption.
3. PSU Efficiency
Power supplies lose some energy during the conversion process. Their efficiency ratings, including 80 PLUS classifications, indicate how effectively they convert incoming electricity into usable power.
4. Connected Components
Include displays and accessories powered outside your measurement point. A whole-PC wall reading already includes its internal fans, drives, and USB-powered accessories. ENERGY STAR's records for off, sleep, and idle modes show how power can vary by operating condition.
Measure AC amps directly, or estimate them from real watts, RMS voltage, and power factor. Compare idle and loaded readings and include separately powered displays or accessories. A PSU rating describes its output capacity. For compatible equipment, compare the EcoFlow DELTA 3 Classic and EcoFlow DELTA 3000 Gen4 using measured total load and the runtime you need.
How many amps does a PC use?
Current depends on power draw, RMS voltage, and power factor. A desktop drawing 150 W at 120 V and PF 0.90 uses about 1.39 A. Read the meter in amps to get the actual value for your setup.
How many amps does a gaming PC use?
Gaming PC consumption varies by hardware and workload. At 500 W, 120 V, and PF 0.90, the calculated current is about 4.63 A. Measure AC current during a representative gaming session before sizing a circuit or backup.
Does a 750W PSU use 750 watts?
No. A 750W PSU rating indicates its maximum rated output, not its constant electricity consumption. Actual wall power depends on the computer's components and workload.
Can a PC share a 15A circuit?
It depends on the equipment already connected and the current they draw. Measure the PC and other loads on the circuit. A qualified electrician can check available capacity and any limits that apply to loads that run continuously.
Will a power station keep my PC on in an outage?
It can, provided its output capacity supports the connected equipment and its transfer behavior is compatible with your PC. Test the complete setup before depending on it during a power interruption.
Tips
