15000 Watt Generator: Will It Actually Run a House?
Short answer yes, a 15,000 watt generator can run most standard home appliances. The nuance is that it usually means two or three big ones running together, not the whole house at once, and the starting surge of a single central air conditioner can alone eat over half that capacity. Here's what you can run on 15,000 watts at home, on a work site, in an RV or off-grid, why the number of appliances matters more than the wattage, what that capacity delivers in amps, and whether this size actually fits your home.
The Real Answer to Will It Run a House?
The honest answer sits between a flat yes and a flat no, and most of the confusion around this question comes from skipping the nuance in between.
  • Technically, yes: A 15,000-running-watt generator has enough capacity to power most standard home appliances individually.
  • Practically, it means some, not all: The more accurate answer is that it can run two or three major appliances at the same time, not every circuit in a house at once.
  • The gap between those two answers: A whole house includes dozens of smaller loads (lighting, electronics, chargers) stacked on top of major appliances, and those add up faster than most people expect.
For a size-by-size breakdown of what running a full house actually requires, matching wattage needs to home size walks through the math across different square footages.
With that expectation set correctly, here is the specific breakdown of what fits within 15,000 watts.
What a 15,000-Watt Generator Can Run
Fifteen thousand watts covers a wide range of uses, and what it can handle depends less on the setting (home, job site, RV, or off-grid) and more on how many of these loads you are running at the same time.
Use case
Appliance
Running watts
Starting watts
Home
Space heater
1,800W
(none)
Home
Well pump
1,000W
2,000W
Home
Washing machine
1,100W
2,200W
Home
Garage door opener
850W
2,200W
Work site
Table saw
1,800W
4,500W
Work site
Circular saw
1,400W
2,300W
Work site
Air compressor
1,600W
4,500W
Work site
Electric drill
550W
800W
RV
RV air conditioner
900W
1,700W
RV
Coffee maker
1,000W
(none)
RV
Microwave
600W
(none)
Off-grid
Sump pump
800W
1,600W
Off-grid
Electric stove
1,500W
(none)
Each of these appliances runs comfortably on its own within a 15,000-watt budget. Math only gets tight once you start layering several together, which is exactly why the next section matters.
One item on that home list is worth a special callout: the garage door opener is easy to overlook in a backup power plan, and its 2,200W starting surge is bigger than its running watts might suggest. Checking a specific opener's rated pull before assuming it will run is worth doing separately.
One appliance from that list changes math more than any other, and it is worth pulling out on its own.
The Surge That Changes Everything: Central Air Conditioning
Central air conditioning is the single biggest factor in whether a 15,000-watt generator can actually cover your home, and it deserves its own section rather than a line in a table.
A central AC unit can draw around 3,800W running and 8,000W starting, which is more than half of a 15,000-watt generator's entire capacity in one surge. That leaves comparatively little headroom for everything else. Running central AC alongside even one or two other major appliances, like a well pump or a space heater, can push the combined total close to the generator's limit fast.
The Surge That Changes Everything: Central Air ConditioningThe Surge That Changes Everything: Central Air Conditioning
If you're weighing a home battery instead of a 15,000-watt generator, run the same AC startup check. The EcoFlow TITAN Plus delivers 7.2kW from the battery, and in EcoFlow's defined 240V test scenario it can start a 3-ton central AC while running about 1kW of essential loads. Results depend on your AC unit and the circuits you choose to back up.
EcoFlow TITAN 5000 Plus
The standard EcoFlow TITAN offers the same 7.2kW of 120V/240V output and can start a 3-ton central AC in the same defined scenario. It suits homes that plan less solar, with one 4kW solar input instead of the two on the EcoFlow TITAN Plus.
EcoFlow TITAN 5000
What 15,000 Watts Delivers in Amps
Watts tell you total capacity, but outlets, breakers, and panels are all rated in amps, so converting between the two is what actually determines whether a circuit or hookup can handle this generator's output.
  • At 240V: A 15,000-watt generator produces roughly 62.5 amps.
  • At 120V: That same capacity delivers about 125 amps.
Knowing both numbers matters because a generator's total wattage is fixed, but how many amps that translates to depends entirely on which voltage a given circuit runs. A standard 30A or 50A transfer switch inlet, for example, is rated well below 62.5A. This generator can be put out at 240V, so matching the generator to a compatible transfer switch or panel connection matters just as much as its total wattage rating.
Amps and watts aside, the most useful question is simply how many of your own appliances can realistically run together.
How Many Major Appliances Can Really Run Together
This is where the abstract wattage numbers turn into a real answer for your specific setup.
  • A safe two-appliance combination: A well pump and washing machine running together stay comfortably within capacity, even accounting for both starting surges.
  • A tighter three-appliance combination: Adding a space heater or garage door opener to that pairing starts to use up meaningful headroom.
  • Where it breaks down: Central AC plus almost anything else with its own starting surge is where most 15,000-watt setups hit their ceiling.
To put real numbers on that first combination: a well pump and washing machine running together land around 2,100W of combined running load, with a worst-case starting spike near 3,300W if the washing machine's motor kicks in while the pump is already running. That leaves well over 11,000W of headroom, which is exactly why it counts as a safe pairing rather than a tight one.
How a home's circuits get grouped and prioritized during an outage decides which things stay on when capacity is limited, and sorting essential circuits from optional ones is worth doing well before an outage, not during one.
Is 15,000 Watts the Right Size for You?
The right size ultimately comes down to how many major systems you need running at the same time, not the biggest number you can find on a spec sheet.
  • Good fit for: Homes prioritizing two or three major systems at a time, a well pump, washing machine, and space heater, for example, without needing everything running at once.
  • Worth sizing up for: Homes that want central AC running alongside other major appliances simultaneously.
For RV owners specifically weighing air conditioning against a generator this size, weighing rooftop AC against hookup limits is worth working through in more detail.
Before settling on this size, it helps to plan around actual needs rather than worst-case assumptions. The U.S. Consumer Product Safety Commission notes that most fatal incidents tied to portable generators involve carbon monoxide poisoning from units run indoors or in partially enclosed spaces, a real cost of the fuel-based option that a battery system like EcoFlow TITAN or EcoFlow TITAN Plus sidesteps entirely, since there is no exhaust to manage in the first place. Planning ahead of an outage, rather than during one, also matters for anyone relying on medical devices or refrigerated medicine.
A 15,000-watt generator can run most standard home appliances individually, but the honest answer to whether it will run a house is two or three major ones at once, with central air conditioning's 8,000W starting surge as the single biggest factor in math. Before buying, list the two or three appliances you would actually need running together during an outage, and check their combined running-plus-highest-starting-watt total against this size rather than assuming it covers everything. The EcoFlow TITAN and EcoFlow TITAN Plus are worth comparing against a fuel-based generator this size, especially if quiet, maintenance-free backup power matters as much as raw capacity.
Will 15000 watts run a house?
It can run most individual appliances, but realistically, that means two or three major ones at once rather than an entire house simultaneously. Dozens of smaller loads add up faster than most people expect.
Will a 15 kW generator run central air conditioning?
Yes, on its own. Central AC's 8,000W starting surge takes up more than half the generator's capacity, though, so running it alongside other major appliances at the same time gets tight fast.
How many amps is a 15000 watt generator?
About 62.5 amps at 240V, or roughly 125 amps at 120V. Which number applies depends on the voltage of the specific circuit or hookup involved.
How many appliances can a 15000 watt generator run at once?
Typically, two to three major appliances comfortably, depending on their starting watts. A well pump and washing machine together are a safe combination, adding central AC to the mix is usually where the limit gets hit.
Is a 15000 watt generator enough for my home?
It depends on how many major systems need to run simultaneously. For homes that prioritize two or three at a time, this size fits well. Households that want central AC running alongside other major appliances may want to compare a larger option like the EcoFlow TITAN Plus instead.
Home Solutions
