What Hurricane Categories Really Mean When a Storm Heads for Canada
- What Are the Hurricane Categories on the Saffir-Simpson Scale?
- What a Hurricane's Category Doesn't Tell You
- How Hurricane Storm Categories Translate Into Power Outages at Home
- Tropical Storm, Hurricane or Post-Tropical Storm: How Canada Labels Storms
- Canadian Storms That Show the Category Scale in Action
- Conclusion
- FAQs
When a hurricane forecast turns toward the Maritimes, the first question is usually simple. What category is it? That number shapes how seriously many of us take a storm. Yet hurricane categories measure only one thing, and storms often change before they reach Canada. This article walks through the Saffir-Simpson scale in km/h. It also covers what the scale leaves out and how Canadian forecasters label and warn about these storms. Finally, it looks at what each category can mean for the power in your home.
The Saffir-Simpson Hurricane Wind Scale sorts hurricanes into five categories. It is based only on a storm's maximum sustained wind speed. The US National Hurricane Center (NHC) and the Canadian Hurricane Centre (CHC) both use it.
The Five Categories at a Glance
Category | Winds (km/h) | Winds (mph) | Typical Wind Damage (NHC) |
1 | 119 to 153 | 74 to 95 | Roof and siding damage, snapped branches, outages of a few to several days |
2 | 154 to 177 | 96 to 110 | Extensive damage, many fallen trees, near-total power loss |
3 (major) | 178 to 208 | 111 to 129 | Devastating damage, power and water out for days to weeks |
4 (major) | 209 to 251 | 130 to 156 | Catastrophic damage, outages of weeks to months |
5 (major) | 252 or higher | 157 or higher | Catastrophic damage, areas unlivable for weeks or months |
Categories 3 to 5 are called major hurricanes. That does not make Categories 1 and 2 safe. Both can bring down trees, power lines and roofs.
What Category 1 Hurricane Winds Can Do
Category 1 hurricane winds start at 119 km/h. That is enough to snap large branches and topple shallow-rooted trees. The CHC says falling trees are the main source of downed power lines. Winds also get stronger with height, so upper floors and exposed balconies may experience stronger gusts.
Is There a Category 6?
No. The scale officially stops at Category 5, which covers any storm at 252 km/h or more. Some researchers have discussed a higher level, but no agency has adopted one. The CHC adds that no Category 3 or stronger hurricane has ever hit land in Canada. Storms often weaken over cooler water as hurricane season reaches Atlantic Canada in late summer. They can still do serious damage.
A category gives a quick read on wind, but it leaves out other hazards.
The NHC is clear that the scale measures wind and nothing else. It does not account for storm surge, rainfall flooding or tornadoes. Storms of any category can bring all three.
Storm surge: The CHC calls surge the greatest hurricane hazard on land. Wind drives most of it, and tides and seabed shape also matter. Knowing how storm surge builds along coastlines helps you judge your street's risk.
Rain: The CHC says storm strength has little link to rainfall. A tropical depression can drop as much rain as a hurricane. Rates of 20 to 50 mm an hour are not unusual.
Size: A category says nothing about how wide a storm's rain and wind reach.
Waves: Some of the highest ocean waves ever measured were recorded in Canadian waters.
The CHC's hurricane hazards and impacts page covers each risk in detail. A "just a Category 1" storm can still cause serious harm.
Wind, rain and surge also strain the power grid, often for days.
Each step up the scale raises the odds of a long outage. The NHC expects outages of a few to several days at Category 1. In Atlantic Canada and eastern Quebec, even a strong post-tropical storm can cut power for days.
Getting Your Home Ready Before the Storm
The Government of Canada's Get Prepared hurricane checklist starts with a few simple steps:
Build a 72-hour kit with water, food, a flashlight, a radio and first aid supplies.
Charge phones and backup batteries while the grid is still up.
Clear drains and secure patio furniture, bins and other loose items.
Use flashlights, not candles, and keep fridge and freezer doors shut.
Run any fuel generator outdoors, never inside your home or garage.
Planning for a long outage in Nova Scotia looks a lot like planning across the region. Fiona showed that power outages in eastern Quebec can follow a storm inland.
Keeping Essentials Running in a Multi-Day Outage
A portable power station can run a fridge, lights, phone chargers and a Wi-Fi router without fuel or fumes. Runtime depends on what you plug in.
The DELTA 3000 Gen4 suits a home that keeps one unit ready through storm season. It accepts up to 1,000W of solar.
The DELTA 3800 Gen4 fits longer outages, with up to 2,000W of solar and expansion to 12kWh.
Both run 120V plug-in devices only, not 240V dryers, electric furnaces, baseboard heaters or a whole home. Fridge runtimes are "up to" figures and vary. Keep either unit dry and indoors, away from flooding. It charges between 0°C and 45°C and discharges between -10°C and 45°C.
Next, it helps to know the labels forecasters use.
Not every storm in the forecast gets a category. Environment and Climate Change Canada (ECCC) uses different names as a storm forms and changes.
The Stages of a Tropical Cyclone
Stage | Sustained Winds | What It Means |
Tropical depression | 37 to 62 km/h | Gets a number |
Tropical storm | 63 to 117 km/h | Gets a name |
Hurricane | 118 km/h or more | Gets a category from 1 to 5 |
Post-tropical storm | Varies | Lost tropical features but keeps its name |
Why Most Storms Reach Canada in Transition
As storms move north over cooler water, many go through extratropical transition. The CHC says most are in some stage of this change when they reach Canada, even Juan in 2003. The strongest winds shift right of the track, while rain spreads left.
Canada began using the "post-tropical" label in 1998 so dangerous storms could keep their names. It pays to know what hurricane remnants bring inland before the next one arrives.
How the Canadian Hurricane Centre Issues Information and Warnings
The CHC, based in Dartmouth, Nova Scotia, leads hurricane forecasting for Canada. It issues bulletins when gales could reach Canadian territory or waters within three days.
Product | When It Is Issued |
Information statement | Gales of 63 to 117 km/h possible within three days |
Tropical storm or hurricane watch | Conditions are a possible threat within 36 hours |
Tropical storm warning | 63 to 117 km/h winds expected within 24 hours |
Hurricane warning | 118 km/h winds or dangerously high water expected within 24 hours |
ECCC's tropical storm and hurricane warnings page says hurricane warnings apply only to tropical cyclones. Post-tropical Storm Noel in 2007 brought gusts of 130 to 140 km/h to Nova Scotia without one. Watch every ECCC alert, not just hurricane ones.
Real storms show how this plays out.
Two storms show why the category is only part of the story. One arrived as a hurricane, and the other did not.
Hurricane Juan (2003)
Landfall: September 29, 2003, between Shad Bay and Prospect, Nova Scotia, as a Category 2.
Winds: Sustained winds near 158 km/h, with gusts over 185 km/h.
Water: Halifax Harbour hit a record 290 cm water level.
Outages and toll: Some customers waited nearly two weeks for power. Eight people died, three in a fire believed to have started from candles.
Post-Tropical Storm Fiona (2022)
Status: A former Category 4 that became post-tropical before landfall in Nova Scotia on September 24, 2022.
Strength: Fiona was post-tropical when it made landfall in eastern Nova Scotia. The Canadian Hurricane Centre measured top winds of 179 km/h and a central pressure of 930 hPa, setting a new Canadian record for the lowest pressure measured over land.
Reach: Gusts over 100 km/h hit five provinces.
Power: More than 600,000 homes and businesses lost power, some for over two weeks.
ECCC's top weather stories of 2022 called Fiona likely the most damaging hurricane in Canadian history. A storm without a category can still leave lasting damage across Atlantic Canada.
Hurricane categories rank a storm's sustained winds from 1 to 5. They do not measure surge, rain or size. In Canada, most storms arrive in transition, and post-tropical storms can be just as destructive. Follow CHC statements and every ECCC alert, not just hurricane warnings. Then plan for days without power. An EcoFlow DELTA 3000 Gen4 or DELTA 3800 Gen4 can keep a fridge, lights and phones running indoors, depending on what you plug in.
What are the 5 categories of hurricanes?
Categories 1 and 2 cover 119 to 153 km/h and 154 to 177 km/h. Categories 3, 4 and 5 cover 178 to 208, 209 to 251, and 252 km/h or more.
What wind speed is a Category 1 hurricane?
Category 1 hurricane winds are sustained at 119 to 153 km/h, or 74 to 95 mph. Gusts can be higher.
Has a Category 5 hurricane ever hit Canada?
No. The Canadian Hurricane Centre says no Category 3 or stronger hurricane has ever hit land in Canada. Juan was a Category 2 at landfall, and Fiona was post-tropical by then.
Is a post-tropical storm less dangerous than a hurricane?
Not necessarily. Fiona was post-tropical at landfall and still caused record damage. These storms often spread heavy rain over a wider area.
How long can a portable power station run a fridge after a hurricane?
It depends on the fridge and other loads. EcoFlow testing shows up to 58 hours for the DELTA 3000 Gen4 and up to 70 hours for the DELTA 3800 Gen4.
