How a Dual Fuel Heat Pump System Splits the Work Through a Canadian Winter
Canadian winters are long, but most of the season is not the deep cold. Many days sit near or just below freezing. That is where a dual fuel heat pump makes sense. It pairs an electric heat pump with a gas or propane furnace. The heat pump covers milder days, and the furnace takes over when it gets truly cold. This guide explains how the switch happens, what drives savings and which rebates apply. It also covers what happens when the power goes out.
What Is a Dual Fuel Heat Pump System?
A dual fuel heat pump system uses two heat sources that share one set of ducts. An electric heat pump does most of the heating. A furnace steps in when the heat pump is no longer the best choice.
The Two Halves of a Hybrid Setup
The outdoor unit moves heat from outside air into your home, and in summer it cools. The way a heat pump moves heat is the same as in an all-electric system.
The furnace keeps its burner, blower and controls. Its blower pushes air across both the heat pump coil and the furnace, so ducted forced-air homes are the usual fit. Many quotes call this a hybrid heating system.
Only One Heat Source Runs at a Time
Natural Resources Canada's guide to heating with a heat pump says a hybrid furnace cannot run alongside the heat pump. A control system selects which heat source operates.
Part | Fuel | Main job |
Outdoor heat pump | Electricity | Mild days and summer cooling |
Furnace | Natural gas or propane | The coldest days |
Blower | Electricity | Moves air for both |
Thermostat or control board | Electricity | Chooses the heat source |
Why Dual Fuel Suits Colder Parts of Canada
Air-source heat pumps lose capacity as the air gets colder. NRCan notes that newer models typically cut out between minus 15°C and minus 25°C. Many Canadian winter nights drop below that.
Dual fuel lets the heat pump handle days near freezing while the furnace covers cold snaps. It can suit gas-served homes in the Prairies, Northern Ontario and the BC Interior.
So how does the system decide when to switch?
How Does a Dual Fuel Heat Pump Decide When to Switch?
The handoff happens at an outdoor temperature called the switchover point. Where it sits shapes your comfort, bills and emissions.
Thermal Balance Point
This is the temperature below which the heat pump lacks the capacity to heat the home alone. A tighter house or a unit built for cold climate winter performance lowers it.
Economic Balance Point
This point is about cost. Below it, the furnace becomes cheaper to run than the heat pump. It depends on your electricity and fuel rates and the efficiency of each unit. NRCan notes that hybrid controls can switch at either balance point.
How the Controls Make the Call
Outdoor temperature sensor: Locks out the heat pump below a fixed set point.
Dual fuel thermostat: Switches at your chosen temperature using a sensor or weather data.
Smart switching controls: Weigh energy prices, time of use and temperature to pick the cheaper source.
Rebates can set limits too. FortisBC requires a switchover of 5°C or lower on Vancouver Island and the Lower Mainland, and 2°C or lower elsewhere in BC.
All of this works while the grid is up. The catch is that every part needs electricity.
Does a Dual Fuel Heat Pump Work During a Power Outage?
Many homeowners assume the gas furnace keeps heat going in a blackout. It usually does not, because both halves depend on electricity.
Why the Furnace Stops Too
The heat pump stops first. The City of Brandon's loss of utilities guidance notes that most natural gas furnaces need electricity to operate. The blower, igniter, control board and thermostat all run on household power.
Knowing how long a house stays warm without power helps you decide which loads matter most.
Furnace Circuit vs Heat Pump Circuit
Circuit | Typical voltage | Backup notes |
Gas furnace | 120V | Smaller load, usually backed up first |
Outdoor heat pump | 240V | Heavier load with high startup demand |
Electric heat strips | 240V | Very heavy, often left off |
Backing up the furnace alone can keep heat running. Adding the heat pump drains stored energy much faster.
Backing Up Selected Heating Circuits With a Home Battery
A furnace is usually hard-wired, so it cannot plug into a battery. It needs the compatible Smart Home Panel 10 (SHP10), installed by a qualified electrician.
The SHP10 covers up to 10 selected circuits, not every appliance at once.
Switchover takes under 20 ms, which is fast but not zero interruption.
Runtime depends on blower draw, cycling and other loads.
If you may also back up the heat pump circuit, consider the TITAN 5000 Plus. It offers 7.2kW of 120V/240V output and up to 8kW of solar input.
The TITAN 5000 offers the same 7.2kW, 120V/240V output, plus generator charging for long outages.
Plug-in devices run directly from either unit, while home circuits need the SHP10. Both are IP20 indoor units that charge between 0°C and 45°C, so keep them dry and heated. Card savings are modelled Toronto estimates on Ontario's ULO plan.
Next comes the money side.
Dual Fuel Heat Pump Costs, Savings and Rebates in Canada
Savings depend on local energy prices more than on the equipment. The same system can save money in one province and break even in another.
How to Think About Running Costs
Electricity vs fuel rates: These set your economic balance point.
Equipment efficiency: Better units shift more hours to the cheaper source.
Time-of-use pricing: Smart controls can lean on the furnace at peak hours.
Fixed gas charges: Monthly delivery charges continue because the gas service stays.
Propane homes often gain more, since propane usually costs more per unit of heat. NRCan's hybrid home heating research near Ottawa found operating costs similar to a gas furnace alone. Emissions fell 30 percent over one season. Upfront heat pump installation prices across Canada vary widely, so get several quotes.
Rebates That Treat Dual Fuel Differently
Here is the status in November 2026. Confirm the details before you book.
Program | Region | How it treats dual fuel |
FortisBC dual fuel heating system rebate | BC | Up to $4,000 for installs from October 15, 2026, replacing a gas furnace at least 15 years old. No stacking with provincial or federal rebates. |
CleanBC Energy Savings Program | BC | Income-qualified dual fuel rebates for gas and propane homes, reduced July 6, 2026. |
Home Renovation Savings Program | Ontario | Furnace can be new or existing but is not rebated. Enbridge Gas homes get $500 per ton, up to $2,000. |
National Heat Pump Rebate | Federal | $2,000, or up to $10,000 for lower-income households. Hybrid rules are not spelled out yet. |
The National Heat Pump Rebate details say applications open in early 2027 for installs from November 1, 2026. The heat pump must be able to heat the whole home. Compare current heat pump rebates across Canada with your utility's listings.
Finally, check whether your home is a good match.
Is a Dual Fuel Heat Pump Right for Your Home?
Dual fuel fits some homes far better than others. Your ducts, furnace age and fuel prices all matter.
Install Considerations Before You Commit
Ductwork: You need a forced-air furnace and ducts.
Furnace age: An old furnace may need replacing soon anyway.
Sizing: Ask for a CSA F280 room-by-room heat load calculation.
Compatibility: Many rebates ask for a matched AHRI reference number.
Controls: You need a dual fuel thermostat with an outdoor sensor.
Electrical panel: The outdoor unit needs its own 240V circuit.
Pros and Cons of a Dual Fuel Heat Pump
Pros | Cons |
Efficient heat on mild days | Two systems to maintain |
Strong furnace heat in deep cold | Fixed gas charges continue |
Replaces your air conditioner | Burns fuel on the coldest days |
Keeps a working furnace | Savings depend on local prices |
If you are still weighing a full switch, compare a heat pump vs a furnace first. Dual fuel then becomes a middle path rather than a default.
A dual fuel heat pump lets an electric heat pump handle most winter days while a gas or propane furnace covers the deep cold. The switchover point, set by capacity or cost, shapes your savings. Rebates vary by province, so confirm current rules first. Remember that both halves need electricity. An EcoFlow TITAN 5000 or TITAN 5000 Plus with a compatible SHP10 can keep selected heating circuits running during outages, depending on load.
What temperature should a dual fuel heat pump switch to the furnace?
There is no single right number. It depends on your heat pump's cold-weather capacity and your local energy prices. Some programs set a limit, such as FortisBC's 5°C or 2°C maximum, depending on region.
Can I add a heat pump to my existing furnace?
Often, yes, if the furnace and ducts are in good shape. The indoor coil must be compatible with the furnace blower. A contractor should check the furnace's age before you commit.
Is a dual fuel system better than an all-electric heat pump?
It depends on your climate, fuel prices and goals. Dual fuel can suit very cold regions with gas service. An all-electric cold-climate heat pump avoids gas bills and on-site fossil fuel use.
Does a dual fuel heat pump work with propane?
Yes. Many systems pair a heat pump with a propane furnace. Because propane often costs more per unit of heat, the heat pump may carry more of the season.
Will my gas furnace run during a power outage?
Usually not. Most gas furnaces need electricity for the blower, igniter and controls. A home battery connected through a compatible panel, installed by a qualified electrician, can keep the furnace circuit running for a time.
