What Canadian Homeowners Should Know Before Buying a Standby Emergency Generator
- What Is a Standby Emergency Generator and How Does It Work?
- How to Size a Standby Generator for Your Canadian Home
- Standby Generator vs Home Battery Backup: An Honest Comparison
- Standby Generator Installation in Canada: Cost, Permits and Safety
- Keeping a Standby Generator Ready Through Canadian Winters
- Conclusion
- FAQs
An ice storm knocks out power just after dinner. A few seconds later, the lights come back on by themselves. That is the promise of a standby emergency generator. It sits outside your home and starts automatically when the grid fails. It is also a permanent install with fuel lines, permits and yearly upkeep. This guide covers how these systems work, sizing, Canadian costs, codes, safety and winter care. It also shows how a fuel-free home battery system compares as an option.
A standby generator is a permanently installed engine generator that powers your home during an outage. It is wired into your electrical system and runs on natural gas or propane. Unlike a portable generator, you don't need to move it into position or manually refuel it during operation.
The Automatic Transfer Switch Does the Thinking
The automatic transfer switch (ATS) watches utility power. When it detects an outage, it signals the generator to start and transfers the connected circuits once generator power is stable. Most systems restore power within seconds, not instantly. When grid power returns, the switch moves you back and the generator shuts off.
Ontario's Electrical Safety Authority (ESA) says a permanently connected generator must have a transfer device. It stops generator power from flowing back into utility lines and endangering line workers. Knowing how a standby generator responds to outages helps you judge which features matter.
Natural Gas or Propane?
Many residential models can run on either fuel after a simple setup change.
Fuel | Best fit | Things to know |
Natural gas | Homes already on a gas line | No refills. Supply depends on the utility's gas network. |
Propane | Rural homes without gas service | Tank size limits runtime. Deep cold slows propane vaporization, so tank sizing matters. |
Your installer will confirm meter or tank capacity for full load. With the basics clear, the next question is how much generator your home needs.
Sizing decides what stays on during an outage and how much you pay. An undersized unit struggles, while an oversized one costs more to buy and run.
Whole-Home vs Essential-Circuit Backup
ir-cooled home standby generators commonly range from about 8 to 26 kW. You can size for one of two goals:
Essential circuits: Furnace blower, fridge, sump or well pump, lights and internet. This needs a smaller unit and transfer switch.
Whole-home: Everything, including central air and an electric range. This needs a larger unit, often with load management.
Baseboard heat, electric backup heat and EV chargers can push the size up sharply. Working out how much backup power your home needs starts with a list of loads you cannot do without.
Buying Criteria That Matter More Than the Brand
There is no single best home standby generator for every house. Compare models on these points:
Rated kW on your fuel: Output is usually lower on natural gas than on propane.
Transfer switch: Sized to your panel. Some units are sold without one.
Cold-weather kit: Battery and oil warmers help starts in deep cold.
Local service: A nearby dealer matters more than a long spec sheet.
It is also worth asking whether a fuel-burning generator is the right tool.
A standby generator is not the only automatic option. A home battery system can also switch on when the grid fails. The two work very differently, and each has real limits.
Factor | Standby generator | Home battery system |
Switchover | Engine starts and transfers within seconds | Very fast, with a brief interruption |
Fuel | Natural gas or propane | None. Recharges from grid or solar |
Runtime | As long as fuel lasts | Depends on stored energy and load |
Emissions and noise | CO exhaust and engine noise | No exhaust, some fan noise |
Upkeep | Oil, filters, battery, yearly service | Little routine upkeep |
Best fit | Long outages and large loads | Selected circuits, shorter outages, solar homes |
A generator handles multi-day outages better if fuel keeps flowing. A battery avoids exhaust and engine upkeep but backs up selected circuits within its output. Weighing battery backup against a fuel generator helps clarify which trade-offs fit your home.
Home Battery Options to Consider
Two EcoFlow models fit this comparison. Both offer 7.2kW of battery output and support 120V/240V home circuits through a compatible panel.
The TITAN 5000 Plus suits homes planning to add solar. Its 8kW solar input helps it recharge during longer outages.
The TITAN 5000 accepts up to 4kW of solar and supports generator charging during a long outage.
Plug-in devices run directly from either unit. Home circuits and hard-wired appliances need the compatible SHP10 installed by a qualified electrician. The SHP10 covers up to 10 selected circuits, not every appliance at once. Switchover takes under 20 ms, not zero. Runtime depends on load. Both are IP20 indoor units that charge between 0°C and 45°C. Card savings are modelled for a Toronto home on Ontario's ULO plan.
If a standby generator is still your choice, the next step is planning a safe and legal install.
A standby generator involves regulated electrical and gas work. Installation deserves as much attention as the unit itself. Rules differ by province and city, so confirm details locally.
What It Costs
Cost depends on size, fuel setup, the transfer switch and distance to the panel and meter. At large Canadian retailers, 22 kW class units list for roughly $5,500 to $10,000 CAD before installation. Some of those listings do not include a transfer switch.
Gas piping, wiring, a pad, permits and panel upgrades add to that. Recent Toronto contractor estimates put a 20 to 26 kW whole-home install at about $13,000 to $16,500 CAD. Get at least two itemized written quotes.
Permits, Inspections and Licensed Trades
Electrical: In Ontario, you must file a notification of work with ESA to connect a generator permanently. ESA strongly recommends a Licensed Electrical Contractor. Other provinces have their own authority, such as Technical Safety BC.
Gas: Work must meet the CSA B149.1 Natural Gas and Propane Installation Code and be done by a licensed gas fitter. Ontario's Technical Standards and Safety Authority (TSSA) oversees fuel safety.
Approved equipment: ESA notes that using unapproved electrical equipment is against the law in Ontario. Look for a recognized mark, such as CSA or cUL.
Base: TSSA guidance calls for a firm, level foundation for small standby units. Where the manufacturer is unclear, the top should sit at least 2 inches above the surrounding ground.
Planning a natural gas home generator installation means calling your gas utility early about meter capacity.
Clearances, Noise and Bylaws
Placement follows the manufacturer's instructions, the gas code and local rules. Installers keep units away from windows, doors, vents and air intakes. Many cities have noise or setback bylaws, and some limit self-test hours.
Carbon Monoxide Safety
Every fuel-burning generator produces carbon monoxide (CO), a gas you cannot see or smell. Health Canada's carbon monoxide prevention page advises directing generator exhaust away from open windows and doors. It also advises closing the windows and doors closest to or downwind from the generator.
Install CO alarms with battery backup in hallways outside sleeping areas, since smoke alarms do not detect CO. In Ontario, the provincial carbon monoxide safety rules require alarms in homes with fuel-burning appliances. Since January 1, 2026, those alarms are also required on every storey.
Once installed, a standby generator is only as reliable as its upkeep.
A standby generator may sit idle for months, then need to start in a blizzard. Regular maintenance makes that start likely.
Self-test cycle: Most units run a short automatic exercise, often weekly. Check the controller for warnings.
Oil and filters: Follow the manual's schedule for oil, oil filter, air filter and spark plugs.
Starting battery: A weak battery commonly causes failed starts. Test it before winter.
Snow and ice: Keep the enclosure, air intakes and exhaust clear. Never pile snow against the unit.
Yearly service: Book a qualified technician each fall.
Propane level: Keep the tank well filled before storm season.
Logging each task on a regular generator maintenance schedule makes it easier to spot problems early. Keep the records, since warranties may require them.
A standby emergency generator offers automatic, long-running backup, but it is a serious install. Size it around the loads you truly need. Choose approved equipment and use licensed trades for permits, gas and wiring. Then keep up with self-tests and winter care. If you would rather skip fuel and engine upkeep, a home battery can cover selected circuits. The EcoFlow TITAN 5000 and TITAN 5000 Plus with a compatible SHP10 are worth comparing.
What size standby generator do I need for my house?
It depends on what you want to run. Electric heat, central air and well pumps raise the size, so ask an electrician for a load calculation.
Do I need a permit to install a standby generator in Canada?
In most cases, yes. Permanent electrical and gas connections are regulated work, so check with your provincial authority and city.
How long can a standby generator run during an outage?
On natural gas, it runs as long as supply holds, with pauses for oil checks. On propane, runtime depends on tank size and load.
Can a standby generator be installed close to the house?
It usually sits outside near the gas meter and panel. Distances from windows, doors and vents come from the manufacturer, the gas code and local bylaws.
Is a home battery a good alternative to a standby generator?
It can be, for selected circuits and shorter outages. A TITAN unit with the compatible SHP10 switches over automatically without fuel, but runtime depends on load.
