What Are Renewable and Nonrenewable Energy? A Simple Guide for Canadian Homes
Every time you flip a light switch, the power comes from somewhere. In Canada, it might come from a river in Quebec, a gas plant in Alberta, or a nuclear station in Ontario. Some of these sources refill themselves naturally. Others are dug out of the ground and will eventually run out. Knowing the difference helps you understand your power bill, your province's grid, and your options at home. This guide explains both types in plain language and shows where Canada's electricity comes from today.
What Are Renewable and Nonrenewable Energy Resources?
Energy sources fall into two big groups. The difference comes down to one question: can nature replace it as fast as we use it? Here is how each group works, with simple examples.
Renewable Energy: Power That Refills Itself
Renewable energy comes from natural sources that keep coming back. The sun rises every day, the wind keeps blowing, and rain refills rivers. These sources renew on a human time scale, so we will not run out of them. Most of them also release little or no greenhouse gas while making electricity.
Non-Renewable Energy: Fuels That Run Out
Non-renewable energy resources come from materials that took millions of years to form. Coal, oil and natural gas are fossil fuels made from ancient plants and animals. Once we burn them, they are gone for good. The supply is large, but it is limited. Canada draws on all of the four main non-renewable fuels for power, heat or transport.
Examples of Renewable and Non-Renewable Energy
Source | How It Makes Energy | Renewable or Not |
Solar | Panels turn sunlight into electricity | Renewable |
Wind | Turbine blades spin a generator | Renewable |
Hydro | Moving water spins turbines at dams | Renewable |
Biomass | Wood, crop waste or garbage is burned for heat or power | Renewable if regrown as fast as it is used |
Geothermal | Underground heat makes steam or warms buildings | Renewable |
Coal | Burned to boil water and make steam | Non-renewable |
Oil | Refined into gasoline, diesel and heating oil | Non-renewable |
Natural gas | Burned in power plants and home furnaces | Non-renewable |
Nuclear (uranium) | Splitting uranium atoms makes heat for steam | Non-renewable, but low emitting |
Nuclear power is a special case. It releases almost no greenhouse gas while running, so Canadian government reports group it with non-emitting sources. Still, uranium is a mined metal with a limited supply. That is why uranium makes nuclear non-renewable, even though many people call it clean energy.
With the two groups clear, the next question is practical. Which of them actually keep the lights on across Canada?
Where Does Canada's Electricity Come From?
Canada makes a larger share of its electricity from renewable sources than many countries. Still, the mix is not the same everywhere. Your province decides how much of your power comes from water, wind, gas, coal or uranium.
Canada's Electricity Mix by Source (2025)
Canada generated 639.5 TWh of electricity in 2025, according to Statistics Canada's 2025 electricity generation analysis. Hydro, wind and solar together supplied roughly 64.1% of it. Add nuclear, and more than three in four units came from sources without direct emissions.
Source | Share of Generation (2025) | Group |
Hydro | 54.5% | Renewable |
Combustible fuels (mostly natural gas, plus coal, oil and biomass) | About 23% | Mostly non-renewable |
Nuclear | About 13% | Non-renewable, non-emitting |
Wind | 8.2% | Renewable |
Solar | 1.4% | Renewable |
The mix shifts with the weather. Drought and record heat cut hydro output by 8.4% in 2023. Dry conditions continued, and hydro's 2025 share was its lowest since Statistics Canada redesigned the series in 2016.
Combustible fuel generation rose 6.6% in 2025. Wind and solar hit record highs, and how wind and solar are growing varies a lot between provinces.
How the Mix Changes From Province to Province
Some provinces run almost entirely on water power. Others still lean on fossil fuels. The figures below come from the Canada Energy Regulator's Renewable Energy in Canada profiles, which use 2023 data.
Province | Main Sources (2023) | Mostly Renewable or Not? |
Manitoba | Hydro about 97%, wind about 3% | Renewable |
Quebec | Hydro about 94%, wind about 5% | Renewable |
British Columbia | Hydro about 87%, biomass about 7% | Renewable |
Ontario | Nuclear about 51%, hydro about 25%, natural gas about 14% | Mixed, mostly non-emitting |
Alberta | Mostly natural gas, with wind about 13% and solar about 3% | Mostly non-renewable |
Saskatchewan | Natural gas about 49%, coal about 32%, hydro about 11% | Non-renewable |
Nova Scotia | Coal about 47%, natural gas about 22%, wind about 15% | Mostly non-renewable |
Alberta — Mostly natural gas, with coal still contributing in 2023; wind and solar were growing. Alberta has continued expanding its wind and solar capacity, while natural gas remains a major source of electricity generation.
Whatever your province's mix, there are steps you can take at home to use more clean power.
How Canadian Households Can Use More Renewable Energy
You do not have to wait for the grid to change. Households can cut their energy use, make their own solar power, and save it for later. These three steps work best together.
Start With Energy Efficiency
The cleanest energy is the energy you never use. Sealing drafts, adding insulation and switching to LED bulbs all cut demand. Small everyday habits that lower electricity use also add up over a year. Using less power means any solar system you add can be smaller.
Add Rooftop Solar Where It Makes Sense
Solar panels let you make renewable electricity right on your roof. Results depend on roof angle, shade and location. Before buying, weigh what rooftop solar costs at home against your yearly power use. Connecting panels to your home's wiring calls for a qualified electrician and any local permits.
Store Solar Power for Later
Solar panels peak at midday, when many people are at work. A home battery stores that extra energy for the evening or an outage. That way, more of your own renewable power gets used at home. The two EcoFlow TITAN models below are built for this kind of storage, and both work with the grid.
The TITAN 5000 Plus suits homes with larger rooftop arrays. It accepts up to 8kW of solar across two 4kW inputs. Its battery alone delivers 7.2kW, or up to 10kW combined with compatible solar.
The TITAN 5000 fits homes with a smaller solar setup. It accepts up to 4kW of solar, runs at 120V/240V, and can also charge from a generator.
Plug-in devices run from either unit directly. Home circuits and hard-wired appliances need the compatible SHP10, installed by a qualified electrician. The SHP10 covers up to 10 selected circuits, not every appliance at once. Both units are rated IP20, so they belong indoors in a dry spot. Runtime always depends on what you run.
Every energy choice involves trade-offs, at home and on the grid. Here is how the two groups compare side by side.
Pros, Cons and Environmental Impacts of Each Energy Type
No energy source is perfect. Renewables are cleaner but can depend on the weather. Non-renewable fuels are steady but bring pollution and a limited supply.
Pros and Cons at a Glance
Factor | Renewable Energy | Non-Renewable Energy |
Supply | Refills naturally and will not run out | Limited and will eventually run out |
Emissions | Little or no greenhouse gas while running | Fossil fuels release carbon dioxide when burned |
Reliability | Solar and wind change with weather and season | Can run day and night on demand |
Fuel cost | Sunlight, wind and water are free | Fuel prices can swing sharply |
How Each Type Affects the Environment
Burning coal, oil and natural gas releases carbon dioxide, a gas that traps heat and drives climate change. Coal is the worst offender, and the gap in greenhouse gas emissions by power source is large. Fossil fuels also cause air pollution that can harm lungs and create smog.
Nuclear power avoids most air pollution. Its main challenge is radioactive waste, which must be stored safely for a very long time.
Renewables have impacts too, but they are usually smaller. Large dams can flood land and change fish habitat. Wind turbines can harm birds and bats. Over its lifetime, though, a solar or wind system produces far fewer emissions than a fossil fuel plant.
Renewable energy comes from sources nature keeps refilling, like sun, wind and water. Non-renewable energy comes from fuels that will run out, like coal, oil, gas and uranium. Canada already gets most of its electricity from renewables, but your province shapes your mix. At home, using less power and adding solar are smart first steps. Pairing panels with a home battery like the EcoFlow TITAN 5000 Plus or TITAN 5000 helps you use more of your own clean energy.
Is nuclear energy renewable or non-renewable?
Nuclear is non-renewable because it runs on uranium, a mined metal with a limited supply. It is low emitting, though. That is why Canadian government data groups it with non-emitting sources.
What is the most common renewable energy in Canada?
Hydro is the largest by far. It made about 55% of Canada's electricity in 2025, according to Statistics Canada. Wind is a distant second at about 8%.
Will non-renewable energy resources run out?
Yes, eventually. Coal, oil, natural gas and uranium form over millions of years, so we use them far faster than nature replaces them. Exact timelines depend on demand and new discoveries.
Is biomass always renewable?
Only when it is managed well. Biomass counts as renewable when trees or crops are replanted as fast as they are used. Burning it still releases smoke, so clean equipment matters.
Can a Canadian home run on solar power alone?
Some can, but it is hard for most homes. Winter days are short, and heating needs are high. Most homes with solar stay connected to the grid and use a battery to store extra daytime power.
