Storm Surge Explained: Causes, Risk, and How to Prepare
The wind and rain get most of the attention during a coastal storm. It's often the rising water that does the real damage. This guide covers what a storm surge actually is. It covers what causes one. It covers where the risk is highest in Canada. It also covers how to prepare before the next warning goes out.
What Is a Storm Surge?
A storm surge is the abnormal rise in sea level caused by a storm, above the water level expected from the normal tide alone. It's measured as the height of water above what the tide would normally predict that day, with no storm at all.
Storm tide is a related but different term. It's the total water level during a storm. It combines the surge itself with the normal astronomical tide happening at the same time. That distinction matters. The two numbers can differ a lot. A surge that arrives at low tide looks very different from the same surge arriving at high tide.
According to NOAA, storm surge is the greatest threat to life during a hurricane. It ranks ahead of wind damage itself. The water, not the wind, has historically caused the highest death tolls in major coastal storms.
The highest storm tides tend to occur when a storm's surge lines up with a new or full moon. That's when the sun, moon, and earth are aligned. Tides are already running higher than usual at that point. This coincidence can turn an otherwise moderate storm into a much more damaging one.
Knowing what a storm surge is explains the effect. Understanding what causes one explains why some storms are far worse than others.
What Causes a Storm Surge
Wind is the main driver. A storm's strongest winds physically push ocean water toward the coast for hours before landfall. This piles water up against the shoreline faster than it can drain away.
Low atmospheric pressure adds a smaller effect. It contributes roughly 5 percent of the total rise in water level. The ocean surface bulges upward under a weaker atmosphere. It's a real contributor, just a minor one compared to wind.
A storm's category, size, and forward speed all matter too. A slower storm pushes water toward shore for longer. That builds a bigger surge over time. A fast-moving storm causes a shorter but sometimes sharper surge. The water doesn't have as much time to build, but the initial push can still be intense.
Coastline shape plays a bigger role than most people expect. Bays and estuaries can funnel and amplify a surge. The surge can grow well beyond what the open coast nearby experiences. The narrowing shoreline has nowhere for the water to spread out. That funneling effect is part of what makes certain Atlantic Canada communities so exposed. It's a factor that shows up clearly in how shifting atmospheric patterns are shaping the 2026 Atlantic hurricane season for the region.
The same wind and pressure system that drives a storm surge is usually what knocks out the power along the coast first. This often happens well before the surge itself arrives. Downed lines and damaged substations tend to fail hours ahead of peak flooding. That means backup power is worth having ready before the surge even builds.
EcoFlow DELTA 3 Max Plus (2048Wh)
• 3000 W Powerful Output: 6,000 W surge output. With X-Boost™ mode, it can support selected appliances rated up to 3,800 W, depending on the device and operating conditions. • 5 Ways to Charge, Ready in Just 43 Mins: Ready in Just 43 mins (0-80%) with generator charging. • 2-10 kWh Expandable Capacity: Easily scale up, and can achieve longer runtime with an EcoFlow Smart Generator featuring automatic start and stop. • Smart Output Priority: Choose which circuits stay powered via the app. Prioritize what matters and extend runtime when it counts most.
Understanding mechanics is one thing. Knowing where in Canada that mechanic actually turns into real risk is another.
Storm Surge Risk in Canada
Atlantic Canada is one of the Canadian regions most exposed to storm surge. The region spans roughly 42,000 kilometers of coastline. It covers sandy beaches, salt marshes, cliffs, and rock shores. Each type responds differently to rising water.
The Chignecto Isthmus and Tantramar Marshlands sit between New Brunswick and Nova Scotia. This low-lying land is a well-documented vulnerability. It's protected mainly by aging dikes, some dating back generations. These dikes were never designed for today's storm intensity. A breach here carries outsized consequences, since it's also the main road and rail link between the two provinces. A major flood there could cut off transportation as well as flood property.
The worst-case setup combines four things happening at once. A spring tide. A lunar perigee. The daily high tide. A powerful storm arriving on top of all three. Nova Scotia and Prince Edward Island have already seen that combination play out through coastal flooding from nor'easters moving through the Maritimes in recent years. The pattern isn't going away.
A storm surge can develop faster than people expect. That's part of why coastal communities are told to treat surge warnings seriously. Don't wait to see how bad conditions actually get before acting.
EcoFlow DELTA 3 Max (2048Wh)
•2400W Powerful Output: 4,800 W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3,400 W such as refrigerators, coffee makers, washers, and circular saws. •4 Ways to Charge, Ready in Just 68 Mins: Ready in 68 mins (0-80%) with Wall Charging or Generator Charging. •Lightweight and Easy to Carry: Weighing just 20.3 kg, 13% lighter than the previous generation 2 kWh product. • Long-Lasting, Durable, and Reliable: Equipped with automotive-grade full-tab LFP cells, offering 10 years of reliable power, 24/7 protection BMS, and EV-grade CTC structure that protects against overnight condensation and off-road bumps during transport.
With the risk mapped out, the next question is how forecasters actually see a surge coming before it arrives.
How Storm Surge Is Forecast and Measured
what is a surge stormwhat is a surge storm
Environment and Climate Change Canada and the Canadian Hydrographic Service monitor coastal water levels and issue storm surge warnings ahead of approaching systems, using a combination of tide gauges and storm modeling.
In the United States, NOAA's Center for Operational Oceanographic Products and Services runs similar mapping and monitoring, and Canadian forecasters also draw on that data for cross-border storm tracking, since major systems often move through both countries' waters.
Forecasts combine storm track, strength, and timing against the local tide schedule. The same storm can produce a very different surge depending on whether it arrives at high or low tide, which is exactly the kind of regional variation a hurricane season forecast for Atlantic Canada lays out year to year.
A storm surge warning is not the same as a hurricane warning. A weaker storm can still produce a dangerous surge if it lines up with the wrong tide and the wrong stretch of coastline, which is why the two warnings sometimes don't match the intensity people expect.
Forecasting buys time. What a household actually does with that time is what determines how the storm goes.
How to Prepare for a Storm Surge
  • Know your evacuation zone. Storm surge evacuation zones are usually separate from general flood zones, so a property that's safe from river flooding isn't automatically safe from surge. Check this before a warning is issued, not after.
  • Move vehicles and valuables early. Get vehicles, important documents, and valuables above expected flood levels ahead of time. Secure or elevate anything in a basement or ground-floor space that can't be moved out entirely.
  • Plan for the power outage, not just the water. Power outages are one of the most common and longest-lasting effects of a coastal storm. A household's ability to keep a fridge, medical equipment, or communication running often matters more day to day than the storm itself, which is exactly the problem a resilient home energy setup built around battery backup is meant to solve.
  • Charge everything before the storm arrives. Devices, power stations, and backup batteries should all be fully charged ahead of time. Charging becomes difficult or impossible once the outage starts, and waiting until the warning is already active leaves little margin for error.
A storm surge is the storm-driven rise in sea level. It often causes more damage than a coastal storm's wind. Atlantic Canada carries most of the country's exposure to it, driven by geography as much as storm frequency.
Know the local evacuation zone. Watch official storm surge warnings. Have backup power ready before a storm reaches the coast, not after. The DELTA 3 Max Plus and DELTA 3 Max linked above both cover the essentials through a coastal power outage, at two different price points.
What is the difference between a storm surge and a storm tide?
Storm surge is the rise in water caused solely by the storm. Storm tide is the total water level during the storm. It combines the surge with the normal astronomical tide happening at the same time.
What causes a storm surge to be worse in some areas than others?
Coastline shape is a major factor. Bays and estuaries funnel and amplify a surge well beyond what the open coast experiences nearby. That's why narrow inlets and marshlands often see the worst flooding.
Which parts of Canada are most at risk from storm surge?
Atlantic Canada carries most of the risk. The Chignecto Isthmus and Tantramar Marshlands between New Brunswick and Nova Scotia are a particularly well-documented vulnerability.
How much warning do you usually get before a storm surge hits?
It varies by storm. A surge can develop faster than expected once a system approaches the coast. That's why official warnings should be taken seriously rather than waiting to see how conditions look first.
What should I do if I live in a storm surge evacuation zone?
Know your zone before a warning is issued, since it's usually separate from general flood zones. Move vehicles and valuables above expected flood levels. Follow evacuation instructions immediately once they're given.
How long do power outages from coastal storms usually last?
It depends on the extent of damage to the local grid. Outages following a major coastal storm commonly run from several hours to multiple days. Downed lines or substation damage often require repair crews to reach affected areas.
