Battery Types Made Simple: Which Chemistry Fits Your Home and Devices?
Walk down any battery aisle in Canada and the labels start to blur. Alkaline, lithium, NiMH and rechargeable all promise long life. The right battery types for your home depend on how you use a device, cold exposure and power needs. A smoke alarm, a game controller and a backup power station each need something different. Picking the wrong one can mean dead cells when you need them most. This guide explains the main chemistries in plain language, settles the NiMH versus lithium question and covers safe storage and recycling in Canada.
Primary vs Rechargeable Batteries: The First Big Split
Every battery falls into one of two groups. Primary batteries are used once and then recycled. Rechargeable batteries, also called secondary batteries, can be charged and used again many times.
Primary batteries suit devices that sip power slowly or sit unused for months, like wall clocks and TV remotes. Rechargeable batteries make more sense for devices you use daily, such as game controllers and power tools. Recharging the same cells saves money and cuts waste over time.
Chemistry and size are two different things. A AA cell can be alkaline, lithium or NiMH, and each behaves differently. The same is true for the AA, AAA and other common sizes sold in Canadian stores. Always check the chemistry on the label, not just the size.
Once you know which group a battery belongs to, the next step is comparing the chemistries inside each group.
Common Battery Types at a Glance
Each chemistry balances energy, lifespan, cost and cold tolerance in its own way. The table below sums up the types most Canadian households will meet. Figures are typical ranges and vary by brand, design and how the battery is used.
Battery type | Rechargeable? | Energy (Wh/kg) | Cycle life | Self-discharge | Cold performance |
Alkaline | No | Moderate | Single use | Low; keeps for years | Capacity drops below freezing |
Lithium primary | No | High | Single use | Very low | Strong; many rated for deep cold |
Lead-acid (flooded, AGM) | Yes | 30 to 50 | 200 to 300 deep cycles | About 5% a month | Loses capacity; a flat battery can freeze |
NiCd | Yes | 45 to 80 | About 1,000 | High | Good |
NiMH | Yes | 60 to 120 | 300 to 500 full cycles | High; lower on low self-discharge cells | Fair; slows in deep cold |
Lithium-ion (NMC) | Yes | 150 to 220 | 1,000 to 2,000 | Low | Do not charge below 0°C |
LFP (LiFePO4) | Yes | 90 to 120 | 2,000 or more | Low | Do not charge below 0°C |
Lead-Acid and AGM Batteries
Lead-acid is the oldest rechargeable chemistry still in wide use. It is heavy for the energy it stores, but cheap and dependable. AGM is a sealed version that needs no water top-ups. Many 12V batteries in cars and RVs still rely on this chemistry today.
Lithium-Ion Chemistries: NMC vs LFP
Lithium-ion is a family, not one battery. NMC (nickel manganese cobalt) packs a lot of energy into phones, laptops and many EVs. LFP (lithium iron phosphate) stores less energy by weight but lasts for more cycles. Battery University lists its thermal runaway point at about 270°C, compared with about 210°C for NMC. The trade-offs between LFP and other lithium-ion chemistries matter most for large batteries that cycle often.
The two rechargeable chemistries people compare most often are NiMH and lithium-ion, so they deserve a closer look.
NiMH vs Lithium-Ion: How They Really Compare
NiMH and lithium-ion are both rechargeable, but they suit very different jobs. NiMH is the classic rechargeable AA and AAA. Lithium-ion powers almost everything with a built-in battery, from phones to home backup units.
What People Mean by a Li MH Battery
Searches for a li mh battery usually blend NiMH (nickel metal hydride) and lithium-ion. No common household battery is sold as "Li MH." Ni-MH on a label means nickel metal hydride, while Li-ion or LiFePO4 means lithium-based.
NiMH vs Li-Ion Side by Side
The biggest differences come down to energy, voltage and how each cell holds charge. Lithium-ion stores far more energy for its weight.
Factor | NiMH | Lithium-ion |
Nominal cell voltage | 1.2V | About 3.6V (NMC) or 3.2V (LFP) |
Energy density (typical) | 60 to 120 Wh/kg | 90 to 220 Wh/kg, by chemistry |
Self-discharge | High on standard cells; low self-discharge versions hold charge longer | Low |
Memory effect | Mild; much less than NiCd | Not a practical concern |
Safety management | Simple; needs a compatible charger | Needs a battery management system |
A standard lithium-ion cell should never be used as a direct replacement for a 1.2V NiMH AA cell. Lithium primary AA batteries are typically 1.5V and are not rechargeable. Some rechargeable lithium-ion AA products include built-in voltage regulation, but they must be used only with devices and chargers approved by their manufacturer. Never attempt to recharge a primary lithium AA battery.
When You Need More Than AA: LFP in Home Backup
At household scale, the NiMH vs lithium question has a clear answer. NiMH packs are too heavy and too short-lived for storing several kilowatt-hours. Many home backup power stations now use LFP for its long cycle life. The long cycle life of LFP is a big reason it has replaced older chemistries in this role.
EcoFlow says both units below keep 70% of their original capacity after 6,000 cycles in lab testing. Real runtime depends on what you plug in.
The DELTA 3000 Gen4 is a practical example of LFP sized for plug-in household backup.
The DELTA 3800 Gen4 shows how LFP scales up for longer outages. Its expansion batteries add stored energy and runtime, not extra output.
Both units run 120V plug-in appliances only, not 240V loads like furnaces or dryers. They charge between 0°C and 45°C, so keep them indoors rather than in a cold garage or shed.
Knowing how the chemistries compare makes it easier to match each device in your home to the right battery.
Choosing Battery Types for Household Devices
The best battery is the one that matches how a device uses power. A remote that runs for a year on one set has different needs than a controller used every night.
Device or use | Good fit |
TV remotes, wall clocks | Alkaline or low self-discharge NiMH |
Smoke and CO alarms | The battery the alarm maker specifies |
Game controllers, wireless mice | NiMH rechargeable |
Outdoor sensors, trail cameras | Lithium primary |
Phones, laptops, power tools | Lithium-ion (built in) |
Home backup power | LFP power station |
Flashlights and radios are only part of the picture during an outage. Bigger loads like a fridge or modem call for choosing a home battery backup sized to what you need to keep running.
Choosing well is half the job. Handling, storing and recycling batteries safely is the other half.
Battery Safety, Storage and Recycling in Canada
Most batteries are safe when used and stored properly. Canada also has well-established drop-off programs, so used batteries should stay out of household garbage.
Swelling, Heat and Thermal Runaway
Lithium-ion batteries store a lot of energy in a small space. A damaged, overcharged or overheated cell can enter thermal runaway. That is a chain reaction where heat builds faster than it can escape. Knowing the warning signs of thermal runaway early helps you act before a fire starts. Stop using any battery that is swollen, dented, leaking or unusually hot.
Storing and Charging Batteries Safely
Health Canada's lithium-ion battery safety page recommends storing batteries at room temperature in a dry place. It also warns against charging below 0°C. Charge where you can watch the device, away from soft surfaces like a couch or bed. Use chargers with a recognized Canadian certification mark, such as CSA, cUL or cETL.
Recycling Batteries in Canada
Call2Recycle Canada accepts rechargeable household batteries weighing up to 5 kg each, including NiMH, NiCd, lithium-ion and small sealed lead-acid batteries. It also accepts common single-use batteries, such as alkaline, lithium primary and carbon-zinc cells. Larger automotive batteries are handled through separate recycling programs.
Rules differ by province. In Ontario, producers must run battery collection under the Batteries Regulation (O. Reg. 30/20).
Tape the terminals of lithium, small sealed lead-acid and 9V batteries with clear, duct or electrical tape. You can also seal each one in a clear bag.
Keep damaged lithium batteries out of regular collection boxes. Store them in sand or cat litter and call Call2Recycle for special handling.
Battery types differ more than the labels suggest. Alkaline and lithium primary cells suit low-drain devices that sit for months. NiMH is the practical rechargeable for AA and AAA gear. Lithium-ion wins on energy and weight, while LFP leads for cycle life at home scale. Match each device to its chemistry, store cells at room temperature and recycle them properly. For plug-in backup power, the EcoFlow DELTA 3000 Gen4 is a useful LFP option to compare.
Is NiMH or lithium better for everyday rechargeables?
For most AA and AAA devices, NiMH is the safer default. Those devices are designed around the 1.2V output that NiMH cells deliver. Lithium AA cells only make sense when sold as drop-in replacements with their own charger.
Is a “Li MH” battery a real type?
Not as a common household product. The term is usually a mix-up of NiMH and lithium-ion. Check the label for Ni-MH, Li-ion or LiFePO4 to know what you have.
Which battery type works best in Canadian winters?
Lithium primary cells generally handle deep cold best among single-use batteries. Rechargeable lithium batteries should not be charged below 0°C. Keep rechargeable gear and power stations indoors when temperatures drop.
How long do lithium-ion batteries last compared with NiMH?
Lithium-ion usually lasts more charge cycles, and LFP versions last the longest. NMC cells typically reach 1,000 to 2,000 cycles. NiMH often lands around 300 to 500 full cycles, depending on the cell and how it is used.
Can I throw batteries in the garbage in Canada?
It is best not to, and Health Canada advises against it. Household batteries can go to Call2Recycle drop-off sites and many municipal depots. Damaged lithium batteries need special handling, so call Call2Recycle or your municipality first.
