Hurricane Fiona: Impacts and Lessons for Atlantic Canada
Hurricane Fiona was a powerful 2022 storm that reached Atlantic Canada on September 24. It had become post-tropical, but it still carried hurricane-force winds, heavy rain, waves, and storm surge.
Fiona affected Nova Scotia, PEI, Newfoundland and Labrador, New Brunswick, and eastern Quebec in different ways. Environment and Climate Change Canada reported that more than 600,000 homes and businesses lost power.
For future storms, the EcoFlow DELTA 3 Ultra Series Portable Power Station (3072Wh) can support key plug-in loads. What it can run depends on output, stored energy, startup demand, and the total connected load.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
• 3600W AC output with 7200W surge output •3072Wh base capacity, expandable from 3–11kWh •6 charging options, with 0–80% in 48 minutes using solar + generator dual charging •10ms auto-switch plus Smart Output Priority for critical backup planning
Fiona's path shows why its changing classification did not reduce the danger.
What Happened When Hurricane Fiona Reached Canada?
Fiona came ashore in eastern Nova Scotia early on September 24, 2022, after becoming post-tropical. It still had sustained winds of 165 km/h and posed a severe threat.
The system formed as a tropical depression over the central Atlantic on September 14. It later caused severe damage in the Caribbean and reached Category 4 strength over the ocean.
As Fiona moved north, it grew wider and joined a mid-latitude weather system. This shift reshaped the storm and made it post-tropical shortly before Canadian landfall.
The centre crossed Cape Breton, then moved through the Gulf of St. Lawrence. It travelled towards southwestern Newfoundland, eastern Quebec, and Labrador before fading over the Labrador Sea.
Date or stage
Storm status or location
What it shows
September 14, 2022
Tropical depression formed
Fiona's life cycle began over the Atlantic
Before Canada
Fiona reached Category 4
This rating describes an earlier tropical stage
Early September 24
Post-tropical landfall in eastern Nova Scotia
The new structure still carried severe wind and water hazards
September 24–25
System crossed Atlantic Canada and eastern Quebec
Damage extended far beyond the landfall point
By September 26
System faded over the Labrador Sea
Fiona is now a past storm, not an active advisory
“Post-tropical” describes how a storm gets its power and how its winds are arranged. It doesn't make the storm safe or weak, though the Saffir-Simpson scale no longer applies.
Why Was Hurricane Fiona So Damaging in Atlantic Canada?
Fiona combined very low pressure, a broad wind field, heavy rain, large waves, and storm surge across several provinces.
ECCC recorded a minimum pressure of 932.7 millibars near the centre over Canadian land. Sustained winds reached 165 km/h when the system entered eastern Nova Scotia.
Some areas received 80 to 150 mm of rain or more. Gusts above 100 km/h occurred across five provinces, while some coastal areas saw surge near two metres.
Offshore waves averaged 12 to 15 metres at one buoy east of Cape Breton. Its highest recorded wave reached 30 metres. These figures came from different places and measure different hazards.
Fiona was also wide, so damaging weather reached far from its centre. Many trees still held their leaves, while wet soil gave their roots less support.
  • Wind brought down trees, poles, roofs, and other structures.
  • Rain flooded roads, basements, culverts, and drainage systems.
  • Surge and waves damaged homes, wharves, shorelines, and low coastal areas.
  • Fallen trees, blocked roads, and damaged networks slowed the response.
In January 2023, the Insurance Bureau of Canada estimated more than $800 million in insured damage. This total leaves out some uninsured loss, public repair, and cleanup costs.
How Did Hurricane Fiona Affect Nova Scotia, PEI and Newfoundland?
Fiona caused broad wind and outage damage, but the worst local threat varied by region.
Region
Main reported impacts
Nova Scotia
Strong wind, heavy rain, fallen trees, coastal damage, and widespread outages
Prince Edward Island
Tree loss, erosion, road and bridge damage, outages, and phone failures
Destructive waves and storm surge in southwestern coastal communities
New Brunswick
Outages, fallen trees, and damage near the Northumberland Strait
Eastern Quebec
High waves, coastal flooding, wind, rain, and evacuations in the Magdalen Islands
Nova Scotia faced wind, rain, and widespread outages
Hurricane Fiona's Nova Scotia impacts began early on September 24. Cape Breton and nearby eastern areas faced strong wind and heavy rain.
Trees fell onto buildings, roads, and power lines. Coastal towns also dealt with large waves, surge, and erosion. Conditions varied by place, so one recorded gust can't represent the whole province.
PEI experienced an island-wide infrastructure emergency
Hurricane Fiona's PEI impacts reached almost the entire province. PEI's after-action report lists gusts from 111 to 149 km/h and more than 90 mm of rain in some places.
More than 82,000 customers lost power, while trees, homes, wharves, roads, and phone networks suffered damage. The report says crews didn't restore power across all of PEI until October 21, 2022.
The outage also hit phone towers, so some people struggled to make mobile calls or reach 911. This gap showed the need for more than one way to get help.
Southwestern Newfoundland faced destructive surge and waves
Port aux Basques and other southwestern towns faced severe coastal damage. Waves and surge destroyed or damaged homes, forced people to leave, and led to local orders.
Damaged roads also made assessment and cleanup harder. Fiona caused further impacts in New Brunswick, the Magdalen Islands, eastern Quebec, and Labrador, so it wasn't only a Nova Scotia storm.
Wind, coastal, and power-line damage across Atlantic Canada after FionaWind, coastal, and power-line damage across Atlantic Canada after Fiona
What Did Fiona Show About Power and Communication Outages?
Fiona damaged power lines across a wide area while trees, blocked roads, and failed phone networks slowed repairs.
More than 600,000 homes and businesses lost power, and some customers waited over two weeks. Crews first needed safe road access before they could reach many damaged poles and lines.
Power companies brought in crews from outside the region, while governments and the military helped clear debris and roads.
PEI showed how one failure can harm another service. Power loss hit phone towers, which cut access to mobile calls and 911 for some people.
Your household plan shouldn't rely on one phone or web link. Keep a battery-powered radio, written contacts, power company numbers, and a set meeting place.
Fiona's track maps are now historical. For a future storm, a hurricane tracker for Canada should lead you to current Canadian Hurricane Centre and local emergency updates.
Backup power covers only part of an outage plan, which must also include food, water, medicine, safe travel, and a clear route out.
How Should Atlantic Canadians Prepare for a Fiona-Like Storm?
Prepare before a watch or warning leaves too little time for outdoor work, travel, or safe setup.
Before hurricane season
  • Build a household plan and keep enough basic supplies for at least 72 hours.
  • Include children, older adults, pets, medicines, and powered health devices in the plan.
  • Choose an inland or higher place to go if surge or flooding threatens your home.
  • Check trees, drains, the roof, windows, garage door, foundation, and sump pump early.
  • Review your insurance and take photos of your home and key property.
  • Test radios, phone batteries, power banks, and approved backup systems.
The broader Atlantic Canada hurricane preparedness guide can help you build a full storm plan before a named system approaches.
When an official update raises the risk
  • Follow the Canadian Hurricane Centre, WeatherCAN, your power company, and local alerts.
  • Secure loose outdoor items while the work remains safe.
  • Charge phones, batteries, radios, and backup equipment.
  • Fuel or charge the vehicle you would use to leave.
  • Keep documents, medicines, water, and supplies ready to take with you.
  • Leave when local officials tell you to go.
Don't tape windows. Government of Canada guidance warns that tape may cause glass to break into larger pieces.
Atlantic Canadian household preparing an emergency kit before a stormAtlantic Canadian household preparing an emergency kit before a storm
How Can Backup Power Support a Hurricane Plan?
Battery backup can support key loads when it is safe to stay home. It can't stop storm damage or replace a plan to leave.
  1. List the devices and circuits that must run.
  2. Record each load's running watts and startup demand.
  3. Estimate its daily energy use in watt-hours.
  4. Choose a safe way to connect them before storm season.
  5. Test the plan while the grid and weather are stable.
The DELTA 3 Ultra Series has 3,072 Wh capacity, 3,600 W continuous output, and 7,200 W surge output. It offers a 10 ms switchover for supported devices.
You can plan for a fridge, lights, internet equipment, phones, and radios when their combined demand fits the limits. This unit doesn't provide auto whole-home backup.
Runtime changes with charge level, usable power, appliance cycling, heat or cold, settings, losses, and each plugged-in device. Keep the unit dry, above likely floodwater, and ready before the storm.
For selected home circuits, consider the EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated).
•7.2 kW AC output, expandable up to 21.6 kW with supported configurations • 6 kWh starting capacity, expandable up to 90 kWh • Supports automatic home backup switchover with EcoFlow Smart Home Panel 2 • Automatic battery self-heating below 0°C for cold-weather operation
One inverter and battery hold about 6.1 kWh and supply 7.2 kW of continuous output. The setup supports 120 V and 240 V loads, with a 10.8 kW surge for supported equipment at startup.
Circuit control and auto switchover need supported gear, including Smart Home Panel 2. Local rules also require a qualified electrician for hardwired work, completed well before a storm.
No output rating proves that every load can run at once. Leave when local officials order it, even when backup power is ready.
What Should You Check After a Major Storm?
Wait for local clearance, then check for building, power, water, and food hazards before normal use.
Stay at least 10 metres from downed lines and report them. Don't enter a building that looks unsafe or step into floodwater. An electrician must check wet panels, outlets, wiring, appliances, and hardwired backup gear.
Use safe drinking water and throw out food that touched floodwater. Health Canada advises following local water notices and checking chilled food after an outage.
Take photos of damage before cleanup when it is safe, then call your insurer. Follow local cleanup rules and let grid power settle before reconnecting gear as directed.
Check backup units, cables, and ports for water or damage before charging or use. Don't run any unit that was submerged or exposed beyond its stated limits.
Apply Fiona's Lessons Before the Next Atlantic Storm
Save current weather, power company, and emergency contacts. Build your household plan and route out before hurricane season, then size backup power from key loads.
Install and test any circuit equipment well before a storm develops. If battery backup fits your plan, compare EcoFlow portable power stations by output, capacity, connections, and supported devices.
Was Hurricane Fiona a Category 4 storm when it hit Canada?
No. Fiona reached Category 4 earlier over the Atlantic. It became post-tropical before reaching Canada, but it retained hurricane-force winds and remained dangerous.
How long did power outages last after Hurricane Fiona?
Repair times varied by place, and some customers remained without power for more than two weeks. PEI reported full restoration on October 21, 2022.
Is Hurricane Fiona still active?
No. Fiona faded over the Labrador Sea in September 2022. Check today's Canadian Hurricane Centre advisories and messages from local emergency officials instead.
Could another storm like Fiona affect Atlantic Canada?
Yes. Hurricanes and post-tropical cyclones can affect Atlantic Canada. However, Fiona's past route can't predict where or how another storm will form.
Home Backup
