How Heat Pumps Keep Canadian Homes Warm All Winter
It sounds a little backwards. How can a machine pull heat out of air that sits well below freezing? Yet heat pump house heating does exactly that across Canada every winter. Instead of burning fuel, a heat pump moves heat that already exists outdoors into your home. This guide explains how that works in the cold. It covers which system suits a whole house and how sizing is done. It also looks at daily life with a heat pump and what happens when the power goes out.
How Does a Heat Pump Heat a House in Winter?
Even cold outdoor air holds heat energy. A heat pump gathers that heat, concentrates it and releases it indoors. It uses the same basic technology as an air conditioner, just running in reverse.
The Refrigerant Cycle in Heating Mode
Refrigerant circulates between an outdoor coil and an indoor coil in four repeating steps:
Absorb: Cold refrigerant in the outdoor coil soaks up heat from outside air and turns into a vapour.
Compress: The compressor squeezes that vapour, and its temperature rises sharply.
Release: The indoor coil gives off that heat as the refrigerant condenses into a liquid.
Expand: An expansion valve drops the pressure, and the loop starts over.
A reversing valve flips the flow so the same unit cools in summer. Knowing the main parts of a heat pump helps you understand what a technician checks.
Why the Outdoor Unit Goes Into Defrost
Near or below freezing, frost builds up on the outdoor coil and blocks airflow. To clear the frost, the heat pump briefly reverses the refrigerant flow, warming the outdoor coil and melting the accumulated frost.
The Natural Resources Canada (NRCan) guide to heating and cooling with a heat pump says demand-defrost controls are generally more efficient. They start defrost only when frost is detected, not on a fixed timer. You may notice a short pause in warm air, a whoosh from the outdoor unit or rising steam. All of this is normal.
Once you know how the cycle works, the next step is picking the setup that fits your home.
Which Heat Pump for a House Fits Your Layout?
There is no single best heat pump for heating a house. The right choice depends on your ducts, your rooms and your current heating system. Climate and lot size matter too.
System type | How it delivers heat | Best fit |
Ducted (central) air-source | Through existing ductwork | Homes with a forced-air furnace |
Ductless multi-zone | One outdoor unit feeding several indoor heads | Homes with baseboards or no ducts |
Cold-climate air-source | Ducted or ductless | Colder regions |
Ground-source (geothermal) | Fluid loop buried in the ground | Larger lots |
Hybrid (dual-fuel) | Heat pump plus a furnace or boiler | Homes keeping a gas system |
The City of Toronto's page on heating and cooling with a heat pump says cold-climate models are designed to work down to about -30°C.
In a hybrid system, the heat pump handles most of the season. A controller switches to the furnace below a set outdoor temperature. If you are still weighing other ways to heat your home, this mix can ease the move away from gas.
Whichever type you choose, a heat pump for your house becomes one of its biggest electrical loads.
What a Heat Pump Needs From Your Electrical System, Including During Outages
Switching from gas or oil to a heat pump moves your heating load onto your electrical service. Most central heat pumps run on a dedicated 240V hard-wired circuit. When the grid goes down, the heat goes with it.
Panel and Circuit Basics Before You Switch
Backup heat strips may need separate circuits too. Many homes manage without a panel upgrade, but not all. The City of Toronto suggests downloading your past usage and peak demand from your utility. Your contractor or electrician can then judge whether an upgrade is needed.
What Happens to Heat Pump House Heating in a Winter Outage
Without power, the compressor, indoor fan and backup heat all stop. A hybrid system's furnace stops too, because its blower and controls need electricity. Your home then starts losing heat. Knowing how long a house stays warm without power helps you decide what to protect first.
Backing Up Selected Heating Circuits With a Home Battery
A home battery can keep selected circuits running when set up correctly. A heat pump is a 240V hard-wired load. It needs the compatible 120V/240V Smart Home Panel 10 (SHP10), installed by a qualified electrician.
The SHP10 covers up to 10 selected circuits, not every appliance at once.
Switchover takes under 20 ms, which is fast but not zero interruption.
Backup heat strips draw far more than the compressor, so they may be left off.
The TITAN 5000 Plus offers 120V/240V output and up to 8kW of solar input for recharging in longer outages.
The TITAN 5000 delivers 7.2kW at 120V/240V, with up to 4kW of solar and generator charging.
Plug-in devices run directly from either unit. A hard-wired heat pump needs the SHP10 and must fit the battery's startup and running limits. Runtime depends on load. Both units are IP20 rated for indoor use, so keep them in a dry, heated space. Card savings figures are modelled Toronto estimates on Ontario's Ultra-Low Overnight plan.
With the electrical side planned, the next question is how big the heat pump itself should be.
How Do You Size a Heat Pump That Copes With Deep Cold?
Sizing decides whether your heat pump carries most of the winter or leans on backup heat. In Canada, it should start with a proper heat load calculation. The old furnace's rating or the home's square footage is not enough.
Heat Load Calculations and CSA F280
NRCan recommends determining heating and cooling loads with a recognized method such as CSA F280-12. That is the Canadian standard for residential heating and cooling capacity. It accounts for insulation, windows, air leakage and your local winter design temperature.
Undersized: The unit relies heavily on supplemental heat.
Oversized: The unit cycles on and off too often, which causes uneven comfort and extra wear.
COP and Outdoor Temperature
Coefficient of performance (COP) shows how much heat you get per unit of electricity. A COP of 3 means three units of heat for every unit of power. The City of Toronto compares a high-efficiency gas furnace to a COP near 0.95.
COP falls as the air gets colder, but it does not drop off a cliff. NRCan gives these typical ranges:
Condition | Typical COP |
Air-source at 8°C | 2.0 to 5.4 |
Air-source at -8°C | 1.1 to 3.7 |
Ground-source in the coldest months | Around 3 |
According to NRCan, newer air-source models typically stop operating somewhere between -15°C and -25°C. Below the balance point, the heat pump can no longer meet the full load alone. Backup heat fills the gap through electric coils, baseboards or a furnace. NRCan suggests setting the backup system 2°C to 3°C below the heat pump's set-point.
When comparing units, check the heating rating (HSPF, now often listed as HSPF2) and the cooling rating (SEER or SEER2). Low-temperature capacity matters most when cold climate heat pumps face winter in places like Winnipeg or Edmonton.
Numbers matter, but most homeowners notice the switch in daily life first.
What Changes When You Switch to Heat Pump House Heating?
A heat pump heats differently from a furnace. The air from your vents feels milder, and the system runs for longer stretches. A few habits change too.
Comfort: Expect steady, gentle warmth instead of short blasts of hot air.
Thermostat: NRCan advises setbacks of no more than 2°C. Larger overnight drops can trigger backup heat in the morning.
Maintenance: Book annual maintenance with a qualified contractor. Clean or change the air filter every three months, and keep snow off the outdoor unit.
Noise: NRCan notes most heat pumps have a sound rating of 76 dB or lower.
Upfront costs and incentives vary by province and change often. Programs offering heat pump rebates across Canada can lower the purchase price. Check what applies where you live before you collect quotes.
Heat pump house heating moves outdoor heat inside, even well below freezing. With the right system type and proper sizing, it can carry most of a Canadian winter. Ask for a CSA F280 load calculation and plan your backup heat. Then plan for outages too. An EcoFlow TITAN 5000 or TITAN 5000 Plus with a compatible SHP10 can keep selected heating circuits running. Runtime always depends on your actual load.
Can a heat pump heat a whole house in a Canadian winter?
Yes, when it is the right type and properly sized. Cold-climate air-source and ground-source systems handle deep cold best. Most air-source systems still lean on backup heat during the coldest days.
Do I still need a furnace or backup heat with a heat pump?
Most air-source systems need some form of backup. That can be heat strips, baseboards or an existing furnace in a hybrid setup.
Why is my heat pump blowing cool air or steaming outside?
It is probably in defrost mode. The unit briefly reverses to melt frost from the outdoor coil. Steam and a short pause in warm air are normal.
What temperature should I set a heat pump to in winter?
Pick a comfortable setting and keep it fairly steady. Limit setbacks to about 2°C, or use a smart thermostat that starts recovery early.
Can a home battery run a heat pump during a power outage?
It can in the right setup. With an EcoFlow TITAN 5000 or TITAN 5000 Plus, the heat pump circuit needs the compatible SHP10 installed by a qualified electrician. The heat pump's startup and running power must fit the battery's limits, and runtime depends on what else is running.
