Dryer Electricity Explained: Watts, kWh and Costs for Canadian Homes
Laundry day can quietly add up on your power bill. An electric clothes dryer is one of the most energy-intensive appliances in most Canadian homes. It heats air with a large element and runs on its own 240V circuit. Knowing how much dryer electricity a load uses helps you compare models and plan your budget. It also helps you decide what matters most when the power goes out. This guide covers dryer wattage, kWh per load, costs, dryer types, labels, savings habits and fire safety.
How Much Electricity Does a Clothes Dryer Use?
It depends on the model, the cycle and how wet the clothes are. Wattage tells you how fast a dryer draws power. Kilowatt-hours tell you how much energy a full load actually uses.
Typical Wattage of a Clothes Dryer
Most full-size electric dryers in Canada run on a 240V circuit. Manufacturer guidance puts electric dryers at roughly 1,800 to 5,000 watts, depending on the load and cycle. Your own model may sit higher or lower.
The heating element does most of the work, and it cycles on and off as the drum heats. So average draw over a load sits below the label rating.
These numbers make more sense once you know how volts, amps and watts relate on a 240V circuit. A 5,000W dryer at 240V draws about 21 amps.
kWh per Load
Natural Resources Canada (NRCan) tracks the energy use of electric dryers shipped in Canada. Its 2020 figure is an average of 584.5 kWh per year. The Canadian test procedure assumes 283 drying cycles per year. That works out to roughly 2.1 kWh per load. Heavy towels use more, while light, well-spun loads use less.
Cost per Load and per Year
The cost formula is simple: kWh per load multiplied by your electricity rate. The table below uses round example rates, not any province's actual price.
Example all-in rate | Cost per load (about 2.1 kWh) | Cost per year (about 584 kWh) |
10¢ per kWh | About $0.21 | About $58 |
15¢ per kWh | About $0.32 | About $88 |
20¢ per kWh | About $0.42 | About $117 |
Delivery charges, taxes and credits change the true cost. Your own dryer's numbers start with its labels.
How to Find the Wattage of Your Clothes Dryer
Every dryer carries clues about its power use. The nameplate shows its electrical rating. The EnerGuide label shows its estimated yearly energy use.
Reading the Nameplate
The nameplate usually sits inside the door frame or on the back panel. If it lists only volts and amps, multiply them to estimate dryer wattage.
Formula: Watts = volts × amps.
Example: 240V × 20A = 4,800W.
That figure is a maximum, not a constant draw. Most electric dryers sit on a dedicated 30A double-pole breaker, and knowing what your circuit breaker ratings mean makes the label easier to read.
EnerGuide and ENERGY STAR Labels in Canada
NRCan's clothes dryer regulations require an EnerGuide label on household electric tumble dryers. The label shows estimated annual energy use in kWh. A lower number means a more efficient model.
Some labels also show the ENERGY STAR symbol. NRCan's ENERGY STAR clothes dryers page says certified models use 20% less energy on average than standard ones. It also notes that all heat pump dryers meet the ENERGY STAR Most Efficient criteria.
That raises a practical question. Can home backup power handle a load this size during an outage?
Can Home Backup Power Run an Electric Dryer?
A dryer can be part of a home backup plan with the right equipment. Still, it is a heavy 240V load and rarely a first priority.
Why a Dryer Is Usually Not a Backup Priority
A full-size electric dryer is a 240V appliance on its own 30A circuit. It is either hard-wired or connected to a dedicated dryer receptacle. A 120V plug-in power station cannot run it.
Energy use is the bigger issue. One average load at about 2.1 kWh uses roughly 40% of a 5kWh battery's stored energy. Most families save that energy for the fridge, furnace fan, lights and router.
Working out how much battery backup you need starts with that kind of list. Add heavier loads only if capacity allows.
Backing Up the Dryer Circuit With TITAN
A dryer never plugs into a home battery. TITAN can back it up only through the dryer's home circuit and the compatible 120V/240V Smart Home Panel 10 (SHP10). A qualified electrician must install it.
The SHP10 covers up to 10 selected circuits, not every appliance at once. Switchover takes under 20 ms, which is fast but not zero interruption. Both models below expand from 5kWh to 30kWh, adding runtime rather than output.
The TITAN 5000 Plus delivers 7.2kW from its battery, or up to 10kW with compatible solar. Its 8kW solar input helps recharge between heavy loads.
The TITAN 5000 offers 7.2kW at 120V/240V, with up to 4kW of solar input and generator charging.
Plug-in devices run directly from either unit, but home circuits need the SHP10. Both are IP20 indoor units that charge between 0°C and 45°C. Runtime depends on load, and card savings are modelled Ontario ULO estimates.
Your dryer type also shapes how much power it needs.
Electric, Gas, Heat Pump and Ventless Dryers Compared
Not every dryer uses electricity the same way. The heat source and how moisture leaves the drum both change energy use.
Electric Vented Dryers
This is the most common type in Canadian homes. A 240V element heats the air, and a vent pushes moist air outside.
Gas Dryers
A gas dryer burns natural gas or propane for heat. It still plugs into a standard outlet to power the drum, fan and controls. It will not run without electricity.
Heat Pump Dryers
A heat pump dryer recycles warm air instead of venting it outdoors. It relies on the same heat pump principle that heats and cools many Canadian homes. NRCan says heat pump dryers use 20% to 60% less energy than standard models. Cycles are often longer.
Ventless Condenser Dryers
A condenser dryer pulls moisture from heated air in a closed loop and sends the water to a tank or drain. It needs no outdoor vent, which suits condos.
Dryer type | Main heat source | Typical power supply | Electricity use |
Electric vented | Electric element | 240V | Highest |
Gas | Natural gas or propane | Standard outlet for motor and controls | Low (plus gas) |
Heat pump | Heat pump | 240V or 120V, by model | Lowest |
Ventless condenser | Electric element | 240V or 120V, by model | Moderate to high |
Whatever dryer you own, a few habits can cut its electricity use and make it safer to run.
Ways to Cut Dryer Electricity and Run It Safely
Small changes add up over hundreds of loads a year. Many habits that save energy also lower fire risk.
Habits That Cut Dryer Electricity
Dry full loads: Fill the drum without overloading it.
Use a high-spin wash: NRCan suggests the high-speed or extended spin setting. Less water in the clothes means less drying time.
Use the moisture sensor: Sensor drying stops the cycle once clothes are dry.
Clean the lint trap: Better airflow means shorter, more efficient cycles.
Your washing machine's power use is small next to the dryer's, so extra spin time is a good trade.
A Quick Note on Ontario Time-of-Use Rates
In Ontario, timing matters too. The Ontario Energy Board's current electricity rates took effect on November 1, 2026. On the ultra-low overnight price plan, overnight power costs 3.7¢ per kWh and weekday on-peak costs 37.7¢. Based on 2.1 kWh per load, the electricity commodity cost is approximately 8¢ during ULO hours and 79¢ during weekday on-peak hours, before delivery charges, taxes and applicable bill credits.
Never run a dryer while you sleep, though. Start it once you are up, before 7 a.m.
Dryer Fire Safety
Lint is highly flammable, and it builds up fast. The City of Toronto's clothes dryer fire safety tips cover the basics:
Clean the lint screen after every load.
Remove lint from metal ducts and exhaust vents regularly.
Check that the outdoor vent flap opens freely and is not blocked.
Turn the dryer off if you leave home or go to bed.
Install a carbon monoxide alarm if you have a gas or propane dryer.
Dryer electricity comes down to a few numbers. Most electric dryers draw roughly 1,800 to 5,000 watts, and an average load uses about 2.1 kWh. Your nameplate, EnerGuide label and rate plan show your real costs. Full loads, high spin, sensor cycles and clean vents cut energy use and fire risk. To cover a selected 240V dryer circuit during outages, compare the EcoFlow TITAN 5000 and TITAN 5000 Plus against your essentials list.
How many watts does a dryer use?
Most full-size electric dryers draw roughly 1,800 to 5,000 watts on a 240V circuit. Check your nameplate for your model's rating.
How many kWh does a dryer use per load?
About 2.1 kWh is a fair average, based on NRCan's 2020 data and 283 test cycles a year. Heavy or very wet loads use more. Sensor cycles on light loads use less.
Does a gas dryer use electricity?
Yes, a small amount for the drum, fan and controls. Gas supplies the heat, but the dryer stops during a power outage.
Is it safe to run a dryer overnight?
No. Canadian fire services advise turning the dryer off when you go to bed or leave home. Run the washer overnight instead, then dry the clothes once you are up.
Can a battery backup run a clothes dryer?
It can with enough 240V capacity and the right wiring. With TITAN 5000 or TITAN 5000 Plus, the dryer circuit needs the 120V/240V SHP10 installed by a qualified electrician. Most homes still put essentials first.
