Heating Home Options in Canada: Find the Right Solution for Cold Weather
What Are the Main Heating Home Options in Canada?
A house heating system may draw heat from a handful of sources: furnaces, heat pumps, boilers feeding radiators or in-floor tubing, electric baseboards, and wood or pellet stoves. What each costs to install, what it costs to run, and how it handles deep cold are three different questions, and they rarely resolve the same way twice. Comparing types of home heating systems helps separate installation needs from winter operating costs.
Heating SystemEnergy SourceUpfront CostOperating CostEfficiencyMaintenanceHeating CoverageCold-Weather Performance
FurnacesNatural gas, propane, electricity, oilModerate; obtain a local installed quoteModerate (Gas) to High (Electric/Oil)80% – 98% AFUELow to Moderate (Annual tune-ups, filter swaps)Whole-home central (Ductwork required)Excellent; unaffected by extreme ambient drops
Heat PumpsElectricityVaries by ducted/ductless design; obtain a local quoteLow to Moderate200% – 400% (COP 2.0 – 4.0)Moderate (Filter care, outdoor coil clearance)Whole-home central or room-by-room ductlessModel-specific; match low-temperature capacity to the heating load
Boilers & Radiant HeatingNatural gas, electricity, heating oilReplacement and new hydronic installations differ; obtain a quoteModerate (Gas) to High (Oil)85% – 95% AFUEModerate (Hydronic purging, valve checks)Whole-home via radiators or underfloor tubingOutstanding; steady, uniform thermal mass
Electric BaseboardsElectricityLow per unit; wiring and labour add costHigh (Except in low-cost hydro regions)100% at point of useVery Low (Occasional dusting)Zoned room-by-roomReliable output, but expensive for whole-home loads
Wood & Pellet StovesFirewood cords, compressed wood pelletsModerate; chimney and installation affect costLow to Moderate (Fuel-source dependent)70% – 85%High (Ash removal, chimney sweeping, fuel staging)Supplemental to zonal living areasUnmatched radiant warmth; completely off-grid capable (cordwood)
Furnaces
For decades the forced-air gas furnace has been the default across the Prairies, Ontario and much of British Columbia, less a decision than something you inherit. Return vents draw in house air, the heat exchanger warms it, and a blower pushes it back through the supply ducts, which carry air conditioning in July. Heat arrives fast. The trade-offs are familiar enough: by February the air turns dry and static, and you hear the blower every time it cycles. Statistics Canada reports that 46% of households used a forced-air furnace as their primary heating system in 2023.
Heat Pumps
Cold-climate air-source heat pumps (ccASHPs) have gone from curiosity to mainstream in under a decade, carried by federal incentives and efficiency numbers no combustion appliance can match. They don’t make heat so much as move it, pulling thermal energy out of outdoor air. Capacity and efficiency vary with outdoor temperature and model. Some Canadian installations use backup heat: the heat pump carries the season, and a gas furnace or electric resistance strips handle the coldest nights.
When evaluating cold climate heat pumps, compare rated low-temperature capacity with your home’s design heating load.
Boilers and Radiant Heating
Hydronic systems circulate heated water through a closed loop, either in floor tubing or through cast-iron radiators. Radiant floor heat has no ducts, so no drafts, nothing blowing dust around, and a floor warm underfoot on a January morning. Threading tubing through an existing multi-storey house is invasive, expensive work, so hydronic heat shows up mostly in new builds and the older character homes of Montreal and Toronto.
Electric Baseboard Heaters
Where hydroelectricity is cheap and abundant, above all in Quebec and Newfoundland and Labrador, electric baseboards dominate the older housing stock. Each room carries its own line-voltage thermostat, so there’s no mechanical room, no web of sheet-metal ducts. Installation is about as cheap as heating gets, but the catch arrives in January: run baseboards through an uninsulated four-bedroom house during a deep freeze and the bill climbs faster than the thermometer falls.
Wood and Pellet Heating
Rural and off-grid households lean on EPA-certified wood stoves and automated pellet appliances for heat that depends on almost nobody. Cordwood is the closest thing to energy independence most homeowners will have: when ice loads take the lines down, a full wood shed keeps the house warm, and you pay for it in wood split, stacked and seasoned by hand. Pellet stoves trade that labour for hopper-fed thermostatic convenience, though their augers and exhaust blowers still want a trickle of electricity.
EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh)
How Much Does It Cost to Heat a Home in Canada?
Annual heating costs vary widely; use your home’s fuel consumption and current local tariffs rather than a single national range. Where you land depends less on the appliance in the basement than on local fuel rates, the building’s age, and how much real cold winter throws at you.
Factors Affecting Heating Costs
Square footage sets the size of the heating load; the building envelope decides how quickly that heat leaves. A century home with uninsulated double-brick walls and tired attic insulation can lose substantially more heat than a well-insulated modern home, and you’re billed for every unit of it. Thermostat habits, window glazing, air leaks around sills, and local delivery tariffs all move the monthly number.
Heating Costs by Canadian Region
Provincial grids and fuel markets draw sharp lines across the country:
  • Alberta and Saskatchewan: Long stretches of -30°C create enormous heating demand, but cheap provincial natural gas can reduce fuel costs relative to some alternatives, but annual bills depend on consumption and tariffs.
  • Quebec: Low Hydro-Québec rates make electric baseboards and heat pumps cheap to run, with seasonal bills depending on consumption and applicable tariffs even in a province whose winters are anything but mild.
  • Ontario: Mixed fuel use is the norm. A high-efficiency gas furnace has operating costs that depend on fuel prices and heating demand; rural propane and oil users should compare delivered fuel prices.
  • Atlantic Canada: Heavy reliance on delivered heating oil and electricity can make annual heating costs substantial, which is why so many households in Nova Scotia and New Brunswick have moved to cold-climate mini-splits.
  • British Columbia: The temperate Lower Mainland keeps winter demand light, relative to colder regions, while the Interior and the North carry heating loads that rival the Prairies.
How Can You Make a Home Heating System More Energy Resilient?
A house without heat cools faster than most people expect: once a blizzard takes the grid down pipes may freeze as indoor temperatures fall, with timing depending on insulation, outdoor temperature and pipe location. That, not the cold, is what turns a blackout into a renovation.
A power station can support essential heating controls during an outage, provided its output, runtime and approved connection arrangement match the equipment.
Improve Heating Efficiency and Reduce Demand
The cheapest kilowatt-hour is the one your house never draws. Air-sealing around doors, rim joists and electrical boxes closes off convective leaks before winter arrives, and costs a weekend and a caulking gun. A smart thermostat handles setbacks while you sleep or sit at the office; blown-in attic insulation up to R-60 keeps heat from leaving through the roof.
Add Flexible Power for Essential Heating
Most heating systems still need electricity: a gas furnace needs it for its controls, igniter and blower, which is why a house goes cold in a storm with a perfectly good gas line. A portable power station such as the EcoFlow DELTA 3 Max Plus Portable Power Station(2048Wh) can provide short-term backup for compatible furnace components and other essential loads, depending on their power requirements and how the system is connected.
EcoFlow DELTA 3 Max Plus Portable Power Station (2048Wh)
25dB whisper-quiet operation. 6000W surge output. With X-Boost™ mode, it supports heavy-duty appliances up to 3800W such as refrigerators, coffee makers, washers, and circular saws. Ready in just 43 mins (0-80%) with generator charging.
Build Higher-Capacity Backup for Extended Needs
Rural properties, electrically heated homes, and households exposed to multi-day winter blackouts need substantial storage capacity to keep indoor temperatures safe.
For broader whole-home continuity, the EcoFlow DELTA Pro Ultra Whole-Home Backup Power provides a high-capacity, scalable electrical foundation. Its split-phase 120V/240V output can support compatible circuits through an approved transfer device installed by a qualified electrician; starting loads and system compatibility must be checked. By scaling up modular battery packs to align with your home’s calculated daily electrical draw, it can support selected heating loads for a duration determined by stored energy, weather and demand.
6kWh-90kWh capacity, whole house backup for weeks with comfort. One hour of solar for one day of power. Powers through the most challenging situations. With a 7.2kW output, EcoFlow DELTA Pro Ultra effortlessly runs even energy-hungry household items.
Diversify Energy Sources for Seasonal Demand
A house that runs on a single energy carrier has a single point of failure. Pair a mini-split with a gas fireplace, a propane wall heater or an airtight wood stove and you've got redundancy built into the floor plan: the heat pump does the efficient work through the shoulder seasons, and the second source is there when a freezing snap puts the grid under strain.
A solar generator adds another charging source to an outage plan; winter sunlight and snow cover affect how much energy it can replenish.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
What Should You Consider Before Choosing a Home Heating System?
Before you sign anything, look hard at four things: how cold your winters actually get, the mechanical system already in the house, what your electrical service can carry, and what energy costs where you live. These checks help match heating options for homes to the conditions the equipment will face.
Local Climate and Winter Temperatures
Design temperature is the number that matters: coastal British Columbia and the Prairies have very different winter design conditions. Check your region's 99% heating design temperature before you buy; where extreme cold snaps are part of winter, plan on a dedicated backup: a heat pump may require supplementary heat when its rated capacity falls below the building's heating demand.
For Ontario households with electrically dependent furnaces, planning for ice storm power outages in Ontario includes choosing an approved backup connection before severe weather arrives.
Existing Heating and Electrical Systems
Cutting ductwork into a house built around hydronic baseboards is expensive and eats ceiling height; a ductless multi-split or a high-efficiency condensing boiler makes more sense in that house. Moving from gas to a whole-home electric heat pump or electric furnace may require a service upgrade, subject to an electrical load calculation, and the same arithmetic applies to the panel.
Energy Prices and Operating Costs
Ignore the sticker price and work out what a gigajoule or a kilowatt-hour costs where you live. Off the gas grid, trading delivered heating oil or bulk propane for a high-efficiency heat pump may reduce operating costs, but payback depends on local fuel rates, installation costs and applicable rebates. Run the numbers the other way and the story changes: replace a working gas furnace with an all-electric system where power rates are steep and tiered, and the payback can stretch out for years.
Installation and Maintenance Needs
Venting and condensate drainage on a complex HVAC setup aren’t things you want a crew learning on your house. High-efficiency condensing appliances produce acidic condensate, which has to be routed away from any exterior wall that can freeze; that’s work for a certified technician who knows this climate. Before you sign, read the warranty terms: on compressors and heat exchangers, 10 years is a common term. Budget the ongoing attention: filters, hydronic balancing, chimney sweeps.
No single system wins everywhere in this country. Climate, fuel prices, the ductwork or hydronics already in the walls, insulation, and what you can put down up front — all of it pulls the answer a different way. Weigh what a system costs to install against what it costs you every winter for the next fifteen years. And if outages are part of life where you live, settle one more question before you buy: what happens to your heat the next time the power goes out.
How Are Most Homes Heated in Canada?
Forced-air furnaces, most of them burning natural gas, heat close to half of Canadian households, most heavily concentrated in Ontario and the Prairies. Electric heating — baseboards and heat pumps — is the second-largest category, dominating in Quebec, Newfoundland and Labrador, and New Brunswick, where electricity is widely used; local tariffs and equipment efficiency determine cost.
Is It Normal for a Heat Pump to Run All Night?
Yes. Modern variable-capacity heat pumps are built to run long and slow. They don’t cycle the way a furnace does; they hold a steady temperature instead of alternating between a blast of hot air and silence. On a freezing night that low-stage operation is exactly what you want, and it’s also where the seasonal efficiency comes from.
Why Is My Electric Bill So High with a Heat Pump?
Usually one of two things. Below its balance point the machine can’t keep up on its own, so it calls on electric resistance strips, the most expensive heat in the house. Or the thermostat’s working against you: deep manual setbacks force the system to fire those same strips just to catch up, and catching up costs more than holding steady.
When Should You Replace Your Heating System?
Start planning once a furnace or boiler passes 15 to 20 years, particularly if service calls have become a line item rather than a nuisance. The warning signs are hard to miss: rooms that never quite match, clanking or grinding from the cabinet, a cracked heat exchanger, or fuel bills that jump for no reason the weather can explain.
