Heat Pump vs. Furnace: Which Is Better for Canadian Homes?
For Canadian homeowners, a heat pump vs furnace comparison comes down to climate, energy prices, insulation, existing services, cooling needs, and the home’s calculated heat loss. Heat pump vs furnace Canada decisions should use local design temperatures and current utility rates rather than a single national rule. A heat pump can reduce electricity use compared with electric resistance heating and provide summer cooling, while a furnace or hybrid system may suit some colder locations and homes with established fuel service.
This guide explains how each system works, how the two compare across Canada’s climate zones, what installation may involve, and how to keep the heat running when winter storms take the grid down.
What Is a Heat Pump?
Most of the confusion about heat pumps comes from assuming they make heat the way a furnace does.
Heat Pumps Transfer Heat
An air-source heat pump moves heat instead of creating it through combustion or electric resistance. Refrigerant absorbs energy at the outdoor coil, and the compressor raises its temperature so the indoor system can deliver heat. The cycle can reverse for summer cooling. Understanding how a heat pump works also explains why low-temperature performance, correct sizing, and controls matter.
Types of Heat Pumps for Canadian Homes
Cold-Climate Air-Source Heat Pumps (ccASHPs): These models are designed and tested for low outdoor temperatures, but capacity and efficiency still vary by model and generally decline as the air gets colder. Select equipment from certified performance data and size it to the home’s design heat loss.
Ground-Source (Geothermal) Systems: These systems utilize underground loops and the constant temperature of the soil to deliver efficient heating throughout the year. The trade-off is the large amount of excavation required to install the loops.
Ductless Mini-Splits: A good choice for older homes and cottages that lack existing sheet-metal ductwork, giving you room-by-room temperature control.
What Is a Furnace?
In Canada, furnaces continue to be a popular choice for heating, especially in houses that already have ductwork and natural gas service.
Furnaces Generate Heat from Fuel or Electricity
A furnace generates heat from fuel or electricity. Gas, propane, and oil furnaces burn fuel in a sealed combustion chamber to heat a metal heat exchanger, and a blower then pushes air across that hot surface and on through the ducts. Electric models skip the fire and run current through high-resistance heating coils, which work much like the elements in a toaster.
Types of Furnaces in Canada
Natural Gas Furnaces: Prized for quick, high-temperature heat, they are the dominant choice across Ontario, Alberta, and parts of British Columbia, where gas service has long been available.
Propane & Oil Furnaces: Common in rural areas, the Maritimes, and on off-grid properties without natural gas service.
Electric Furnaces: Common in provinces with abundant, lower-cost hydroelectricity, including Quebec and Manitoba, though their high electricity use makes them expensive to run where rates are higher.
What Is the Difference Between a Heat Pump and a Furnace?
Both systems heat a home, but they use energy differently and perform differently as outdoor conditions change. A portable power station is a separate backup option for compatible electrical loads; it does not determine which heating system is more economical.
Feature / Metric | Cold-Climate Heat Pump | High-Efficiency Furnace |
Primary Energy Source | Electricity | Natural gas, propane, oil, or electricity |
Operational Method | Moves ambient heat | Generates heat via combustion/resistance |
Seasonal Functionality | Heating & cooling (2-in-1 system) | Heating only (requires separate AC) |
Efficiency Rating (COP / AFUE) | Model- and temperature-dependent COP | Model-specific AFUE |
Heat Delivery Feel | Lower-temperature, steady airflow | Warmer supply air; cyclic airflow |
Lifespan Expectation | Varies by model, use, and maintenance | Varies by model, use, and maintenance |
Typical Upfront Investment | Often higher; incentives vary by jurisdiction | Moderate |
Energy Sources and Heating Methods
Gas, propane, and oil furnaces generate heat by burning fuel, while electric furnaces use resistance elements. An air-source heat pump uses electricity to operate a compressor and move heat from outdoor air into the home. Its delivered heat per unit of electricity varies with the model, outdoor temperature, sizing, and installation.
Heating Efficiency and Heat Output
A condensing furnace is rated by annual fuel utilization efficiency, while a heat pump is rated by measures that reflect how much heat it moves for the electricity used. Heat-pump capacity and efficiency generally decline as outdoor temperature falls, and neither rating alone determines operating cost. Natural Resources Canada recommends evaluating climate, sizing, installation, fuel and electricity prices, and the performance of the specific equipment.
Year-Round Heating Versatility
A furnace heats your home, but summer cooling requires a separate central air conditioner. A heat pump handles both heating and cooling in a single footprint, so when it replaces both your furnace and your air conditioner, there is one system to maintain instead of two.
Replacing an existing furnace may be simpler when suitable ductwork, venting, and fuel service are already in place. Switching to a heat pump can require duct changes, outdoor-unit placement, condensate planning, and an electrical assessment. Panel or service upgrades depend on the selected equipment and the home’s existing capacity, so include all required electrical and building work in written quotes.
Is a Heat Pump or Furnace Better for Canadian Winters?
The better choice depends on location, the building, and available energy sources. Comparing heating home options can help place heat pumps and furnaces alongside boilers, electric resistance, and other systems.
Choose a System for Your Local Climate
Mild Coastal Zones (e.g., Vancouver, Victoria): Heat pumps often work well here. They can run efficiently for most of the winter without backup heat because freezing temperatures aren’t that common.
Central & Eastern Regions (e.g., Greater Toronto Area, Montreal): A cold-climate heat pump installed with an existing gas furnace can be a good dual-fuel solution. On the milder days of winter, the heat pump does the job, with the furnace taking over during deep January cold snaps.
Prairies and Far North: Equipment must be selected from low-temperature performance data and sized to the home’s design heat loss. Depending on the model, location, and electrical service, a furnace, a cold-climate heat pump with auxiliary heat, or a hybrid system may be appropriate.
Compare Heating Costs and Energy Use
The cost of heat pump vs furnace operation depends on local electricity and fuel prices, equipment performance, weather, and the home’s heat loss. Natural Resources Canada’s Canadian modelling shows that savings differ by location, existing system, building type, and whether a hybrid configuration is used. Compare current utility rates and contractor estimates for the specific property.
Consider Winter Maintenance Needs
A furnace stays tucked away in the basement, protected from blizzards, though its exterior PVC vent pipe can still frost over. The heat pump’s outdoor unit needs to be raised on stands to stay clear of drifting snow, and its coils need periodic checks for ice.
How to Choose Backup Power for Your Home Heating System
Winter storms can interrupt power, and most heating systems need electricity for controls, blowers, pumps, or compressors. Planning starts with measured voltage, running demand, and starting surge. A solar panel can recharge compatible storage when site conditions, weather, and system design allow, but winter production varies.
Check Your Heating System’s Electrical Requirements
Most people assume a gas furnace will keep the house warm when the power goes out. It won’t. The blower motor, the electronic ignition, and the digital circuit boards all run on 120V power, so without it the furnace cannot ignite the gas or circulate warm air, even with gas still flowing to the house. A heat pump needs considerably more power, since electricity has to spin the outdoor compressor and power the indoor air handler, with auxiliary electric resistance strips adding a heavy load on top. Check the equipment data plate for the starting surge wattage and the continuous running wattage.
Match Backup Power to Heating Loads
The backup source has to meet your heating equipment’s startup surge, continuous running wattage, and voltage requirements. Surge is the number people miss, since a compressor or blower motor needs a burst of power to get moving that it doesn’t need once running, so sizing for running wattage alone can leave the backup source unable to handle startup. For heat pumps, add the draw of the compressor and fans, plus any auxiliary electric heat strips that will be used.
For homes with a gas or propane furnace, EcoFlow TITAN 5000 Classic Whole-Home Backup Power may support compatible 120V furnace components, including the blower, ignition system, and controls, when the measured load and connection method are within the backup system’s specifications.
For larger homes, dual-fuel systems, or selected heat pump setups, EcoFlow TITAN 5000 Plus Whole-Home Backup Power offers higher output capacity for more demanding backup scenarios. Whole-home heat-pump backup should be sized using the equipment nameplate, starting surge, voltage requirements, connection method, and any auxiliary electric heat.
The answer depends on the house. For homeowners comparing heat pump vs furnace cost, local winter temperatures, energy prices, insulation, existing ductwork, electrical capacity, cooling needs, and access to fuel all matter. A cold-climate heat pump can suit milder regions and homes replacing electric resistance or oil heat, while a furnace or a carefully designed hybrid system may suit other conditions. Before choosing, compare current electricity and fuel rates, obtain load calculations and written quotes, check available incentives, and plan backup power for the electrical components that must operate during an outage.
Can I Keep My Furnace And Add A Heat Pump?
Yes, you can pair an existing fuel-burning furnace with an add-on heat pump to create a hybrid “dual-fuel” system. In this setup, the heat pump heats efficiently during mild and cool weather, while the furnace automatically takes over when temperatures fall well below freezing.
Does A Furnace Last Longer Than A Heat Pump?
Service life varies with equipment quality, installation, climate, maintenance, and annual operating hours. A furnace may last longer than a heat pump in some homes, but published age ranges are planning estimates rather than guarantees. Compare warranties, maintenance history, and replacement costs for the specific models.
Do You Need Backup Heat With A Heat Pump?
Backup heat is not automatically required for every Canadian heat-pump installation. The decision depends on the home’s calculated heat loss, the selected unit’s low-temperature capacity, local design conditions, code requirements, and the consequences of an outage. A qualified designer or contractor should size the complete system for the home.
What Percentage Of Canadian Homes Have Heat Pumps?
Heat-pump adoption varies considerably by province, housing type, climate, and access to fuel. Natural Resources Canada maintains current information on heat-pump technology and federal home-energy programs; homeowners should also check provincial, territorial, municipal, and utility programs before budgeting.
Do Heat Pumps Use A Lot Of Electricity?
Not compared with other electric heat. Modern cold-climate heat pumps use significantly less electricity than traditional electric baseboards or standard electric furnaces, because they move existing ambient warmth rather than generating heat through direct electrical resistance.
Why Is My House So Cold With A Heat Pump?
A heat pump’s airflow can feel cooler than a furnace’s even while the system is heating. Supply-air temperature varies by equipment and operating conditions, and moving air can feel cool at the vent. If the house does not reach the thermostat setting, possible causes include sizing, controls, a defrost cycle, refrigerant issues, or snow and ice obstructing the outdoor unit.
