What to Do If Basement Floods: Step-by-Step Guide
- Make Sure It's Safe Before You Go Downstairs
- Shut Off the Power and Stop the Water at Its Source
- Running Pumps and Drying Equipment When the Power's Already Off
- Getting the Water Out and Drying Within 48 Hours
- Documenting the Damage and What Insurance Actually Covers
- Stopping It From Happening Again
- Conclusion
- FAQs
A flooded basement is scary. The first ten minutes matter more than the next ten hours. Rushing downstairs to bail water out can put you near a live wire before you even know it's there. This guide walks through what to do if your basement floods, in order. It covers checking for danger. It covers cutting power. It covers getting the water out. It covers drying everything before mold sets in. And it covers what your insurance will and won't pay for.
Don't rush downstairs the moment you spot water. A few quick checks come first. Water conducts electricity, and a flooded basement often means outlets, cords, or appliances are sitting right in it.
Don't enter if water touches outlets, cords, or an appliance. Skip it too if the water is moving or deep. Skip it if you smell gas.
A rotten egg smell means one thing. So does a hissing sound near a gas line. Get out right away. Don't flip a light switch. Don't use your phone inside. Don't do anything that could spark, even outside near the house.
Standing water from a sewer backup counts as contaminated. So does outside floodwater. Treat it that way until you know otherwise. It can carry bacteria and chemical runoff, even if it looks clear.
Call 911 if there's a threat to a person. Do the same for a threat to the structure. A bowing wall counts. So does a foundation that looks like it's giving way. Property damage alone doesn't need a 911 call.
Look for warning signs beyond the water itself. A crack that seems to be growing is one sign. A wall that bows inward is another. So does a foundation that looks like it's giving way. So is a floor that feels soft underfoot. Treat those as a reason to wait for a professional, not just cut power and get to work.
Knowing power and water safety basics first makes everything that follows a lot less stressful.
Once it's safe to go down, the next move is cutting power.
Power and water are a dangerous mix. Cutting power comes first. Finding the water source comes next. Basements flood for a handful of common reasons, and each one points to a different fix.
Shut off electricity in the basement from a dry spot. The main panel usually works. Only do this if you can reach it without stepping into water.
If the panel is flooded, stop. Call a licensed electrician instead. Don't take the risk yourself, even if the water looks shallow.
Figure out where the water is coming from. It could be a burst pipe. It could be an overflowing appliance. It could be a failed sump pump. It could be a sewer backup, or water pushing in from outside during heavy rain.
A burst pipe is usually a fix you or a plumber can handle. A dead sump pump too. A sewer backup needs a professional, given the contamination risk, since that water can carry bacteria you can't see.
If the water is rising fast from outside, act on entry points. Sandbags or door barriers at ground-level doors can slow it down while you wait for help.
Know your home's main shutoffs. Build a flood plan for your home too, one that covers where water tends to get in. Do this before an emergency, not during one.
With the power off, you now need to run pumps and drying gear. But you just cut your own outlet.
Cutting power is the right call. But your sump pump, wet-vac, and dehumidifier now have nothing to plug into. A sump pump failure is one of the most common reasons a small leak turns into a serious flood. Losing power mid-storm is exactly when that failure tends to happen.
This is the exact problem a battery backup solves. A sump pump losing power mid-flood often turns a small puddle into a ruined basement. That's especially true overnight, when nobody's around to notice.
Pairing a battery straight to your sump pump beats an extension cord across the house. Wiring a pump to a battery is simpler than most homeowners expect, and most setups don't require rewiring the whole circuit.
A larger battery can also run a shop-vac or a dehumidifier later. That shortens how long the basement stays wet, which matters since drying time is what decides whether mold shows up next.
Size the battery to your pump's actual draw, not just its horsepower rating on the box. A pump that starts and stops often, like during a long storm, pulls more total power than one steady run.
DELTA Pro Ultra X covers a full sump pump and drying setup. It can run for as long as the outage lasts. DELTA 3 Max is enough to get one pump or a wet-vac going right away. That works well for a smaller basement or a shorter outage. The water problem is under control now. The clock is now ticking on getting the basement dry.
How you handle water in your home depends on where it came from.
A small amount of clean water needs only towels, a mop, or a wet-vac, after you confirm the power is safe. Water from sewage or an unknown source is different: call a professional restoration service and don't touch it yourself. Restoration pros sort water into three categories. Clean water from a burst pipe is the safest. Gray water from an appliance carries some contamination. Black water from sewage or outside flooding is the most dangerous: stay away from it without protective gear.
Whatever the category, drying speed decides what happens next.
You have a 24- to 48-hour window to dry everything fully before mold takes hold. Run dehumidifiers and fans to pull moisture out of the air, but turn the fans off if you already see mold—blowing air across it spreads spores through the house. Open windows once the air outside is drier than the air inside. Wear gloves, goggles, and a respirator while sorting wet items, and bag anything porous, carpet padding, cardboard, and anything that can't dry on time.
If water stays for more than a day, pull the baseboards and lower drywall.
Moisture trapped behind a wall feeds mold long after the floor looks dry. And if you're running cleanup gear on backup power, check how many watts a sump pump uses, add your fans and dehumidifier on top, and you'll know how long a portable battery can run all of it at once.
Once things are dry, the next job is getting credit for what just happened.
Document Everything First
Insurance claims live or die on documentation, and a typical basement cleanup runs a few thousand dollars once you count equipment rental, repairs, and professional help. A solid paper trail matters more than it seems in the moment. Before you throw anything away:
Photograph the damage. Capture the water level, damaged structures, appliances, and belongings.
Start a written inventory. Go room by room if you can manage it.
Save every receipt. Wet-vac rentals, replacement drywall, anything tied to cleanup. Insurers want proof of both the loss and the recovery cost.
Keep damaged items until the adjuster sees them, if you have the space. Throwing everything out too soon can slow down or shrink a claim.
Call your insurer early, even before cleanup is finished. Ask what documentation they need and whether an adjuster must see the damage in person before you start repairs.
Know What Your Policy Covers
Coverage depends entirely on where the water came from:
Water source | Typical coverage |
Burst pipe or appliance discharge | Often covered under standard homeowners policy |
External flooding (rain, overflowing river) | Usually excluded, needs separate flood insurance |
Sewer or drain backup | Only covered with optional backup endorsement |
Sump pump failure | Depends on cause and specific policy terms |
Gradual seepage or neglect | Typically excluded |
Standard homeowners insurance rarely covers flooding caused by outside water like heavy rain or a rising river. Closing that gap usually means a separate policy. That comes through the National Flood Insurance Program, or a private carrier. A flood policy typically takes about 30 days to kick in after you buy it. So this isn't something to sort out once water is already in the basement. It helps to check which coverage applies to your loss before you assume you're covered. Sewer backup endorsements especially tend to come with their own separate limits.
Cleanup and paperwork aside, the real win is not doing this again next season.
A little prevention beats a lot of cleanup. These steps cut your odds of a repeat, and most of them cost far less than a single restoration bill.
Your sump pump is your first line of defense
So test it often; don't wait for a flood to learn it's already failing. A quick test is simple: pour a bucket of water into the pit and watch it kick on. Check the check valve too, since a worn one lets water flow back into the pit after each cycle, making the pump work harder and fail sooner. And consider a battery backup before the next storm, not after one. Power outages and heavy rain tend to arrive together, which is exactly when a primary pump is most likely to fail.
A lot of basement water starts outside the house, so manage where it goes
Clean your gutters and point downspouts well away from the foundation, ideally 6 to 10 feet out. Repair foundation cracks and fix any grading that slopes toward the house instead of away — even a small backward slope funnels water straight to your foundation over time. Check window wells for cracked covers or clogged drains, because a well that fills during a storm can push straight through an old seal and into the basement.
Catch problems early and think ahead
Install water leak sensors near major appliances and plumbing so a slow leak gets caught long before it becomes standing water. And if your basement has flooded more than once, price these upgrades against your last cleanup bill. The comparison usually settles the decision fast.
Handling a flooded basement safely starts with checking for electrical and gas hazards. Cut the power. Stop the source. Then dry everything out within 48 hours, before mold becomes the bigger problem. Document everything before cleanup starts. Confirm what your specific policy actually covers. Don't wait for the next flood to test your sump pump. A battery like EcoFlow's DELTA Pro Ultra X or DELTA 3 Max keeps a sump pump running when the power goes out, too.
What's the first thing I should do if my basement floods?
Check for danger first. Look for water touching outlets or cords. Smell for gas. If it's safe, cut power from a dry spot, like the main panel. Then find where the water is coming from, since the fix depends heavily on the source.
Is it safe to go into a flooded basement?
Not always. Skip it if the water is moving, deep, or touching outlets and cords. Skip it if you smell gas too. A rotten egg smell near a gas line means evacuate and call for help right away, rather than trying to check it yourself.
Will homeowners insurance cover a flooded basement?
It depends on the water source. A burst pipe is usually covered under a standard policy. Flooding from outside water, like heavy rain, usually isn't. That needs separate flood insurance, and it typically takes about 30 days to take effect after you buy it. Sewer backup often needs its own endorsement too, and that coverage usually comes with its own separate limit.
How fast do I need to dry out a flooded basement to avoid mold?
Within 24 to 48 hours, per EPA guidance. That window usually decides whether mold takes hold. Dehumidifiers, fans, and open windows all speed up drying once the water is out. Pulling wet baseboards helps too, if the water sat for more than a day.
How can I keep my sump pump running if my basement floods during a power outage?
A battery backup keeps it running without the grid. EcoFlow's DELTA Pro Ultra X can run a full sump pump and drying setup for hours at a stretch, and its capacity can be stacked with extra battery packs or solar input to stretch through a longer outage. The smaller DELTA 3 Max can get one pump or a wet-vac going right away, which fits a smaller basement just fine.
