National Preparedness Month: How to Prepare Your Home for a Power Outage
National Preparedness Month comes around every September. It comes from FEMA’s annual Ready Campaign initiative, aimed at individuals and families. What’s asked of them is simple enough. You learn your local risks, you draw up an emergency plan, and you stock up on supplies before disaster strikes. (Ready.gov)
Many U.S. households take a more practical message from it, and that message is to get ready for sudden power outages. The triggers are familiar ones. Hurricanes and wildfires do a lot of the damage. So do extreme heat, winter storms, and plain grid failure. A solid plan proves its worth once the power goes out. It protects your family, keeps communication open, and leaves essential devices running.
What Is National Preparedness Month?
FEMA runs a campaign nudging Americans to get themselves ready for emergencies. That means sizing up local risks, putting together some basic supplies, and writing down a simple plan.
Why Every Home Should Prepare for a Power Outage
A short outage? Flashlights and phone chargers cover it. Longer ones quickly creep into food storage, communication, and household comfort. Households that prepare ahead spend the outage focused on safety. Households that don’t spend it scrambling for supplies in the dark.
Common Causes of Power Outages Across the United States
Power outages can result from severe weather, equipment or grid failures, and periods of high electricity demand. Risks vary across the U.S., from hurricanes and tornadoes to ice storms, wildfires, and extreme heat.
Where you live decides which risks matter. On the coasts that means hurricane-related outages; out West it means wildfire-driven shutdowns. Every practical emergency plan begins the same way.
How an Outage Can Disrupt Essential Household Needs
Electricity touches far more than the lights. In an extended outage, the needs pile up fast. The food has to stay cold while phones and Wi-Fi stay alive, and that’s before you count medical equipment, a livable indoor temperature, or the essential work that can’t just stop.
Not every appliance deserves backup power, though. Figure out which ones do, and the right emergency supplies and backup solution become much clearer.
Identify the Unique Needs of Your Household
Every household ranks things differently. Take an Arizona family in a summer heat wave. Cooling and communication top the list. In a colder region, heating comes first. So does keeping the pipes from freezing.
Before an outage ever occurs, take stock of household size, medical needs, pets, climate, plus the appliances you count on most. The plan that comes out of all this is realistic instead of theoretical.
How to Build a Complete Home Emergency Preparedness Plan
A complete power outage preparedness plan brings supplies, communication, and backup power into one practical system. You’re not predicting every possible event. You’re making sure the household can respond when normal services stop.
Create a Family Communication and Evacuation Plan
How will family members reach each other if phone networks or internet access start failing? Decide now. Spell out emergency contacts and meeting locations. Spell out evacuation options. And settle who looks after the pets.
Keep the important details offline too. A dead device or a lost connection can’t touch them there.
Sign Up for Local Emergency and Utility Alerts
Severe weather, a planned outage, another hazard: the first warning usually comes via local emergency alerts and utility notifications. Received early, that warning buys you hours to charge devices, gather supplies, and secure the house.
Prepare a Power Outage Emergency Kit
A basic power outage emergency supply kit should include:
  • Flashlights and batteries
  • Drinking water
  • Non-perishable food
  • First-aid supplies
  • Portable chargers
  • Battery-powered radio
And when outages drag on, plenty of households turn to backup power to keep essential devices running.
Protect Food, Water, and Medications
Most of the food-safety work during an outage comes down to keeping the refrigerator and freezer doors closed. FoodSafety.gov has the exact numbers on this. Leave the refrigerator unopened, and food stays cold for about four hours, generally speaking. A full freezer, with the door kept closed, holds a safe temperature for roughly 48 hours.
Refrigerated medications change the picture for some households; if yours is one of them, work out in advance how to hold storage temperatures steady through an extended outage.
Plan for Children, Older Adults, Pets, and Medical Needs
Nobody in the household falls outside the plan. Children, older adults, pets, anyone relying on powered medical equipment — each needs extra preparation. Think those needs through beforehand and, when conditions get rough, much of the stress is already handled.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
How to Choose the Right Backup Power Solution for Your Home
Start with what you need to keep running. Factor in how long an outage might last. Then decide between portable flexibility and whole-home coverage.
Calculate Your Essential Power and Runtime Needs
Before choosing any home backup power system, estimate what the devices you want to run actually demand. Count both running power and startup surge, especially for appliances with motors or compressors like refrigerators and pumps. Common essential loads include:
DeviceWhy It Matters
RefrigeratorHelps protect food supplies
Wi-Fi routerSupports communication
LightsProvides basic visibility
Phone chargersKeep devices available
Medical equipmentSupports essential needs
That way you’ll match the system to your household instead of picking a system by battery size or output numbers alone.
Prioritize Critical Appliances During an Outage
Backup power does the most good in an outage when you spend it strategically. Refrigeration, communication devices, lighting, medical equipment, essential work gear — that’s what most households put first.
When using a portable power station for backup power, prioritizing critical devices can help stretch the available energy through a longer outage.
Flexible Backup Power for Essential Household Appliances
For homeowners who want reliable power for essential devices without installing a full-home system, the EcoFlow DELTA Pro 3 Portable Power Station offers a flexible option. It can support common outage needs such as refrigerators, Wi-Fi equipment, lighting, and home office devices, while expandable capacity allows users to adjust backup time based on their household requirements.
Delivers both 120V and 240V outputs with up to 4000W in a single unit, capable of powering a 3-ton central AC and all other essential appliances. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6000W of power when needed.
Its portable design also makes it easier to move power where it is needed, whether that means a garage workspace, basement, or another area of the home.
Whole-Home Backup for Longer Power Outages
For households that need more extensive backup capability during longer outages, the EcoFlow DELTA Pro Ultra Whole-Home Backup Power system is designed for larger energy needs. With support for 120V/240V power and expandable battery capacity, it can help support higher-demand loads, including HVAC systems, kitchen appliances, and other critical home circuits when properly configured.
The EcoFlow DELTA Pro Ultra is the only portable power station certified to both UL1973 and UL9540. It delivers 7.2-21.6kW, powerful enough to run your whole home even with a central AC. It features a scalable 6-90kWh capacity for weeks of backup. With Smart Home Panel 2 for auto-switchover, 5 charging modes, and self-heating for freezing weather, it’s the ultimate fail-safe power solution.
A whole-home backup system requires proper electrical integration. Depending on the setup, homeowners may need compatible transfer equipment or a Smart Home Panel, and installation should follow local electrical requirements with help from qualified professionals.
What to Do Before, During, and After a Power Outage
Problems shrink when preparation happens before the outage, never after it begins.
Before an Outage: Charge, Test, and Prepare
Severe weather in the forecast, an outage on the horizon — that’s the moment to charge phones and backup batteries, test the emergency equipment, and confirm the food, water, medications, and other essentials are on hand.
Use that same moment to review the emergency plan; everyone in the household should know their part.
During an Outage: Conserve Power and Protect Food
Once the power goes out, only the essentials matter. Use backup power on priority devices only. Everything nonessential stays off. The refrigerator and freezer doors stay shut. That keeps temperatures safe.
Updates, wherever possible, should come from official channels, especially during severe weather. That means Wireless Emergency Alerts (WEA) and NOAA Weather Radio, plus notifications from local emergency agencies or utility companies. Utility outage maps add real-time detail, and so do the apps from FEMA and the American Red Cross.
After Power Returns: Inspect and Reconnect Safely
The power coming back doesn’t mean the job is done. Check appliances before reconnecting everything. Inspect the home for storm damage. Recharge the backup equipment and replace whatever emergency supplies you used.
Afterward, review your response and update your emergency plan based on what worked and what could be improved.
National Preparedness Month, year after year, carries one reminder. Start emergency planning before disaster occurs. That means understanding your local risks, having the essential supplies ready, and choosing a backup power approach that fits. Do all of this, and the household stays ready, even when an outage arrives without warning.
Some households will want flexible power for the essential devices. Others will want a larger backup system that carries them through extended outages. Either way, the right call comes down to your own needs and priorities.
What is the best food to eat during a power outage?
Shelf-stable options with barely any prep work best here. Picture canned foods, dried foods, bottled water, and ready-to-eat meals. Stock foods your household already knows and uses; the stockpile stays fresh on its own.
Does hot water work when power is out?
It comes down to your water heater. A gas water heater may keep working through an outage. An electric one simply stops heating without power. Households that need hot water in an emergency should check which system type they own and write it into the outage plan.
What should I unplug during a power outage?
Sensitive electronics and any nonessential appliances should be unplugged during an outage. Power can return with a surge or voltage fluctuation, and connected devices take the hit.
Computers, televisions, gaming systems, small appliances with no need to stay powered: those are the usual ones to unplug. Essential devices are the exception. Medical equipment, refrigerators, and communication devices can stay connected when a suitable backup power source supports them.
How to survive 3 days without electricity?
Three days without electricity sounds long. It isn’t if the basics are covered: safe drinking water, food, communication, lighting, medications, a plan for essential power needs.
Most households keep several days’ worth of emergency supplies on hand, things like flashlights, batteries, portable chargers, food that won’t spoil. On top of that, a backup power solution keeps the important devices going, everything from phones and Wi-Fi routers to refrigerators and medical equipment. How much it covers depends on system capacity and household needs.
Why fill a bathtub with water during a power outage?
Some households fill the bathtub ahead of certain emergencies. The stored water covers non-drinking uses, flushing toilets among them; whether it’s worth doing depends on the emergency and on local conditions.
Power Outages
