What Size Generator for 200 Amp Service? Why Your Load Matters More Than Your Panel
What size generator for 200 amp service? The panel rating does not answer that. It shows how much power the service can deliver, not how much a home draws in an outage. Generator size comes from a load calculation of the circuits and motors that need backup, and how many start at once. Heavy appliances may take turns to keep the total lower. This article explains the gap, shows how electricians calculate load, and covers where a home battery fits when only selected circuits need power.
Why "200 Amp Service" Doesn't Tell You What Size Generator You Need
The amp rating on the main breaker is a ceiling. It was set when the service and panel were installed. Most homes use only a fraction of it on a normal day. Sizing backup from that ceiling often means paying for unused capacity, or guessing wrong about the loads that matter. So what size generator for 200 amp service is right? It depends on the load.
Service size comes from a load calculation
The City of Scottsdale, Arizona, publishes permit requirements for single-family services. They cover 120/240 volt, single-phase residential services and require an electrical load calculation using the NEC Standard or Optional method. The service was sized from a calculation, so backup should be too.
The math behind 200 amps
The arithmetic is short: 200 amps × 240 volts = 48,000 volt-amperes (VA) of service capacity. That is the most the service can carry, not a measured load. Many people asking what size generator for a 200 amp service expect that figure to become a generator rating. It does not.
Two homes, two very different loads
Two 200 amp homes can draw very different amounts of power. A few differences explain why:
  • Heating fuel: Gas heat means a much smaller electric load than electric heat.
  • Cooling equipment: One central air conditioner is a different load than two. Each compressor adds its own startup demand.
  • Well pump: A well adds a motor load that city water does not.
One kilowatt number for every 200 amp house would be wrong.
Main breaker rating versus actual loadMain breaker rating versus actual load
What local permit offices expect
Palm Beach County's residential generator permitting checklist, revised 12/31/24, places residential standby generators under NEC Article 702. A transfer switch is required, and a whole-house system uses the NEC 220 optional method.
Volts, amps, and power factor all shape a generator's full-load current, which is why the panel number and the generator number rarely match.
If the panel rating is not the answer, the real starting point is how much of the house needs coverage.
Whole House, Selected Circuits, or Load Management: Three Ways to Cover a 200 Amp Home
Local permit checklists show more than one acceptable way to back up a 200 amp home. A homeowner can size for the whole house, pick a smaller set of circuits, or add equipment that sheds lower-priority loads near the limit. Each choice changes the size.
Strategy
What gets backed up
What it means for size
Source
Whole house
Everything on the service
Sized from a full NEC 220 load calculation; transfer switch sized for the entire load
Palm Beach County checklist; Broward County standby generator standards
Selected circuits
A preselected set of loads moved to a separate standby panel
Sized for those loads only, counted at 100%
Load management (load shedding)
Whole house or a large set of loads, with automatic shedding of lower-priority loads
Total load imposed on the generator must not exceed its output
Anyone asking what size whole house generator for a 200 amp service is asking about the first row. The answer is a full NEC 220 load calculation, not the panel label.
What the permit documents say
Three local sources show how rules differ:
  • Broward County, Florida: Broward's standby generator standards, reflected in this Lauderdale-by-the-Sea permit checklist, use NEC Article 220 for existing loads and require all connected loads to be identified. Automatic load shedding can reduce the total load.
  • West University Place, Texas: The calculated load under NEC Article 220 must not exceed the generator's output rating. The city does not accept demand load in its place.
  • Palm Beach County, Florida: A demand meter reading may be used in some cases with the chief electrical inspector's approval. Some jurisdictions allow this, but it is not a general right.
In the end, what size standby generator for 200 amp service a home needs is decided by the inspector's review of the load calculation, not the panel label.
Choosing between full coverage and a short list of essentials is usually the biggest cost lever. Budget, fuel or battery capacity, and outage history all shape the choice of whole-home versus essential-circuit backup in a 200 amp house.
The selected-circuit route is also where a home battery becomes a practical alternative to a fuel generator.
Battery Backup Sized to Your Circuits: EcoFlow TITAN 5000 Classic and EcoFlow TITAN 5000 Plus
A home battery is not measured against a 200 amp rating either. It is matched to the circuits a calculation produces, like a selected-loads generator. Simple division shows why neither model below is a "200 amp generator."
For homeowners who land on the selected-circuit route, EcoFlow TITAN batteries offer a fuel-free way to cover the loads that made the list. They do not replace a 200 amp service or a full load calculation. Instead, each model is paired with a Smart Home Panel 10 that an electrician wires to a set of chosen circuits, sized by voltage and calculated demand.
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. •North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
If the calculated list includes 240V equipment, the next model up handles split-phase circuits. Its output is still far below a 200 amp service, which is fine once the load list is right.
• 100% Whole-Home Backup. 7.2–10kW output and 5kW single-circuit capacity power your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter required. • 100% Whole-Home Savings. Save up to $3,100 per year, with ROI in as little as 3 years. •Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, from upfront purchase and installation to long-term use. • OASIS 3.0 — Your AI Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • Built to North America's Highest Safety Standards. UL 9540A tested and UL 9540 certified, with EV-grade LFP cells and 24/7 BMS monitoring.
How the two models divide the job
The EcoFlow TITAN 5000 Classic fits calculated 120V critical loads. The EcoFlow TITAN 5000 Plus fits calculated 240V home circuits, such as a compatible central AC, through Smart Home Panel 10 (240V).
The math is short. 7,200W ÷ 240V = 30 amps, about 15% of a 200 amp service. The Classic follows the same load-first logic.
A sample runtime estimate
This example assumes an illustrative calculated load of 1,500W.
  • One battery unit: 5,017.6Wh × 0.85 (a planning allowance for conversion losses) ÷ 1,500W ≈ 2.8 hours.
  • Six units (30kWh, about 30,106Wh): 30,106Wh × 0.85 ÷ 1,500W ≈ 17 hours.
Swap 1,500W for the calculated load of the chosen circuits. Output stays at the model's rated watts however many batteries are added. Extra units add hours, not power.
Daily kWh use, peak watts, and outage length are the three numbers behind sizing a home battery backup for selected circuits.
Whichever route is chosen, size comes down to the numbers on the home's own appliances.
How to Build Your Load List Before Anyone Quotes a Size
Electricians do the formal NEC 220 calculation, but a homeowner's list speeds the job and sharpens the quote. Gather nameplate data, note which appliances have motors, and mark what truly has to run. None of this needs contact with the panel.
Virginia Cooperative Extension explains how to read appliance nameplates for volts, amps, and watts. Ready.gov's power outage guidance helps decide which items must keep running.
Appliance or circuit
Voltage
Running watts or amps (nameplate)
Motor?
Must run in an outage?
Refrigerator
120V
About 725W (example: frost-free, 16 cubic foot model)
Yes (compressor)
Yes
Furnace blower or boiler controls
120V
About 750W (example furnace); boiler controls vary
Yes (blower or circulator motor)
Yes in cold weather
Central AC or heat pump
240V
Use nameplate running watts or a measured value. At 240V, amps × 240 gives VA; real watts also depend on power factor.
Yes (compressor)
Depends on climate and budget
Well pump
240V (some are 120V)
About 250W to 1,100W (deep-well pump range)
Yes
Yes if the home has a well
Sump pump
120V
Use nameplate running watts or a measured value. At 120V, amps × 120 gives VA; real watts also depend on power factor.
Yes
Yes in flood-prone areas
Lights, router, small electronics
120V
Printed on each device or its power adapter; add them up
No
Yes
Why motors drive the size
The University of Wisconsin-Extension explains in its standby generator publication that a part-load system works only if the generator is sized to start the largest motor. Running watts tell part of the story. Startup demand tells the rest.
Compressor startup is the main reason the generator size for AC often runs larger than its running watts suggest.
Two quick planning tips
  • Convert amps to watts: For AC appliances, volts × amps gives apparent power in VA. Real input watts also depend on power factor. Use nameplate watts or a measured value, because 240V × 10A is 2,400VA, not necessarily 2,400W.
  • Stagger big loads: Some large loads can take turns. A lower simultaneous total can mean a smaller system.
What the manufacturer says
Anyone asking what size Generac generator for 200 amp service will find the same point on Generac's sizing page. The company recommends a professional load analysis and says a site survey is the only way to ensure full accuracy.
With a load list in hand, the last step is a permitted, safe installation.
Permits, Placement, and Questions to Ask Your Installer
Any backup source tied into a 200 amp panel needs a permit, an inspection, and a licensed installer. Fuel generators add exhaust placement rules. A few direct questions show whether a quote rests on a real load calculation.
Concrete pad for outdoor equipmentConcrete pad for outdoor equipment
Safety rules that apply to every setup
  • Transfer switch: Palm Beach County requires one for all residential generators, along with a load calculation to size both.
  • No backfeeding: The U.S. Consumer Product Safety Commission warns in its portable generator alert never to power house wiring by plugging a generator into a wall outlet. It risks electrocution for utility workers and neighbors.
  • Outdoor placement: The CDC says to keep a generator outside, at least 20 feet from doors, windows, and vents. The CPSC adds never to run one in a garage, basement, crawlspace, or shed, and to install CO alarms with battery backup.
  • Licensed installation: EcoFlow states that Smart Home Panel 10 installation and wiring require a qualified, licensed electrician.
Questions to ask an installer
  1. Did the quote include an NEC 220 load calculation? Ask to see it. A real one lists the loads and the method.
  2. Is this whole house, selected circuits, or load managed? The answer sets size and price.
  3. Which loads will not be covered? Every system leaves something off.
  4. Who pulls the permit? State it up front.
  5. How does the system prevent backfeed? The answer should name the transfer switch or panel.
Permits, gas lines, concrete pads, and electrical work all shape typical standby generator installation costs beyond the unit's price.
A 200 amp rating shows service capacity, not the generator or battery size a home needs. Size comes from a load calculation, motor startup needs, and whether the plan covers the whole house, selected circuits, or load management. Build a nameplate load list, pick a coverage strategy, and ask installers for their NEC 220 calculation. For a fuel-free, selected-circuit route, compare the EcoFlow TITAN 5000 Classic for 120V loads and the EcoFlow TITAN 5000 Plus for calculated 240V circuits, each with Smart Home Panel 10 installed by an electrician.
Do I need a 200 amp generator for a 200 amp service?
No. A generator is sized to the calculated load, not the service rating. Local rules decide whether that load covers the whole house, selected circuits, or a load-managed setup.
How many watts is 200 amp service?
At 240 volts, 200 amps works out to 48,000 volt-amperes of capacity. That is the most the service can carry, not what a home actually uses on an average day.
What size standby generator do I need for a 200 amp house?
It depends on the load calculation for the circuits planned for coverage. Two 200 amp homes with different heating, cooling, and pump loads can need very different sizes.
What size Generac generator is right for 200 amp service?
Generac's own sizing guidance recommends a professional load analysis and site survey rather than a size based on amp rating. The same approach applies to any brand.
Can a home battery back up a 200 amp panel?
A home battery backs up selected circuits matched to its output, not the full 200 amp service. The EcoFlow TITAN 5000 Plus is rated at 7,200W from the battery and connects through Smart Home Panel 10 installed by a licensed electrician.
Home Backup
