Water Heater Breaker Size: Read the Nameplate, Run the Numbers, Then Call an Electrician
- What Decides a Water Heater's Breaker Size
- Working It Out: Nameplate Examples From 120V to 240V
- Hot Water During an Outage: Where EcoFlow TITAN 5000 Fits a 240V Water Heater
- Heat Pump, Tankless, and Gas Water Heaters Follow Their Own Labels
- Tripping Breakers, Permits, and When to Call a Licensed Electrician
- Conclusion
- FAQs
Most people go looking for a water heater breaker size after a breaker trips, a tank gets replaced, or a remodel adds a bigger heater. The honest answer isn't one magic number. It comes from the label on your heater, the voltage feeding it, and a code rule that sizes the circuit above the heater's rating. This article walks through that calculation with real examples, explains why the wire and breaker have to match, and covers what changes for heat pump, tankless, and gas models. It also explains how backup power fits in.
Your water heater's rating label tells you where to start. It lists important electrical specifications, including voltage and wattage. Those numbers help determine the current the circuit must carry.
Start with the manufacturer's label, not a chart based on tank capacity.
Find the nameplate
Look for the rating plate on the tank jacket or the label specified in the installation manual. If you need to remove an access cover to locate electrical information, turn off the breaker first. Don't open electrical covers if you're unsure how to do so safely.
Record these details:
Voltage: The electrical supply the heater is designed for, such as 120V, 208V, or 240V.
Wattage: The rated power consumption of the heating element or unit.
Manufacturer's instructions: The manual may specify circuit, breaker, and wiring requirements.
The basic electrical calculation is straightforward:
Amps = Watts ÷ Volts
For example, a 4,500-watt heater operating at 240 volts draws 18.75 amps.
Once you know the basic electrical calculations for amps, the rating plate on a water heater is easier to understand.
Why the heating element configuration matters
Some electric water heaters use single-element designs. Others use two elements that operate alternately or simultaneously. Simultaneous operation can increase the total electrical demand.
Use the unit's listed electrical rating and installation instructions. Don't assume every two-element tank draws the combined wattage of both elements at once. The configuration determines how the elements operate.
Why tank size doesn't determine breaker size
A 50-gallon tank doesn't automatically need the same breaker as another 50-gallon tank. The models may have different wattage ratings and electrical requirements.
Local electrical codes also matter. California city permit documents, including the Milpitas residential water heater handout and Newport Beach checklist, describe a 125% sizing requirement for covered water heater installations. These documents reflect locally adopted electrical requirements, and the exact rules can vary by jurisdiction.
Check with your local building department before installing or replacing a heater.
With the label in hand, the next step is turning its watts and volts into a minimum circuit rating.
The calculation involves two straightforward steps. First, divide the listed watts by the supply volts to get running current. Second, multiply that current by 1.25 to meet the minimum circuit rating described in permit documents. From there, a licensed electrician selects a standard breaker that meets or exceeds that minimum while matching the conductor wire size.
The following table demonstrates how these calculations work across different residential nameplate examples:
Example nameplate (illustration only) | Amps = watts ÷ volts | Minimum at 125% (amps × 1.25)
4,500W at 240V | 4,500 ÷ 240 = 18.75A | 23.44A |
5,500W at 240V | 5,500 ÷ 240 = 22.92A | 28.65A |
6,000W at 240V | 6,000 ÷ 240 = 25.00A | 31.25A |
4,500W at 208V (label lists 208V) | 4,500 ÷ 208 = 21.63A | 27.04A |
1,500W at 120V (small point-of-use unit) | 1,500 ÷ 120 = 12.50A | 15.63A |
Note: Every row above is an example. Always use the numbers printed on your own equipment label. The calculated output represents a code minimum, not a specific breaker recommendation. Final equipment selection belongs to a licensed electrician based on your local code and the manufacturer's manual.
Notice how supply voltage changes the math in the 208-volt row. Multi-family condo buildings and apartment complexes often use 208-volt three-phase utility supplies instead of standard 240-volt single-phase residential power. If you install a 240-volt heater on a 208-volt line, the heating element will not deliver its full rated wattage. Always have an electrician verify your actual supply voltage before buying a unit.
Why is the circuit sized at 125%
Permit rules require dedicated storage water heater circuits to be sized to at least 125% of the heater's rating.
Electric water heaters run continuously for long periods when recovering from heavy use, such as back-to-back showers or laundry cycles. Sizing the circuit to 125% of the running load gives the wiring and breaker adequate safety margin.
Stated from the opposite perspective, the water heater load should not exceed 80% of the breaker's total continuous carrying capacity (1 ÷ 1.25 = 0.8).
The breaker and the wire are a pair
The circuit breaker and the branch circuit wiring operate as a matched safety pair. Permit documents from Milpitas and Newport Beach explicitly apply the 125% sizing rule to both the overcurrent device and the circuit conductors. The City of Ventura's inspection checklist instructs inspectors to verify that the breaker and conductors are properly sized for the equipment nameplate.
Installing a larger breaker on undersized wire creates an extreme fire hazard because the breaker will not trip before the wire overheats.
Breakers exist primarily to prevent branch circuit wiring from melting inside your walls.
Conductor sizing depends on wire material, insulation rating, run distance, and ambient temperatures.
Dedicated 240-volt electric tank heaters require a two-pole breaker to disconnect both hot legs of the incoming supply simultaneously.
Electricians confirm the wire size for a 30-amp breaker before a new heater circuit is switched on. Never guess on conductor sizing; let a professional handle it.
Sizing the circuit covers normal days on the grid; keeping that same 240V heater running when the grid goes down is a separate question with its own numbers.
A backup power source does not change your water heater breaker size. The water heater keeps its dedicated breaker, branch conductors, proper grounding, and local disconnect switch regardless of how your home is powered. What changes during an outage is whether your stored battery capacity can handle that heavy heating load, and for how long.
A typical 4,500-watt, 240-volt water heater element draws 18.75 amps whenever the internal thermostat calls for heat. That is a massive continuous electrical draw. It requires substantial inverter capacity and will deplete stored battery reserves quickly:
Estimated water heater runtime on backup power
Backup configuration | Calculation | Estimated element-on time |
One EcoFlow TITAN 5000 unit, 5,017.6Wh | 5,017.6 × 0.85 ÷ 4,500 | About 57 minutes |
Expanded system, 30kWh | 30,000 × 0.85 ÷ 4,500 | About 5.7 hours |
The calculations assume 85% of stored energy is available after allowing for conversion losses. Actual performance depends on operating conditions and the system's specifications.
Element-on time isn't the same as clock time: A thermostat switches the heating element on and off as needed. Household water use, incoming water temperature, tank insulation, and other electrical loads affect the results.
Output capacity also matters. A 4,500-watt heating element consumes 62.5% of the 7,200-watt total continuous output of the EcoFlow TITAN 5000. That leaves approximately 2,700 watts to run remaining household circuits while the element heats.
Note that standard 120-volt backup power stations cannot power dual-pole 240-volt resistance heaters. The EcoFlow TITAN 5000 Classic, for instance, provides 120-volt output and does not support 240-volt appliances like electric water heaters. You must have split-phase 120V/240V capability to run a standard electric water tank.
Homes that want a 240V water heater on outage backup need split-phase output, a panel that switches that circuit over, and an electrician who has checked the heater's amps against the system. The EcoFlow TITAN 5000 is a home battery built for that 120V/240V role, and it works through the EcoFlow Smart Home Panel 10 (240V), not through a cord
Comparing whole-home versus critical-load battery setups helps you decide if the water heater circuit belongs on the list. Because resistance water heating requires immense energy, many homeowners prioritize refrigerators, lights, and medical equipment during emergencies.
Standard electric tanks follow the calculation above, but heat pump, tankless, and gas heaters each bring their own electrical needs.
Not every water heater is a 240-volt resistance tank. Heat pump, electric tankless, and gas models can need very different circuits, from a simple 120-volt plug to multiple large breakers. The same golden rule holds for all of them: check the manufacturer label and installation manual.
Heat pump (Hybrid) water heaters
According to ENERGY STAR, hybrid electric water heaters use heat pump technology to pull heat from surrounding air into the water tank. They work best in interior spaces that remain between 40°F and 90°F year-round.
Because compressors consume far less energy than traditional heating elements, their electrical requirements vary widely:
Some modern 120-volt hybrid models plug directly into a standard wall receptacle.
Rheem's ProTerra 120V dedicated-circuit plug-in heat pump model requires a dedicated 15-amp time-delay circuit.
Ruud's Ultra plug-in heat pump shared-circuit model is designed to operate on a 120-volt shared branch circuit.
Many 240-volt hybrid models with backup resistance elements require a dedicated 30-amp circuit, but 15-amp and 30-amp models are available. Use the exact model's nameplate and manual.
Always read the specific manufacturer documentation. Even two 120-volt models from the same brand can have completely different circuit demands.
Electric tankless water heaters
Electric tankless models do not store preheated water. Instead, they heat incoming cold water on demand using massive arrays of heating elements.
These instantaneous units draw enormous amounts of power. For example, Martin County, Florida's electrical load calculation form includes tankless water heaters when assessing whether the existing electrical service can handle the load. Large whole-home models may require a service upgrade and multiple dedicated circuits; follow the exact model's instructions and a licensed electrician's load calculation.
Gas and hybrid systems
Gas water heaters burn natural gas or propane to heat water, so breaker sizing only applies if the model uses electrical components.
Before an outage, check the manual, since some tanks are gas water heaters that need electricity to run. Power-vented models, electronic ignitions, draft inducers, and digital temperature displays need a 120-volt circuit. Gas piping, gas line testing, and chimney venting require a licensed plumber or certified gas technician.
If you are switching from gas to an electric water heater, you will need a new dedicated circuit installed back to your main breaker panel. The City of Milpitas requires an electrical permit whenever you run new branch circuits or receptacles for a water heater upgrade.
Whatever type you have, a breaker that keeps tripping is a sign to stop and get the circuit checked, not to reach for a bigger breaker.
A breaker that trips is doing its job. It is telling you something on that circuit drew more current than it should, or a fault developed. The fix is a professional diagnosis, not a larger breaker.
The dangers of upsizing breakers
Never replace a tripping water heater breaker with a higher-amperage breaker. As established in permit documents from Milpitas, Newport Beach, and Ventura, the breaker is sized specifically to protect the conductors connected to it.
If you put a 40-amp breaker on wiring rated only for 30 amps:
The wire can overheat inside walls without tripping the breaker.
Insulation melts away, exposing bare live conductors.
Internal arcing can cause an electrical house fire.
Equipment manufacturer warranties and homeowner insurance coverage may be voided.
Warning signs that demand professional help
Simple ways to keep breakers from tripping start with knowing which appliances share each circuit. When a dedicated water heater breaker trips, possible causes include a problem with the heater, its wiring, or the breaker and circuit sizing. A licensed electrician should diagnose the cause.
Call a licensed professional if you notice:
A breaker that trips repeatedly immediately after being reset.
The breaker handle feels unusually hot to the touch or smells like burning plastic.
Scorch marks or melted insulation at the breaker panel or the heater's electrical junction box.
The breaker remains on, but the water heater fails to heat water.
Safety note: Never open water heater access covers while the power is live. If you see active sparks, smoke, or a glowing panel, evacuate the immediate area and dial 911.
Permits and local building codes
Water heater installations almost always require permits and official inspections to ensure life safety:
City of Ventura, CA: Its water heater replacement checklist describes a final inspection and requires the breaker and conductors for electric heaters to be adequately sized to the equipment rating.
City of Rancho Palos Verdes, CA: Water heater replacement is a listed permit project. The required permit types, including any electrical permit, depend on the work being performed; confirm them with the building department.
Check with your local city or county building division before starting any water heater project. When your electrician arrives, have a photo of the heater's nameplate, the existing breaker rating, and your future hot water plans ready.
Your water heater breaker size comes straight from the equipment rating label. Divide listed watts by supply volts to calculate operating amps, multiply by 1.25 to determine the minimum circuit rating, and let a licensed electrician select the right breaker and wire size. Start by photographing the nameplate and confirming whether the heater is rated for 120V, 208V, or 240V. Then ask a licensed electrician to verify the existing circuit before replacing the heater or increasing its wattage.
If you want reliable hot water during grid failures, an electrician can check whether your 240-volt water heater circuit can integrate with the EcoFlow TITAN 5000 using the EcoFlow Smart Home Panel 10 (240V). A qualified electrician can assess the load and estimate realistic runtime alongside your other essential circuits.
What size breaker does a 4,500-watt water heater need?
At 240V, a 4,500W heater draws 18.75A. Multiplying by 1.25 gives a minimum circuit rating of 23.44A under the applicable 125% rule. An electrician must select the appropriate standard breaker and conductors based on local code and the manufacturer's instructions.
Is a water heater a continuous load?
Local permit documents such as the City of Milpitas handout require circuits for storage-type water heaters of 120 gallons or less to be sized at no less than 125% of the heater's rating. That 125% sizing is how continuous loads are treated.
Can I put a bigger breaker on my water heater if it keeps tripping?
No. A larger breaker can leave the existing wire inadequately protected. Repeated tripping needs a professional diagnosis, not a breaker upgrade without a proper circuit assessment.
Can a water heater share a circuit?
It depends on the model and its installation instructions. Some 120V plug-in heat pump water heaters allow shared circuits, while others require dedicated circuits. Check the exact model's requirements before adding another load.
Can a home battery run an electric water heater?
A 240V-capable home battery can, if an electrician confirms the circuit fits its output. With the EcoFlow TITAN 5000, a 4,500W element would use about 57 minutes of stored energy per unit in a labeled estimate.
