Pond Heater or De-Icer? How to Keep Backyard Pond Fish Safe Through Winter
Most backyard ponds don't need to be heated. They need a small opening in the ice. Fish slow down in cold water and can spend winter near the bottom, but gases can build up under a sealed surface. That's why a product called a pond heater is often a thermostat-controlled de-icer. A small aerator may also help keep an opening in the ice. This guide explains the differences, compares power needs, and shows what you can realistically run when a winter storm knocks out electricity.
De-Icer, Aerator, or Pond Heater: What Each One Actually Does
A de-icer keeps a small area of water open, an aerator adds oxygen and moves water, and a pond heater raises the water temperature. Most backyard fish ponds need an opening in the ice rather than warm water. As the water cools, fish slow down and stay in deeper areas. Ice and snow limit sunlight, while fish, plants, and decaying leaves continue to use oxygen. Small, shallow ponds with many fish or lots of organic matter face a greater risk of low oxygen. Choose a de-icer or aerator based on your pond's depth, fish load, and existing equipment.
De-Icer, Aerator, or Pond Heater: What Each One Actually DoesDe-Icer, Aerator, or Pond Heater: What Each One Actually Does
How the three options compare
Equipment
What it does
Typical listed wattage
When it makes sense
Pond aerator
Adds oxygen and moves water near the outlet
About 6W to 15W for the Aquascape kits reviewed
When a small opening and oxygen exchange are the main goals
Pond de-icer
Uses heat to keep a small area of water open
About 250W to 300W for the examples discussed
When you need to prevent the surface from sealing over
Larger floating pond heater
Supplies more heat to the water
Some models use 750W to 1,500W
When the pond and equipment call for more heating capacity
These wattages are examples from the products reviewed, not universal ratings. Check the manufacturer's sizing chart before choosing equipment.
Does every pond need a de-icer?
No, not every pond needs a de-icer. A pond without fish may not need an open hole or winter aeration. For fish ponds, consider the depth, oxygen levels, and local winter conditions. Iowa State University Extension recommends at least 4 feet of depth for ponds without a pump or heater to help prevent freezing to the bottom. Never break the ice with a hammer or shovel, as the shockwave can harm fish and damage the liner. Use a suitable de-icer or aerator instead. Fish need suitable winter conditions, not necessarily warmer water. Understanding how fish behave in cold water can help you choose the right equipment. Check its wattage, too, so you can plan for normal use and possible power outages.
How Many Watts Does a Pond Heater Use?
Winter pond equipment ranges from a few watts to well over a thousand. Aerators sit at the low end, de-icers in the middle, and large floating heaters at the top. Use the manufacturer's listed watts and sizing charts, not guesses.
Product (manufacturer page, checked 2026-10-28)
Listed watts
Notes from the maker
Aquascape 2-Outlet Pond Aeration Kit
6W
Ponds up to 2,000 gallons; 6-foot cord; keeps a small hole open in winter
Aquascape Pro Air 20 Pond Aeration Kit
15W
Ponds up to 5,000 gallons; outdoor-rated compressor; 6-foot cord; 30-foot freeze-resistant tubing
Aquascape 300-Watt Pond De-Icer
300W when actively heating
Thermostat-controlled, does not run continuously
K&H Thermo-Pond Perfect Climate Deluxe De-Icer
250W, 750W, or 1,500W
Keeps average water just above freezing; 12-foot cord; MET listed; 110/120V; no extension cord; pick wattage with K&H's zone chart
K&H notes that its 750W pond heater uses three times as much electricity as its 250W model while running. K-State Research and Extension and Aquascape both recommend stopping fish feeding when water temperatures fall below 50°F. If a label lists only amps and volts, calculating watts can help you estimate the power needed. These wattage differences matter when an ice storm cuts power, and your pond equipment stops working.
Keeping a Pond Open During a Winter Power Outage
When the power goes out, an electric de-icer stops heating. The surface may begin to freeze again. A short outage may pose little risk to a deep, healthy pond, but a longer outage during severe cold needs more attention. For backup power, start with the smallest useful load. An aerator is usually easier to run from a battery than a de-icer because it draws far less power.
Estimate runtime before an outage
The EcoFlow DELTA 3 Max has a rated capacity of 2,048Wh. For these estimates, assume 85% is available after conversion losses, leaving about 1,740Wh. Actual runtime will vary with the device and operating conditions.
Load (listed watts)
Estimate
Aquascape Pro Air 20 aerator, 15W
1,740 ÷ 15 ≈ 116 hours on paper (see caveat)
K&H Thermo-Pond 250W de-icer, while heating
1,740 ÷ 250 ≈ 7.0 hours of active heating
Aquascape 300W de-icer, while heating
1,740 ÷ 300 ≈ 5.8 hours of active heating
K&H Thermo-Pond 1,500W de-icer, while heating
1,740 ÷ 1,500 ≈ 1.2 hours (not a practical battery load)
These runtimes are estimates, not guarantees. Cold and wind affect de-icer cycling, while the power station's own energy use can reduce aerator runtime. Treat the figures as upper limits, test your setup, and monitor the battery. Don't rely on it for overnight or all-winter use. EcoFlow lists a recharge time of about 68 minutes to reach 80% using wall or generator charging. Always run gas generators outdoors, away from doors, windows, and vents, to prevent carbon monoxide exposure. The EcoFlow DELTA 3 Max can provide temporary backup for a suitable aerator or low-wattage de-icer during an outage. Check power requirements before connecting equipment, and keep the power station dry and protected.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The EcoFlow DELTA 3 Max can temporarily power a suitable low-wattage de-icer or aerator during a winter outage, provided you check its wattage and estimated runtime first. Keep the power station dry, indoors, and away from water. The same planning steps apply to battery backup for aquarium pumps: check power needs, test runtime, and plan for safe placement. Before connecting any pond equipment, check the outlet protection and follow the manufacturer's safety instructions.
Outlet, Cord, and Ice Safety for Pond De-Icers and Aerators
Follow the instructions for your specific pond equipment. Use the required voltage, grounding, and outlet protection. Don't modify electrical connections to keep a pond running during a storm.
Use GFCI protection
Outdoor electrical outlets need ground-fault circuit interrupter (GFCI) protection under applicable electrical code requirements. A GFCI monitors current and cuts power when it detects an imbalance that could cause a serious shock. Test the GFCI at least once a month and after a power failure, following its instructions. Never remove or bypass it. Have a licensed electrician install any new outdoor outlet and check local code requirements. When using a portable power station, don't assume its outlets provide GFCI protection. Follow the power station and pond device manuals, and ask the manufacturers or an electrician how to maintain appropriate shock protection.
Check cords and keep off the ice
Use the voltage and grounding recommended by the manufacturer. K&H de-icers need a properly grounded 110/120V outlet and shouldn't be used with extension cords. Clean the unit as directed to prevent mineral buildup. Keep children off the ice, and never step onto a frozen pond to reach equipment. Use a pole or rope from the bank instead. Don't chip or strike the ice to create an opening. Follow the manufacturer's instructions and learn why outdoor outlets need GFCI protection before setting up pond equipment.
A Winter Routine for Backyard Ponds
Winter pond care is easier when you plan ahead. Clear leaves in fall, check the equipment before temperatures drop, and keep an eye on the pond during cold spells. The right routine depends on the pond's depth, fish load, and equipment.
A Winter Routine for Backyard PondsA Winter Routine for Backyard Ponds
In fall
  • Remove fallen leaves and other organic debris from the pond.
  • Trim aquatic plants as needed.
  • Stop feeding fish when the water drops below 50°F.
  • Winterize pumps, waterfalls, and fountains according to the manufacturer's instructions.
  • Install and test the aerator or de-icer before the first hard freeze.
  • Check outdoor outlets, GFCI protection, cords, and connections.
  • If you plan to use battery backup, test the setup and confirm where the power station will stay dry and protected.
During winter
  • Check the pond opening and equipment periodically.
  • Watch for a tripped GFCI, damaged cord, or de-icer that no longer works.
  • Keep snow from covering safe, accessible areas of the pond where light needs to reach the water. Penn State Extension gives guidance on snow cover for larger ponds, but don't step onto ice to clear it.
  • If the power goes out, prioritize a low-wattage aerator when suitable and follow the equipment's safety instructions.
Ice storms can damage trees and power lines, so consider portable power stations if you need temporary backup for small equipment. The important step is to calculate the load and test the runtime before an outage.
In spring
  • Remove the de-icer and switch off winter aeration once the pond is ice-free, following the equipment instructions.
  • Inspect cords and equipment before storing them.
  • Check the pond for damaged liners, loose fittings, or other problems caused by winter weather.
  • Resume feeding only when water temperature and fish activity make it appropriate.
Most backyard fish ponds need oxygen exchange and a small opening in the ice, not warm water. A de-icer or aerator can help, but the right choice depends on pond depth, fish load, and the equipment manufacturer's guidance. Check wattage before buying, keep outdoor electrical connections protected, and never strike the ice to open a hole. For a winter outage, a low-wattage aerator is usually the easier load to support with battery backup. The EcoFlow DELTA 3 Max may run a suitable aerator or provide a few hours of active heating for a compatible low-wattage de-icer. Keep the power station dry and protected, confirm the load, and test the setup before the first freeze.
Do I need a pond heater in winter?
Usually not. Most fish ponds need a small opening in the ice for gas exchange, which a suitable de-icer or aerator can help provide. Iowa State University Extension says ponds without a pump or heater should be at least 4 feet deep to help prevent them from freezing to the bottom.
What's the difference between a pond de-icer and a pond heater?
A de-icer keeps a small area of water open and typically uses a thermostat to control heating near freezing. A true pond heater aims to raise water temperature and may use much more power. Most backyard fish ponds don't need their entire volume heated.
How many watts does a pond de-icer use?
The de-icers reviewed for this guide range from about 250W to 1,500W. Aquascape's 300W model draws 300 watts while actively heating. The exact power requirement depends on the model, so check its label and sizing chart.
Can a portable power station run a pond de-icer?
It may run a compatible low-wattage de-icer for a limited time. Using a planning allowance of 85% of the EcoFlow DELTA 3 Max's 2,048Wh capacity, a 300W de-icer has an estimated 5.8 hours of active heating. Actual runtime depends on thermostat cycling and operating conditions. This is a short-term backup option, not a promise of overnight operation.
Should I break the ice on my pond?
No. Don't strike or chip pond ice to create an opening. K-State Research and Extension warns that the shockwave can harm fish and damage the liner. Use a suitable de-icer or aerator, and follow its instructions instead.
Home Solutions
