How Many Amps Does a 1500 Watt Heater Draw? About 12.5 on a Standard Outlet, and Why It Matters
A 1500-watt space heater is one of the hungriest things most people ever plug into a regular outlet. On a standard 120-volt circuit, it pulls about 12.5 amps. That's a big share of what the circuit was built to carry. This article explains the simple formula behind that number, why actual readings can vary, and what the draw means for cords and outlets. It also covers how long a heater could realistically run on home battery backup during a winter outage.
The Short Answer: 12.5 Amps at 120 Volts
Amps tell you how much electric current a device pulls through your wiring. For an electric heater, you find that number by dividing its rated watts by the voltage it runs on. At 120 volts, a 1,500-watt heater works out to exactly 12.5 amps.
You do not need an electrical engineering degree to run the math. It comes down to basic arithmetic:
The formula is simple:
Amps = Watts ÷ Volts
1,500 ÷ 120 = 12.5 amps
That 12.5-amp draw explains why space heaters get so much attention from electricians and fire safety experts. A typical household outlet is built for 15 amps total. When you turn on a 1500W space heater, you take up almost that entire capacity in a second.
Wattage and Amps Across Different Voltages
You might occasionally see a 1,500-watt heating rating tied to a different voltage. It helps to look at the numbers side by side:
Heater Rating
Voltage
Calculation (Amps = Watts ÷ Volts)
Operating Amps
1,500W plug-in space heater
120V
1,500 ÷ 120
12.5A
1,500W hardwired heater (labeled for 240V)
240V
1,500 ÷ 240
6.25A
The 240V row applies strictly to heaters manufactured and labeled for 240V service. These include baseboard heaters or permanent garage wall units wired directly by a licensed electrician.
A portable space heater you buy at a home improvement store is a 120V appliance. Never attempt to plug a standard 120V portable heater into a 240V outlet. Doing that will destroy the unit immediately and creates an extreme fire hazard.
Energy Use vs. Current Draw
Current draw and total energy consumption are two different things:
  • Current is measured in amps, which tells you how much flow happens right now.
  • Energy is measured in watt-hours or kilowatt-hours, which tracks that flow over time.
Running a 1,500-watt heater at full blast consumes 1.5 kilowatt-hours (kWh) of electricity every hour it stays on:
1,500 W × 1 hour = 1,500 Wh = 1.5 kWh
This cumulative energy consumption becomes critical when you plan backup power during a winter storm.
Checking Your Heater's Nameplate
Do not guess your space heater's power rating. Every legal portable space heater sold in the United States features an electrical specification label. You can usually find this plate on the underside, the back panel, or stamped near the power cord.
Here is what you should check on that label:
  • Look for the listed wattage on high, medium, and low modes.
  • Many heaters switch between 750W, 1,000W, and 1,500W settings.
  • Check the rated voltage (typically listed as 120V AC, 60Hz).
  • Confirm the listed operating amperage before plugging into an unfamiliar circuit.
Knowing what volts, amps, and watts mean makes any heater label easy to decode.
Why a Meter Might Show 11.9 or 13.1 Amps
Household voltage doesn't stay exactly at 120 volts all the time. It can vary with utility conditions and electrical demand.
Illustration: AC current measurement with an enclosed 1X line splitter, for a short-term professional test only.Illustration: AC current measurement with an enclosed 1X line splitter, for a short-term professional test only.
For example, Pacific Gas and Electric Company's residential service rules specify a normal voltage range of 114 to 126 volts for nominal 120-volt service, subject to stated exceptions. Other utilities have their own requirements, so this isn't a universal national range.
For a simple resistance heater, we can estimate how that voltage variation affects current.
First, calculate the heating element's approximate resistance at its rated operating point:
120² ÷ 1,500 = 9.6 ohms
Using that resistance as a simplified, fixed value:
  • At 114 volts: 114 ÷ 9.6 = approximately 11.88 amps.
  • At 120 volts: 120 ÷ 9.6 = 12.5 amps.
  • At 126 volts: 126 ÷ 9.6 = approximately 13.13 amps.
Real heating elements can change resistance as they heat up. Therefore, these calculations illustrate the relationship rather than guarantee an exact meter reading.
The practical takeaway is straightforward: plan around 12.5 amps for a 1,500-watt heater on a 120-volt supply. Small differences in measured current can be normal.
Twelve and a half amps is a substantial load for one plug. That's why your outlet, circuit, and cord choices matter as much as the heater itself.
What a 12.5-Amp Load Means for Your Outlet and Cord
A space heater does not share wall outlets or circuit capacity well. At 12.5 amps, it takes up most of a typical household circuit by itself. It keeps drawing that heavy current for as long as the heating element runs. That continuous draw is why fire agencies issue strict safety warnings about where you plug it in.
Federal Fire-Safety Warnings
National public safety agencies identify portable electric heaters as a leading ignition risk when misused.
The U.S. Fire Administration (USFA), a division of FEMA, states plainly in its portable heater safety materials: plug space heaters directly into wall outlets, and do not use an extension cord or power strip. The USFA also stresses checking heater cords for damage or loose prongs before turning them on.
The Office of Congressional Workplace Rights (OCWR) echoes this rule in its portable space heater safety guidance: always plug space heaters directly into a grounded wall receptacle, never into a power strip or extension cord.
Here is why fire officials take such a hard line:
  • Light-duty extension cords use thin 16-gauge or 14-gauge copper wire.
  • Continuous high current generates resistance heat along the entire cord length.
  • Standard power strips rely on internal contact strips not rated for hours of maximum load.
  • Overheated cords can soften, melt their vinyl insulation, and ignite nearby carpet or curtains.
Understanding Circuit Sharing
Household branch circuits supply multiple outlets across one or two rooms. The breaker in your panel protects the wiring behind the walls from overheating.
When you run a 12.5A heater on a standard bedroom circuit, you have very little room left. If someone plugs in an 8-amp vacuum or a 10-amp hair dryer on that same branch, the total current shoots past 20 amps. The circuit breaker trips to cut the power before the wiring overheats.
If your breaker clicks off, do not force it back on repeatedly:
  1. Unplug the space heater immediately.
  2. Identify what other devices were running in the room at that moment.
  3. Move the other high-wattage device to an outlet connected to a different breaker.
  4. Reset the tripped breaker handle at the main panel.
  5. Never replace a 15-amp breaker with a 20-amp breaker to stop nuisance tripping. Doing that creates a severe fire risk inside your walls.
The gap between 15- and 20-amp household circuits explains why a heater trips one room's breaker but not another's.
During a winter outage, the same 12.5 amps still has to come from somewhere, and a home battery has to supply every one of them.
Running a 1500W Heater During a Power Outage: EcoFlow TITAN 5000 Classic
When severe winter storms drop power lines, a space heater is often the first appliance people want to run. Switching to backup power does not change the physical load of the heater. It still pulls 12.5 amps at 120 volts from your backup system.
What a home battery decides is how long that heat can last. The honest answer is that a 1500W heater uses energy quickly, meaning backup power provides heat for a matter of hours rather than days on end.
Electric space heaters require emergency-level management during blackouts. A high-wattage heater should warm one closed living space for a set period rather than replace a central heating furnace.
Labeled Runtime Breakdown
Battery runtimes depend on capacity, load size, and internal power conversion efficiency. A standard residential inverter uses energy to convert direct current (DC) stored in battery cells into 120V alternating current (AC).
Consider the EcoFlow TITAN 5000 Classic, which features a baseline storage capacity of 5,017.6Wh:
Usable capacity = 5,017.6Wh × 0.85 (planning allowance for conversion losses) = 4,264.96Wh
To estimate runtime, allow for energy lost during power conversion.
Example 1: Heater running alone
5,017.6Wh × 0.85 ÷ 1,500W = approximately 2.8 hours.
Example 2: Heater plus 100W of other essentials
5,017.6Wh × 0.85 ÷ 1,600W = approximately 2.7 hours.
These are planning estimates, not guaranteed operating times. The 85% allowance is an illustrative assumption for conversion losses, not a guaranteed efficiency figure.
Actual runtime depends on the system's operating conditions, battery state, temperature, and connected loads. A thermostat may cycle the heater off periodically, extending runtime. Lower heat settings can also help.
Output Share on 120V Home Backup
Running a heavy 12.5-amp load requires an inverter that can carry that load without straining. A 1,500W heater uses 37.5% of the 4,000W rated 120V continuous output capacity on an EcoFlow TITAN 5000 Classic. That leaves roughly 2,500 watts of real-time capacity to power a refrigerator, home medical equipment, and living area lights simultaneously.
Safety rules do not disappear during an emergency. Your space heater must plug into its usual grounded wall outlet on an isolated, backed-up circuit. Running heaters through extension cords draped across floors during an outage creates trip hazards and fire risks.
Because a 1500W heater is a 120V load, a 120V home battery fits the job without paying for 240V output the heater cannot use. The EcoFlow TITAN 5000 Classic puts selected 120V circuits on battery power by way of the EcoFlow Smart Home Panel 10 (120V). This lets your heater and vital essentials run safely from their regular wall outlets during a winter emergency.
Because a 1500W heater is a 120V load, a 120V home battery fits the job without paying for 240V output the heater can't use. The EcoFlow TITAN 5000 Classic puts selected 120V circuits on battery by way of the EcoFlow Smart Home Panel 10 (120V), so the heater and a few essentials can stay on their normal outlets for a while.
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don’t even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. •North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
A safe outage plan starts with matching heaters to backup power using the wattage on the heater's label.
Whether the power comes from the grid or a battery, a heater drawing 12.5 amps for hours needs the same safety habits.
Space Heater Safety Habits for a 12.5-Amp Load
Portable heaters account for a small share of total home heating fires, but they cause a disproportionate number of fatal blazes. Most official guidance focuses on clear placement, proper connections, and active user supervision. These safety rules become even more vital during winter power failures, when families rely on auxiliary heat sources for extended periods.
According to the U.S. Fire Administration's "Heating Fire Safety" data, portable space heaters caused just 3% of home heating fires annually between 2017 and 2019. However, those same portable units accounted for 41% of all fatal home heating fires during that period. A 12.5-amp electrical load produces extreme heat, and common mistakes can turn dangerous fast.
Essential Space Heater Safety Checklist
Protect your home by following these federal fire safety rules from the USFA and OCWR every time you run a heater:
  • Maintain 3 Feet of Clearance: Keep all blankets, curtains, clothing, rugs, and furniture at least three feet away from the heating element.
  • Set on Solid, Flat Floors: Always place the heater on an uncarpeted, level surface so it cannot tip over easily.
  • Never Use Power Strips or Extension Cords: Plug the heavy-duty power cord directly into an existing grounded wall receptacle.
  • Inspect Hardware Seasonally: Inspect the cord, plug prongs, and heater housing for frayed insulation, bends, or scorch marks before plugging in.
  • Turn Off When Unattended: Switch the unit off whenever you leave the room or head to bed for the night.
  • Do Not Leave Kids or Pets Unsupervised: Keep children and pets away from hot surfaces to prevent accidental contact burns or tip-overs.
Safety rulesSafety rules
Emergency Winter Outage Precautions
When winter blizzards knock out regional electrical service, do not let desperation compromise safety.
The Centers for Disease Control and Prevention (CDC) warns: never use a gas cooking range, grill, camping stove, or kitchen oven to heat your home. These fossil fuel appliances generate deadly carbon monoxide (CO) gas quickly inside closed rooms.
Always keep working, battery-powered carbon monoxide alarms on every floor of your home. If a CO detector sounds its alarm, leave the house immediately and dial 911 from outside. During severe freezes, listen to updates from the National Weather Service and emergency officials.
Signs of an Overloaded Outlet
You should regularly check your wall outlet while running a 12.5-amp heater:
  • Touch the plastic faceplate; if it feels hot, turn off the heater immediately.
  • Look for burned smells, sizzling sounds, or brownish discoloration around the receptacle slots.
  • Stop using that outlet immediately if you notice damage, and call a licensed electrician.
  • If you see active sparks, smoke, or flames, evacuate your family and dial 911.
Understanding carbon monoxide dangers in winter emergencies keeps families from using grills or ovens for heat.
If 12.5 amps is more than your circuit or backup plan can comfortably handle, the easiest fix is often a smaller load.
Lower Settings and Smaller Heaters: Cutting the Amp Draw
You do not always need to blast 1,500 watts to keep yourself comfortable. Choosing a lower heat setting or using a physically smaller heater cuts your operating amps and conserves power. Because the electrical formula stays identical, checking the nameplate tells you everything you need to know.
According to data compiled by the Office of Congressional Workplace Rights, standard electric space heaters typically span an operating spectrum from 400 watts up to 1,500 watts.
Amp Draw by Heater Wattage at 120 Volts
The table below outlines common heater wattages and shows the current they draw from a standard 120V household receptacle:
Example Heater Wattage
Voltage
Formula (Amps = Watts ÷ Volts)
Amps at 120V
400W (Personal Mini Heater)
120V
400 ÷ 120
3.33A
750W (Low Setting on Dual-Mode)
120V
750 ÷ 120
6.25A
1,000W (Medium Setting)
120V
1,000 ÷ 120
8.33A
1,500W (High Setting / Standard)
120V
1,500 ÷ 120
12.50A
Maximizing Heat with Lower Power
Electric heat output scales directly with input wattage. A smaller heater draws fewer amps, but it also warms a smaller physical footprint.
You can stay warm on lower wattage settings with smart heat-trapping habits:
  • Shut interior doors to seal off unused rooms, hallways, and closets.
  • Block chilly drafts by tucking rolled towels or draft stoppers under exterior doors.
  • Dress in warm thermal base layers, wool socks, and fleece sweaters.
  • Wrap up in insulated wool blankets while working or relaxing in your designated room.
Cutting your heating load makes an enormous difference when running on home battery power. Halving the wattage roughly doubles your runtime estimate. For example, switching the heater powered by an EcoFlow TITAN 5000 Classic from a 1,500W setting down to a 750W low setting changes your estimated runtime:
  5,017.6Wh × 0.85 ÷ 750W = about 5.7 hours
This calculation remains an estimate rather than a firm promise, but it demonstrates how lower settings stretch battery reserves.
Checking how much electricity space heaters use helps you choose between a lower setting and a smaller model.
A 1500-watt space heater draws about 12.5 amps at 120 volts (1,500 ÷ 120), give or take a little depending on your home's exact voltage. That is a heavy, steady electrical load for any single wall outlet. Always plug your heater directly into a wall receptacle, keep other power-hungry appliances off that branch circuit, and drop to a lower setting whenever possible.
For short-term warmth during an outage, the EcoFlow TITAN 5000 Classic can back up the heater's 120V circuit and a few essentials through the EcoFlow Smart Home Panel 10 (120V), with runtime measured in hours. It delivers reliable power for your essential 120V home circuits during unexpected winter freezes.
How many amps does a 1500 watt heater draw at 240 volts?
A 1,500-watt heater rated for 240 volts draws 6.25 amps (1,500 ÷ 240). This applies only to heaters designed and labeled for 240-volt operation, such as certain hardwired wall or baseboard heaters.
Can a 1500 watt heater go on a 15-amp circuit?
It can operate on a suitable 15-amp circuit, but it draws 12.5 amps and leaves limited capacity for other appliances. Keep additional heavy loads off the circuit and consult an electrician if the breaker trips repeatedly.
Why does my space heater trip the breaker?
A breaker trips when the total load exceeds its rated safety limit. When your heater pulls 12.5 amps and shares a circuit with another running appliance, the combined draw overloads the circuit breaker. Move the secondary appliance to an outlet wired to a different breaker instead of replacing your breaker with a larger one.
Can I plug a space heater into a power strip?
No. The U.S. Fire Administration warns homeowners to plug electric space heaters directly into a wall outlet and avoid power strips or extension cords. Standard power strips and light extension cords are not built to handle continuous 12.5-amp loads safely, which can melt insulation and cause fires.
How long can a home battery run a 1500 watt heater?
A single EcoFlow TITAN 5000 Classic has an estimated runtime of about 2.8 hours for continuous 1,500-watt heating, assuming 5,017.6Wh of capacity and an 85% usable-energy allowance. Thermostat cycling, other connected loads, battery conditions, and lower settings will change actual runtime.
Home Solutions
