Tankless Water Heater Maintenance: Descaling, Inlet Filters, and What the Manual Requires
Tankless water heater maintenance comes down to three jobs: a descaling flush about once a year, a clean inlet filter, and a licensed pro for gas, venting, and electrical work. The manual sets the exact schedule. Hard water shortens that cycle, and skipped upkeep can affect warranty coverage. A tankless unit has no tank to drain, but it still collects minerals. This article follows what manufacturers say, shows which tasks need a pro, and covers gas models during winter outages.
Why Tankless Heaters Need Regular Maintenance
Tankless units heat water as it flows through a compact heat exchanger. Calcium and magnesium in hard water build up inside it, and the harder the water, the faster that happens. Makers tie performance and warranty coverage to water quality and upkeep.
Rheem notes that these deposits reduce efficiency. Navien states that skipping the upkeep in its user manual may void the limited warranty. Most tankless water heaters maintenance schedules therefore start with water hardness. Skipped tankless hot water heater maintenance can cost more than a service visit.
Checking Water Hardness
The U.S. Geological Survey sorts hardness into four classes. Community water systems must provide their customers with an annual Consumer Confidence Report. The EPA's Consumer Confidence Report site has a "find your local CCR" tool for the lookup.
USGS hardness class
mg/L as calcium carbonate
Soft
0 to 60
Moderately hard
61 to 120
Hard
121 to 180
Very hard
More than 180
Sources: USGS Water Science School and the EPA Consumer Confidence Report page.
A report number only means something next to the model's own limits. Rinnai's RSC SENSEI manual lists total hardness up to 200 mg/L, pH 6.5 to 8.5, and chlorides up to 250 mg/L. Other brands set other limits, so the local report should be compared with the manual for that exact model.
Yearly descaling is one of the pros and cons of tankless heaters that new owners don't always hear about. Next comes matching each task to a schedule and to the right person.
The Maintenance Routine: Owner Checks and Professional Service
Most makers recommend service about once a year, with more frequent descaling for hard water. A few checks suit owners. Gas, burners, venting internals, and electrical parts stay with a licensed pro. Sound tankless water heater maintenance follows that split.
Task
How often (maker guidance)
Who
Descaling flush of the heat exchanger
Yearly; about every 6 months in hard water (Rheem). Annual (Navien). More often in hard water (Rinnai), with an optional Service Soon indicator
Licensed pro, or a handy owner if the maker allows it (Navien)
Clean the cold-water inlet filter or screen
Regularly; more often with sediment (Rheem, Navien)
Owner, per manual
Check that vent openings and air intake are clear
Part of routine checks (Rheem)
Owner looks; pro services
Inspect gas connections, burner, igniter, sensors
Annual service visit (Rheem)
Licensed pro only
Check for leaks, odors, or uneven temperature
Ongoing; call a licensed technician if found (Rheem)
Owner reports; pro repairs
Descaling at the Manual's Level
A descaling flush removes mineral deposits from the heat exchanger with a solution such as vinegar or a maker-approved cleaner. Makers disagree on who should do it, so the manual decides.
  • Isolation valves: Rinnai strongly recommends these valves, since they isolate the heater from the home's plumbing and make flushing easier.
  • Pump and solution: Navien describes a flush that circulates cleaning solution with a pump. Handy owners can follow the manual, or a certified technician can do it.
  • Licensed help: Rheem calls heat exchanger flushing "best left to a licensed professional."
Steps vary by model, so they belong in the manual or with a licensed plumber. Basic maintenance tankless water heater owners handle alone usually stops at the filter.
The Inlet Filter
The cold inlet has a water screen that catches sediment. Some Navien models also have a recirculation inlet screen. Rheem says to remove the filter and rinse it under running water.
Safety comes first. Shut off water at the isolation valves, then follow the manual's power and gas shutdown steps. Each manual lists the maintenance for tankless water heater models in its own order.
Gas and Venting Are Pro Territory
Rinnai states that installation and service must be done by a trained, qualified professional, service agency, or gas supplier. Owners should not adjust the internal gas valve. Any maintenance on tankless water heater burners or sensors belongs to that person.
The U.S. Consumer Product Safety Commission advises a yearly professional inspection of fuel-burning heating equipment. It also calls for carbon monoxide (CO) alarms on every level of the home and outside sleeping areas, tested monthly. A gas water heater is also a fuel-burning appliance. Details are on the CPSC carbon monoxide page.
Clear vents and working alarms are the best defense against carbon monoxide risks in winter emergencies. A descaled heater still shuts down when the power goes out, which surprises many gas tankless owners.
Gas Tankless Models Still Need 120V Power: Where EcoFlow TITAN 5000 Classic Fits
A gas tankless heater burns gas for heat. On models like the Rinnai and Navien units below, the controls, ignition, and fans run on household electricity. When the grid goes down, so does the hot water. The manual lists the model's electrical rating.
Model
Supply
Listed draw
Rinnai RSC199 / RSC160
120V AC, 60 Hz, max 4 A
78W (RSC199) or 55 to 57W (RSC160) normal; 2.3W standby; 150 to 172W freeze protection
Navien NPE-2 Series
120V AC, 60 Hz
200W max (2 A), or 350W (4 A) with an external pump
Rinnai indoor models plug into a standard grounded 3-prong 120V outlet, and the manual allows no extension cord or adapter plug. ENERGY STAR advises installers to check for electricity near forced-ventilation gas tankless models.
The reasons gas water heaters need electricity come down to the igniter, the control board, and the vent fan. Power access also belongs in tankless hot water maintenance planning, since a heater that cannot start cannot be tested.
On the models above, the controls and ignition draw a few hundred watts or less. That fits within 120V home backup. EcoFlow TITAN 5000 Classic can keep the heater's outlet circuit and a short list of critical loads powered through an EcoFlow Smart Home Panel 10 installed by a licensed electrician.
•4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. • 5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. •≤20 ms Automatic Switchover. The lights don’t even flicker. •OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. •North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
The battery does not descale the unit, clear a filter, or fix an error code.
A Labeled Estimate of the Heater's Own Draw
  • Usable energy: 5,017.6Wh × 0.85 (a planning assumption for conversion losses) is about 4,265Wh.
  • Illustrative day, Rinnai RSC199: One hour at 78W is about 78Wh. Twenty-three hours of standby at 2.3W is about 53Wh. The total is near 131Wh, a small share of 4,265Wh. The fridge and other critical loads usually decide runtime.
  • Freeze protection caution: The manual lists 150 to 172W. Nonstop at 172W for 24 hours, that would use about 4,128Wh. It cycles in practice, but a hard freeze can raise the draw well above mild-weather levels.
Gas supply and venting must also work. In cold climates, electricity also powers the built-in freeze protection.
Freeze Protection, Winter Outages, and When to Drain
Tankless units protect themselves from freezing, but only while they have power. A winter outage removes that protection. The manual's instructions decide what happens next.
Frosted exterior wall near heater ventFrosted exterior wall near heater vent
Rinnai's RSC manual says freeze protection works only with gas and 120V power connected. With power, indoor models are protected to -22°F. Outdoor models are protected to -4°F when shielded from direct wind. If power or gas fails in below-freezing weather, the heater should be drained of all water by hand, along with the condensate trap, drain line, and pressure relief valve.
An optional Drain Down Kit drains the heater automatically on power loss, but the trap and relief valve still need manual draining. Freezing damage may not be covered, so the manual's draining section is the place to start. Skipping maintenance on a tankless water heater before winter can leave a unit less ready for a hard freeze. If gas or venting seem off after an outage, a pro should look.
Backup power for the heater's circuit keeps freeze protection running only as long as the battery has charge. It does not replace the manual's drain guidance in a long outage.
Pipes near the heater face the same risk once the house cools. Preventing frozen pipes in winter starts with knowing which lines run along outside walls. Electric models skip the gas checks but have their own power needs.
Electric Tankless Water Heater Maintenance: What Changes
Electric tankless heaters still collect scale and still have an inlet screen. The difference is the electrical load, which is large and runs on dedicated breakers. That is why every service step starts at the breaker panel.
Stiebel Eltron's Use and Care Manual for its electric tankless units sets the order:
  • Power off first: Turn off all breakers and disconnect switches serving the unit before service.
  • Filter screen: Clean it regularly after shutting off power and water. Never run the unit without it.
  • Hard water: Descale as needed.
  • Owner limits: Beyond the filter screen, no parts are owner-serviceable. A licensed plumber or electrician handles malfunctions.
Electrical panel with labeled double-pole breakersElectrical panel with labeled double-pole breakers
Ratings differ by model. For example, a Rheem brochure (Form TK-205, Rev. 4, October 2012) lists the RTE 13 at 13kW and 240V on a 60A breaker. The RTE 27 is 27kW at 240V on two dedicated 60A breakers. The brochure is older, so the unit's data plate is the reliable source.
Stiebel Eltron also warns that water above 125°F can cause severe burns. Homes with young children or older adults may need 120°F or lower.
No backup product is recommended for electric tankless units here. Their loads are far beyond a 120V control circuit, and the EcoFlow TITAN 5000 Classic page lists electric water heaters among the 240V appliances it does not support. Knowing the difference between 120V and 240V power explains why an electric tankless unit needs its own breakers.
Tankless water heater maintenance comes down to water hardness, a descaling flush about once a year (more often with hard water), a clean inlet filter, and a licensed pro for gas, venting, and electrical work. The model's manual sets the schedule and protects the warranty.
A practical first step is to look up water hardness in the annual water quality report, then check the manual's flushing interval and isolation valves.
For owners of gas tankless models who want hot water controls covered during outages, EcoFlow TITAN 5000 Classic can back up the heater's 120V circuit through an EcoFlow Smart Home Panel 10 installed by a licensed electrician. The setup supports the controls only. It does not replace the manual's service and draining guidance.
How often should you flush a tankless water heater?
About once a year for most homes, according to Rheem and Navien. Rheem suggests about every six months in hard-water areas, since minerals build up faster there. The model's manual has the final word on timing and warranty terms.
Can I flush my tankless water heater myself?
Some makers allow it. Navien says handy owners can follow the manual, while Rheem recommends a licensed professional. Gas, burner, and electrical work always go to a pro, so the manual decides which steps owners may try.
What happens if you don't descale a tankless water heater?
Scale keeps building in the heat exchanger, which lowers efficiency and can lead to error codes. Rinnai's manual also says component damage from water quality isn't covered by its warranty, so skipped flushes can become a cost.
Does a gas tankless water heater work during a power outage?
Models that rely on 120V power for controls, ignition, and fans stop when the power does. The Rinnai and Navien models covered here all list 120V AC supply requirements, so the manual's electrical rating is worth checking.
How do I know if my water is hard?
Check the water supplier's annual water quality report. USGS classifies water above 120 mg/L as calcium carbonate as hard, and anything above 180 mg/L as very hard. The EPA's CCR tool can help find that local report fast.
Home Solutions
