How to Calculate the Full Load Current of a Generator
When your generator runs, it pulls electrical current through the wires. You need to know how much current to pick the right wire size and breakers. Use the wrong size, and you’ll get overheated wires, tripped breakers, or worse - fires. This generator calculator guide shows you the exact formulas to calculate the current for any generator.
What is Full Load Current in a Generator
Full load current is how many amps flow when your generator runs at maximum output. A 10 kVA generator running at full power draws a specific number of amps. The exact amount depends on your voltage and something called power factor.
You need to know three basic terms. Kilowatts (kW) is the actual power that runs your stuff. Kilovolt-amperes (kVA) includes both useful power and wasted power. Power factor shows the difference between them.
Key Power Terms
  • kW: Power that actually works
  • kVA: Total power including waste
  • Power Factor: How well your equipment uses electricity
Generator nameplates show kVA ratings because kVA tells you the total load capacity. When you convert kVA to amps, you get the wire and breaker sizes you need.
Basic Formula for Single-Phase Generator Current
Use this formula for single-phase generators:
I = (kVA × 1000) / (V × PF)
What Each Part Means
  • I = Current in amps
  • kVA = Your generator’s power rating
  • V = Voltage (120V or 240V for homes)
  • PF = Power factor (use 0.8 if you don’t know)
Real Example
Here’s a 5 kVA generator running at 120V with 0.8 power factor:
I = (5 × 1000) / (120 × 0.8) = 5000 / 96 = 52.1 amps
The same generator at 240V draws: I = 5000 / (240 × 0.8) = 26.0 amps
See how 240V needs half the current? That’s why big appliances use 240V - smaller wires cost less.
Formula for Three-Phase Power Calculation
Three-phase generators use this formula:
I = (kVA × 1000) / (√3 × V × PF)
The √3 (1.732) comes from how three-phase power works. Each wire carries current, but the three wires together give more total power than you’d expect.
Big Generator Example
Here’s a 1000 kVA three-phase generator at 480V with 0.8 power factor:
I = (1000 × 1000) / (1.732 × 480 × 0.8) = 1,000,000 / 664.3 = 1,506 amps per wire
That’s a massive current. You need thick cables and a professional electrician for anything this big.
Person sitting with generator at sunrise.Person sitting with generator at sunrise.
How to Convert kVA to Amps per Phase
Step-by-Step for 210 kVA Example
Converting kVA to amps works the same way for single-phase and three-phase. Three-phase just adds the √3 factor.
Step 1: Multiply kVA by 1000 210 × 1000 = 210,000 volt-amperes
Step 2: Use the three-phase formula I = 210,000 / (1.732 × 480 × 0.8) = 316.2 amps per wire
Each of the three wires carries 316.2 amps. You need to size each wire for this current.
Quick Reference Tables
You can use the formulas for exact results or the tables for quick estimates.
Single-Phase Generator Current (Amps)
Generator Size 120V 240V
3 kVA 31 16
5 kVA 52 26
7.5 kVA 78 39
10 kVA 104 52
15 kVA 156 78
20 kVA 208 104
Three-Phase Generator Current (Amps per Wire)
Generator Size 240V 480V 600V
25 kVA 75 38 30
50 kVA 151 75 60
75 kVA 226 113 90
100 kVA 301 151 120
150 kVA 451 226 181
200 kVA 602 301 241
500 kVA 1505 752 602
These numbers use a 0.8 power factor. Most businesses run at 0.8. Homes usually run better at 0.9, so the home current will be about 10% less.
What Changes Your Actual Current
Power Factor Differences
Different equipment has different power factors:
  • Heaters: 1.0 (perfect)
  • Motors: 0.7 to 0.9
  • Computers: 0.7 to 0.9 (varies)
Load Type Matters
What you’re powering makes a big difference. An office building might run at 0.85 power factor. A machine shop with lots of motors might drop to 0.75. Lower power factor means more current for the same kVA.
Weather and Altitude Hurt Performance
High altitude means thin air, so your generator works harder. Hot weather also cuts power output. Long wire runs drop voltage, which increases current.
How Much Power You Lose
Condition Power Loss
5,000 feet high 15-20% less
100°F weather 5-10% less
Both together Up to 25% less
A 100 kVA generator in Denver (5,280 feet) might only make 80 kVA on a hot day. Plan for this.
Why Getting Current Right Matters
Safety First
Wrong wire size creates fire risks. Wires that are too small get hot when electricity flows through them. This heat melts the wire coating and can start fires inside your walls.
Breakers that are too small will trip over and over during normal use. This cuts your power when you need it most, especially during storms.
Better electrical parts cost more money at first. But getting the wire size right prevents house fires. Professional electricians add extra safety room when they size your system.
Save Money on Fuel
Generators work best when you use them at moderate power levels. The right electrical sizing keeps your generator running efficiently. This means it uses less fuel per hour.
Small wires waste power because they create heat. You need more total power to push the same electricity through smaller wires. Generators sized correctly burn less fuel every time you run them.
During long power outages, using less fuel saves you money. It also means your stored fuel lasts longer.
Protect Your Equipment
Overloaded generators work too hard. They run hotter and break down faster. The internal parts get damaged when you constantly overload the generator.
Electrical problems create voltage drops. These voltage drops damage electronics like refrigerators and computers. These devices need steady power to work properly.
Hot wires break down over time. The insulation cracks. The connections get loose from repeated heating and cooling. Getting your calculations right protects expensive equipment. It also prevents failures when you need power most.
Fix Problems Faster
When you know what your current should be, finding problems becomes easy. Your electrical meter readings show you what works and what does not work.
Normal current readings mean everything works fine. High current readings point to specific problems. Motors that are failing use more electricity. Air conditioners with dirty filters work harder and use more power.
Power factor problems show up as current readings that are higher than expected. When your calculations do not match what you measure, you can find errors quickly.
EcoFlow DELTA Pro Portable Power Station offers 3.6-25kWh expandable capacity, powering 99% of appliances with 3600W-7200W AC output.
Easier Options: Battery Power Stations
Generator calculations take electrical knowledge that most people don’t have. You need to figure out kVA, convert to amps, size wires, and install transfer switches.
Battery Systems Are Simpler
Modern battery power stations skip all the math. The EcoFlow DELTA Pro gives you up to 25 kWh capacity - enough to run large appliances without any calculations.
Why Battery Systems Work Better
Gas generators need current calculations and electrical work. Battery systems plug into regular outlets. Built-in computers handle all the power conversion and prevent overloads automatically.
Real Benefits You Get
  • No noise: Neighbors won’t complain
  • No fumes: Safe to use inside
  • No gas storage: No carbon monoxide danger
  • Easy to expand: Add more batteries without rewiring
If you want backup power without electrical headaches, battery systems work great. You still need to know your power needs, but the system handles everything else.
What to Remember
Use the right formula:
  • Single-phase: I = (kVA × 1000) / (V × PF)
  • Three-phase: I = (kVA × 1000) / (√3 × V × PF)
Power factor numbers:
  • 0.8 for businesses
  • 0.9 for homes
  • Measure it for critical stuff
Real conditions change things. Hot weather, high altitude, and different equipment types change your actual current. Plan for this.
Check your work twice for important jobs. Use our tables for quick estimates, but double-check the math for safety jobs. Call a pro for big or complex systems.
Battery power stations skip these calculations completely and still give reliable backup power.
Bottom Line
Generator current calculations keep your electrical system safe and working. Use our formulas for gas generators, or skip math with smart battery systems.
You now know how to make the right choice for backup power. If you want reliable power without the electrical work, check out EcoFlow’s battery power stations. They handle all the technical stuff automatically, so you can focus on what matters during power outages.
Want backup power without the hassle? Discover EcoFlow solutions today.
Solar Energy
