Heated Mattress Pad: Answers to the Questions Buyers Ask Most
A heated mattress pad is a fitted cover with heating wires inside. It sits on top of your mattress, under your fitted sheet, and warms the bed from below. Most models plug into a standard household outlet and use one or two temperature controllers. In the US, UL 964 covers electrically heated bedding, including mattress pads. But the details matter when you're shopping. Mattress depth, control settings, timers, and washing instructions can vary by model. Heated bedding recalls also appear on the Consumer Product Safety Commission's website. This guide covers the main buying questions, safety tips, and what you can do if a winter storm knocks out your power.
What Is a Heated Mattress Pad, and How Is It Different From an Electric Blanket?
What Is a Heated Mattress Pad, and How Is It Different From an Electric Blanket?What Is a Heated Mattress Pad, and How Is It Different From an Electric Blanket?
A heated mattress pad warms your bed from underneath. An electric blanket warms you from above. Both use heating elements and fall under the same US safety standard for electrically heated bedding, UL 964. The right choice depends on how you sleep. A pad stays in place under your sheet, which may suit people who move around or kick off their covers. A blanket is easier to pull up, fold back, or remove when you get too warm.
Question
Heated mattress pad
Electric blanket
Where it sits
On the mattress, under the fitted sheet
On top of the sleeper
Fit
Elastic or knitted skirt, sized to mattress depth
Drapes over the bed
Heat direction
From below
From above
Standard
UL 964
UL 964
Heated mattress pads have one or two temperature controls, so some queen and king pads let each sleeper choose a different setting. Both products use electricity, so check the wattage on the label before buying. This is especially important if you plan to use a battery during an outage. Knowing how much power electric blankets use can help you compare energy needs. Once you understand the differences, check the pad's fit, controls, timer, and care instructions to find one that suits your bed.
Which Features Matter Most When You Compare Heated Mattress Pads?
Focus on fit, temperature controls, timers, safety certification, and washing instructions. These features affect how well a pad fits your mattress and how easy it is to use and care for.
Check the mattress size and depth
Measure your mattress, including any topper, before buying. A pad that fits too tightly may not sit properly. The Westinghouse Heated Mattress Pad Quilted comes in queen size, measuring 60 by 80 inches. Its knitted skirt fits mattresses up to 15 inches deep. The Sharper Image Dual Zone Heated Mattress Pad comes in full, queen, and king sizes, but its product page doesn't list a maximum mattress depth.
Choose controls that suit your bed
Dual controls let two people choose different heat settings. This helps when one person prefers a warmer bed than the other. Westinghouse lists two controllers and 10 heat settings. Sharper Image also offers two independent controllers on its queen and king models. Its full-size version has one controller and one heating zone.
Check the timer and safety features
A timer or automatic shutoff can help limit how long the pad stays on. The two models list different options. Westinghouse offers a timer with settings from one to 12 hours. Its product page also lists overheat protection and a setting that returns to the previous temperature after 15 minutes upon restart. Sharper Image lists automatic shutoff after 10 hours. Both manufacturers list ETL certification for their pads. Westinghouse also lists FCC certification. Check the product details and instructions for the exact model you're considering.
Compare washing instructions and warranty terms
Care instructions vary by product. Westinghouse recommends washing its quilted pad in cold water on a gentle or delicate cycle. It allows line drying or tumble drying on low heat. Sharper Image describes its pad as machine washable, but check its care guide for the permitted cycle and drying method. Warranty terms are worth checking, too. Westinghouse lists a five-year limited warranty. Sharper Image's product page lists a 60-day satisfaction guarantee, but no product warranty.
Compare the listed features
The table below summarizes the specifications published on the manufacturers' pages, checked on October 28, 2026. It compares features rather than ranking either product.
Feature
Sizes on page
Queen (60" x 80")
Full, queen, king
Mattress depth
Up to 15"
Not listed
Controls
Dual control, 10 settings
Two controllers (queen, king); one on Full; 10 heat levels
Timer / auto-off
1 to 12 hour time setting
Auto shut-off after 10 hours
Listing
ETL, FCC
ETL
Washing
Gentle or delicate, cold water; line dry or tumble low
Machine washable
Warranty on page
5-year limited
Not listed
Wattage on page
Not listed
Not listed
The Westinghouse product page showed a "Notify me when available" message on the date checked, so confirm availability before considering it. A heated mattress pad may let you warm your bed without raising the temperature of the whole house. It's one of several ways to save electricity in winter, though any savings depend on your home's heating system and how you use it. These features can help you choose a pad for everyday comfort. But if a winter storm knocks out your power, you'll also need to consider how to keep it running.
Can a Heated Mattress Pad Keep Working During a Power Outage?
A heated mattress pad won't work during a power outage unless it has a power source. You can connect it to a suitable portable power station for short warm-up sessions. How long it runs depends on the pad's wattage and the battery's usable energy. Before a winter storm, keep extra blankets, sleeping bags, and warm clothes ready. The CDC recommends these supplies for power outages. A heated pad can add warmth, but it can't replace your home's heating system or other cold-weather preparations. A portable power station also differs from a gas generator. It produces no exhaust while running, so you can use it indoors according to the manufacturer's instructions. Never run a fuel-powered generator inside your home, basement, or garage, or within 20 feet of a window, door, or vent.
How Many Warm-Up Sessions Can a Battery Give? (labeled estimates)
Check the wattage on your pad's label or controller first. The examples below use sample wattages for illustration. They aren't specifications for any named mattress pad. For planning, this estimate assumes that 85% of the battery's rated energy is available after conversion losses. One session means one hour of use.
If the pad label reads
EcoFlow DELTA 3 Classic, one pad (870Wh usable)
EcoFlow DELTA 3 Max, two pads (1,741Wh usable)
50W per pad
870 ÷ 50 ≈ 17 one-hour sessions
1,741 ÷ 100 ≈ 17 sessions with both pads on
100W per pad
870 ÷ 100 ≈ 8 sessions
1,741 ÷ 200 ≈ 8 sessions
150W per pad
870 ÷ 150 ≈ 5 sessions
1,741 ÷ 300 ≈ 5 sessions
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
If you need backup power for a heated mattress pad during a winter outage, the right power station depends on how many heating zones you plan to use. The EcoFlow DELTA 3 Classic may suit one pad or one heating zone. For a dual-zone pad, the EcoFlow DELTA 3 Max offers more capacity and room for small extras, such as a reading lamp or Wi-Fi router. Check your pad's wattage and the station's output rating before connecting them.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The EcoFlow DELTA 3 Classic may suit one heated mattress pad or one heating zone, along with a phone. The EcoFlow DELTA 3 Max offers more capacity for two pads or both zones of a dual-zone pad, with some power left for a lamp or Wi-Fi router. Before connecting a pad, check its manual and wattage label. Make sure its power needs stay within the station's output rating, and plan how long you'll use it. A battery can provide extra warmth during an outage, but it doesn't replace home heating. Indoor temperatures can drop quickly when the furnace stops, which is one reason winter blackouts can be more dangerous. Battery backup is only part of the plan. The mattress pad itself must also be safe to use, so check its safety listing, condition, and any precautions that apply to the person using it.
Are Heated Mattress Pads Safe to Sleep On?
A heated mattress pad with a recognized safety listing, in good condition and used as directed, is designed for bedding use. Still, it isn't suitable for everyone. Check the product's safety mark, read the manual, and search for recalls before buying or using one. The Consumer Product Safety Commission reported a September 2026 recall of about 195,000 JKMAX heated blankets and heating pads sold through Amazon. The recall followed reports of smoking, melting, and burning, including reports of burn injuries. Check the CPSC recall website for current notices and details about affected products.
Who should take extra care?
Some people should avoid heated bedding or follow special precautions.
  • People with diabetes:UL notes that diabetes can reduce sensitivity to heat and increase the risk of burns from electric blankets. Sharper Image's mattress pad manual says not to use the pad if you are insensitive to heat. Follow the instructions for your exact model.
  • People with incontinence: Do not use heated bedding where moisture could reach the powered pad or controller. Sharper Image's mattress pad manual says never to plug in the product while damp. Check your exact model’s instructions before use.
  • Infants and young children: UL advises against heated bedding for infants and young children.
  • People who can't operate the controls safely: They shouldn't use a heated pad if they can't adjust it or turn it off when needed.
  • Owners of adjustable beds: Use only a pad whose instructions allow it. Bedding for mechanical or adjustable beds needs extra consideration under UL 964.
If you plan to use an electric blanket and a heated mattress pad together, check both manuals. Don't assume every combination is safe or approved. For older relatives who may need extra help during a winter outage, prepare an outage kit for seniors with warm clothing, blankets, medication, and other essentials.
How Do You Wash and Store a Heated Mattress Pad?
Unplug the pad and detach its controller before cleaning. Follow the care label for washing and drying. Some pads can go in a washing machine, but the allowed cycle and drying method vary by model. For example, Westinghouse directs users to wash its quilted pad on a gentle or delicate cycle with cold water. Its instructions allow line drying or tumble drying on low heat and prohibit dry cleaning, bleaching, and ironing. Other models may have different rules, so use the guide that came with your pad.
Follow these steps before storing it
Proper care helps keep your heated mattress pad in good condition. Follow these steps before storing it for the season.
  • Unplug the controllers: Turn the pad off and disconnect the cords before cleaning.
  • Wash according to the label: Use only the cycle and cleaning method the manufacturer allows.
  • Dry it as directed: Don't use high heat unless the instructions specifically permit it.
  • Inspect the pad: Look for worn fabric, loose plugs, damaged cords, or scorch marks.
  • Roll it loosely: Avoid tight folds that can damage the heating wires.
  • Store it in a dry place: Keep it away from moisture and anything that could crush or bend the wiring.
Before using the pad each fall, inspect it again. Replace it if you find damage. UL also advises against buying used heated bedding because you may not know its condition or history. Seasonal checks are a good time to review the rest of your cold-weather supplies, too. Include bedding, flashlights, batteries, and a plan for charging essential devices in your routine for winter home preparation.
The right heated mattress pad should fit your mattress, offer the controls you need, include a timer or automatic shutoff, and carry a recognized safety mark. Check the care instructions before buying, and inspect the pad before each cold-weather season. If winter outages are common in your area, read the pad's wattage label and plan for short warm-up sessions rather than assuming a battery can run it all night. Keep blankets and warm clothing ready, and check the CPSC website for recalls. The EcoFlow DELTA 3 Classic may suit one compatible pad and a phone. The EcoFlow DELTA 3 Max offers more capacity for a dual-zone setup and a small extra device. Compare their ratings with your pad's power needs, then choose the setup that fits your plans for a winter outage.
Is a heated mattress pad better than an electric blanket?
Neither is better for everyone. A heated mattress pad warms the bed from below and stays under the fitted sheet. An electric blanket warms you from above and is easier to move or fold back when you get too warm. Both fall under the UL 964 safety standard for heated bedding. Your choice depends on how you sleep and where you prefer the warmth.
Do heated mattress pads use a lot of electricity?
Their power use varies by model. Check the wattage on the pad's label to estimate consumption. For comparison, a portable space heater often draws much more power, but the exact difference depends on the devices.
Can you put a heated mattress pad on an adjustable bed?
Only if the manufacturer says the pad is suitable for your bed type. Adjustable bases bend and move, so not every pad is designed to work with them. Check the manual for both the mattress base and the pad before use. Follow any instructions about placement and movement to avoid damaging the heating wires.
How long does a heated mattress pad stay on?
It depends on the model and its timer settings. For example, Westinghouse lists timer settings from one to 12 hours for its quilted pad. Sharper Image lists automatic shutoff after 10 hours. Check your model's manual for its exact settings, and don't assume every pad has the same shutoff feature.
Can I run a heated mattress pad on a portable power station?
Often, yes, if the pad's power needs fall within the station's output rating. Divide the station's estimated usable watt-hours by the pad's wattage to estimate runtime. Leave room for other devices, and follow the pad's manual.
Home Solutions
