What Is an Accessory Dwelling Unit (ADU)? Types, Benefits, Costs, and More
High housing costs and flexible living arrangements have turned backyards across the United States into opportunities to make extra money. An Accessory Dwelling Unit (ADU) can provide flexible space for aging parents, creating a private home office, or earning extra rental income. In this complete guide, we’ll explore what defines an ADU and compare the primary types you can build. It also gives you estimated construction costs and shares some essential options to consider before building. These include how to plan for a flexible, whole-home energy backup for your property.
You may have noticed that many residential properties across the country have secondary structures nestled behind main residences. The accessory dwelling unit meaning refers to a flexible living space added to an existing residential property. People often call these units “granny flats,” “in-law suites,” or “backyard cottages.” ADUs have become increasingly common as homeowners look for flexible ways to use existing property space. Before you make an investment decision, you need to understand more about them.
ADU Definition and Basic Features
The accessory dwelling unit definition describes a secondary, self-contained residential unit located on the same lot as a primary single-family home. ADUs typically include essential living features such as a kitchen, bathroom, and private entrance. Traditionally, ADUs were considered part of the main property and prohibited from being sold separately. However, some jurisdictions are exploring changes that allow ADUs to be sold separately under specific local programs. For example, California’s AB 1033 allows cities and counties to establish processes for separate ADU ownership if they choose to adopt them.
ADU Requirements and Living Features
Local building departments set requirements to ensure ADUs meet safety and living standards. Many permitted ADUs must meet local standards for foundations, emergency exits, utilities, and building systems. Requirements and permitted sizes vary significantly by jurisdiction and ADU type. Some areas allow units up to 400 square feet, while others permit larger secondary homes of 1,200 square feet or more. Size limits often depend on factors such as lot size and setback rules. While California has some of the most established ADU regulations in the country, homeowners should always check local rules before starting a project.
ADU vs. Other Housing Options
Homeowners often confuse ADUs with tiny homes on wheels, standard guest houses, or duplexes. These housing options differ not only in design and regulations but also in how they connect to utilities, including how tiny homes get electricity and solar backup power. You need to understand and distinguish between these residential options to avoid costly permitting headaches down the road:
Housing OptionKey CharacteristicsFoundation / Placement Rental Eligibility
Accessory Dwelling Unit (ADU)Self-contained residential unit with kitchen and bathroom on the same lot as a primary homeMust comply with local zoning and building codesYes (Long-term or short-term, depending on local laws)
Standard Guest HouseExtra living or sleeping space, usually without a full kitchenMust comply with local building codes Restricted (Usually cannot be leased as a separate dwelling)
Tiny House on Wheels (THOW)Movable housing unit built on a trailer chassisSubject to local rules for placement and residential useVaries (Often restricted by local regulations)
DuplexTwo independent housing units within a multi-family residential structureMust comply with applicable zoning and building codes Yes (Both units can generally be rented independently)
EcoFlow DELTA Pro 3 Portable Power StationEcoFlow DELTA Pro 3 Portable Power Station
What Are the Different Types of ADUs?
Every backyard and floor plan presents unique architectural possibilities. Choosing which style is best depends mostly on your available lot space, existing home structure, and overall project budget.
Detached ADU Designs
Standalone backyard cottages offer maximum privacy for both the primary residents and the ADU occupants. Since they are built completely separate from the main residence, these units are great for rental properties or private guest spaces. While they deliver superior quiet and autonomy, they require independent foundation work and utility trenching, making them the most capital-intensive option.
Attached ADU Options
Attached ADUs are constructed as an extension of your existing home and share at least one common wall with the primary structure. This configuration allows builders to tie directly into existing framing and exterior rooflines. Families prefer these to save backyard space and keep loved ones close. These also benefit from lower construction costs without compromising private living spaces.
Garage Conversion ADUs
Transforming a garage, whether detached or attached, ranks among the most popular and cost-effective ADU conversions. The framing, slab foundation, and roof structure already exist, so homeowners have a huge head start and save substantially on core materials. Converting a two-car garage into a stylish studio apartment can maximize existing living space without expanding the building footprint, making it one of the most rewarding DIY home improvement projects for modern homeowners.
Interior ADU Conversions
Unused square footage within your main home, such as a daylight basement or a large attic, can become an interior ADU. In California, smaller interior spaces may qualify as a Junior Accessory Dwelling Unit (JADU). A JADU is limited to 500 square feet and must be created within an existing or proposed single-family residence according to California’s JADU requirements. It can share sanitation facilities with the main house and requires only a small efficient kitchen. Both options provide an efficient way to add additional living space with minimal changes to the exterior of the home.
What Are the Benefits of Building an ADU?
Investing in a secondary unit extends far beyond simply adding drywall and roofing. States including California, Oregon, and Washington have introduced policies to support ADU development.
Create Additional Living Space
A growing family’s space needs evolve over time. An ADU can fulfill short-term and long-term space requirements. They can be used as a dedicated work-from-home office, a creative art studio, or a comfortable sanctuary for returning college graduates who need independence while saving for their own homes.
Support Multigenerational Living
Caring for aging relatives while respecting their autonomy is a primary driver for ADU construction across the U.S. An in-law cottage allows elderly parents to live steps away from adult children and grandchildren. It also eliminates the large expense of assisted living facilities while preserving dignity, privacy, and peace of mind.
Generate Rental Income
An ADU can provide additional rental income from that unused yard space and improves your financial security. ADUs are often rented to travelling nurses, local professionals, or long-term tenants. Adding energy solutions such as a home battery system can help improve energy resilience, manage electricity costs, and add value for properties where energy efficiency is a priority.
Increase Property Value
A permitted, well-designed ADU may increase a property’s appeal and potentially improve resale value, although the impact varies by location and market conditions. Buyers increasingly look for homes with income-generating potential or built-in multi-family accommodations. This can add significantly to your long-term equity growth.
EcoFlow DELTA Pro Ultra Whole-Home Backup PowerEcoFlow DELTA Pro Ultra Whole-Home Backup Power
How Much Does an ADU Cost to Build?
Budgeting properly takes more than just using standard cost per-square-foot estimates. You need to understand the total investment to prevent surprise expenses during construction.
Average ADU Construction Costs
ADU construction costs vary widely by location, size, design, and site conditions. Garage conversions and interior ADUs are generally more affordable because they can reuse existing structures, while detached custom-built units usually require more materials, labor, and site preparation. In many U.S. markets, ADU construction costs can range from roughly $80,000 for simpler conversions to $350,000 or more for larger custom builds. Local labor rates, permitting requirements, utility connections, and site work can significantly affect the final cost.
Source: ADU construction cost estimates are based on recent industry cost data from Angi. Actual costs vary depending on location, ADU type, size, materials, permitting requirements, and site conditions.
Factors Affecting ADU Prices
Several variables impact your final invoice. Site slope and soil quality add to foundation complexity, while customized architecture drives up engineering expenses. Premium interior finishes, custom cabinetry, and high-efficiency HVAC systems will naturally elevate overall expenditures.
Permit and Infrastructure Costs
Soft costs catch many homeowners off guard. Municipal plan review fees, school district fees, utility hookup charges, and architectural design drafts can add thousands of dollars before construction begins. Trenching power lines and plumbing connections across long yards can also add significant costs. For properties looking to improve energy flexibility, planning for solutions such as a solar battery system during the design stage can help homeowners better manage future electricity needs.
What Should You Consider Before Building an ADU?
Thorough research and planning work will pave the way for a smooth build process. Be sure to know your regulatory requirements and use smart infrastructure where you can to protect your investment for decades to come.
Check Local ADU Regulations
Review your local municipal zoning codes and HOA guidelines before hiring an architect. Key items to check include maximum height allowances, lot coverage ratios, rear and side yard setbacks, and off-street parking mandates. Confirming local rules upfront saves months of delayed permit approvals.
Plan ADU Space and Energy Flexibility
An ADU’s function rarely stays fixed forever. A newly constructed unit might initially be a quiet remote workspace or guest quarters. Later on, it could change to a full-time tenant rental or independent senior suite as family needs change. Consequently, your electrical setup must remain as flexible as your layout plan.
For families who want to adapt their energy storage as ADU usage evolves, the EcoFlow DELTA Pro 3 Portable Power Station offers modular flexibility. Its expandable capacity allows homeowners to choose a storage setup that matches their current energy needs. You can expand available battery capacity over time as your backup and energy needs grow.
Delivers both 120V and 240V outputs with up to 4000W in a single unit, capable of supporting a 3-ton central AC under suitable conditions. Exclusive X-Boost technology allows the unit to exceed its rated output, providing up to 6000W of power when needed.
Integrate ADU Power with Whole-Home Backup
When an ADU becomes a long-term rental unit, its power demands must be factored into your primary property’s overall energy architecture. If your property loses power, a well-designed backup system can help keep essential loads in both the main house and secondary living space running, supporting needs such as refrigeration, communication, and basic comfort.
Designed for large-scale energy requirements, the EcoFlow DELTA Pro Ultra Whole-Home Backup Power provides substantial power output and expandable capacity. It can be a whole-home backup strategy when properly configured with the home’s electrical system, which can include an ADU. The actual backup coverage for the main house and ADU depends on factors such as the home’s electrical configuration, transfer equipment, connected panels, and overall load requirements.
The EcoFlow DELTA Pro Ultra is the only portable power station certified to both UL1973 and UL9540. It delivers 7.2-21.6kW, powerful enough to run your whole home even with a central AC. It features a scalable 6-90kWh capacity for weeks of backup. With Smart Home Panel 2 for auto-switchover, 5 charging modes, and self-heating for freezing weather, it’s the ultimate fail-safe power solution.
Building an Accessory Dwelling Unit is one of the most flexible home improvement projects a property owner can undertake. Converting spare land or unused indoor space into a high-functioning home can give you additional flexibility for changing household needs. It gives you an opportunity to foster closer family ties, and build substantial equity. The process starts with careful budgeting, local research, and long-term planning. In the end, your ADU will deliver flexibility, comfort and financial dividends for decades.
What Is Another Name for an Accessory Dwelling Unit?
An Accessory Dwelling Unit is most commonly called a granny flat, in-law suite, backyard cottage, or secondary suite. Other regional terms include carriage house, casita, garage apartment, or laneway house.
What Are the Downsides of ADUs?
The primary downsides of building an ADU include high upfront construction costs, reduced yard space, and increased property tax assessments. Homeowners may also experience loss of privacy and face complex local permitting timelines during construction.
What Type of ADU Is the Cheapest?
Garage conversions and interior basement conversions are typically the cheapest types of ADUs to build. By utilizing existing foundations, framing, and roofing, these projects eliminate structural site costs, reducing overall expense compared to detached builds.
Can a Tiny Home Be an ADU?
A tiny home can serve as an ADU if it meets the applicable local zoning and building requirements for an ADU. Tiny homes built on wheels may be subject to different rules and are not automatically eligible to function as permanent ADUs.
What Are the Common Mistakes When Building an ADU?
The most common mistake when building an ADU is underestimating utility connection costs and failing to verify local zoning setbacks early. Skipping comprehensive energy planning or ignoring long-term space adaptability can also create costly future retrofits.
Home Solutions
