TITAN vs. Powerwall: Which Home Backup Setup Fits You?
Choosing a whole-home backup power solution is not only about capacity. A more useful question is how backup power should reach your home. Do you want to plug a few appliances into a battery today, or do you want selected 120V or 240V circuits to switch over automatically during an outage?
TITAN supports both starting points. Powerwall begins as a professionally installed home-energy system. That difference affects which model and accessories you need, whether an electrician is required, and which installation timeline is relevant.
Can You Use TITAN Without an Electrician?
Yes, if you are powering compatible appliances directly from the TITAN main unit. Choose the appropriate output, confirm the appliance voltage and running and starting power, and use the recommended cables. This standalone path does not involve your home's electrical panel.
An electrician is required when TITAN is connected to household circuits through Smart Home Panel 10. The electrician must select the backed-up circuits, confirm the correct 120V or 120V/240V configuration, complete the wiring, and verify local permit and inspection requirements.
EcoFlow TITAN main unit and expansion battery positioned beside professionally installed home backup equipment in a residential garage.EcoFlow TITAN main unit and expansion battery positioned beside professionally installed home backup equipment in a residential garage.
Which Connection Path Fits Your Home?
You can start with the connection path, then choose the model. The same 5kWh starting capacity can serve very different homes depending on whether you need direct appliance power, 120V circuit backup, or split-phase 120V/240V backup.
Your goal
Recommended model
Core equipment
Electrician?
Direct appliance backup
Any TITAN model; match voltage and output
Main unit, model-appropriate appliance cables; optional expansion batteries and cables
No panel work
Automatic 120V circuit backup
TITAN 5000 Classic
Smart Home Panel 10 (120V configuration), selected circuits, optional expansion batteries
Yes
Automatic 120V/240V circuit backup
TITAN 5000 or TITAN 5000 Plus
Smart Home Panel 10 (240V configuration), selected circuits; optional batteries, solar, or supported generator equipment
Yes
EcoFlow TITAN 5000
• Certified Safety: UL9540, UL9540A, and UL1741 certified, with LFP cells and an IP20 rating for indoor installation. • Split-Phase Output: 7.2kW of 120V/240V split-phase output for the home circuits you choose to back up. • Expandable Capacity: 5kWh base capacity, expandable up to 30kWh with additional TITAN batteries (sold separately). • Home Connection: Auto-switchover and circuit-level backup require Smart Home Panel 10, installed by a qualified electrician. Heavy 240V loads running at the same time may need more capacity. • Recharging: 4kW single-MPPT solar input, plus a NEMA L14-30R outlet.
When Is Direct Appliance Backup the Better Starting Point?
You should choose standalone use when your priority loads can connect directly to the main unit and you do not need automatic transfer to the electrical panel. TITAN 5000 Classic is the simplest fit for 120V essentials such as a refrigerator, lights, router, and computers. Then, you can choose TITAN 5000 or TITAN 5000 Plus when your plan includes compatible 240V equipment or a higher total output requirement. Before choosing, calculate the power needs of your appliances from their running and startup requirements.
For this path, you generally need the main unit and the correct appliance cables. You'd better add compatible TITAN Battery 5kWh units and their required connection cables when you need more runtime. Expansion batteries increase stored energy, not the inverter's rated output. You can also use our home battery backup runtime guide to turn your essential-load estimate into a practical capacity target
When Should You Choose 120V Circuit Backup?
If your backup list is limited to 120V circuits, TITAN 5000 Classic with the 120V Smart Home Panel 10 configuration is the straightforward route. It provides 4kW of output and can support automatic backup for up to 10 selected circuits. This is a practical fit for homes focused on refrigeration, lighting, communications, outlets, and other 120V essentials.
Smart Home Panel 10 is the part that connects the system to household circuits, so this path requires a qualified, licensed electrician. The main unit and optional expansion batteries remain modular, but the panel and household wiring are not a DIY installation.
EcoFlow TITAN 5000 Classic
•Certified Safety: UL9540, UL9540A, and UL1741 certified, with an IP20 rating for indoor use. • Essential 120V Output: 4kW for essential 120V loads such as a refrigerator, lights, and a Wi-Fi router. It is not designed for 240V appliances like central AC, a well pump, or an electric dryer. • Expandable Capacity: 5kWh base capacity, expandable up to 30kWh with additional TITAN batteries (sold separately). •Outage Backup: An entry-level indoor option for critical circuits during an outage. It has no grid-interactive or AC-coupled solar features. • Recharging: 3.2kW single-MPPT solar input, plus a NEMA TT-30R outlet.
When Do You Need 120V and 240V Circuit Backup?
Choose TITAN 5000 or TITAN 5000 Plus with the 240V Smart Home Panel 10 configuration when the selected backup circuits include compatible central air conditioning, pumps, or other 240V loads. Both models provide 7.2kW of battery output and 120V/240V split-phase operation. The electrician must verify the actual running and startup requirements of the equipment you plan to back up.
TITAN 5000 Plus is the better fit when you need more solar input, greater flexibility for uneven 120V loads, or the supported FlowMaster generator path. Its X-Boost 2.0 capability can provide up to 5kW on either 120V leg in a supported configuration, while total battery output remains limited to 7.2kW. With sufficient compatible solar, total output can reach up to 10kW.
EcoFlow TITAN 5000 Plus
• Certified Safety: UL9540, UL9540A, and UL1741 certified, with 40160 tabless LFP cells and an IP20 rating for indoor installation. •Backup Output: 7.2kW from the battery alone, rising to up to 10kW only when compatible solar panels are connected and producing. •Heavy Loads: In EcoFlow's defined 240V test scenario, it can start a 3-ton central AC while running about 1kW of essential loads. Results depend on your AC unit, the circuits you back up, and available battery and solar power. •Expandable Capacity: 5kWh base capacity, expandable up to 30kWh with additional TITAN batteries (sold separately). • Home Connection: Backup of up to 10 selected circuits with 20ms auto-switchover requires Smart Home Panel 10, installed by a qualified electrician.
Which TITAN Model and Accessories Should You Choose?
  • TITAN 5000 Classic: Choose it for 120V essentials, 4kW output, up to 3.2kW of compatible solar input, and the 120V SHP10 path.
  • TITAN 5000: Choose it for 7.2kW battery output, 120V/240V split-phase loads, up to 4kW of compatible solar input, and the 240V SHP10 path.
  • TITAN 5000 Plus: Choose it for the same 7.2kW battery output plus X-Boost 2.0, up to 8kW of compatible solar input, up to 10kW with sufficient solar contribution, and the supported FlowMaster route.
Every TITAN main unit starts with 5kWh. Compatible TITAN Battery 5kWh units can expand total capacity to 30kWh, using the required battery connection cables. For circuit backup, select the SHP10 configuration specified for the model and voltage path. For solar or generator integration, use only the supported equipment and connection method for the exact model. If you are still balancing load coverage, storage, and installation scope, this whole-house battery backup sizing guide provides a useful next step.
Where Does Powerwall Take a Different Route?
Powerwall begins as a professionally installed home-energy system. It does not offer the same standalone appliance-first path as TITAN, so comparing a TITAN main unit with a fully integrated Powerwall project is not a like-for-like comparison. TITAN with SHP10 is the closer comparison because both routes connect backup power to household circuits.
If you want the step-by-step Powerwall side of the comparison, read Inside the Tesla Powerwall Installation Process. You can also compare other Powerwall alternatives. Here, the decision is simpler: TITAN lets you begin with direct appliance power and add home integration later, while Powerwall starts with professional integration.
TITAN can reduce on-site assembly because the inverter and first 5kWh battery are integrated in the floor-standing main unit, while SHP10 uses a factory-prepared layout and connections. That can make the circuit-backup project simpler, but it does not remove the electrician, site assessment, permits, or code requirements.
When Does the 7-Business-Day Installation Clock Start?
EcoFlow's 7-day installation commitment is measured in business days, not calendar days. The clock does not start when you place the order, pay, or receive the equipment. It begins the day after all required local permits and approvals have been obtained; if several approvals are needed, it begins after the last one is secured. The period ends when on-site product installation is completed.
Coverage is limited to eligible ZIP codes. Please enter the installation ZIP code when ordering the official turnkey installation service. If the order cannot be placed, the area is not currently shown as serviceable. ZIP-code verification can occasionally change after review; if service is ultimately unavailable, customer service will contact the customer and process a refund.
The 7-business-day commitment excludes delays caused by:
  • Shipping, transit, or product availability.
  • Failure to respond, confirm the appointment, or remain reachable within two business days.
  • Customer-requested appointment changes.
  • Permit submission, government approval, or additional inspection time.
  • Complex or non-compliant site conditions, legal restrictions, severe weather, or force majeure.
The commitment also depends on site readiness, timely customer cooperation, applicable law, and regulatory requirements. The standard service does not include wiring TITAN to solar or PV systems, and additional materials, panel upgrades, breakers, permit costs, travel, or work outside the standard installation scope may be charged separately. Review the official EcoFlow Installation Terms and Conditions before purchasing installation service.
You'd better start with the connection path rather than the largest model. If direct appliance power meets your needs, choose a TITAN model whose voltage and output match those appliances. For automatic 120V circuit backup, consider TITAN 5000 Classic with the 120V SHP10 configuration. For 120V/240V circuit backup, choose TITAN 5000 or TITAN 5000 Plus with the 240V SHP10 configuration and a licensed electrician.
Moreover, you should size storage for the runtime you want and add only the accessories required by that path. You can use the TITAN installation preparation guide to gather your load, solar, generator, and site details before requesting a quote. For broader outage planning, see how a whole-house battery backup can power a home during an outage.
Which TITAN model is suitable for 120V circuit backup?
TITAN 5000 Classic is the 120V model. Pair it with the supported 120V Smart Home Panel 10 configuration for automatic backup of up to 10 selected 120V circuits.
Which TITAN models support 120V and 240V circuit backup?
TITAN 5000 and TITAN 5000 Plus support 120V/240V split-phase operation. Pair the selected model with the supported 240V Smart Home Panel 10 configuration and professional installation.
Does adding TITAN batteries increase output?
No. Compatible expansion batteries increase stored energy and runtime. They do not increase the main unit's rated inverter output.
Does the 7-business-day commitment start when I place my order?
No. It starts the day after all required local permits and approvals have been obtained and applies only to eligible ZIP codes, subject to the exclusions and conditions in EcoFlow's official installation terms.
Home Battery for Power Outages
