Snow Flurries Explained: What Flurries, Snow Showers, and Squalls Mean for Your Day
The forecast app says "flurries." Does that mean grab a coat, or cancel the drive? The National Weather Service (NWS) uses flurries, snow showers, and snow squalls for three very different situations. The gap between them decides whether roads stay wet or turn white.
This article covers a plain flurries meaning, a side-by-side comparison of the three terms, tips for reading forecast wording, and a short checklist for when a forecast escalates. Most days, a flurry is no big deal. A few days, knowing the difference matters.
What Are Snow Flurries? The NWS Meaning in Plain English
Snow flurries are the lightest kind of falling snow in a forecast. The NWS describes them as intermittent, short-lived light snow that leaves no measurable accumulation. Flakes fill the air, but the shovel stays in the garage.
The official definition
Two NWS sources describe the term in nearly the same way.
  • NWS glossary: Snow flurries are "an intermittent light snowfall of short duration," often described as light snow showers. The glossary also lists "no measurable accumulation (trace category)."
  • NWS Spokane winter terms: The office describes "light snow falling for short durations." It adds that "no accumulation or light dusting is all that is expected."
  • What "trace" means: Snow fell, but not enough to measure. A ruler would read zero.
Signs you're looking at flurry snow
These are common observations, not official criteria.
  • Flakes come and go. Snow starts and stops instead of falling steadily for hours.
  • Pavement looks wet. Moisture shows on the surface, but snow does not pile up.
  • The sky has gaps. Passing clouds often leave patches of open sky between bursts.
The first flakes of the season often arrive as flurries. A first snowfall forecast can help tell a passing dusting from a real storm.
Flurries rarely cause trouble on their own. But forecasts change, and a short plan helps.
If the Forecast Escalates: A Conditional Home Power Checklist
Flurries alone are not a reason to buy backup power. They also do not mean the power will go out. This section only matters if the local NWS office upgrades the forecast to accumulating snow, ice, or a warning. It also applies if an area is already dealing with outages.
Upgrade signals to watch for
The NWS winter alerts page lists the main steps up from a flurry forecast.
  • Winter Weather Advisory: Wintry precipitation is expected. Conditions "should not be hazardous enough to meet warning criteria," according to the NWS.
  • Winter Storm Warning: The NWS calls this a significant winter weather event that includes snow, ice, sleet, or blowing snow.
  • Ice Storm Warning: Usually issued for ice buildup of around 1/4 inch or more. The NWS notes that heavy ice can bring down trees and topple utility poles. It can also disrupt communications and power for days.
A backup power plan makes sense once one of these appears for the area. The word "flurries" alone is not the trigger.
Before you plug anything in
Preparation starts with basic gear and a clear device list.
  • Light and information: The NWS advises keeping a flashlight, extra batteries, and a battery-powered NOAA Weather Radio. A generator should never run in an enclosed space.
  • Food safety: FoodSafety.gov says a closed refrigerator keeps food safe for up to 4 hours in an outage. A full freezer holds about 48 hours, or 24 hours if half full.
  • Device list: Write down the devices that matter to the household. Then add up the watts from each nameplate.
If an upgraded forecast has a household thinking about a backup plan, here are two ways to match the size of the battery to the size of the list.
A short list of small devices is the easiest place to start. Phones, lamps, and a Wi-Fi router add up to a modest load. The EcoFlow DELTA 3 Classic (1024Wh) fits that kind of list.
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
A refrigerator changes the math. It adds a larger load that cycles on and off. Households that want to protect food usually need more capacity and more output, which is where the EcoFlow DELTA 3 Max (2048Wh) comes in.
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
How the two products divide the job
  • EcoFlow DELTA 3 Classic: The "stay connected" option. It covers phones, LED lights, and a router, so the household can follow NWS updates and check in with family.
  • EcoFlow DELTA 3 Max: The "keep food cold" option for homes that also want the refrigerator running. Compare the real device list and how often recharging is possible between outages.
  • Ground rules: Neither unit replaces NWS warnings. Check each appliance's startup load, add the total wattage, and estimate runtime before relying on it.
A quick runtime estimate (example only)
The basic formula is simple: runtime in hours ≈ capacity (Wh) × 0.85 ÷ total load (W). The 0.85 is a planning assumption for conversion losses.
  • EcoFlow DELTA 3 Classic example: 1,024Wh × 0.85 is about 870Wh. A placeholder 50W combined load covers phones, two LED lamps, and a router. That works out to about 17 hours. Real nameplate values should replace the 50W figure.
  • EcoFlow DELTA 3 Max example: 2,048Wh × 0.85 is about 1,741Wh. Next, add the refrigerator's average running watts from its label or the maker's spec sheet. Include the small loads, then divide. Refrigerators cycle on and off, so real draw varies.
Whichever size is chosen, stocking an emergency supply kit covers what a battery can't, like water, food, and medications.
With the backup question settled, it's time for the comparison most people came for.
Flurries vs. Snow Showers vs. Snow Squalls
Flurries, snow showers, and squallsFlurries, snow showers, and squalls
These three terms describe showery snow at very different strengths. The flurries vs snow showers question comes down to buildup. Flurries are light and leave no measurable snow. Snow showers can stack up. Snow squalls can turn a highway white within minutes.
Term
NWS description
Accumulation
What it means
Snow flurries
Intermittent light snowfall of short duration
No measurable accumulation (trace)
Usually a normal day; roads may look damp
Snow showers
"A short duration of moderate snowfall"
"Some accumulation is possible"
Possible slick spots; allow extra time
Snow squall
"An intense, but limited duration, period of moderate to heavy snowfall," with strong, gusty winds and possibly lightning
"May be significant"
Sudden whiteouts; delay travel
Heavy snow (for comparison)
Generally 4 inches or more in 12 hours or less, or 6 inches or more in 24 hours or less
Measurable and significant
Plan around closures
What are snow showers? (the NWS wording)
The snow showers definition in the NWS glossary is short. Two offices word it a little differently, so each is credited below.
  • NWS glossary: A snow shower is "A snow shower is a short duration of moderate snowfall." The glossary adds that some accumulation is possible.
  • NWS Terminology: The office describes "Snow falling at varying intensities for brief periods of time. Some accumulation is possible."
  • Everyday use: Snow showering is how people describe on-and-off snow that starts and stops. It can look like flurries at first, then thicken for a few minutes.
When a squall warning changes the plan
A snow squall is a different kind of event. The NWS State College office explains the risk in its snow squall FAQ.
  • Wind and visibility: Squalls bring strong winds (30+ mph) and whiteout conditions, with visibility under 1/4 mile.
  • Road impact: Roads can "turn into a sheet of ice in just a few minutes."
  • Alerts: Only snow squall warnings tagged with a "Significant" impact, used when a squall poses a substantial threat to safe travel, trigger a Wireless Emergency Alert on phones. Other warnings may not send a pop-up, so local NWS alerts are worth checking too.
  • Advice: The NWS says to avoid or delay motor travel until the squall passes.
A dusting on the lawn and a few inches on the porch rail can mean very different things. That is why forecasters track both snowfall and snow depth.
Knowing the terms is half the job. The other half is reading the wording that comes with them.
Reading the Forecast: Chance, Coverage, and Timing
The word "flurries" rarely appears alone. It usually comes with a probability like "chance" or "likely." Sometimes it adds a coverage word like "scattered." Those small words show how sure the forecaster is and how much of the area might see snow.
NWS term
Percent
Slight chance
Chance
30, 40, and 50%
Likely
60 and 70%
Isolated / few
10% coverage
Widely scattered
20% coverage
Scattered
30, 40, and 50% coverage
Numerous
60 and 70% coverage
These terms come from NWS Binghamton forecast terms. Probability of precipitation (PoP) is "the likelihood of occurrence (expressed as a percent) of a measurable amount of liquid precipitation."
Two ideas are easy to mix up here, so it helps to keep them apart.
  • PoP is about chance, not amount: It is the probability that measurable precipitation, at least 0.01 inch of liquid equivalent, falls at a given point in the forecast period. It says nothing about how much snow piles up.
  • Trace is about amount: A trace means snow fell but was too light to measure. Flurries that only leave a trace may be worded with "chance" or "scattered" and no number at all. A numerical PoP usually appears once measurable precipitation becomes possible.
Qualifiers also do not have to pair with a low percentage. A "likely" forecast can still describe light snow. The snow vs flurries wording adds a hint, since a "snow" forecast often points to more buildup than a flurry mention.
Three questions to ask a flurry forecast
  • Is the road surface near or below freezing overnight? Cold pavement changes how light snow behaves.
  • Does the forecast mention snow showers or squalls later? Conditions can shift during the day.
  • Has the local NWS office issued an advisory or warning? That is the clearest sign of a bigger event.
Light snow on cold pavement is where trouble often starts. Black ice can form even when the snow itself looks harmless.
One more factor shapes how flurries look and feel: the kind of snow that is falling.
Why Some Flurries Look Bigger Than Others
Snow grains on jacket sleeveSnow grains on jacket sleeve
Not all flurries look the same. Some are tiny grains that bounce. Others are fat flakes that melt on a sleeve. So what are flurries made of? The answer comes down to ice crystals and the air they fall through.
  • Snow: The NWS glossary describes ice crystals formed directly from water vapor freezing in the air, often clumped into flakes.
  • Snow grains: "White, opaque ice particles usually less than 1 mm in diameter." That is smaller than a grain of rice.
  • Snow pellets: Round or conical ice particles about 2 to 5 mm across, the same as graupel. They look like tiny white beads.
Temperature also decides whether flakes are powdery or heavy. The difference between wet and dry snow explains why some light snow sticks while other snow blows away.
Snow flurries are light, short, on-and-off snow with no measurable buildup. Snow showers can accumulate, and snow squalls can cause sudden whiteouts. Reading the probability and coverage words, then watching for an advisory or warning, makes plans easier to adjust. If the forecast escalates, compare the EcoFlow DELTA 3 Classic or EcoFlow DELTA 3 Max against the real device list.
What is a snow flurry?
A snow flurry is light snow that falls on and off for a short time. The NWS says it leaves no measurable accumulation, so flakes may fill the air without covering the ground or building up much on roads and sidewalks.
What's the difference between flurries and snow showers?
The difference is intensity and buildup. Flurries are light with no measurable snow. The NWS describes snow showers as a short burst of moderate snowfall where some accumulation is possible, so slick spots can form.
Do flurries stick to the ground?
Usually not in a measurable way. A light dusting may show on grass, cars, or rooftops, especially when temperatures are low. Roads often just look wet, although cold pavement can still turn slick in some conditions.
Can flurries cause a power outage?
Flurries on their own are not a typical outage cause. Outage risk rises with heavy wet snow, ice accumulation, or strong winds. Watching local NWS advisories and warnings is a better signal than the word flurries alone.
Are snow flurries dangerous to drive in?
Usually they are not a big hazard, but cold pavement can still turn slick. If the forecast upgrades to a snow squall warning, the NWS says to avoid or delay motor travel until the squall passes.
