The Best Battery Powered Snow Blower for Your Driveway, Snow, and Tool Platform
Every winter, homeowners hit the exact same realization. The "best" battery powered snow blower is never just one universal machine. Instead, it is the one rig that matches your local winter storms. It has to fit your driveway layout. Most of all, it must match the tool batteries already sitting in your garage. The picks below come straight from manufacturer specification sheets, not lab test scores. Coverage claims reflect maker test benchmarks under specific conditions.
Below, we break down top models side by side. You will see how to match blower stages to your snowfall. Plus, you will learn how to recharge your battery packs when a blizzard takes down the neighborhood power grid.
Three Questions That Narrow the Field Fast
Most cordless snow blowers look identical in catalog photos. What separates them is how much snow they clear per pass. Runtime and battery platform ecosystems matter just as much.
Answer these three questions before you buy a snow thrower.
1. What does a typical storm drop where you live?
The National Weather Service generally defines heavy snow as 4 inches or more within 12 hours, or 6 inches or more within 24 hours. Your usual snowfall helps determine which machine you need.
  • Single-stage blowers: Best for light to moderate snowfall on driveways and walkways.
  • Two-stage blowers: Better suited to deeper snow and more demanding clearing jobs.
For example, Toro's Power Max e24 has a 20-inch intake height. Its single-stage Power Clear e21 has a 12-inch intake. That difference matters when snow piles up after a major storm.
Remember that storm forecasts can deceive you. The forecast number and what is on your driveway rarely match. Knowing how snowfall differs from snow depth explains why a 6-inch storm can leave 9 inches by your garage door.
2. How much area do you clear?
Manufacturers often express coverage in car spaces or car driveways. These figures help compare models, but they're not guaranteed results.
Snow depth, moisture, temperature, terrain, and battery condition can all affect coverage. A wide driveway covered in wet snow may require more battery power than a smaller driveway with light powder.
3. Which batteries do you already own?
Cordless tool platforms are brand-specific.
  • EGO POWER+ runs on a 56V platform.
  • Toro uses a 60V MAX system.
  • Ryobi outdoor gear runs on 40V packs.
  • Greenworks Pro operates on an 80V platform.
A battery pack from one brand will never slide into another.
If you already own an electric lawn mower, stick with that ecosystem. Buying a bare-tool snow thrower will save you hundreds of dollars upfront.
With your storm habits, driveway size, and platform set, let us see how current units compare.
Six Cordless Snow Blowers and One Snow Shovel, by the Spec Sheet
Every figure listed below comes directly from maker product specification sheets as of October 2026. Some listings may show products as coming soon, sold out, or available only through dealers. Check current availability before purchasing.
Model
Stage
Width
Battery platform and packs included
Maker's coverage claim
EGO POWER+ SNT2425
Two-stage, self-propelled
24 in
56V; two 7.5Ah
Up to an 18-car driveway with 8 in of snow per charge
Toro Power Max e24 (39924)
Two-stage
24 in
60V MAX; two 6.0Ah (324Wh each)
Up to 24 car spaces in up to 10 in of snow
EGO POWER+ SNT2124 (Peak Power)
Single-stage
21 in
56V; two 6.0Ah
Up to a 14-car driveway with 8 in of snow per charge
Ryobi 40V HP Brushless 21 in Whisper Series kit
Single-stage (kit)
21 in
40V; two 7.5Ah
Up to 19 car spaces
Toro Power Clear e21 (39901)
Single-stage
21 in
60V MAX; one 7.5Ah (405Wh)
Up to a 12-parked-car driveway; 2 to 9 in of snow at a time
Greenworks 80V 22 in (SNB403)
Single-stage
22 in
80V; one 4.0Ah
Up to a 6-car drive per charge
EGO Multi-Head Snow Shovel Attachment (SSA1220)
Shovel attachment
12 in
56V; 4.0Ah recommended, sold separately; needs PH1400 or PH1420 power head
A 4-car driveway with 6 in of snow per charge
Best for deep, frequent storms: EGO SNT2425 or Toro Power Max e24
Both models offer a 24-inch clearing width and a 20-inch intake. They're worth considering if your driveway regularly collects deep snow.
EGO POWER+ SNT2425
  • Throws snow up to 50 feet.
  • Includes two 7.5Ah batteries and a dual-port CH2800D charger.
  • Offers IPX4 weather resistance.
  • Includes a 5-year tool warranty, and a 3-year battery warranty.
  • Charges both included batteries in approximately 120 minutes, according to EGO's listed estimate.
  • Throws snow up to 45 feet.
  • Weighs approximately 172 pounds.
  • Lists at $1,649, with dealer-only availability noted.
  • It has a 3-year tool and battery warranty, with an estimated 180-minute charge time.
  • Offers a third battery port to extend coverage.
Toro Power Max e24 (39924)Toro Power Max e24 (39924)
Living near the Great Lakes brings extreme squalls. A single squall can bury one town while leaving the next dry. That brutal lake-effect snow along the shoreline is why snowbelt homeowners rely on these two-stage workhorses.
Best all-rounder for typical driveways: EGO SNT2124
The EGO SNT2124 Peak Power single-stage blower hits the sweet spot for suburban homeowners.
  • Clears a 21-inch path with a 13-inch intake height.
  • Throws powder up to 42 feet.
  • Holds IPX4 weather-resistance certification.
  • Ships with a 550W charger that fills a 6.0Ah pack in roughly 45 minutes.
  • Includes a 5-year tool warranty and a 3-year battery warranty.
Best if you're already on Ryobi 40V
If your shed is full of Ryobi 40V lawn tools, this Whisper Series kit makes practical sense.
  • Throws snow up to 35 feet away with reduced operational noise.
  • Ships with the OP406 40V Rapid Charger. Ryobi notes it fills 40V packs in an hour or less.
  • Backed by a 5-year tool warranty and a 3-year battery warranty.
Note: Ryobi lists model numbers RY408010 and RY408101 across retailer listings; confirm the SKU before ordering.
Lighter single-stage options: Toro Power Clear e21 and Greenworks SNB403
Small driveways do not need massive machines. These lightweight options are easy to push, turn, and store away.
  • 21-inch clearing width with a 12-inch intake.
  • Approximately 55 pounds.
  • One 60V MAX 7.5Ah battery, rated at 405Wh.
  • Listed price of $749.
  • Listed charging time of 180 minutes.
  • Coverage of up to a 12-parked-car driveway, with 2 to 9 inches of snow handled at a time.
Greenworks 80V SNB403
  • 22-inch clearing width and 13-inch clearing depth.
  • Approximately 56.9 pounds.
  • Includes one 80V 4.0Ah battery.
  • Throws snow up to 30 feet.
  • Lists at $599.99.
  • Its 4A rapid charger can recharge the included battery in under 60 minutes.
  • Includes a 4-year tool and battery warranty.
Greenworks 80V SNB403Greenworks 80V SNB403
These models suit homeowners who prioritize straightforward clearing over heavy-duty snow removal. Check current inventory and the exact kit contents before purchasing.
Best battery powered snow shovel for steps and decks: EGO SSA1220
Do not drag a 150-pound blower up deck stairs. A dedicated power shovel clears tight walkways and raised porches with ease.
  • Clears a 12-inch path and throws snow up to 25 feet.
  • Features integrated directional discharge fins.
  • Connects directly to EGO's PH1400 or PH1420 multi-head power heads.
Every one of these machines has the same weak point in a big storm: its charger needs a live outlet.
Building a Charging Station That Works When the Grid Doesn't
When a winter storm brings down power lines, your snow blower's batteries may run out before the driveway is clear. A portable power station can run compatible tool chargers through its AC outlets. It doesn't replace the tool batteries, and the charger's input must stay within the station's limits.
Critical operating ground rules
Follow these rules to charge safely when the power is out:
  • Power original chargers only: Plug the tool maker's original AC charger directly into the station outlet. Never wire a station straight to the tool.
  • Inspect the nameplates: Check the charger's nameplate input wattage. Match it against the output limits of the power station.
  • Respect temperature limits: Cold lithium batteries refuse to take a charge. Toro requires charging between 41°F and 104°F. The EcoFlow DELTA 3 Ultra Plus charges between 32°F and 113°F and discharges from 14°F to 113°F. Always check your manual for exact operating temperatures.
  • Charge in a dry, warm space: Set your station up inside a heated mudroom, basement, or insulated garage. Never let power stations or chargers sit outdoors in the snow.
Selecting the right setup comes down to your storm recovery plan. Are you just recharging one routine set of packs, or powering a full bench of chargers?
If you mainly need to recharge one or two tool batteries, the EcoFlow DELTA 3 Max offers a practical starting point. Its 2,048Wh capacity and 2,400W rated output can support compatible chargers whose power requirements fit the unit.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
A household running several high-power chargers alongside essential devices needs more output. The EcoFlow DELTA 3 Ultra Plus provides 3,600W of rated AC output at 120V, giving a larger charging setup more room.
EcoFlow DELTA 3 Ultra Plus (3072Wh)
•Smart Output Priority: Choose in the app which outputs stay powered to stretch runtime when it counts. Controlling home circuits requires a compatible home connection installed by an electrician. • Expandable Capacity: 3kWh base, expandable to approximately 11kWh. Pairs with a compatible EcoFlow Smart Generator for automatic start and stop. •6 Ways to Charge: Reaches 0 to 80% in 48 minutes with combined solar and generator charging.
How the two products divide the job
The EcoFlow DELTA 3 Max suits single-family homes that need to charge one or two packs. It handles standard 550W chargers with ease.
The EcoFlow DELTA 3 Ultra Plus fits heavy-duty properties clearing extensive pathways. It powers multiple high-amperage chargers alongside basic indoor emergency circuits.
Keep your power station warm during winter storms. Power station batteries also face cold-weather limits. Knowing how power stations behave below freezing explains why stations must always stay inside your heated living space.
Charging estimates (upper-bound examples)
These estimates use 85% of rated station capacity as a planning allowance. They're upper-bound examples, not guaranteed charge counts. Actual consumption depends on charger behavior, battery condition, and charging losses.
Scenario
Calculation
Estimate
EcoFlow DELTA 3 Max, EGO 550W charger, 6.0Ah pack (about 45 min listed)
2,048 × 0.85 = 1,741 Wh; 550 W × 0.75 h = 413 Wh per charge; 1,741 ÷ 413
About 4 full charges
EcoFlow DELTA 3 Max, two EGO 550W chargers running together
1,100 W combined, under 2,400W rated; 1,741 ÷ 1,100
About 1.6 hours of both chargers at full draw
EcoFlow DELTA 3 Ultra Plus, Toro 6-pod charger (nameplate 120V, 12.0A = 1,440 W) + two EGO 550W chargers + example 300 W of essentials
2,840 W total, over 2,400W and under 3,600W; 3,072 × 0.85 = 2,611 Wh; 2,611 ÷ 2,840
About 55 minutes at full nameplate draw
The final example uses a Toro charger rated at 120V and 12A, or 1,440W of nameplate input. That is a ceiling, not its guaranteed continuous draw. The 300W essential-device load is an example; add up the actual nameplate ratings in your setup.
The EGO 550W figure comes from the SNT2124 product page. One 56V 6.0Ah EGO battery holds approximately 336Wh based on voltage multiplied by amp-hours.
Good charging only helps if the packs come back from the driveway in shape to take it.
Getting the Most From Every Pack in Freezing Weather
Lithium-ion tool batteries can operate in cold weather, but charging has tighter temperature limits. Toro lists an operating range of -22°F to 120°F for its 60V packs, while charging and storage should remain between 41°F and 104°F.
A simple storm-day routine
  1. Store batteries indoors: Keep packs in a clean, dry space within the manufacturer's storage temperature range.
  2. Warm batteries before charging: After clearing snow, bring cold packs indoors and let them reach an acceptable temperature. Greenworks also advises allowing cold or hot batteries and chargers to rest indoors.
  3. Choose a ventilated charging area: Follow the charger manufacturer's instructions and keep the charging area dry.
  4. Rotate spare batteries: Use one set while another warms or charges, provided the charger and power source can support the load.
The chemistry behind these rules is simple. Learning how lithium batteries handle the cold reveals why attempting to recharge frozen cells causes permanent internal plating damage.
Safety at the machine
Clearing heavy snow requires proper safety precautions.
The Consumer Product Safety Commission (CPSC) warns of severe snow thrower hazards every year, including finger amputations. Never clear a clogged discharge chute with your bare hands. Always shut off the motor, remove the safety key or battery pack, and clear ice with a cleanout stick.
The National Weather Service (NWS) warns that cold temperatures paired with heavy manual labor strain your heart. Self-propelled machines reduce physical fatigue, but you should take regular breaks and pace your clearing passes.
The best battery powered snow blower fits your storm patterns, driveway size, and current battery collection. Two-stage units, like the EGO SNT2425 and Toro Power Max e24, clear deep drifts and icy plow berms. Single-stage blowers handle everyday suburban snowfalls without extra bulk.
Keep your battery packs warm, rotate spares during long storms, and plan for grid outages. Compare your chargers' nameplate ratings against the EcoFlow DELTA 3 Max and EcoFlow DELTA 3 Ultra Plus to keep your driveway clear all season long.
What is the best battery powered snow blower for heavy snow?
A two-stage cordless model is best for heavy, wet snow. The EGO SNT2425 and Toro Power Max e24 both feature 24-inch clearing widths and 20-inch intake depths. Their serrated metal augers easily chew through icy snowbank berms left by street plows.
Can I use my mower batteries in my snow blower?
Only when the batteries belong to a compatible platform and the snow blower manufacturer confirms compatibility. Voltage, battery design, and model-specific requirements matter. Batteries and chargers from different brands generally aren't interchangeable.
How long does it take to recharge a snow blower battery?
Recharge speed depends on the battery pack capacity and charger wattage. An EGO 6.0Ah pack refills in roughly 45 minutes on a 550W rapid charger. High-capacity commercial packs, like Toro's large 60V batteries, take up to 180 minutes on standard chargers.
Is a battery snow shovel worth it?
Yes, an electric snow shovel works wonders for raised porches, tight walkways, and wooden decks. The EGO SSA1220 clears a 12-inch path without scratching deck boards. It eliminates the back strain of lifting wet, heavy slush by hand.
Can I charge snow blower batteries in a cold garage?
No, never charge lithium-ion batteries in below-freezing temperatures. Toro requires charging its 60V packs between 41°F and 104°F. Recharging frozen battery cells can cause internal lithium plating, permanently reducing battery lifespan and causing safety risks.
Tips
