How Does Sleet Form? The Two Air Layers Behind Winter's Ice Pellets
The forecast says snow. Then a sharp rattle hits the windows, and tiny ice beads bounce across the porch. That is sleet. It shows up when the air above a roof is not the same temperature all the way down.
This article explains how sleet forms in plain terms, one air layer at a time. It also shows how to tell sleet from freezing rain and graupel at a glance. Last, it covers when a sleet forecast is a cue to check the home backup plan, but only if the local forecast also mentions ice, strong wind or outage risk.
How Sleet Forms, One Layer of Air at a Time
Most winter precipitation starts out as snow high in the cloud, according to NOAA's National Severe Storms Laboratory (NSSL). What happens next depends on the air it falls through. Sleet needs a very specific stack: a shallow warm layer up high and a deep freezing layer near the ground.
So how is sleet created from that stack? Three steps do the work.
Air layers that form sleetAir layers that form sleet
Step 1: Snow forms in the cold top of the storm
The top of a winter storm is usually cold enough to make snowflakes. If temperatures stay at or below 32°F (0°C) all the way down, the precipitation stays snow. Nothing melts, so nothing can refreeze into a pellet.
Step 2: A thin warm layer partly melts the flakes
Sleet occurs when snowflakes only partially melt as they fall through a shallow layer of warm air. That warm layer is usually a tongue of above-freezing air riding over colder air near the surface. The flakes turn slushy, but they do not melt all the way.
Step 3: A deep freezing layer refreezes them into pellets
The slushy drops then fall through a deep layer of freezing air above the surface. They refreeze and reach the ground as frozen drops that bounce. This is the short answer to how sleet is formed: partial melting, then refreezing before landing.
What the warm layer does to a falling snowflake
Forecasters use the wet-bulb temperature (Tw) to judge this. Wet-bulb temperature runs at or below the regular air temperature. The table below comes from a National Weather Service training slide by Stewart and King (1987). Treat the values as rules of thumb, not hard cutoffs.
Warmest wet-bulb temperature in the warm layer
What usually happens
Likely result at the ground
Below about 34°F (1°C)
Only partial melting
Snow usually refreezes
About 34°F to 37°F (1°C to 3°C)
Partial melting, then refreezing
Sleet, or a sleet and freezing rain mix depending on warm layer depth
Above about 37°F to 39°F (3°C to 4°C)
Complete melting
Rain or freezing rain
The same slide adds a useful point. The temperature of the cold layer matters more than its depth. A cold layer colder than about 18°F (minus 8°C) favors refreezing into sleet. A warmer one lets melted drops stay supercooled, which favors freezing rain.
How does sleet occur in real storms? Often a warm, moist air mass slides over a shallow pool of Arctic air. Reading those forecasts gets easier with a basic grasp of air mass types and how they stack.
How does sleet happen in a single storm, then? It can start as snow, switch to sleet when the warm layer arrives, and change again as the layers shift. A small change in the warm layer can flip the result.
Once the recipe is clear, the pellets on a porch rail say a lot about what the sky is doing.
What Falling Sleet Looks Like Next to Freezing Rain and Graupel
Sleet is easy to confuse with its winter cousins, especially at night or under a streetlight. The quickest tests are what it looks like, what it does when it lands, and whether it sticks. Here is how to tell them apart without a weather station.
Sleet, freezing rain, and graupelSleet, freezing rain, and graupel
  • Appearance: NOAA JetStream describes sleet as transparent or translucent pellets of ice. They can be round or irregular hard grains. They form from frozen raindrops or from snowflakes that largely melted, then refroze.
  • Behavior: The National Weather Service (NWS) glossary notes that the pellets usually bounce after hitting the ground or other hard surfaces. That bounce is the "rattle on the window" most people notice.
Type
How it forms (NWS/NSSL)
What is seen and heard
What it leaves behind
Sleet (ice pellets)
Snow partly melts in a shallow warm layer, refreezes in a deep cold layer
Clear or translucent beads that bounce and tick on glass
Loose, gritty pellets that can pile up
Freezing rain
Snow melts completely in a warm layer, falls as liquid through a thin cold layer, freezes on contact
Looks like ordinary rain
A clear glaze on roads, trees and power lines
Graupel (snow pellets)
Per the NWS glossary: crisp, white, opaque ice particles, round or conical, about 2 to 5 mm across
White and soft-looking, often in brief bursts
Soft white pellets, usually short-lived
The rule is simple. White and opaque points to graupel. Clear and bouncy points to sleet.
Soft white pellets that squish between the fingers are a different animal. The graupel vs hail split comes down to how each one grows inside the cloud.
Sleet on its own is mostly a travel headache. The picture changes when the same forecast also calls for glaze ice and gusty wind.
When a Sleet Forecast Belongs on Your Backup Power Checklist
A sleet forecast does not mean the power will go out. The NWS describes sleet as ice pellets that make wet roads freeze and turn slippery. It ties the coating of trees and power lines to freezing rain. So it helps to check whether the local forecast pairs sleet with freezing rain, strong wind or an ice storm before treating it as an outage warning.
A short checklist for ice and outage risk
Use this list if the local NWS forecast or warning mentions ice accumulation, strong wind or possible outages.
  1. Name the must-run loads: Think refrigerator, lights, Wi-Fi router and phone charging. Some homes also rely on a well pump or heating equipment.
  2. Check the voltage of each load: Look at the nameplate or ask the installer to see whether it is 120V or 240V.
  3. Find the starting watts. Motor loads list surge (starting) watts on the nameplate or in the manual. Motors draw more at startups than while running.
  4. Estimate the outage length: Base it on the local forecast and on past outages in the area.
  5. Charge backup batteries early: Top them off while grid power is still on.
According to the U.S. Consumer Product Safety Commission (CPSC), a generator should never run in an enclosed space. Check that carbon monoxide detectors are working, and keep the outdoor vents of combustion equipment, such as furnaces, clear of snow to prevent carbon monoxide buildup indoors. For downed lines or any danger, call 911.
Two EcoFlow TITAN setups fit this checklist, and the dividing line is voltage.
Ice-related outages tend to hit the basics first. The refrigerator starts to warm, the lights go dark, and the Wi-Fi router drops, which can cut off storm alerts. For homes where those are the only must-run loads, and all of them sit on standard 120V circuits, a battery backup sized for essentials can help keep them running. The EcoFlow TITAN 5000 Classic is built for that kind of setup.
• 4,000W Whole-Home Essential Power. Run your fridge, microwave, Wi-Fi, lighting, and CPAP all at once. •5–30kWh Expandable Capacity. Get 1 day to 1 week of essential backup. Add batteries anytime, with no installer needed. • <25 dB. Quiet enough for indoor use—quieter than a whisper. • ≤20 ms Automatic Switchover. The lights don't even flicker. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. • North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, UL 1741 compliant, with EV-grade LFP cells, 24/7 BMS monitoring, and a 5-year warranty.
Some homes need more than the basics. A private well pump often runs on 240V, and without it there is no running water during an ice storm. Heating equipment approved for battery backup can also sit on 240V circuits. A 120V-only system cannot cover those loads, so the voltage check from the checklist matters here. The EcoFlow TITAN 5000 uses a split-phase design aimed at that second group of homes.
EcoFlow TITAN 5000
• 100% Whole-Home Backup. 7.2kW powers your 3-ton AC, refrigerator, and the rest of your home simultaneously, with no soft starter needed. •100% Whole-Home Savings. Save up to $2,900/year, with ROI in 3 years. • Only 30% of Traditional System Cost. Industry-first 200V architecture, custom high-rate LFP cells, and a pre-wired SHP10 help lower costs across the entire lifecycle, including upfront purchase, installation, and long-term use. • OASIS 3.0 — Your AI-based Home Energy Manager. Charges off-peak, powers your home during peak hours, and helps lower your electricity bill every day. •North America Highest Safety Standards. UL 9540 certified and tested to UL 9540A, with EV-grade LFP cells and 24/7 BMS monitoring.
How the two products divide the job
  • EcoFlow TITAN 5000 Classic: The pick when every must-run load is 120V, such as a refrigerator, lights and internet. It cannot run any 240V appliance, so a 240V well pump rules it out.
  • EcoFlow TITAN 5000: Built for homes that also need a 240V well pump or heating equipment approved for battery backup. Size it by the motor's starting watts, the number of circuits and the expected outage length. Central AC, electric water heaters, electric ranges and electric resistance furnaces can exceed or crowd out a 7,200W setup, so they need a careful load review.
  • Both models: Home circuits need the Smart Home Panel 10 version matched to that model (the 120V version for the Classic) and a licensed electrician. Both back up chosen circuits, not every outlet in the house.
A quick runtime estimate shows how the math works. Take 5,000Wh, multiply by 0.85 for system losses, and divide by an example combined load of 300W (refrigerator, LED lights and router). That gives about 14 hours on one EcoFlow TITAN 5000 Classic unit. The 300W value is an example, not a measured one, so real nameplate values should replace it. Each added 5kWh battery adds about the same again at that load.
Rural homes on private wells lose water along with power. Working out well pump battery size before winter avoids guessing during the storm.
Back outside, the bigger question for most people is what sleet does once it reaches the ground.
Does Sleet Accumulate? What It Does to Roads, Walks and Driveways
Yes, sleet can pile up, though far less deep than snow from the same amount of water. The pellets are dense, so an inch or two of sleet holds much more water than an inch or two of snow. That makes it heavy to shovel and slow to melt.
Four facts help set expectations:
  • Snow-to-water ratio: NSSL notes the ratio can be as low as about two inches of sleet per inch of liquid. Snow averages about 13 inches per inch of liquid in the US.
  • Warnings: The NWS glossary says a Sleet Warning was once used when accumulation above one-half inch was expected. Today, heavy sleet is usually covered under a Winter Storm Warning.
  • Slick surfaces: The NWS says sleet makes moisture on roads freeze and become slippery. Bridges and overpasses freeze before other surfaces.
  • Heavy loads: Wet, packed pellets weigh more than fluffy snow, so shoveling takes more effort and more breaks.
Simple ways to handle a sleet cover
  • Clear it early: Pellets compact under foot and tires, and compacted sleet is much harder to remove.
  • Add traction on steps: Sand or similar traction material gives shoes something to grip.
  • Slow down on bridges: They are often the first spots to turn slick.
Shovel on sleet covered drivewayShovel on sleet covered driveway
A thin film of refrozen meltwater is often the real danger after sleet ends. Black ice matters most on the drive to work the next morning.
The best defense is knowing which type of ice the forecast is actually calling for.
Reading a Sleet Forecast Before the Pellets Start
Forecasters cannot always pin down where the sleet line will set up. A small change in the warm layer can flip sleet to freezing rain or snow. NWS winter weather alerts say which hazard dominates and how much is expected, so a quick look at the right alert saves a lot of guesswork.
Common NWS winter alerts
  • Winter Weather Advisory: Snow, ice, sleet or a mix that stays below warning criteria.
  • Winter Storm Warning: Significant snow, ice, sleet or a combination of them.
  • Ice Storm Warning: Usually ice of around 1/4 inch or more.
Why ice storm wording matters most
NSSL calls freezing rain that lasts several hours or more, with significant accumulation, an ice storm. That wording, not sleet alone, is the stronger outage signal. It ties back to the checklist above.
A weather radio as a backup
NOAA Weather Radio All Hazards broadcasts continuous weather information from the nearest NWS office. A battery-powered unit keeps alerts coming if the internet drops.
The wording on an alert carries real meaning. The winter storm watch, warning and advisory differences show how much time there is to prepare.
Sleet forms when snow partly melts in a shallow warm layer aloft and refreezes in a deep cold layer near the ground. It lands as clear pellets that bounce. That is the core answer to how sleet forms.
Treat sleet alone as a travel hazard. When the local forecast adds freezing rain, strong wind or outage risk, run the checklist and charge backup batteries early.
For a low-pressure starting point, the EcoFlow TITAN 5000 Classic suits homes where every must-run load is 120V. Homes with a 240V well pump can compare the EcoFlow TITAN 5000 with an electrician.
Is sleet the same as freezing rain?
No. Sleet starts as snow that partly melts in a shallow warm layer, then refreezes in a deep cold layer and lands as bouncing pellets. Freezing rain falls as liquid and freezes on contact, leaving a clear glaze on roads, trees and power lines.
What does sleet look like when it falls?
Sleet looks like small, clear or translucent ice beads, round or slightly irregular. They bounce and tick off windows, cars and hard ground. Unlike soft white graupel, sleet is hard and see-through, which makes the rattling sound easy to notice.
Can sleet pile up like snow?
Yes, but far less deeply. Sleet pellets are dense, so an inch of sleet holds much more water than an inch of snow. NSSL notes ratios as low as about two inches of sleet per inch of liquid, which makes piles heavy to shovel and slow to melt.
Can sleet cause a power outage?
Sleet alone is not a reliable outage signal. Outages are more often tied to ice buildup from freezing rain, heavy snow or strong wind. Check the local NWS forecast for ice accumulation, strong wind or an ice storm warning before deciding.
What temperature does sleet form at?
Sleet needs above-freezing air in a shallow layer aloft and air at or below 32°F (0°C) in a deeper layer near the ground. Surface temperature alone does not tell the full story, since the layers above decide whether snow melts and refreezes.
