How to Keep Dogs Warm Outside in Winter, and When to Bring Them In
The honest truth comes first. The warmest place for any dog in a hard freeze is inside with you. The American Veterinary Medical Association (AVMA) does not recommend keeping any pet outside for long periods.
Still, many dogs spend daily hours in the yard. You need practical ways to keep outdoor dogs warm in the winter. That means a shelter built to trap body heat. It means drinking water that never turns to solid ice. It also requires safe heated gear and clear eyes for cold warning signs. Finally, you need a backup plan when winter power outages strike. Here is how to keep dogs warm outside during winter and keep them safe.
The First Rule: Bring Them Inside When It Gets Cold
No doghouse or heated bed makes deep freezes safe for long hours. AVMA cold weather guidance is clear. In extreme cold, even outdoor pets should stay inside.
Every owner should know their pet's personal cold limits. The AVMA puts it simply: "We don't recommend keeping any pet outside for long periods of time."
Know your dog's cold tolerance
Cold tolerance shifts wildly from one dog to the next. Several physical traits determine how well a dog handles freezing air:
  • Coat type: Thick, double-coated breeds like Huskies manage cold far better than short-haired Boxers.
  • Body fat: Lean dogs lose body heat much faster than heavier dogs.
  • Overall size: Small dogs have more skin surface per pound. They chill rapidly.
  • Age: Very young puppies and senior dogs cannot regulate their internal body heat well.
  • Health status: Heart disease, kidney illness, or arthritis make cold weather dangerous.
Ask your veterinarian how long your dog can safely stay outside during winter. Avoid relying on one temperature threshold for every dog.
What safe yard time looks like
When outdoor time is necessary, keep it brief and closely watched.
  1. Keep outdoor bathroom trips quick.
  2. Supervise playtime in the yard so your dog stays active and moving.
  3. Bring your dog inside right away when playtime ends.
  4. Towel dry their belly, legs, and paws immediately.
Never rely on a single cut-off temperature from an online chart. Safe limits vary widely across breeds, ages, and medical backgrounds. Talk with your vet to set safe limits for your own dog.
Immediate warning signs
Watch your dog's body language closely while they are outside. Bring them inside right away if you notice warning signs. The AVMA advises calling a vet if a pet is shivering or extremely lethargic after cold exposure. Severe cold can force families to evacuate, and having a plan for pet evacuation during severe weather keeps dogs safe with the people who love them.
For dogs that do spend part of the day in the yard, the shelter does most of the work.
Shelter, Bedding, and Water That Won't Freeze
A good winter doghouse blocks wind, keeps dogs off frozen soil, and stays dry inside. Water is just as critical. A frozen water bowl means your dog has no water at all. Dehydration actually speeds up hypothermia.
Shelter, bedding, and water that won't freezeShelter, bedding, and water that won't freeze
Shelter basics (AVMA)
Follow these doghouse basics to improve protection during cold weather:
  • Choose an insulated shelter: Solid walls and insulation help reduce heat loss.
  • Raise the floor: Keep the shelter off the ground to limit heat transfer into cold soil.
  • Block prevailing winds: Position the entrance away from the direction of the strongest winds.
  • Keep bedding dry: Replace damp or dirty bedding regularly.
  • Check for leaks: Inspect the roof, walls, and entrance before winter storms arrive.
  • Allow enough room: Your dog should be able to stand, turn around, and lie down comfortably.
  • No open heaters: Never use space heaters or heat lamps inside a pet shelter due to severe burn and fire risks.
Straw works best because it lets dogs burrow and traps warm air pockets. Blankets and towels often absorb moisture, freeze solid, and make dogs colder. Pack fresh straw tightly, and check it daily for dampness. Learning how to heat a dog house without electricity helps you create a warm, dry refuge using basic windproofing and insulation.
Water and food
Dogs need access to fresh, unfrozen drinking water throughout winter. Check the bowl frequently, particularly overnight and during severe cold snaps.
You can help keep water available by:
  • Changing the water often.
  • Placing the bowl in a sheltered area away from strong winds.
  • Using a pet-safe heated water bowl according to its instructions.
  • Checking that the water remains liquid and the bowl works properly.
The AVMA also notes that outdoor pets may need additional calories during winter to maintain body heat. Ask your veterinarian whether your dog needs a dietary adjustment rather than increasing food portions without guidance.
Hazards around the yard
Winter yards bring hidden dangers. Keep these outdoor safety precautions in mind:
  • Clean antifreeze immediately: Antifreeze smells sweet to animals but is deadly even in tiny amounts.
  • Wipe paws after walks: Clean paws to clear off salt, chemical ice melt, and snowballs packed between toes.
  • Bang on the car hood: Cats and wildlife crawl near warm car engines on frosty nights. Rap the hood firmly before turning the key.
  • Check livestock water: The National Weather Service reminds owners to check that pets and livestock have unfrozen food and water during winter storms.
Shelter and water handle regular chilly days. But a winter power outage changes everything, especially when heated bowls and pads go cold.
Power Out? A Short-Term Plan for Pets
When a winter storm knocks out power, the house cools down fast and any heated outdoor bowl or pad stops working. The fix is strictly temporary: bring dogs into the warmest interior room immediately. You only need to keep a few low-watt essentials running for the hours or days until grid power returns.
Keep in mind that backup power is an emergency bridge, never an excuse to leave a dog outside in freezing conditions long term. Never use a human electric blanket as a pet warming pad, as it can overheat and lacks chew-resistant protection.
Two EcoFlow DELTA 3 units fit this short, specific job, depending on how many animals and devices you need to cover.
For a household with one dog, the EcoFlow DELTA 3 Classic can help power a few low-wattage essentials during a short outage. Its 1,024Wh capacity may support a pet-safe heated water bowl and a small LED lamp, depending on their power requirements.
EcoFlow DELTA 3 Classic (1024Wh)
•Fast AC Recharging: Reaches 0 to 80% in 45 minutes from a standard wall outlet, with 4 charging methods in total. • 1,800W Output: 3,600W surge, and up to 2,600W with X-Boost for compatible devices such as some microwaves and window AC units. Check each device's wattage first. • 10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit, such as a Wi-Fi router or NAS.
Homes with several pets may need to support more than one water bowl, along with other essential devices. The EcoFlow DELTA 3 Max offers a 2,048Wh capacity, giving households more stored energy to work with during a temporary outage.
EcoFlow DELTA 3 Max (2048Wh)
•2,400W Output: 4,800W surge. X-Boost mode can run some higher-wattage appliances up to 3,400W, though it works by lowering voltage, so results vary by device. • Fast Recharging: 4 ways to charge, reaching 0 to 80% in 68 minutes with wall or generator charging. • Easy to Carry: About 44.8 lb (20.3 kg), 13% lighter than EcoFlow's previous 2kWh model. •10ms Auto-Switch: Switches to battery power within 10ms for devices plugged directly into the unit. •Warranty: Up to 5 years (3-year standard plus a 2-year extension when you register in the EcoFlow App).
The EcoFlow DELTA 3 Classic is for a single-dog household: lights, phone charging, and one approved heated water bowl. The EcoFlow DELTA 3 Max is for homes with several pets, more than one water station, and a pet heating pad the maker allows, sized by adding up every device's watts and the hours you need. Either way, use the bowl, pad, and chew-resistant cord only as their makers intend, follow their supervision and placement rules, and keep the power station dry and out of reach of pets. No power setup prevents frostbite or hypothermia on its own. Warm indoor space and supervision do that.
Example runtime estimates
Below is an example breakdown of expected runtimes during a blackout using standard low-watt pet gear.
Device (maker spec)
Watts used in example
K&H Thermal-Bowl (12W to 25W by size)
25W (largest)
K&H Original Lectro-Kennel pad, Medium
60W
LED room lamp (10W assumed example)
10W
EcoFlow DELTA 3 Classic (One bowl + lamp = 35W):
1,024 × 0.85 ÷ 35 ≈ 24.9 hours (Assuming both run continuously at maximum draw)
EcoFlow DELTA 3 Max (Two bowls + one Medium pad + lamp = 120W):
2,048 × 0.85 ÷ 120 ≈ 14.5 hours (Assuming all devices draw continuous maximum power)
Note: The 0.85 factor accounts for typical inverter efficiency losses. Because both K&H products feature internal thermostats that cycle on and off automatically, real-world runtimes will typically be longer than these conservative calculations.
Safety Rules for Heated Pet Gear
When operating electric pet gear off backup power, stick closely to these manufacturer requirements:
  • K&H Thermal-Bowl: This unit operates without an on/off switch. Do not connect it to an extension cord (a mandatory MET safety label requirement). Unplug the bowl entirely during extended absences, and keep the unit shielded from heavy drafts and wind.
  • K&H Lectro-Kennel: This pad includes a steel-wrapped cord designed to deter chewing. Never position the pad in a tight space where your dog cannot freely choose to step completely off of it. Always consult a veterinarian prior to using heated pads with young puppies, sick or recovering pets, or animals unable to shift positions on their own. Do not use an extension cord, and use only the manufacturer-provided fleece cover over the pad surface.
  • Safe Unit Placement: Because manufacturer safety rules strictly prohibit extension cords on these devices, position your portable power station inside a dry, heated room close enough that each appliance's built-in power cord reaches the unit naturally without tension.
A household emergency plan works best when it is written down early, and the practical steps to prepare for an incoming cold wave should always include a designated indoor corner set up with your dog's bed and supplies.
Even with a reliable backup plan in place, your most useful skill remains spotting when a dog is getting too cold in real time.
Signs Your Dog Is Too Cold and What to Do
Dogs cannot speak up when they are freezing, but their actions tell the story. Spotting early signs helps you act quickly before hypothermia sets in.
Common signs your dog is freezing
Watch for these physical and behavioral clues:
  • Persistent shivering or trembling
  • Lifting paws off the frozen ground or limping
  • Hunched posture with a tucked tail
  • Whining, barking, or showing sudden anxiety
  • Reluctance to walk or continue playing
  • Extreme lethargy, slow movement, or weakness
The AVMA highlights shivering and severe lethargy as critical warning signs. If you see these signs, take action right away.
What to do immediately
Act promptly if your dog shows signs of cold distress:
  1. Bring the dog indoors immediately.
  2. Towel dry their coat and paws to remove moisture and road salt.
  3. Wrap them in dry, room-temperature blankets within a warm room.
  4. Offer fresh, lukewarm drinking water.
  5. Call your veterinarian for guidance if shivering continues or the dog seems weak.
Warm your dog safelyWarm your dog safely
Never leave a dog unattended inside a parked vehicle during winter. Cold cars turn into metal refrigerators, trapping freezing air inside.
Build a pet emergency kit ahead of time. Include extra food, bottled water, medications, medical records, and leashes. Remember that many municipal emergency shelters cannot accept pets due to health codes. Map out pet-friendly hotels or boarding facilities before storms hit. Knowing what gear to bring also makes camping with dogs in cold weather safer and far more comfortable.
The safest way to keep dogs warm outside in winter is to limit outdoor exposure and bring them inside during extreme cold. When your dog spends time in the yard, provide an insulated, raised shelter, dry bedding, and unfrozen drinking water. Watch for shivering, lethargy, and other signs of cold stress. Prepare for winter outages by identifying essential devices and estimating their power needs. If backup electricity is part of your plan, compare the EcoFlow DELTA 3 Classic and EcoFlow DELTA 3 Max for short-term use while keeping your dog safely indoors.
How cold is too cold for a dog to stay outside?
There's no single temperature that's safe for every dog. Cold tolerance depends on coat, size, age, health, wind, and moisture. The AVMA advises bringing pets inside during extreme cold. Ask your veterinarian about your dog's specific needs.
Are heated dog pads safe?
Heated pet pads are safe when used strictly according to manufacturer instructions. The AVMA notes heated mats can cause burns if misused. Buy only pet-specific pads, never use human heating pads, ensure the cord is chew-proof, and verify your dog can easily step off the pad.
How do I keep my dog's water from freezing outside?
Change the water frequently and consider a pet-safe heated bowl designed for outdoor use. Place it in a sheltered area and follow the manufacturer's electrical safety instructions. Check the bowl regularly to confirm the water remains available.
Can I use a human electric blanket for my dog?
No. Never use human electric blankets or heating pads for pets. They lack chew-resistant cords and can reach temperatures that burn sensitive dog skin. Dogs can also puncture the internal wiring with their claws, creating severe shock and fire hazards.
Should I use a space heater in the doghouse?
No. The AVMA advises against using space heaters or heat lamps inside pet shelters. These units create severe fire hazards in enclosed spaces packed with dry bedding. They can also cause serious contact burns if your dog bumps into them.
Tips
